Autor Thema: Problem pairing MAX! Eco Switch using CUL  (Gelesen 1355 mal)
Offline alangward
  • New Member
« am: 04 Juli 2019, 10:31:03 »
Recently the batteries gave up on my ECO switch.
I replaced them, but the light on the front stays on permanently and I cannot pair it.
It is transmitting OK as I can see its initial output in the log.
I originally installed it with a MAX! Cube, before I started using FHEM.
When I switched from the MAX Cube to a CUL I just re-assigned the same RF address to the CUL so all my devices continued to be paired - hence this Eco Switch continued to work.
Any ideas?,
Thanks
Alan
Offline RaspiLED
  • Es begann alles so klein ;-)
« Antwort #1 am: 04 Juli 2019, 11:24:40 »
please give us the details in Code Tags.
list <Device>
list <CUL>
Gruß Arnd
Signalduino (Nano, ESP, ...), CUL (Busware, Nano, Maple, ...), Homematic (HM-MOD-UART-RPI, ESP, Maple, ...), LaCrosseGateway (LGW, ESP, ...), 1-wire, ESPEasy, Bravia, Yamaha, ...
Offline alangward
  • New Member
Antw:Problem pairing MAX! Eco Switch using CUL
« Antwort #2 am: 10 Juli 2019, 11:05:15 »
Hi
Thanks for your reply.
I've not been around - so only just seen it.
I have attached a short text file that contains the lists requested.
Thanks,
Alan
Offline RaspiLED
« Antwort #3 am: 10 Juli 2019, 19:56:13 »
First of all not a attachment but please use the code tags like I did in my Post.
Secondly I asked for the list of the CUL!
What is that MAX_C is it a CUBE?
Why is the IODev in the Switch still CUBE?
What did you exactly change?
How dies the Eventmonitor look like when you try to pair?
What is in the log?
Warm regards,
Arnd
decade-submarginal
