Not getting a "gassistantFHEM.loginURL"
Begonnen von Zaleo, 20 Juli 2019, 21:22:15
Zaleo
Hello all,
It has been some time that I worked with FHEM, and my Pi3 with CCD (v1.1) really needed an update.
My German is not great, as I am Dutch, however I have tried to follow the instructions on: https://wiki.fhem.de/wiki/Google_Assistant_FHEM_Connect#Installation
Zitat von: Installation documentationCa. 30s warten bis ein Reading gassistantFHEM.loginURL erscheint. Wenn der Link nicht erscheint, dann bitte in der Konsole einmal "gassistant-fhem" ausführen und die Fehlermeldung beachten. Gerne diese im Forum posten.
So here I am with my problem, I do not get a google login URL, and I did notice an error in the gassistant log file.
Code (gassistant log) Auswählen
/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:80
    throw new Error(
Error: Timed out waiting for sync-rpc server to start (it should respond with "pong" when sent "ping"):
events.js:174
      throw er; // Unhandled 'error' event
Error: connect ECONNREFUSED 127.0.0.1:40723
    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1104:14)
Emitted 'error' event at:
    at emitErrorNT (internal/streams/destroy.js:82:8)
    at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
    at process._tickCallback (internal/process/next_tick.js:63:19)
    at waitForAlive (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:80:11)
    at start (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:40:3)
    at sendMessage (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:117:17)
    at createClient (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:157:27)
    at Object.<anonymous> (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-request/lib/index.js:16:14)
    at Module._compile (internal/modules/cjs/loader.js:689:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
    at Module.load (internal/modules/cjs/loader.js:599:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
    at Function.Module._load (internal/modules/cjs/loader.js:530:3)
Loading cli.js...
Loading version.js...
Loading server.js...
Loading user.js...
Loading logger.js...
Loading fhem.js...
Loading database.js...
OS:Raspbian GNU/Linux 10 (buster)
# npm -v
6.10.1
# node -v
v10.15.2
Fhem version 5.9.19853
gassistant-fhem@2.0.0
sync-rpc@1.3.4
Did check netstat too see if node was lisseinging on ports in the higher ranges, and yes this seems the case, but on different ports numbers.
Zitat von: netstatroot@Domotica:/opt/fhem/log# netstat -tulpn | grep LISTEN
tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      390/perl
tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      390/perl
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      389/sshd
tcp6       0      0 :::36127                :::*                    LISTEN      663/node
tcp6       0      0 :::46729                :::*                    LISTEN      976/node
tcp6       0      0 :::22                   :::*                    LISTEN      389/sshd
Please do you have any advice?
With kind regards,
Zeo
dominik
do you have any special security settings on your system? It looks like the internal rpc communication isn't working.
Cheers
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
Zaleo
Thanks dominik for the effort.
Zitat von: dominikdo you have any special security settings on your system?
Not that I am aware, basic Raspbian Buster Lite image and followed the instructions on the busware.de (ccdv1) and FHEM website to get things running.
amenomade
Zaleo
Zitat von: amenomadeWhat does
ip a
say?
Code (ip a) Auswählen
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:ba:b0:68 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.175/24 brd 192.168.1.255 scope global noprefixroute eth0
    inet6 fe80::f6fe:57df:320f:6262/64 scope link
Zaleo
#5
The answer from dominik got me thinking  ???
I installed the light image of Raspbian, so thing I needed to start the portmapper.
# sudo service portmap start
This did supress the error in the gassistant log...
Made it permanent
# sudo systemctl enable portmap
But after a quick reboot, still I get an errormessage (Never got a loginURL).
dominik
Can you post the output from the gassistant-fhem log after the portmapper change?
Zaleo
#7
Yes I can.
After a reboot, or a "set gassistant restart" I get an errors....
Zitat von: gassistant log/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:80
    throw new Error(
events.js:174
Error: connect ECONNREFUSED 127.0.0.1:45327
    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
    at emitErrorNT (internal/streams/destroy.js:91:8)
    at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
    at Module._compile (internal/modules/cjs/loader.js:776:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
Loading cli.js...
Loading user.js...
Loading fhem.js...
When I do "sudo service portmap start" in the console and then a "set gassistant restart" the logging looks like:
Loading user.js...
Loading fhem.js...
No error....
So I think the portmap service is started at boot or after FHEM, or is not related.
# sudo systemctl is-active portmap
active
However in both situations I do not get a loginURL.  :'(
Hope this is clear?
dominik
Even after a minute or so nothing more appears in the log after the restart? Can you please check FHEM log as well in that case.
Zaleo
Waited 10 minutes now... Still no URL
Code (FHEM log) Auswählen
2019.07.21 21:24:56 1: Including fhem.cfg
2019.07.21 21:24:59 3: WEB: port 8083 opened
2019.07.21 21:24:59 3: telnetPort: port 7072 opened
2019.07.21 21:25:00 3: Opening CCD device /dev/ttyAMA0
2019.07.21 21:25:00 3: Setting CCD serial parameters to 38400,8,N,1
2019.07.21 21:25:00 3: CCD: Possible commands: mbCFiAZGMRTVWXefltux
2019.07.21 21:25:00 3: CCD device opened
2019.07.21 21:25:02 2: eventTypes: loaded 32 events from ./log/eventTypes.txt
2019.07.21 21:25:02 1: Including ./log/fhem.save
2019.07.21 21:25:02 2: gassistant: starting gassistant-fhem: /usr/local/bin/gassistant-fhem -c ./gassistant-fhem.cfg
2019.07.21 21:25:02 3: gassistant: starting
2019.07.21 21:25:02 3: gassistant: using logfile: ./log/gassistant-2019-07-21.log
2019.07.21 21:25:02 0: Featurelevel: 5.9
2019.07.21 21:25:02 0: Server started with 27 defined entities (fhem.pl:19805/2019-07-09 perl:5.028001 os:linux user:fhem pid:374)
2019.07.21 21:25:41 3: gassistant: read: end of file reached while sysread
Here I got the error, and restarted gassistant - No more error.
2019.07.21 21:26:49 3: gassistant: stopped
2019.07.21 21:26:49 2: gassistant: starting gassistant-fhem: /usr/local/bin/gassistant-fhem -c ./gassistant-fhem.cfg
2019.07.21 21:26:49 3: gassistant: starting
2019.07.21 21:26:49 3: gassistant: using logfile: ./log/gassistant-2019-07-21.log
dominik
Stop gassistant again and try to start it in the console. Just type gassistant-fhem, nothing more. I hope you get some more log messages there.
Zaleo
Code (console) Auswählen
root@Domotica:/opt/fhem# /usr/local/bin/gassistant-fhem -c ./gassistant-fhem.cfg
Loading cli.js...
Loading user.js...
Loading fhem.js...
Illegal instruction
Illegal instruction  :o ???
dominik
Looks like a grpc issue.
Try
npm rebuild --build-from-source --unsafe-perm grpc
It can take 2 hours to compile.
Zaleo
Cooking  ;D
root@Domotica:/usr/local/lib/node_modules/gassistant-fhem#  npm rebuild --build-from-source --unsafe-perm grpc
> grpc@1.20.0 install /usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc
> node-pre-gyp install --fallback-to-build --library=static_library
node-pre-gyp WARN Using request for node-pre-gyp https download
make: Entering directory '/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/build'
  CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
etc. etc.
@dominik thanks for all the help this far!!!! It is appreciated.
Will come back when finished.
Zaleo
#14
The rebuild failed....  :(
Zitat von: rebuild
<-- snip-->
CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/client_channel/lb_policy/grpclb/load_balancer_api.o
../deps/grpc/src/core/ext/filters/client_channel/lb_policy/grpclb/load_balancer_api.cc: In function 'grpc_grpclb_request* grpc_grpclb_request_create(const char*)':
../deps/grpc/src/core/ext/filters/client_channel/lb_policy/grpclb/load_balancer_api.cc:70:10: error: 'char* strncpy(char*, const char*, size_t)' specified bound 128 equals destination size [-Werror=stringop-truncation]
   strncpy(req->initial_request.name, lb_service_name,
           GRPC_GRPCLB_SERVICE_NAME_MAX_LENGTH);
cc1plus: all warnings being treated as errors
make: *** [grpc.target.mk:482: Release/obj.target/grpc/deps/grpc/src/core/ext/filters/client_channel/lb_policy/grpclb/load_balancer_api.o] Error 1
make: Leaving directory '/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Linux 4.19.57+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--library=static_library" "--module=/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node" "--module_name=grpc_node" "--module_path=/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
gyp ERR! cwd /usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc
gyp ERR! node -v v10.16.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --library=static_library --module=/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node --module_name=grpc_node --module_path=/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
node-pre-gyp ERR! System Linux 4.19.57+
node-pre-gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--library=static_library"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc
node-pre-gyp ERR! node -v v10.16.0
node-pre-gyp ERR! node-pre-gyp -v v0.12.0
node-pre-gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! grpc@1.20.0 install: `node-pre-gyp install --fallback-to-build --library=static_library`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the grpc@1.20.0 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2019-07-21T21_01_37_769Z-debug.log
Zitat von: debug.log
<-- snip-->
75 info lifecycle grpc@1.20.0~install: Failed to exec install script
476 verbose stack Error: grpc@1.20.0 install: `node-pre-gyp install --fallback-to-build --library=static_library`
476 verbose stack Exit status 1
476 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
476 verbose stack     at EventEmitter.emit (events.js:198:13)
476 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
476 verbose stack     at ChildProcess.emit (events.js:198:13)
476 verbose stack     at maybeClose (internal/child_process.js:982:16)
476 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
477 verbose pkgid grpc@1.20.0
478 verbose cwd /usr/local/lib/node_modules/gassistant-fhem
479 verbose Linux 4.19.57+
480 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "rebuild" "--build-from-source" "--unsafe-perm" "grpc"
481 verbose node v10.16.0
482 verbose npm  v6.9.0
483 error code ELIFECYCLE
484 error errno 1
485 error grpc@1.20.0 install: `node-pre-gyp install --fallback-to-build --library=static_library`
485 error Exit status 1
486 error Failed at the grpc@1.20.0 install script.
486 error This is probably not a problem with npm. There is likely additional logging output above.
487 verbose exit [ 1, true ]
dominik
Ok, then try to uninstall grpc and install it with
npm install grpc --unsafe-perm
again.
If it works, it should download the grpc binary during the install process.
Zaleo
#16
Zitat von: console# npm uninstall grpc
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN gassistant-fhem@2.0.0 No repository field.
audited 349 packages in 52.8s
found 0 vulnerabilities
Zitat von: console# npm install grpc --unsafe-perm
> grpc@1.20.0 install /usr/local/lib/node_modules/gassistant-fhem/node_modules/@firebase/firestore/node_modules/grpc
[grpc] Success: "/usr/local/lib/node_modules/gassistant-fhem/node_modules/@firebase/firestore/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node" is installed via remote
> grpc@1.22.2 install /usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc
[grpc] Success: "/usr/local/lib/node_modules/gassistant-fhem/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node" is installed via remote
+ grpc@1.22.2
added 70 packages from 27 contributors, removed 3 packages, updated 12 packages and audited 500 packages in 313.934s
I assume there is no need to rebuild the full package again, as there are new binaries?
Seems to be the same error(s):
Zitat von: console# sudo /usr/local/bin/gassistant-fhem -c ./gassistant-fhem.cfg
sudo: unable to resolve host Domotica: Name or service not known
Loading cli.js...
Loading user.js...
Loading fhem.js...
Illegal instruction
    throw new Error(
events.js:174
Error: connect ECONNREFUSED 127.0.0.1:37351
Loading cli.js...
Loading user.js...
Loading fhem.js...
Zitat von: FHEM log2019.07.21 23:58:12 1: Including fhem.cfg
2019.07.21 23:58:15 3: WEB: port 8083 opened
2019.07.21 23:58:16 3: telnetPort: port 7072 opened
2019.07.21 23:58:16 3: Opening CCD device /dev/ttyAMA0
2019.07.21 23:58:17 3: Setting CCD serial parameters to 38400,8,N,1
2019.07.21 23:58:17 3: CCD: Possible commands: mbCFiAZGMRTVWXefltux
2019.07.21 23:58:17 3: CCD device opened
2019.07.21 23:58:18 2: eventTypes: loaded 32 events from ./log/eventTypes.txt
2019.07.21 23:58:18 1: Including ./log/fhem.save
2019.07.21 23:58:19 2: gassistant: starting gassistant-fhem: /usr/local/bin/gassistant-fhem -c ./gassistant-fhem.cfg
2019.07.21 23:58:19 3: gassistant: starting
2019.07.21 23:58:19 3: gassistant: using logfile: ./log/gassistant-2019-07-21.log
2019.07.21 23:58:19 0: Featurelevel: 5.9
2019.07.21 23:58:19 0: Server started with 27 defined entities (fhem.pl:19805/2019-07-09 perl:5.028001 os:linux user:fhem pid:381)
dominik
No, no need to rebuild.
This one sounds strange
I think you have some issues with your network parts of your installation. Have you set the hostname properly?
Zaleo
#18
# hostname
Domotica
Yhea I have to change my DHCP server to set 192.168.1.1 as primary DNS server.
It is now using 1.1.1.1 as primary, and cloudfare does not know my local device names  ::)
Manually change the sequense in /etc/resolv.conf untill just now, but did forget it after the last boot.
Fixed it presently by adding my hostename in the /etc/hosts file.
The problem with starting and getting a loginURL by gassistantFHEM remains the same. Don't think this is related, but prove me wrong.
Would really love to control FS20 devices with my Google home.
dominik
I'm really running out of ideas. Can you please verify if the error in the gassistant-fhem log really appears before Loading cli.js? That would mean that the loading mechanism of the libraries is not working.
dominik
Please also try to run following code in a node console:
const path = require('path');
var request = require('sync-request');
var {NodeVM} = require('vm2');
Zaleo
Please have a look at the following..
root@Domotica:/home/pi# echo > /opt/fhem/log/gassistant-2019-07-22.log
root@Domotica:/home/pi# reboot
Waited, logged in again and this.....
root@Domotica:/home/pi# cat /opt/fhem/log/gassistant-2019-07-22.log
    throw new Error(
events.js:174
Error: connect ECONNREFUSED 127.0.0.1:44257
Loading cli.js...
Loading user.js...
Loading fhem.js...
Is that verified enough?
Zaleo
#22
root@Domotica:/usr/local/lib/node_modules/gassistant-fhem# node
undefined
undefined
undefined
But this only works if I am in the /usr/local/lib/node_modules/gassistant-fhem/ folder, not anywhere else.
root@Domotica:/home/pi# node
undefined
Thrown:
{ Error: Cannot find module 'sync-request'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Module.require (internal/modules/cjs/loader.js:690:17)
    at require (internal/modules/cjs/helpers.js:25:18) code: 'MODULE_NOT_FOUND' }
Thrown:
{ Error: Cannot find module 'vm2'
So I tried something really different, just to see if nodeJs is working.
> 10+10
20
I find it really strange we only get the error once after a reboot, not when restarting gassistant/fhem-connection and not in the shell etc.
But that might just be me.
dominik
Can you do a require('cli') in node console within the gassistant-fhem/lib folder?
Zaleo
#24
Think we are now narrowing it down:
Code (shell) Auswählen
> require('cli');
Thrown:
{ Error: Cannot find module 'cli'
>_
dominik
Please do it in the lib folder, not gassistant-fhem folder.
Zaleo
#26
Oeps, hope I did not mess anything up now, tried to install the cli module.
# npm install cli --unsafe-perm
But no luck, or should it be installed globally?
Anyway, now I get this:
root@Domotica:/usr/local/lib/node_modules/gassistant-fhem/lib# node
> require('cli');
Thrown:
TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string. Received type undefined
    at validateString (internal/validators.js:125:11)
    at Object.basename (path.js:1289:5)
    at Object.cli.setArgv (/usr/local/lib/node_modules/gassistant-fhem/node_modules/cli/cli.js:148:31)
>_
dominik
cli is a local js file, it's not a library which can be installed.
Can you please type within the gassistant-fhem directory just bin\gassistant-fhem and see the console output.
Zaleo
#28
Zitatroot@Domotica:/usr/local/lib/node_modules/gassistant-fhem# bin\gassistant-fhem
bash: bingassistant-fhem: command not found
root@Domotica:/usr/local/lib/node_modules/gassistant-fhem# bin/gassistant-fhem
Loading cli.js...
Loading user.js...
Loading fhem.js...
Illegal instruction
No error, but yhea.. Get it only the first time around..
Zaleo
#29
After a lot of support from dominik the issue did not seem to get resolved.  :-[
We narrowed it down to a corrupt installation of nodeJS.
Seems like I am using a RPi v2 with an armv6 processor and the nodeJS package that came with npm does not support this architechture.
When I put the same SDCard in a RPi v3 I had, gassistatn-FHEM suddenly worked.
:) ;) :D
bmaehr
I was only able to solve this by editing my package.json:
  "dependencies": {
    "@firebase/firestore": "1.6.4",
    "grpc": "1.24.2",
  "resolutions": {
    "grpc": "1.24.2"
