Hauptmenü
apptime
Begonnen von Joachim, 20 Dezember 2013, 14:00:23
Joachim
Moin Martin,
kannst Du zu apptime eventuell etwas mehr Informationen geben?
name                  function                 max  count    total  average param Max call
     tmr-OWX_Discover       HASH(0x1e6c0b8)   5777      1     5777  5777.00 HASH(0x1e6c0b8)
   tmr-OWID_GetValues       HASH(0x2033578)    428      2      855   427.50 HASH(0x2033578)
             LinkUSBi              OWX_Poll    109  32849     2371     0.07 HASH(0x1e6c0b8)
           FS_KG_Flur OWXMULTI_AfterExecute     89     33      164     4.97 HASH(0x20acd18); readscratchpadvad; 1; 1; 26.9D0C6A010000.9b; ?; 9;
          TS_KG_gross  OWTHERM_AfterExecute     75      6      128    21.33 HASH(0x20ad0c0); read; 1; 1; 28.559E87040000.0F; ?; 9;
               WHR960           WHR960_Read     72  22809    35790     1.57 HASH(0x20b65b0)
              TS_Flur  OWTHERM_AfterExecute     66      6       94    15.67 HASH(0x20872e0); read; 1; 1; 28.2E1BBA030000.D9; ?; 9;
      TS_Kuehlschrank  OWTHERM_AfterExecute     57      6      115    19.17 HASH(0x20ae418); read; 1; 1; 28.198B72040000.59; ?; 9;
                TS_GZ  OWTHERM_AfterExecute     56      6       60    10.00 HASH(0x2087e80); read; 1; 1; 28.2F4ABA030000.B6; ?; 9;
    TS_Gefrierschrank  OWTHERM_AfterExecute     55      6      107    17.83 HASH(0x20ad980); read; 1; 1; 28.212772040000.07; ?; 9;
     TS_KG_Verteilung  OWTHERM_AfterExecute     55      6       59     9.83 HASH(0x20ad528); read; 1; 1; 28.161ABA030000.58; ?; 9;
    TS_WHR960_Sole_in  OWTHERM_AfterExecute     55      6       85    14.17 HASH(0x20b5768); read; 1; 1; 28.B449BA030000.B1; ?; 9;
    TS_WHR960_Luft_in  OWTHERM_AfterExecute     54      6       83    13.83 HASH(0x20b51b0); read; 1; 1; 28.0C2E88040000.62; ?; 9;
               TS_Bad  OWTHERM_AfterExecute     52      6      105    17.50 HASH(0x200cc08); read; 1; 1; 28.7556BA030000.0A; ?; 9;
                TS_SZ  OWTHERM_AfterExecute     52      6      107    17.83 HASH(0x20b4bf8); read; 1; 1; 10.9AEB01020800.99; ?; 9;
               TS_Bue  OWTHERM_AfterExecute     51      6       55     9.17 HASH(0x204ddc0); read; 1; 1; 28.8B49BA030000.78; ?; 9;
        FS_Bue_Zuluft OWXMULTI_AfterExecute     43     33      123     3.73 HASH(0x204e7b0); readscratchpadvad; 1; 1; 26.930C6A010000.88;
tmr-OWMULTI_GetValues       HASH(0x204e7b0)     36      2       65    32.50 HASH(0x204e7b0)
tmr-OWMULTI_GetValues       HASH(0x20acd18)     33      2       62    31.00 HASH(0x20acd18)
       FileLog_Keller           FileLog_Log     32     55      146     2.65 HASH(0x20f5818); HASH(0x20ad0c0)
        TS_Bue_Zuluft  OWTHERM_AfterExecute     27      6       55     9.17 HASH(0x204e378); read; 1; 1; 28.1FB087040000.EF; ?; 9;
name = aufrufende Funktion?
funktion = aufrufende Routine?
max = maximallaufzeit von name und funktion?
etc.
Das wär super, danke
Gruß Joachim
FHEM aktuellste Version auf FB 7570 und 7390 mit Zebradem Toolbox Freetz
FHEM auf Raspberry
1-Wire mit LinkUSBi und Rs-Pi ds2482-800  1-Wire-9 Board; Max mit Cube, HMLAN
div. 1-Wire Sensoren; MAX-Thermostaten; Homematic-Komponenten, Zehnder KWL über RS-232
martinp876
Hallo Joachim,
name : entity, für die es ausgeführt wird
funktion: name der Funktion, die ausgeführt wird
param max call: input parameter an die Funktion beim längsten aufruf
max: maximale laufzeit in ms
count: anzahl der Aufrufe
total: accumulierte Laufzeit der Funtion in ms
average: durchschnittliche Laufzeit (total/count) in ms.
wenn 'tmr-' vor dem Namen steht ist es durch einen timer  (InternalTimer) aufgerufen worden.
Bei timern es etwas anders. Da ist der
funktion: parameter der Funktion
param max call: parameter der Funktion
Es werden gerne nur Adressen übergeben.... die sind nicht dekodiert
Gruss Martin
Joachim
Danke Martin,
dann habe ich es glaube ich begriffen.
Bei max steht der längste Wert, den die Funktion während der Laufzeit jemals gebraucht hat,
und
bei total die gesamtzeit die diese Funktion seit reload apptime verbraucht hat.
In diesem Beispiel:
                    tmr-OWX_Discover           HASH(0x23ee0a8)   5877      1     5877  5877.00 HASH
                            LinkUSBi                  OWX_Poll    655  28793     2737     0.10 HASH
                  tmr-OWID_GetValues           HASH(0x25b5538)    630      2     1259   629.50 HASH
                          TS_KG_Flur      OWTHERM_AfterExecute    572      6      601   100.17 HASH
                      FileLog_Keller               FileLog_Log    515    118      817     6.92 HASH
                              WHR960               WHR960_Read    328  18666    32933     1.76 HASH
                             myDbLog                 DbLog_Log    274    118     1364    11.56 HASH
                              TS_Bad      OWTHERM_AfterExecute    135      6      164    27.33 HASH
                          FS_KG_Flur     OWXMULTI_AfterExecute     94     33      176     5.33 HASH
                    TS_KG_Verteilung      OWTHERM_AfterExecute     61      6       65    10.83 HASH
                   TS_WHR960_Sole_in      OWTHERM_AfterExecute     59      6       93    15.50 HASH
                              TS_Bue      OWTHERM_AfterExecute     58      6       86    14.33 HASH
                  TS_WHR960_Sole_out      OWTHERM_AfterExecute     57      6       86    14.33 HASH
                   TS_Gefrierschrank      OWTHERM_AfterExecute     56      6      113    18.83 HASH
                             TS_Flur      OWTHERM_AfterExecute     55      6       59     9.83 HASH
                               TS_GZ      OWTHERM_AfterExecute     55      6       84    14.00 HASH
                   TS_WHR960_Luft_in      OWTHERM_AfterExecute     51      6       55     9.17 HASH
                       FS_Bue_Zuluft     OWXMULTI_AfterExecute     48     33      133     4.03 HASH
                     TS_Kuehlschrank      OWTHERM_AfterExecute     40      6       70    11.67 HASH
               tmr-OWMULTI_GetValues           HASH(0x25d0768)     32      3       78    26.00 HASH
               tmr-OWMULTI_GetValues           HASH(0x262ecd8)     32      3       75    25.00 HASH
hat zwar tmr-OWX_Discover sehr lange gebraucht, da es allerdings ein einmaliger Aufruf war fällt er nicht ins Gewicht,
Im Gegensatz dazu ist die Funktion WHR960_Read zwar eigentlich kurz, bremst das System aber über die Fülle der Aufrufe deutlich.
Gruß Joachim
FHEM auf Raspberry
martinp876
korrekt.
Du kannst die Ausgaben sortieren lassen
apptime count
apptime max
apptime total
apptime ?
Kritisch für echtzeit sind m.E. besonders lange laufzeiten - die verschieben das timing...
LuckyDay
Wo finde ich das apptime :)
Joachim
FHEM auf Raspberry
Joachim
Hallo Martin,
kann man apptime eigentlich automatisch starten lasen?
Gruß Joachim
FHEM auf Raspberry
martinp876
schreiben
reload apptime
nach fhem.cfg
Joachim
Moin Martin,
Das war dann gestern abend der Tunnelblick, define wollte nicht gehen.
FHEM auf Raspberry
P.A.Trick
Weihnachten ist zwar vorbei, allerdings hätte ich doch noch einen Wunsch :-)
Kann man die Spalten in apptime "total" "average" usw. klickbar machen? Das wäre der Hit in Tüten!
Cubietruck,RPI,QNAP Ts-419p+, FS20, FRITZ!DECT200, 7 MAX! Thermostate, 3 MAX! Fensterkontakte, Kodi, CUL V3.3, EM1000S, LW12, LD382, HUE, HM-CFG-USB-2, 1x HM-LC-SW1-FM, 2x HM-LC-SW2-FM, 2x HM-LC-Sw1PBU-FM, 3xHM-LC-Bl1PBU-FM,HM-SEC-RHS, 2xHM-SEC-SD,HM-WDS30-T-O, 3x HM-LC-Dim1TPBU-FM, RPI+AddOn
martinp876
Hm... Schwer. Es hat kein Frontend....
Du könntest in myutils ein Frontend definieren incl Kommando und Parameter.
Also apptime:maxDly,total,.....
Das sind genau die Funktionen, die ich in mu (myutils) zugänglich mache. Z.b. das anzeigen aller timer in fhem.
P.A.Trick
Ah ok, also das übersteigt meine (derzeitigen FHEM) Fähigkeiten! Trotzdem Danke!
martinp876
Hm. Eigentlich nicht schwer. Leider ist mein system immer noch hinüber, dauert noch etwas. Mal sehen, vielleicht bekomme ich es hin.
martinp876
ich hatte es ja schon begonnen.
schreiben das file in die FHEM dir. dann definiere ein
define mu myUtils
du kannst es als übungsprojekt sehen. es ist sicher einiges enthalten, was du nicht brauchst, aber es ist ausbaufähig, wie du willst.
wenn du es in FHEM editierst wird es automatisch neu geladen. Wenn du es extern editierst musst du ein reload 99_myUtils eingeben.
Die Initialisierung zu ändern bedarf eines neustart von FHEM.
viel Spass.,
P.A.Trick
Danke Martin ich werde es versuchen!
