[gelöst] Nach heutigem update Fehler mit DbLog
Begonnen von franky08, 13 September 2014, 12:47:06
franky08
Hallo, habe gerade einen update gemacht und nach einem Blick in Log folgendes:
2014.09.13 12:42:18 3: Connecting to database SQLite:dbname=/opt/fhem/fhem.db with user
2014.09.13 12:42:18 3: Connection to db SQLite:dbname=/opt/fhem/fhem.db established for pid 3356
2014.09.13 12:42:18 2: DbLog: Failed to insert new readings into database: DBD::SQLite::st execute failed: attempt to execute on inactive database handle at ./FHEM/93_DbLog.pm line 447.
# $Id: fhem.pl 6542 2014-09-12 09:03:55Z rudolfkoenig $
# $Id: 10_CUL_HM.pm 6538 2014-09-11 17:54:18Z martinp876 $
# $Id: 57_Calendar.pm 6499 2014-09-02 10:16:51Z borisneubert $
# $Id: 93_DbLog.pm 5782 2014-05-08 06:15:58Z tobiasfaust $
# $Id: 72_FB_CALLMONITOR.pm 6445 2014-08-22 20:27:56Z markusbloch $
# $Id: 93_FHEM2FHEM.pm 6203 2014-07-06 12:31:20Z rudolfkoenig $
# $Id: 01_FHEMWEB.pm 6545 2014-09-12 17:46:39Z rudolfkoenig $
# $Id: 95_FLOORPLAN.pm 6174 2014-06-29 05:51:28Z ulimaass $
# $Id: 92_FileLog.pm 5876 2014-05-16 19:54:51Z rudolfkoenig $
# $Id: 00_HMLAN.pm 6471 2014-08-27 12:32:38Z martinp876 $
# $Id: 98_HMinfo.pm 6501 2014-09-03 18:46:32Z martinp876 $
# $Id: 99_SUNRISE_EL.pm 5851 2014-05-13 19:39:03Z rudolfkoenig $
# $Id: 98_SVG.pm 6542 2014-09-12 09:03:55Z rudolfkoenig $
# $Id: 98_Text2Speech.pm 6493 2014-09-01 08:57:43Z tobiasfaust $
# $Id: 99_Utils.pm 6446 2014-08-23 10:09:44Z rudolfkoenig $
# $Id: 70_VIERA.pm 6347 2014-08-02 16:25:27Z teevau $
# $Id: 59_Weather.pm 6432 2014-08-20 15:46:12Z borisneubert $
# $Id: 90_at.pm 5319 2014-03-25 10:11:47Z rudolfkoenig $
# $Id: 98_autocreate.pm 6505 2014-09-06 12:24:48Z rudolfkoenig $
# $Id: 98_average.pm 5443 2014-04-05 06:37:49Z rudolfkoenig $
# $Id: 98_dummy.pm 4934 2014-02-15 08:23:12Z rudolfkoenig $
# $Id: 91_notify.pm 6371 2014-08-07 05:33:37Z rudolfkoenig $
# $Id: 33_readingsGroup.pm 6262 2014-07-16 07:46:03Z justme1968 $
# $Id: $
# $Id: 98_telnet.pm 6484 2014-08-31 07:45:45Z rudolfkoenig $
# $Id: 91_watchdog.pm 5622 2014-04-24 08:04:29Z rudolfkoenig $
./FHEM/95_webViewControl.pm: No such file or directory
# $Id: 98_weblink.pm 5608 2014-04-23 10:57:16Z rudolfkoenig $
VG
Frank
mit FHEM aktuell
franky08
#1
@Puschel
Bitte nach Automatisierung verschieben, bin im falschen Bereich gelandet!
VG
Frank
mit FHEM aktuell
Puschel74
wobei ich eher vermute das nicht 93_DbLog.pm der Übeltäter ist sondern update.
Irgendwas muss die alter Version ja bei dir auf dein System gespielt haben.
franky08
#3
Ja, denke auch das es mit dem Update Modul zusammenhängt
nach dem zurückspielen des Backups ist die DbLog.pm immer noch vom Mai, an der liegt es dann wohl nicht!
Aus dem Backup:
# $Id: 10_CUL_HM.pm 6500 2014-09-03 18:42:22Z martinp876 $
# $Id: 01_FHEMWEB.pm 6447 2014-08-24 07:38:52Z rudolfkoenig $
# $Id: 98_SVG.pm 6498 2014-09-01 19:24:40Z rudolfkoenig $
# $Id: 98_autocreate.pm 6436 2014-08-21 05:40:35Z rudolfkoenig $
# $Id: $
Nach dem fehlerhaften update (kein schreiben in DbLog möglich)
# $Id: $
VG
Frank
mit FHEM aktuell
LuckyDay
man könnte auch mal im
fhem/restoreDir nachsehen das update anlegt
franky08
#5
Da siehst du aber nur die ge-updateten Module, die vorher gesichert wurden. Da ist nichts verdächtiges dabei. Die fhem.pl ist es auch nicht, da beide Versionen vom 12.09. sind.
cubie@Cubian:/opt/fhem/restoreDir/2014-09-13/FHEM$ ls
00_CUL.pm      02_RSS.pm       10_UNIRoll.pm    35_SWAP_0000002200000003.pm  36_LaCrosse.pm  42_SYSMON.pm    66_ECMD.pm        71_YAMAHA_AVR.pm  98_RandomTimer.pm  firmware
00_TCM.pm      10_CUL_HM.pm    14_CUL_TX.pm     36_EC3000.pm                 36_PCA301.pm    51_RPI_GPIO.pm  67_ECMDDevice.pm  91_sequence.pm    98_SVG.pm          HMConfig.pm
01_FHEMWEB.pm  10_OWServer.pm  31_HUEDevice.pm  36_JeeLink.pm                36_WMBUS.pm     55_GDS.pm       70_ENIGMA2.pm     98_autocreate.pm  controls_fhem.txt  WMBus.pm
VG
Frank
mit FHEM aktuell
LuckyDay
franky08
Ja, hab ich schon geschrieben, die ist vom Mai und eine neuere gibt es nicht. Der Fehler hängt mit irgendeinem anderen Modul zusammen, welches nicht mehr in die Datenbank schreiben kann.
VG
Frank
mit FHEM aktuell
Sommerfeld
auch ich habe nach dem heutigen Update das Problem, dass FHEM nicht mehr startet.
FHEM läuft bei mir auf einem Raspi. Über Putty habe ich Zugriff. Stoße ich einen Neustart
von FHEM an, kommt im IE die Meldung, dass die Seite nicht angezeigt werden kann.
Bei Putty gibt es folgende Fehlermeldung, s. Anhang.
Was und wie kann ich wieder Zugriff auf FHEM bekommen?
Kann mir bitte jemand helfen, bin leider noch in den Anfängen mir die Kenntnisse anzueignen.
Deine Datenbank ist zerschossen. Da hilft nur neu anlegen oder ein (hoffentlich vorhandenes) Backup der Datenbankdatei einzuspielen.
Mit fhem oder irgendwelchen Updates hat das nichts zu tun.
franky08
#10
@Sommerfeld
An was es letztendlich bei mir gelegen hat, kann ich nicht sagen. Ich bin mit meinem Backup auf:
# $Id: $
zurückgegangen und danach lief alles wieder problemlos. Hatte heute Nachmittag keine Zeit mehr, dass einzugrenzen, da ich zur Arbeit musste.
Als wenn die Datenbank nicht laufen würde  :o
VG
Frank
mit FHEM aktuell
Sommerfeld
Hallo Betateilchen,
nach Backup der Datenbank läuft alles wieder, vielen Dank
franky08
Ich mus den Thread nochmal hochholen. Habe eben einen update gemacht und danach wieder im Log
2014.09.16 16:06:18 3: Connecting to database SQLite:dbname=/opt/fhem/fhem.db with user
2014.09.16 16:06:18 3: Connection to db SQLite:dbname=/opt/fhem/fhem.db established for pid 3328
2014.09.16 16:06:18 2: DbLog: Failed to insert new readings into database: DBD::SQLite::st execute failed: attempt to execute on inactive database handle at ./FHEM/93_DbLog.pm line 447.
Spiele ich folgende Versionen zurück, funktioniert alles wieder tadellos:
# $Id: fhem.pl 6498 2014-09-01 19:24:40Z rudolfkoenig $
# $Id: 42_SYSMON.pm 6390 2014-08-10 22:06:38Z hexenmeister $
# $Id: $
An was kann es liegen? Folgende Module wurden aktualisiert:
2014.09.16 15:56:01 1: RMDIR: ./restoreDir/2014-09-01
2014.09.16 15:56:01 1: UPD ./CHANGED
2014.09.16 15:56:01 1: UPD ./fhem.pl
2014.09.16 15:56:01 1: UPD FHEM/00_CUL.pm
2014.09.16 15:56:01 1: UPD FHEM/00_TCM.pm
2014.09.16 15:56:01 1: UPD FHEM/01_FHEMWEB.pm
2014.09.16 15:56:02 1: UPD FHEM/02_RSS.pm
2014.09.16 15:56:02 1: UPD FHEM/10_CUL_HM.pm
2014.09.16 15:56:02 1: UPD FHEM/10_EnOcean.pm
2014.09.16 15:56:02 1: UPD FHEM/10_MAX.pm
2014.09.16 15:56:03 1: UPD FHEM/10_OWServer.pm
2014.09.16 15:56:03 1: UPD FHEM/10_UNIRoll.pm
2014.09.16 15:56:03 1: UPD FHEM/14_CUL_TX.pm
2014.09.16 15:56:03 1: UPD FHEM/31_HUEDevice.pm
2014.09.16 15:56:03 1: UPD FHEM/35_SWAP_0000002200000003.pm
2014.09.16 15:56:03 1: UPD FHEM/36_EC3000.pm
2014.09.16 15:56:03 1: UPD FHEM/36_JeeLink.pm
2014.09.16 15:56:03 1: UPD FHEM/36_LaCrosse.pm
2014.09.16 15:56:03 1: UPD FHEM/36_PCA301.pm
2014.09.16 15:56:04 1: UPD FHEM/36_WMBUS.pm
2014.09.16 15:56:04 1: UPD FHEM/42_SYSMON.pm
2014.09.16 15:56:04 1: UPD FHEM/51_RPI_GPIO.pm
2014.09.16 15:56:04 1: UPD FHEM/55_GDS.pm
2014.09.16 15:56:04 1: UPD FHEM/66_ECMD.pm
2014.09.16 15:56:04 1: UPD FHEM/67_ECMDDevice.pm
2014.09.16 15:56:04 1: UPD FHEM/70_ENIGMA2.pm
2014.09.16 15:56:05 1: UPD FHEM/71_YAMAHA_AVR.pm
2014.09.16 15:56:05 1: UPD FHEM/72_FB_CALLMONITOR.pm
2014.09.16 15:56:05 1: UPD FHEM/91_sequence.pm
2014.09.16 15:56:05 1: UPD FHEM/98_CustomReadings.pm
2014.09.16 15:56:05 1: UPD FHEM/98_HMinfo.pm
2014.09.16 15:56:05 1: UPD FHEM/98_IF.pm
2014.09.16 15:56:05 1: UPD FHEM/98_RandomTimer.pm
2014.09.16 15:56:06 1: UPD FHEM/98_SVG.pm
2014.09.16 15:56:06 1: UPD FHEM/98_THRESHOLD.pm
2014.09.16 15:56:06 1: UPD FHEM/98_autocreate.pm
2014.09.16 15:56:06 1: UPD FHEM/98_statistics.pm
2014.09.16 15:56:06 1: UPD FHEM/HMConfig.pm
2014.09.16 15:56:06 1: UPD FHEM/WMBus.pm
2014.09.16 15:56:07 1: UPD FHEM/firmware/JeeLink_PCA301.hex
2014.09.16 15:56:07 1: UPD docs/commandref.html
2014.09.16 15:56:08 1: UPD docs/commandref_DE.html
2014.09.16 15:56:08 1: UPD www/images/fhemSVG/light_exclamation.svg
2014.09.16 15:56:08 1: update finished, "shutdown restart" is needed to activate the changes.
2014.09.16 15:56:11 1: Fhem info:
  Release  : 5.5
  Branch   : DEVELOPMENT
  OS       : linux
  Arch     : arm-linux-gnueabihf-thread-multi-64int
  Perl     : v5.14.2
  uniqueID : 7226521e078c77d74f367f68ca943827
  upTime   : 1 day, 23:32:20
Defined modules:
  CUL_HM         : 158
  Calendar       : 2
  DbLog          : 1
  ENIGMA2        : 1
  FB_CALLMONITOR : 1
  FHEM2FHEM      : 2
  FHEMWEB        : 22
  FLOORPLAN      : 3
  FileLog        : 2
  HMLAN          : 2
  HMinfo         : 1
  SVG            : 34
  SYSMON         : 1
  THRESHOLD      : 5
  Text2Speech    : 1
  VIERA          : 1
  Weather        : 2
  at             : 70
  autocreate     : 1
  average        : 2
  dummy          : 71
  notify         : 131
  readingsGroup  : 3
  remotecontrol  : 2
  telnet         : 2
  watchdog       : 1
  weblink        : 6
Defined models per module:
  CUL_HM         : ActionDetector,CCU-FHEM,HM-CC-RT-DN,HM-ES-PMSw1-Pl,HM-LC-SW1-PL2,HM-LC-SW2-PB-FM,HM-LC-SW4-PCB,HM-LC-Sw1PBU-FM,HM-OU-LED16,HM-RC-4-2,HM-SEC-MDIR-2,HM-SEC-SC-2,HM-WDS10-TH-O,HM-WDS30-OT2-SM,HM-WDS40-TH-I,virtual_1
  ENIGMA2        : dm7020hd
Transmitting this information during an update:
  onUpdate (Note: You can change this via the global attribute sendStatistics)
server response: ==> ok
2014.09.16 15:57:07 0: Server shutdown
VG
Frank
mit FHEM aktuell
franky08
Da der Fehler scheinbar bei niemand anderen auftritt, versuche ich es morgen noch einmal, mit update force. Vielleicht bringt es ja was. Warum die sqlite nicht aktiv sein soll, kann ich nicht nachvollziehen denn wenn ich auf die alten Modul Versionen zurück gehe, gibt keine Fehlermeldung im Log.
VG
Frank
mit FHEM aktuell
franky08
mit FHEM aktuell
