[gelöst] Gtag wird nach Batteriewechsel nicht mehr erkannt, nur noch "absent"
Begonnen von ujaudio, 16 Mai 2019, 14:34:40
Gasmast3r
Das kann ich mir kaum vorstellen,
Ich würde die mal für paar min die Batterie entfernen und dann nach und nach neu testen, ewentuell mal auf kalte Lötstellen prüfen.
Gesendet mit Tapatalk
update hatte das eben wieder.
[Gigaset G-tag]# help
Available commands:
  list                       List available controllers
  show [ctrl]                Controller information
  select <ctrl>              Select default controller
  devices                    List available devices
  paired-devices             List paired devices
  power <on/off>             Set controller power
  pairable <on/off>          Set controller pairable mode
  discoverable <on/off>      Set controller discoverable mode
  agent <on/off/capability>  Enable/disable agent with given capability
  default-agent              Set agent as the default one
  advertise <on/off/type>    Enable/disable advertising with given type
  set-advertise-uuids [uuid1 uuid2 ...] Set advertise uuids
  set-advertise-service [uuid][data=[xx xx ...] Set advertise service data
  set-advertise-manufacturer [id][data=[xx xx ...] Set advertise manufacturer data
  set-advertise-tx-power <on/off> Enable/disable TX power to be advertised
  set-scan-filter-uuids [uuid1 uuid2 ...] Set scan filter uuids
  set-scan-filter-rssi [rssi] Set scan filter rssi, and clears pathloss
  set-scan-filter-pathloss [pathloss] Set scan filter pathloss, and clears rssi
  set-scan-filter-transport [transport] Set scan filter transport
  set-scan-filter-clear      Clears discovery filter.
  scan <on/off>              Scan for devices
  info [dev]                 Device information
  pair [dev]                 Pair with device
  trust [dev]                Trust device
  untrust [dev]              Untrust device
  block [dev]                Block device
  unblock [dev]              Unblock device
  remove <dev>               Remove device
  connect <dev>              Connect device
  disconnect [dev]           Disconnect device
  list-attributes [dev]      List attributes
  set-alias <alias>          Set device alias
  select-attribute <attribute> Select attribute
  attribute-info [attribute] Select attribute
  read                       Read attribute value
  write <data=[xx xx ...]>   Write attribute value
  notify <on/off>            Notify attribute value
  register-profile <UUID ...> Register profile to connect
  unregister-profile         Unregister profile
  version                    Display version
  quit                       Quit program
[Gigaset G-tag]# paired-devices
Device 00:1A:22:09:0F:5D CC-RT-BLE
Device 00:1A:22:05:24:41 CC-RT-BLE
Device 00:1A:22:09:0F:24 CC-RT-BLE
Device 00:1A:22:05:22:1C CC-RT-BLE
Device 00:1A:22:05:27:E5 CC-RT-BLE
Device 00:1A:22:05:28:2C CC-RT-BLE
Device 00:1A:22:09:0F:34 CC-RT-BLE
Device 00:1A:22:09:1A:74 CC-RT-BLE
Device 00:1A:22:09:0F:19 CC-RT-BLE
Device 00:1A:22:05:27:BD CC-RT-BLE
Device 00:1A:22:05:F8:18 CC-RT-BLE
Device 00:1A:22:07:54:44 CC-RT-BLE
[Gigaset G-tag]# pairable off
Changing pairable off succeeded
[NEW] Device 00:1A:22:05:28:2C 00-1A-22-05-28-2C
[Gigaset G-tag]#  trust 7C:2F:80:96:3D:CE
[CHG] Device 7C:2F:80:96:3D:CE Trusted: yes
Changing 7C:2F:80:96:3D:CE trust succeeded
[DEL] Device 00:1A:22:05:28:2C 00-1A-22-05-28-2C
[NEW] Device 00:1A:22:05:F8:18 00-1A-22-05-F8-18
[DEL] Device 00:1A:22:05:F8:18 00-1A-22-05-F8-18
[NEW] Device 00:1A:22:09:0F:5D 00-1A-22-09-0F-5D
[DEL] Device 00:1A:22:09:0F:5D 00-1A-22-09-0F-5D
[Gigaset G-tag]# untrust 7C:2F:80:96:3D:CE
[CHG] Device 7C:2F:80:96:3D:CE Trusted: no
Changing 7C:2F:80:96:3D:CE untrust succeeded
[Gigaset G-tag]# pair 7C:2F:80:96:3D:CE
Attempting to pair with 7C:2F:80:96:3D:CE
Failed to pair: org.bluez.Error.AuthenticationFailed
[CHG] Device 7C:2F:80:96:3D:CE ServicesResolved: no
[CHG] Device 7C:2F:80:96:3D:CE Connected: no
[00-1A-22-05-28-2C]#
ujaudio
Ich kämpfe noch immer mit dem Problem. Dieser Tage war beim letzten der 3 Gtags die Batterie auf 5%. Da bin ich extra ohne Mobiltelefon in den Wald gefahren und habe dort die Batterie gewechselt (kein Witz!). Als ich nach Hause kam wurde de Gtag, der zuvor einwandfrei funktioniert hat, nicht mehr erkannt. Wobei "erkannt" hier nur bedeutet, dass die Meldung auf "absent" bleibt und dass auch kein Batteriestatus mehr aktualisiert wird - es zeigt noch immer 5% an. An der neuen Batterie kann es nicht liegen, die ist in Ordnung und richtig eingelegt.
Irgendwie macht das so keinen Spaß. Am Raspberry kann es wohl nicht liegen, denn der weiß nicht, ob die Batterie gewechselt wurde. Es muss also beim Batteriewechsel irgendetwas mit dem Gtag passiert sein. Ich kann mir aber nicht vorstellen, dass ich alle 3 kaputt gemacht habe. Ich werde mal versuchen die App aufs Handy zu laden und die Gtags zu koppeln - hoffentlich bekomme ich sie auch wieder entkoppelt. Kann man die Dinger irgendwie auf Werksreset bringen?
Einen lieben Gruß
Jürgen
CoolTux
Das TuxNet Wiki:
https://www.cooltux.net
komisch, ich hatte noch nie Probleme nach einem Batteriewechsel bei einem G-Tag. Allerdings wechsle ich die Batterie auch immer erst dann aus, wenn das Gerät überhaupt nicht mehr sendet (erst daran bemerke ich überhaupt, dass ich die Batterie wechseln muss...)
Probier doch mal, das Ding komplett ohne Batterie eine Stunde (oder auch über Nacht) liegen zu lassen und erst dann die neue Batterie wieder einzusetzen.
CoolTux
Ich habe schon 2 oder 3 Mal die Batterie bei meinen 4 GTags gewechselt. Meistens so ab 15%
Das TuxNet Wiki:
isy
Ich hatte auch noch nie Probleme. Die GTAG behalten ihre Adresse.
Mein erstes hatte ich mit der App gekoppelt. Muss also funktionieren,  es wieder zu entkoppeln.
Hast du mal die Batteriespannung mit einem Voltmeter gemessen?
Also am Gerät selbst.
Das sollten 3,1 V bei neuen Batterien sein. Wenn nicht, sind die Batterien nicht neu oder haben Kontaktprobleme
Ein Weg wird erst zu einem Weg, wenn man ihn geht
ujaudio
#21
Also das hat nichts gebracht. Jetzt werde ich als nächstes messen, welche Spannung die neue(!) Batterie im Gerät hat und dann "hcitool lescan" prüfen, ob das Teil vorhanden ist.
Also: Batteriespannung = 3,1 V
"hcitool lescan" liefert permanent Werte - aber meine Gtags sind nicht dabei:
$ sudo hcitool lescan
LE Scan ...
4A:A4:EF:A5:28:08 (unknown)
3C:BD:3E:C1:FB:48 (unknown)
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB (unknown)
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4 (unknown)
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
F8:04:2E:B0:65:13 (unknown)
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
F8:77:B8:12:6F:EA (unknown)
88:C6:26:45:03:EB
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB
88:C6:26:45:03:EB
88:C6:26:45:03:EB
88:C6:26:45:03:EB
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
C0:28:8D:82:6C:E4
88:C6:26:45:03:EB
88:C6:26:45:03:EB
Ich habe das dann abgebrochen und ein anderes Kommando eingetippt:
$ sudo bluetoothctl
[NEW] Controller 00:1A:7D:DA:71:0F UJ2-Assistent [default]
[NEW] Device 7C:2F:80:DD:2A:C7 Gigaset keeper
[NEW] Device 7C:2F:80:DD:32:E8 Gigaset keeper
Und hier sind 2 meiner 3 Gtags sichtbar - der dritte hat derzeit keine Batterie.
bluetoothctl sagt, die beiden sind nicht gepaired:
[bluetooth]# info 7C:2F:80:DD:2A:C7
Alias: Gigaset keeper
Paired: no
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Immediate Alert           (00001802-0000-1000-8000-00805f9b34fb)
UUID: Link Loss                 (00001803-0000-1000-8000-00805f9b34fb)
UUID: Tx Power                  (00001804-0000-1000-8000-00805f9b34fb)
UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
UUID: Battery Service           (0000180f-0000-1000-8000-00805f9b34fb)
UUID: Dialog Semiconductor GmbH (0000fef5-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific           (6d696368-616c-206f-6c65-737a637a796b)
Modalias: bluetooth:v0180p0002d0100
ManufacturerData Key: 0x0180
ManufacturerData Value: 0x02
ManufacturerData Value: 0x15
ManufacturerData Value: 0x01
ManufacturerData Value: 0x00
ManufacturerData Value: 0x80
ManufacturerData Value: 0xdd
ManufacturerData Value: 0x2a
ManufacturerData Value: 0xc7
ManufacturerData Value: 0xc5
[bluetooth]# info 7C:2F:80:DD:32:E8
Paired: no
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
Einen lieben Gruß
Jürgen
ujaudio
Zitat von: Gasmast3r am 19 Mai 2019, 13:42:53
Wie gesagt schau mal unter bluetoothctl, wenn nicht bluetoothctl am Anfang steht ist was gepairt.
Ich habe den alten Beitrag nochmals gelesen: wie ist das "wenn nicht bluetoothctl am Anfang steht ist was gepairt" genau zu verstehen?
Einen lieben Gruß
Jürgen
Gasmast3r
Ja dann steht da irgendwas anderes, bin aber grad nicht zu hause um das zu zeigen
PatrickR
$ sudo bluetoothctl
Das sind leider keine G-tags sondern Keeper. Damit haben wir die Ursache.
Patrick
Von unterwegs gesendet.
lepresenced - Tracking von Bluetooth-LE-Tags (Gigaset G-Tag) mittels PRESENCE
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the universe trying to produce bigger and better idiots. So far, the universe is winning." - Rich Cook
ujaudio
Mhm??!?  Ich habe mal google angeworfen - und es gibt tatsächlich Gigaset Keeper und Gigaset G-Tags - und beide sehen identisch aus!
Ok, ich glaube ja, dass es da Unterschiede gibt, aber als Ursache des Verhaltens kann ich mir das noch nicht erklären. Bevor ich jetzt noch viel Zeit und Enregie in die wahre Ursachenfindung investiere, möchte ich gerne die "richtigen" Teile kaufen. Wer kann mir da eine Bezugsquelle nennen (kein Ebay!), damit ich auch wirklich die richtigen bekomme?
Einen lieben Gruß
Jürgen
CoolTux
Das TuxNet Wiki:
haben die Keeper nicht eine LED im Gehäuse? Die G-Tags sind bei mir jedenfalls ringsrum komplett glatt.
Gasmast3r
Hy war grad bei Jawol dort haben die von Byte Suchen und Finden Anhänger werden als iTag angezeigt und funktionieren recht gut.
Preis ist 5.99€
Hoffe das Bild wird auch angezeigt. (https://uploads.tapatalk-cdn.com/20190927/8b839e37108caffafcd823a262c3e4ce.jpg)
PatrickR
Und eine Taste in der Mitte.
Mein Keeper verhält sich jedenfalls komplett ruhig im Gegensatz zu den plärrenden G-Tags.
Patrick
