Autor Thema: Decoding of unsupported ARC codes (Lighting4)  (Gelesen 21291 mal)
Offline Willi
  • Sr. Member
Aw: Decoding of unsupported ARC codes (Lighting4)
« Antwort #45 am: 13 April 2013, 18:40:17 »
Bert from RFXCOM gave me the answer.
I have to set the switch to S instead to R of the WD18. Now it shows up as a DS10A dor switch and everything works as expected. On Alarm it shows Opened and after alarm is show closed.
-- Willi
FHEM@Q600(debian) mit DS9490R (1Wire) | FHEM@Sheevaplug(debian) mit RFXCOM-Receiver(80002), CULv3 & USB-WDE1 | FHEM@odroid mit CULv2 & RFXtrx433
Offline oliv06
  • Full Member
    • Play with Free : FHEM
« Antwort #46 am: 13 April 2013, 23:37:42 »
-- Willi
Thank you. I changed the switch to S.
Offline Willi
  • Sr. Member
« Antwort #47 am: 14 April 2013, 22:50:59 »
I have found out that battery works now ok, but some other things (like tamper) works different.
I am currently testing a new dev_type WD18 which should give the correct results.
I will let you know when I put it into SVN. The new define for it will look like:
define TRX_Wassermelder1 TRX_SECURITY WD18 16fc water
