Hallo Krikan,
habe die Installation per CPAN durchgeführt. Da ich nicht "so der Unix-Typ" bin, muss ich hier passen.
Es scheint aber ein Problem mit "XML::Parser" und "XML::SAX::Expat" zu geben.
cpan[1]> install XML::Simple
Reading '/home/pi/.cpan/Metadata'
Database was generated on Fri, 19 Jul 2019 16:41:03 GMT
Running install for module 'XML::Simple'
Checksum for /home/pi/.cpan/sources/authors/id/G/GR/GRANTM/XML-Simple-2.25.tar.gz ok
Scanning cache /home/pi/.cpan/build for sizes
............................................................................DONE
'YAML' not installed, will not store persistent state
Configuring G/GR/GRANTM/XML-Simple-2.25.tar.gz with Makefile.PL
Checking if your kit is complete...
Looks good
Warning: prerequisite XML::SAX::Expat 0 not found.
Generating a Unix-style Makefile
Writing Makefile for XML::Simple
Writing MYMETA.yml and MYMETA.json
/usr/bin/perl Makefile.PL INSTALLDIRS=site -- OK
Running make for G/GR/GRANTM/XML-Simple-2.25.tar.gz
---- Unsatisfied dependencies detected during ----
---- GRANTM/XML-Simple-2.25.tar.gz ----
XML::SAX::Expat [requires]
Running install for module 'XML::SAX::Expat'
Checksum for /home/pi/.cpan/sources/authors/id/B/BJ/BJOERN/XML-SAX-Expat-0.51.tar.gz ok
Configuring B/BJ/BJOERN/XML-SAX-Expat-0.51.tar.gz with Makefile.PL
Looks good
Warning: prerequisite XML::Parser 2.27 not found.
Writing Makefile for XML::SAX::Expat
Running make for B/BJ/BJOERN/XML-SAX-Expat-0.51.tar.gz
---- BJOERN/XML-SAX-Expat-0.51.tar.gz ----
XML::Parser [requires]
Running install for module 'XML::Parser'
Checksum for /home/pi/.cpan/sources/authors/id/T/TO/TODDR/XML-Parser-2.44.tar.gz ok
Configuring T/TO/TODDR/XML-Parser-2.44.tar.gz with Makefile.PL
Expat must be installed prior to building XML::Parser and I can't find
it in the standard library directories. Install 'expat-devel' (or
'libexpat1-dev') package with your OS package manager. See 'README'.
Or you can download expat from:
http://sourceforge.net/projects/expat/
If expat is installed, but in a non-standard directory, then use the
following options to Makefile.PL:
EXPATLIBPATH=... To set the directory in which to find libexpat
EXPATINCPATH=... To set the directory in which to find expat.h
For example:
perl Makefile.PL EXPATLIBPATH=/home/me/lib EXPATINCPATH=/home/me/include
Note that if you build against a shareable library in a non-standard location
you may (on some platforms) also have to set your LD_LIBRARY_PATH environment
variable at run time for perl to find the library.
Looks good
Writing Makefile for XML::Parser::Expat
Running make for T/TO/TODDR/XML-Parser-2.44.tar.gz
cp Parser/Encodings/iso-8859-5.enc blib/lib/XML/Parser/Encodings/iso-8859-5.enc
cp Parser/Encodings/iso-8859-3.enc blib/lib/XML/Parser/Encodings/iso-8859-3.enc
cp Parser/Encodings/iso-8859-4.enc blib/lib/XML/Parser/Encodings/iso-8859-4.enc
cp Parser/Encodings/x-sjis-cp932.enc blib/lib/XML/Parser/Encodings/x-sjis-cp932.enc
cp Parser/Style/Tree.pm blib/lib/XML/Parser/Style/Tree.pm
cp Parser/Encodings/windows-1251.enc blib/lib/XML/Parser/Encodings/windows-1251.enc
cp Parser/Style/Subs.pm blib/lib/XML/Parser/Style/Subs.pm
cp Parser/Encodings/big5.enc blib/lib/XML/Parser/Encodings/big5.enc
cp Parser/Encodings/koi8-r.enc blib/lib/XML/Parser/Encodings/koi8-r.enc
cp Parser/Style/Debug.pm blib/lib/XML/Parser/Style/Debug.pm
cp Parser/Encodings/iso-8859-8.enc blib/lib/XML/Parser/Encodings/iso-8859-8.enc
cp Parser/Encodings/windows-1255.enc blib/lib/XML/Parser/Encodings/windows-1255.enc
cp Parser/Style/Stream.pm blib/lib/XML/Parser/Style/Stream.pm
cp Parser/Encodings/Japanese_Encodings.msg blib/lib/XML/Parser/Encodings/Japanese_Encodings.msg
cp Parser/Style/Objects.pm blib/lib/XML/Parser/Style/Objects.pm
cp Parser/Encodings/iso-8859-2.enc blib/lib/XML/Parser/Encodings/iso-8859-2.enc
cp Parser/Encodings/iso-8859-7.enc blib/lib/XML/Parser/Encodings/iso-8859-7.enc
cp Parser/Encodings/x-sjis-jdk117.enc blib/lib/XML/Parser/Encodings/x-sjis-jdk117.enc
cp Parser/Encodings/x-sjis-unicode.enc blib/lib/XML/Parser/Encodings/x-sjis-unicode.enc
cp Parser/LWPExternEnt.pl blib/lib/XML/Parser/LWPExternEnt.pl
cp Parser/Encodings/x-sjis-jisx0221.enc blib/lib/XML/Parser/Encodings/x-sjis-jisx0221.enc
cp Parser/Encodings/x-euc-jp-unicode.enc blib/lib/XML/Parser/Encodings/x-euc-jp-unicode.enc
cp Parser/Encodings/windows-1250.enc blib/lib/XML/Parser/Encodings/windows-1250.enc
cp Parser/Encodings/x-euc-jp-jisx0221.enc blib/lib/XML/Parser/Encodings/x-euc-jp-jisx0221.enc
cp Parser/Encodings/euc-kr.enc blib/lib/XML/Parser/Encodings/euc-kr.enc
cp Parser/Encodings/README blib/lib/XML/Parser/Encodings/README
cp Parser/Encodings/iso-8859-9.enc blib/lib/XML/Parser/Encodings/iso-8859-9.enc
cp Parser/Encodings/windows-1252.enc blib/lib/XML/Parser/Encodings/windows-1252.enc
cp Parser.pm blib/lib/XML/Parser.pm
cp Parser/Encodings/ibm866.enc blib/lib/XML/Parser/Encodings/ibm866.enc
make[1]: Entering directory '/home/pi/.cpan/build/XML-Parser-2.44-NpYumK/Expat'
cp Expat.pm ../blib/lib/XML/Parser/Expat.pm
Running Mkbootstrap for XML::Parser::Expat ()
chmod 644 Expat.bs
/usr/bin/perl /usr/share/perl/5.20.2/ExtUtils/xsubpp -noprototypes -typemap /usr/share/perl/5.20/ExtUtils/typemap -typemap typemap Expat.xs > Expat.xsc && mv Expat.xsc Expat.c
cc -c -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fwrapv -fno-strict-aliasing -pipe -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"2.44\" -DXS_VERSION=\"2.44\" -fPIC "-I/usr/lib/arm-linux-gnueabihf/perl/5.20/CORE" Expat.c
/usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1: /usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1: no version information available (required by /usr/lib/arm-linux-gnueabihf/libmpfr.so.4)
Inconsistency detected by ld.so: dl-version.c: 224: _dl_check_map_versions: Assertion `needed != ((void *)0)' failed!
Makefile:317: recipe for target 'Expat.o' failed
make[1]: *** [Expat.o] Error 1
make[1]: Leaving directory '/home/pi/.cpan/build/XML-Parser-2.44-NpYumK/Expat'
Makefile:592: recipe for target 'subdirs' failed
make: *** [subdirs] Error 2
/usr/bin/make -- NOT OK
Has already been unwrapped into directory /home/pi/.cpan/build/XML-SAX-Expat-0.51-Yoal8b
Has already been prepared
Warning: Prerequisite 'XML::Parser => 2.27' for 'BJOERN/XML-SAX-Expat-0.51.tar.gz' failed when processing 'TODDR/XML-Parser-2.44.tar.gz' with 'make => NO'. Continuing, but chances to succeed are limited.
cp Expat.pm blib/lib/XML/SAX/Expat.pm
Manifying blib/man3/XML::SAX::Expat.3pm
/usr/bin/make -- OK
Running make test
PERL_DL_NONLAZY=1 PERL_USE_UNSAFE_INC=1 /usr/bin/perl "-MExtUtils::Command::MM" "-MTest::Harness" "-e" "undef *Test::Harness::Switches; test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
t/00basic.t ... Can't locate XML/Parser.pm in @INC (you may need to install the XML::Parser module) (@INC contains: /home/pi/.cpan/build/XML-SAX-Expat-0.51-Yoal8b/blib/lib /home/pi/.cpan/build/XML-SAX-Expat-0.51-Yoal8b/blib/arch /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at /home/pi/.cpan/build/XML-SAX-Expat-0.51-Yoal8b/blib/lib/XML/SAX/Expat.pm line 11.
BEGIN failed--compilation aborted at /home/pi/.cpan/build/XML-SAX-Expat-0.51-Yoal8b/blib/lib/XML/SAX/Expat.pm line 11.
Compilation failed in require at t/00basic.t line 3.
BEGIN failed--compilation aborted at t/00basic.t line 3.
t/00basic.t ... Dubious, test returned 2 (wstat 512, 0x200)
Failed 1/1 subtests
t/98podsyn.t .. skipped: Test::Pod 1.00 required for testing POD
t/99podcov.t .. skipped: Test::Pod::Coverage required for testing pod coverage
Test Summary Report
t/00basic.t (Wstat: 512 Tests: 1 Failed: 1)
Failed test: 1
Non-zero exit status: 2
Files=3, Tests=1, 2 wallclock secs ( 0.28 usr 0.05 sys + 0.77 cusr 0.06 csys = 1.16 CPU)
Result: FAIL
Failed 1/3 test programs. 1/1 subtests failed.
Makefile:829: recipe for target 'test_dynamic' failed
make: *** [test_dynamic] Error 255
one dependency not OK (XML::Parser); additionally test harness failed
/usr/bin/make test -- NOT OK
//hint// to see the cpan-testers results for installing this module, try:
reports BJOERN/XML-SAX-Expat-0.51.tar.gz
Has already been unwrapped into directory /home/pi/.cpan/build/XML-Simple-2.25-FzqyUE
Warning: Prerequisite 'XML::SAX::Expat => 0' for 'GRANTM/XML-Simple-2.25.tar.gz' failed when processing 'BJOERN/XML-SAX-Expat-0.51.tar.gz' with 'make_test => NO one dependency not OK (XML::Parser); additionally test harness failed'. Continuing, but chances to succeed are limited.
cp lib/XML/Simple/FAQ.pod blib/lib/XML/Simple/FAQ.pod
cp lib/XML/Simple.pm blib/lib/XML/Simple.pm
Manifying blib/man3/XML::Simple.3pm
Manifying blib/man3/XML::Simple::FAQ.3pm
/usr/bin/make -- OK
Running make test
# Package Version
# perl 5.20.2
# XML::Simple 2.25
# Storable 2.49_01
# XML::Parser Not Installed
# XML::SAX 1.02
# XML::NamespaceSupport 1.12
# XML::SAX::PurePerl 1.02 (default parser)
t/0_Config.t ............. ok
t/1_XMLin.t .............. ok
t/2_XMLout.t ............. ok
t/3_Storable.t ........... ok
t/4_MemShare.t ........... ok
t/5_MemCopy.t ............ ok
t/6_ObjIntf.t ............ ok
t/7_SaxStuff.t ........... ok
t/8_Namespaces.t ......... ok
t/9_Strict.t ............. ok
t/A_XMLParser.t .......... skipped: no XML::Parser
t/author-pod-syntax.t .... skipped: these tests are for testing by the author
t/B_Hooks.t .............. ok
t/C_External_Entities.t .. skipped: no XML::Parser
All tests successful.
Files=14, Tests=487, 36 wallclock secs ( 0.90 usr 0.11 sys + 24.93 cusr 0.70 csys = 26.64 CPU)
Result: PASS
Tests succeeded but one dependency not OK (XML::SAX::Expat)
[dependencies] -- NA
Failed during this command:
TODDR/XML-Parser-2.44.tar.gz : make NO
BJOERN/XML-SAX-Expat-0.51.tar.gz : make_test NO one dependency not OK (XML::Parser); additionally test harness failed
GRANTM/XML-Simple-2.25.tar.gz : make_test NO one dependency not OK (XML::SAX::Expat)
cpan[2]>
Was kann / muss ich nun machen?
Besten Dank für Unterstützung und beste Grüße,
Desedo
