Autor Thema: #gelöst# HM-ES-PMSW1-PL-DN-R1 und SabotageMeldungen  (Gelesen 349 mal)
Offline Helmi55
    • Helmi's Fotoseite
« am: 02 Juni 2019, 10:37:47 »
Hallo verwende obigen Aktor und bekomme im Log diese Meldungen
2019.06.02 10:22:15 2: CUL_HM switch8 attack:1130088461989C0201C80000,1130088461989C0201000000:122035561989C010E
2019.06.02 10:22:20 2: CUL_HM switch8 attack:1130088461989C0201C80000,1130088461989C0201000000:122035561989C010E
2019.06.02 10:22:24 2: CUL_HM switch8 attack:1130088461989C0201C80000,1130088461989C0201000000:122035561989C010E
2019.06.02 10:22:25 2: CUL_HM switch8 attack:1130088461989C0201C80000,1130088461989C0201000000:122035561989C010E
2019.06.02 10:22:30 2: CUL_HM switch8 attack:1130088461989C0201C80000,1130088461989C0201000000:122035561989C010E
Ein List des Aktors
   CFGFN
   DEF        61989C
   FUUID      5cf0f94f-f33f-ee2d-c56a-a1aa38154eea925c
   IODev      myHmUART
   LASTInputDev myHmUART
   MSGCNT     1042
   NAME       switch8
   NOTIFYDEV  global
   NR         728
   STATE      CMDs_done
   TYPE       CUL_HM
   chanNo     01
   channel_01 Kugel
   channel_02 HM_61989C_Pwr
   channel_03 HM_61989C_SenPwr
   channel_04 HM_61989C_SenI
   channel_05 HM_61989C_SenU
   channel_06 HM_61989C_SenF
   lastMsg    No:7B - t:5E s:61989C d:000000 80002E000000000008C0FE
   myHmUART_MSGCNT 1042
   myHmUART_RAWMSG 0500001E7B845E61989C00000080002E000000000008C0FE
   myHmUART_RSSI -30
   myHmUART_TIME 2019-06-02 10:33:51
   protErrIoAttack 85 last_at:2019-06-02 10:22:30
   protErrIoId_220355 85 last_at:2019-06-02 10:22:30
   protLastRcv 2019-06-02 10:33:51
   protRcv    958 last_at:2019-06-02 10:33:51
   protSnd    91 last_at:2019-06-02 10:24:14
   protState  CMDs_done
   rssi_at_myHmUART cnt:958 min:-85 max:-30 avg:-57.72 lst:-30
   rssi_myHmUART cnt:9 min:-83 max:-37 avg:-61.66 lst:-37
     2019-06-01 18:42:43   Activity        alive
     2019-05-31 11:52:27   CommandAccepted yes
     2019-05-31 11:52:20   D-firmware      2.5
     2019-05-31 11:52:20   D-serialNr      OEQ1544910
     2019-05-31 11:52:30   PairedTo        0x300884
     2019-05-31 11:52:30   R-pairCentral   0x300884
     2019-05-31 11:52:30   RegL_00.         00:00 02:01 0A:30 0B:08 0C:84 15:FF 18:00
     2019-06-02 10:22:30   sabotageAttackId_ErrIoId_220355  cnt:85
     2019-06-02 10:22:30   sabotageAttack_ErrIoAttack cnt 85
     2019-06-02 10:24:14   state           CMDs_done
   helper:
     HM_CMDNR   123
     PONtest    0
     cSnd       1130088461989C0201C80000,1130088461989C0201000000
     mId        00AC
     peerFriend
     peerOpt    -:powerMeter
     regLst     0
     rxType     1
     supp_Pair_Rep 0
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newChn     +61989C,00,00,00
       nextSend   1559464309.61396
       prefIO
       rxt        0
       vccu
       p:
         61989C
         00
         00
         00
     mRssi:
       mNo        7B
       io:
         myHmUART:
           -22
           -22
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       dev        1
       prs        1
     rssi:
       at_myHmUART:
         avg        -57.7202505219206
         cnt        958
         lst        -30
         max        -30
         min        -85
       myHmUART:
         avg        -61.6666666666667
         cnt        9
         lst        -37
         max        -37
         min        -83
     shadowReg:
     tmpl:
   IODev      myHmUART
   IOgrp      VCCU:myHmUART
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   2.5
   model      HM-ES-PMSW1-PL-DN-R1
   room       HM-Steuerung
   serialNr   OEQ1544910
   subType    powerMeter
   webCmd     getConfig:clear msgEvents
Was mir bei den attacks auffällt ist die ID220355. Das ist die ID meiner VCCU in der Garage am 2ten Pi???
Aus der Nachbarschaft kann der angriff nicht kommen. Hinterm Haus Wald, zur Straße 80 Meter und die Nachbarn links und rechts sind keine IT Freaks.
Jemand bitte eine Idee?
Helmut
« Letzte Änderung: 02 Juni 2019, 16:59:50 von Helmi55 »
System1 fhem 5.9 auf RPi 4B mit 4GB, HMUSBConfig, DS9490R-1Wire, Busware USB 868, Pool-Solarsteuerung mit FHEM. System2 fhem 5.9 auf RPi 3B mit Busware USB 868 und 433 und HMUARTLGW für Haussteuerung
https://www.flickr.com/photos/canonhelmi/album
Offline frank
Antw:HM-ES-PMSW1-PL-DN-R1 und SabotageMeldungen
« Antwort #1 am: 02 Juni 2019, 12:52:15 »
warum funken bei dir 2 "zentralen" (vccu) den selben aktor an?
eventuell chaos in deinen definitionen, pairings und peerings? warum 2 vccu?
FHEM: 6.0(SVN) => Pi3(stretch)
WebUI [hm.js]: https://forum.fhem.de/index.php/topic,106959.0.html
Offline Helmi55
    • Helmi's Fotoseite
« Antwort #2 am: 02 Juni 2019, 13:14:27 »
Servus
habe soeben festgestellt, dieser Autor war noch am Pi in der Garage angemeldet (lag in unsorted) und der hat das Chaos ausgelöst.
Habe ihn jetzt in der Garage deleted.
Warum 2 VCCU: ich habe 2 unabhängig voneinander arbeitende Pi's die mit RFHEM verbunden sind.
Die Verbindung geht vom Haus zur Garage (Entfernung ca. 80Meter) über powerLan. Sollte diese Verbindung abbrechen, habe ich aber noch immer eine funktionierende
Poolsteuerung und Gartenbeleuchtung
So war zumindest mein Gedankengang. In der Garage arbeitet an der VCCu ein HMLanConfig Adapter und im Haus ein HMUart
Bin aber gerne für Vorschläge offen
Helmut
Offline frank
Antw:#gelöst# HM-ES-PMSW1-PL-DN-R1 und SabotageMeldungen
« Antwort #3 am: 02 Juni 2019, 19:42:17 »
für deine umgebung macht die zweite vccu durchaus sinn, finde ich. alles gut.
Offline Helmi55
    • Helmi's Fotoseite
« Antwort #4 am: 02 Juni 2019, 20:46:39 »
