Autor Thema: Assistant hat alle Geräte verloren  (Gelesen 725 mal)
Offline Udomatic
« am: 21 Juli 2019, 10:08:34 »
ich hatte bisher in Google Assistant meine Leuchten und Sonos gemappt. Heute morgen habe ich meine Rollos hinzufügen wollen. Nun habe ich keine Devices mehr in der Assitant App. In FHEM steht aber, dass der Assitant connected ist.
Seitdem wird das Log mit diesen Meldungen gefüllt:
[2019-7-21 10:03:58] GOOGLE MSG RECEIVED: {"log":"  wrong syntax: minStep=50 TargetPosition=userposition","msg":"LOG_ERROR","ts":1563696238034}
[2019-7-21 10:03:58] Received firestore2fhem: {"log":"  wrong syntax: minStep=50 TargetPosition=userposition","msg":"LOG_ERROR","ts":1563696238034}
[2019-7-21 10:03:58] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-lastServerError%20%20%20wrong%20syntax%3A%20minStep%3D50%20TargetPosition%3Duserposition&XHR=1
[2019-7-21 10:03:58] [FHEM] Rollo_Bad-a-room moved to room GoogleAssistant
[2019-7-21 10:04:06] GOOGLE MSG RECEIVED: {"featurelevel":3,"msg":"UPDATE_SYNCFEATURELEVEL","ts":1563696246733}
[2019-7-21 10:04:06] Received firestore2fhem: {"featurelevel":3,"msg":"UPDATE_SYNCFEATURELEVEL","ts":1563696246733}
[2019-7-21 10:04:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-usedFeatureLevel%203&XHR=1
[2019-7-21 10:04:06] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-googleSync%20Google%20SYNC%20finished&XHR=1
[2019-7-21 10:04:07] GOOGLE MSG RECEIVED: {"delay":40,"id":"15455435776751047252","msg":"REPORTSTATEALL","ts":1563696246949}
[2019-7-21 10:04:07] Received firestore2fhem: {"delay":40,"id":"15455435776751047252","msg":"REPORTSTATEALL","ts":1563696246949}
[2019-7-21 10:04:07] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=setreading%20gassistant%20gassistant-fhem-connection%20connected&XHR=1
[2019-7-21 10:04:37] reportstateall initiated
Der hier aufgezeigte wrong syntax Fehler ist die Definition meines Homebridge Mappings für die Somfy Rollos, was auch ohne Probleme in der Kombination FHM / Homebridge funktioniert.
Warum Google damit ein Problem hat verstehe ich nicht zumal ich das Mapping natürlich nicht raus nehmen kann.
Kann mir bitte jemand das Problem erklären?
Danke vorab.
Udo
« Letzte Änderung: 21 Juli 2019, 10:12:10 von Udomatic »
2x Raspberry 3B+, Signalduino 433 (Somfy), CUL_HM (HM-MOD-RPI-PCB), Hue, ConBee 2, Sonos, MQTT, Alexa, Homebridge, Pushover
Offline dominik
Antw:Assistant hat alle Geräte verloren
« Antwort #1 am: 21 Juli 2019, 14:19:40 »
Bitte die homebridgeMappings von Leerzeichen Trennung auf Enter umstellen, dann klappt's auch wieder.
Autor: 10_EQ3BT (EQ-3 Bluetooth Thermostat), 98_BOSEST (BOSE SoundTouch), 98_DLNARenderer (DLNA Renderer), 98_GOOGLECAST (Google Cast), 39_gassistant (Google Assistant), 10_GFPROBT (G.F.Pro Watering)
Kaffeespende: https://paypal.me/todominik
Offline Udomatic
« Antwort #2 am: 21 Juli 2019, 15:22:32 »
Blöde Frage, wie muss das dann aussehen? So sieht mein Homebridge Mapping aus?
clear CurrentPosition=userposition,minValue=0,maxValue=100,minStep=50
TargetPosition=userposition,minValue=0,maxValue=100,minStep=50,cmds=0:close;;50:my;;100:open
Offline dominik
« Antwort #3 am: 21 Juli 2019, 16:35:13 »
Nach clear muss auch noch ein Enter rein, dann passt's.
Offline Udomatic
« Antwort #4 am: 21 Juli 2019, 20:52:18 »
Danke dir! Geräte sind wieder da, aber da wäre ich nie drauf gekommen, dass die Art und Weise, wie der Code im Mapping steht solch eine Ursache auslösen kann.
Aber mir ist bewußt, dass es rund um FHEM viel zu lernen gibt.
Das Forum ist schon super!
« Letzte Änderung: 21 Juli 2019, 20:54:02 von Udomatic »
Offline dominik
« Antwort #5 am: 21 Juli 2019, 21:02:01 »
Ich musste den alten Support mit Leerzeichen leider einstellen, da sonst manche neue Funktionen (zB FanSpeed) nicht möglich wären.
Bei weiteren Fragen einfach melden, helfe gerne weiter damit es bei jedem funktioniert.
