FRM_In reading setzt aus
Begonnen von Marodeur, 13 Juni 2019, 12:27:34
Marodeur
Hier das List FIRMATA
   CONNECTS   1
   DEF        3030 global
   DRIVER_VERSION 0.64
   DeviceName 3030
   FD         4
   FUUID      5cf57319-f33f-1008-e746-a282d1cb2711e2dd
   NAME       FIRMATA
   NOTIFYDEV  global
   NR         16
   NTFY_ORDER 50-FIRMATA
   PORT       3030
   STATE      Initialized
   TYPE       FRM
   analog_pins 54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   analog_resolutions 54:10,55:10,56:10,57:10,58:10,59:10,60:10,61:10,62:10,63:10,64:10,65:10,66:10,67:10,68:10,69:10
   firmware   FHEM-Firmata.ino
   firmware_version V_2_10
   i2c_pins   20,21
   input_pins 2,3,5,6,7,8,9,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   onewire_pins 2,3,5,6,7,8,9,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   output_pins 2,3,5,6,7,8,9,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   protocol_version V_2_06
   pullup_pins 2,3,5,6,7,8,9,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69
   pwm_pins   2,3,5,6,7,8,9,11,12,13,44,45,46
   pwm_resolutions 2:8,3:8,5:8,6:8,7:8,8:8,9:8,11:8,12:8,13:8,44:8,45:8,46:8
   Helper:
     DBLOG:
       state:
         DBLogging:
           TIME       1561223414.59808
           VALUE      Initialized
     2019-06-22 17:10:14   state           Initialized
   SERIAL:
   SocketDevice:
     BUF
     DeviceName 3030
     FD         12
     NAME       FIRMATA_
     NR         55
     PEER
     PORT
     SNAME      FIRMATA
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FRM
       2019-06-22 17:10:08   state           Connected
   sampling-interval 30
Marodeur
Zitat von: PeMue am 22 Juni 2019, 19:06:42
was ich nicht verstehe ist folgendes:Der Zähler gibt (in Abhängigkeit vom Durchfluss) ein digitales Signal aus (manchmal ist der Ausgang on, d.h. das Relais ist offen und umgekehrt). Sprich: in FHEM ist der Pin manchmal on und manchmal off. Über die Anzahl der Zählungen (z.B. alle on's) pro Zeiteinheit und den Umrechnungsfaktor (Impulse pro Liter) wird die Menge pro Zeiteinheit daraus errechnet. So ähnlich (Wasseruhr mit Impulsausgang und GPIO am Raspberry Pi) ermittle ich meinen Wasserverbrauch). Auch da ist der Pin manchmal on und manchmal off.
Gruß PeMue
Das das reading off geht wenn keine Daten mehr kommen kann ich verstehen, aber es schaltet sich nicht wieder von alleine on und hohlt neue Daten, erst wenn ich den Pullup von Hand kurz umschalte, dann Zählt der Counter wieder für 1 bis 2 Sekunden und das reading geht dann wieder dauerhaft auf off.
PeMue
Schaltet sich dann der pullup um? Kannst Du das irgendwie rausbekommen? Der pullup ist ja auf dem Arduino, oder?
Im Moment weiß ich nicht, ob die Firmata Firmware nicht das macht, was sie soll oder ob es das FHEM Modul ist.
Gruß Peter
Marodeur
Gruß Peter
Also von alleine schaltet der Pullup nicht um, das muss ich von Hand machen.
