MAXLAN_Parse: Command was discarded
Begonnen von emnagel, 23 November 2013, 13:07:44
emnagel
I am getting the discarded lines in the log file from my MAX cube. And it also seems the weekprofile is not working recently.
ml device opened
2013.11.23 13:03:27 2: MAXLAN_Parse: Command was discarded
2013.11.23 13:03:28 2: MAXLAN_Parse: Command was discarded
The code in the configuration file looks like:
## -- Week profielen --
set wt_badkamer weekProfile Mon 14,06:30,23,8:00,14,18:30,22,21:00,14
set wt_badkamer weekProfile Tue 14,06:30,23,8:00,14,18:30,22,21:00,14
set wt_badkamer weekProfile Wed 14,06:30,23,8:00,14,18:30,22,21:00,14
set wt_badkamer weekProfile Thu 14,06:30,23,8:00,14,18:30,22,21:00,14
set wt_badkamer weekProfile Fri 14,06:30,23,8:00,14,18:30,22,21:00,14
set wt_badkamer weekProfile Sat 14,06:45,23,9:00,14,18:30,22,21:00,14
set wt_badkamer weekProfile Sun 14,06:45,23,9:00,14,18:30,22,21:00,14
pet22
just try a one-liner, it simply aborbs less credits:
set wt_badkamer weekProfile Mon 14,06:30,23,8:00,14,18:30,22,21:00,14 Tue 14,06:30,23,8:00,14,18:30,22,21:00,14 Wed 14,06:30,23,8:00,14,18:30,22,21:00,14 Thu 14,06:30,23,8:00,14,18:30,22,21:00,14 Fri 14,06:30,23,8:00,14,18:30,22,21:00,14 Sat 14,06:45,23,9:00,14,18:30,22,21:00,14 Sun 14,06:45,23,9:00,14,18:30,22,21:00,14
HIH
Pet22
Debian 11/ Intel Atom MB/ CUL V3/ Raspberrymatic/ Homematic classic, Homematic IP, WTs & HTs
emnagel
Thx Pey, but that is not the issue.
logs still tells me discarded even after update code and reboot today.
2013.11.24 19:17:08 3: ml device opened
2013.11.24 19:17:09 2: MAXLAN_Parse: Command was discarded
Line of config code is simple
pet22
ugh -- don't really understand what do you mean with 'reboot'
Let me do a wild guess: once you updated FHEM you did a reboot of your FritzBox/ NAS/ Raspberry/ etc. or a restart of FHEM. However, unless you un-power the Cube for a few mins in addition, the last no. of credits are stored in the Cube memory. So the misery is the same as before.
Also a few more details about your configuration would be helpful: e.g. no. of WT/ HTs, etc.
Kind regards
Pet22
emnagel
I did both.
1) I powered down the Cube and checked for new firmware. No update and running fine under the default software
2) I updated FHEM and did a shutdown reboot.
No results. Just setting the desired tempature manual works fine.
pet22
Sorry - running out of ideas. Maybe you need to dump your config file and Matthias Gehre or John are able to support you further.
Thx
Pet22
John
Hi emnagel
I think fhem.cfg is not an appropriate place for these commands
since the initialization at the time of execution is not yet completed.
Moreover, it is not necessary to perform the commands every time you start FHEM.
It is sufficient to manually perform this commands, since the information is stored in the thermostats.
John
CubieTruck Docker Node-Red Tasmota Shelly Homematic-IP
emnagel
Thx John for your response. But where to store this type of information then if fhem.cfg is not the correct place?
Furthermore by manually you mean via the default MAX Cube portal interface? If yes I do not like this idea, because I am looking for a solution to do configuration at one place / tool and not to many places even if it is a one time of exercise.
cheers, Erik
