Temperaturmessung einer Lüftungsanlage
Begonnen von peble, 03 November 2013, 11:18:12
peble
Hallo Joachin
jetzt siehts so aus
pi@raspberrypi ~ $ dmesg | grep -i usb
[    0.949790] usbcore: registered new interface driver usbfs
[    0.955377] usbcore: registered new interface driver hub
[    0.960964] usbcore: registered new device driver usb
[    1.373153] usbcore: registered new interface driver smsc95xx
[    1.845650] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.851962] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number                            1
[    1.860523] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.877244] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.885449] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                           1
[    1.894077] usb usb1: Product: DWC OTG Controller
[    1.900154] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[    1.907281] usb usb1: SerialNumber: bcm2708_usb
[    1.913886] hub 1-0:1.0: USB hub found
[    1.924838] Initializing USB Mass Storage driver...
[    1.931202] usbcore: registered new interface driver usb-storage
[    1.938610] USB Mass Storage support registered.
[    1.944709] usbcore: registered new interface driver libusual
[    2.084132] usbcore: registered new interface driver usbhid
[    2.091139] usbhid: USB HID core driver
[    2.351441] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.562011] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.570279] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.579912] hub 1-1:1.0: USB hub found
[    2.871670] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.991949] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.000285] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber                           =0
[    3.076428] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-                           1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:29:b8:00
[    3.171572] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.293361] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0608
[    3.301888] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber                           =0
[    3.310759] usb 1-1.2: Product: USB2.0 Hub
[    3.317408] hub 1-1.2:1.0: USB hub found
[    4.681743] usb 1-1.2.3: new full-speed USB device number 5 using dwc_otg
[    4.809006] usb 1-1.2.3: New USB device found, idVendor=0403, idProduct=6001
[    4.817628] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumb                           er=3
[    4.827966] usb 1-1.2.3: Product: FT232R USB UART
[    4.834132] usb 1-1.2.3: Manufacturer: FTDI
[    4.839735] usb 1-1.2.3: SerialNumber: A501HXID
[   46.010367] usbcore: registered new interface driver usbserial
[   46.281629] usbcore: registered new interface driver usbserial_generic
[   46.289874] USB Serial support registered for generic
[   46.586126] usbserial: USB Serial Driver core
[   46.675953] usbcore: registered new interface driver ftdi_sio
[   46.782798] USB Serial support registered for FTDI USB Serial Device
[   46.904467] ftdi_sio 1-1.2.3:1.0: FTDI USB Serial Device converter detected
[   46.996385] usb 1-1.2.3: Detected FT232RL
[   47.047815] usb 1-1.2.3: Number of endpoints 2
[   47.091483] usb 1-1.2.3: Endpoint 1 MaxPacketSize 64
[   47.098058] usb 1-1.2.3: Endpoint 2 MaxPacketSize 64
[   47.187609] usb 1-1.2.3: Setting MaxPacketSize 64
[   47.240417] usb 1-1.2.3: FTDI USB Serial Device converter now attached to tt                            USB0
[   47.279378] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 3354.152725] usb 1-1.2.3: USB disconnect, device number 5
[ 3354.158025] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnect                           ed from ttyUSB0
[ 3360.538466] usb 1-1.2.1: new full-speed USB device number 6 using dwc_otg
[ 3360.655984] usb 1-1.2.1: New USB device found, idVendor=0403, idProduct=6001
[ 3360.656016] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumb                           er=3
[ 3360.656034] usb 1-1.2.1: Product: FT232R USB UART
[ 3360.656048] usb 1-1.2.1: Manufacturer: FTDI
[ 3360.656062] usb 1-1.2.1: SerialNumber: A501HXID
[ 3360.664763] ftdi_sio 1-1.2.1:1.0: FTDI USB Serial Device converter detected
[ 3360.664948] usb 1-1.2.1: Detected FT232RL
[ 3360.664970] usb 1-1.2.1: Number of endpoints 2
[ 3360.664991] usb 1-1.2.1: Endpoint 1 MaxPacketSize 64
[ 3360.665006] usb 1-1.2.1: Endpoint 2 MaxPacketSize 64
[ 3360.665021] usb 1-1.2.1: Setting MaxPacketSize 64
[ 3360.667056] usb 1-1.2.1: FTDI USB Serial Device converter now attached to tt                            USB1
Cubietruck mit FHEM
1-Wire mit LinkUSBi / Com to 1Wire USB Adapter CUL 868 V3 von busware / ESA2000 Strommessung
Uniroll Gurtwickler über CUL 868 / verschiedeneFS 20 Geräte
Joachim
Diese Zeile ist zwar nicht vollständig,
aber es sieht so aus, dass er ttyUSB1 zugeordnet ist.
Jetzt noch
define 1_Wire OWX /dev/ttyUSB0
attr 1_Wire buspower real
in Deine fhem.cfg eintragen, und OWX sollte rennen.
Gruß Joachim
FHEM auf Raspberry
peble
OWX: Can't open serial device /dev/ttyUSB0: No such file or directory
FHEMWEB
Cubietruck mit FHEM
Joachim
Sorry, mein Fehler,
natürlich so
define 1_Wire OWX /dev/ttyUSB1
Gruß Joachim
FHEM auf Raspberry
peble
ok jetzt klappts
musste
eingeben
wenn ich die Sensoren parasitic also mit 2 Kabeln anschließen will muss ich dann nicht
attr 1_Wire buspower parasitic eingeben
und wenn jetzt schon real drin ist wie ändere ich das?
Danke im Voraus
Cubietruck mit FHEM
Joachim
Ändern tust Du das in der fhem.cfg
aber schön, dass es rennt.
Gruß Joachim
FHEM auf Raspberry
peble
Ja vielen Dank
"Ändern tust Du das in der fhem.cfg"
und wie?
Cubietruck mit FHEM
peble
ok habs einfach gelöscht
und den Befehl neu eingegeben.
hier mal ein Auszug aus der Logfile
2013.11.07 21:44:59 1: OWX: 1-Wire bus 1_Wire: interface master DS2480 detected for the first time
2013.11.07 21:45:10 3: OWID: Device OWX_01_875687150000 defined.
2013.11.07 21:45:10 1: OWX: 1-Wire devices found on bus 1_Wire (OWX_01_875687150000)
wo sehe ich jetzt eigentlich die Temperatur des Sensors?
Cubietruck mit FHEM
Joachim
Der linkUSBi1-Wire Teilnehmer auf dem Bus sollten automatisch gefunden werden, es sei denn, Du hast autocreate deaktiviert.
Gruß Joachim
FHEM auf Raspberry
peble
1 Wire steht auf active
unter Owid gibt es ein:
OWX_01_875687150000
ist das der Sensor
und wo sehe ich die Temperatur
Cubietruck mit FHEM
Joachim
Nein, dass ist die ID vom linkUSBi, mehr hat er nicht gefunden.
Mach mal einen shutdown restart, und poste das log.
Guß Joachim
FHEM auf Raspberry
peble
2013.11.08 06:55:32 1: OWX: Warning - Some parameter(s) ignored, must be define <name> OWX <serial-device>|<cuno/coc-device>|<arduino-pin>
2013.11.08 06:55:32 3: Opening 1_Wire device /dev/ttyUSB1
2013.11.08 06:55:32 3: Can't open /dev/ttyUSB1: No such file or directory
2013.11.08 06:55:32 1: OWX: Serial device /dev/ttyUSB1 not defined
2013.11.08 06:55:32 1: define: OWX: Can't open serial device /dev/ttyUSB1: No such file or directory
2013.11.08 06:55:32 0: Strange call for nonexistent 1_Wire: ReadyFn
1 Wire ist auch nicht mehr da!
Cubietruck mit FHEM
Joachim
Moin peble,
hast Du den Raspberry neugestartet?
Sieht so aus, als wenn der linkUSBi jetzt auf einem anderen Namen (evtl. /dev/ttyUSB0) sitzt. Plug & Pray ist geil!
Endgültig vermeiden kann man das mit einer udev-Regel
http://wiki.siduction.de/index.php?title=Symlink_zur_eindeutigen_Erkennung_mittels_udev-Regel
http://wiki.ubuntuusers.de/udev
Um jetzt weiterzukommen, nocheinmal
und schauen, welcher Name zugewiesen ist. fhem.cfg entsprechend ändern, rereadcfg machen, dann das Log posten.
Gruß Joachim
FHEM auf Raspberry
peble
2013.11.08 09:38:54 1: OWX: Warning - Some parameter(s) ignored, must be define <name> OWX <serial-device>|<cuno/coc-device>|<arduino-pin>
2013.11.08 09:38:54 3: Opening 1_Wire device /dev/ttyUSB0
2013.11.08 09:38:54 3: Setting 1_Wire baudrate to 9600
2013.11.08 09:38:54 3: 1_Wire device opened
2013.11.08 09:38:54 1: OWX: Serial device /dev/ttyUSB0 defined
2013.11.08 09:38:54 1: OWX: 1-Wire bus 1_Wire: interface master DS2480 detected for the first time
2013.11.08 09:39:06 3: OWTHERM: Device OWX_28_1A52AA040000 defined.
2013.11.08 09:39:06 3: OWID: Device OWX_01_875687150000 defined.
2013.11.08 09:39:06 1: OWX: 1-Wire devices found on bus 1_Wire (OWX_28_1A52AA040000,OWX_01_875687150000)
so jetzt passts
Temp wird in OWTHERM angezeigt
im Moment 1 Fühler
wie kann man das Temperaturdiagramm aktivieren?
Cubietruck mit FHEM
peble
Hallo Joachim,
vielen Dank für die bisherige Unterstützung.
Der Sensor wird jetzt unter OWTHERM angezeigt
bei mir so
OWX_28_1A52AA040000
kann ich jetzt diesem Fühler einen Namen vergeben?
so das man unter Everything dann die Temperatur des entsprechenden Fühlers ablesen kann?
und wie mach ich das Ganze in einem Diagramm über z.b mehrere Tage oder Stunden sichtbar?
Vielen Dank
Cubietruck mit FHEM
