Autor Thema: New MQTT module  (Gelesen 2158 mal)
Offline andreafno
  • New Member
New MQTT module
« am: 12 Mai 2019, 10:23:50 »
could somebody help me with MQTT module? In the past it worked correctly using this simple configuration:
#set zehnder device
define ZL ComfoAir /dev/ttyUSB1@9600 30
attr ZL event-min-interval .*:60
#set mqtt
define mq MQTT server:port user password
define mq_ZL MQTT_BRIDGE ZL
attr mq_ZL publishReading_Temp_EWT /user/ext_temperature
How can I make this work with the new MQTT2 module?
Thank you!
Andrea
Offline rudolfkoenig
  • Administrator
Antw:New MQTT module
« Antwort #1 am: 12 Mai 2019, 10:43:22 »
There are some alternatives:
- use MQTT_GENERIC_BRIDGE, this is compatible with MQTT2 (MQTT_BRIDGE is not).
- use a notify, which will call "set mqtt2_client publish XX YY" or "set mqtt2_server publish XX YY"
- define an additional MQTT2_DEVICE with a setList, and set this device via notify.
In each of these cases you need an MQTT2_CLIENT or an MQTT2_SERVER
Offline andreafno
  • New Member
« Antwort #2 am: 12 Mai 2019, 11:06:14 »
Hi rudolfkoenig,
thank you! Where can I find documentation in english to understand how to rewrite the cfg in the correct way? In fhem commandref I can see MQTT_GENERIC_BRIDGE under "Device modules" but clicking it nothing happens.
Thanks again
  • Administrator
Offline andreafno
  • New Member
« Antwort #4 am: 12 Mai 2019, 11:32:01 »
Ok, sorry.. local html commandref only doesn't work for me.
  • Administrator
« Antwort #5 am: 12 Mai 2019, 11:36:02 »
Define one, go to its FHEMWEB details page, and click on "Device specific help" in the bottom right corner.
Offline andreafno
  • New Member
« Antwort #6 am: 12 Mai 2019, 12:06:08 »
I defined mqtt2, then I set the password with "set" directly in fhemweb
define mq MQTT2_CLIENT mqtt.dioty.co:1883
attr mq username myusername
If I execute in fhemweb the command:
defmod mqttGeneric MQTT_GENERIC_BRIDGE mqtt ZL
I receive "Cannot load module MQTT_GENERIC_BRIDGE"
Should I install something?
  • Administrator
« Antwort #7 am: 12 Mai 2019, 12:45:14 »
Probably. Did you checked the FHEM log?
Note: I am not the maintainer of this module.
Personally I would use notify (as I know _that_ module), but there are at least 120 FHEM installations using MQTT_GENERIC_BRIDGE according to our statistics, so it ought to work.
Offline andreafno
  • New Member
« Antwort #8 am: 12 Mai 2019, 13:36:16 »
Wow, you know it better than any other  :)
Could you please make me an example using notify to publish a reading of my ZL device, now that I set MQTT2_CLIENT?
#1) set zehnder device
#2) define mqtt2 client
#3) automatic publishing ZL reading using "notify" (previously "attr mq_ZL publishReading_Temp_EWT /user/ext_temperature")
ps. sorry for my english; in the log file nothing appears after the "Cannot load module MQTT_GENERIC_BRIDGE" message
  • Administrator
« Antwort #9 am: 12 Mai 2019, 13:51:47 »
I would try something like:define ZL_notify notify ZL:Temp_EWT.* set mq publish /user/ext_temperature $EVTPART1Since I dont know the MQTT module, nor MQTT_BRIDGE, my example may be wrong.
I would start the Event Monitor in FHEMWEB, wait for the right event from ZL, mark the line and press "Create/modify device".
Offline andreafno
  • New Member
« Antwort #10 am: 12 Mai 2019, 14:34:28 »
Thank you! The notify works, I see in the event monitor. I can't see the messages on the broker, but this is a different problem.
Thank so much for your help!
Have a good Sunday
