[gelöst] Zwei Tasmota (MQTT2_DEVICE) Steckdosen schalten
Begonnen von Bracew, 02 August 2019, 19:54:38
Bracew
ich habe via MQTT2_SERVER
define myBroker MQTT2_SERVER 1883 global
setuuid myBroker 5d1e4efa-f33f-8319-c525-5b4xxx
   CONNECTS   2
   DEF        1883 global
   FD         10
   FUUID      5d1e4efa-f33f-8319-c525-5b4xxx
   NAME       myBroker
   NR         174
   PORT       1883
   STATE      Initialized
   TYPE       MQTT2_SERVER
     2019-08-02 19:27:59   RETAIN          {"tele/Obi1/LWT":"Online","tele/sonoff/LWT":"Online"}
     2019-08-02 19:27:59   nrclients       2
     2019-08-02 19:27:45   state           Initialized
   clients:
     myBroker_192.168.0.70_8802 1
     myBroker_192.168.0.71_29358 1
   retain:
     tele/Obi1/LWT:
       ts         1564766876.97737
       val        Online
     tele/sonoff/LWT:
       ts         1564766879.35858
       val        Online
eine Sonoff S20 Steckdose mit Tasmota Version 6.6.0(release-sonoff)
define Poolpumpe MQTT2_DEVICE DVES_B0B3EB
setuuid Poolpumpe 5d1f3d1b-f33f-8319-925c-56ca9dad6a973a49
attr   Poolpumpe IODev myBroker
attr   Poolpumpe autocreate 0
attr   Poolpumpe devStateIcon .*on:on .*off:off on.(for.timer|till.*):on-for-timer:off off.(for.timer|till.*):off-for-timer:on blink.*:light_toggle:off
attr   Poolpumpe group Pool
attr   Poolpumpe icon scene_swimming
attr   Poolpumpe model A_01a_tasmota_basic_state_power1
attr   Poolpumpe readingList tele/sonoff/LWT:.* LWT\
  tele/sonoff/STATE:.* { json2nameValue($EVENT) }\
  tele/sonoff/SENSOR:.* { json2nameValue($EVENT) }\
  tele/sonoff/INFO.:.* { json2nameValue($EVENT) }\
  stat/sonoff/RESULT:.* { json2nameValue($EVENT) }
attr   Poolpumpe room Garten
attr   Poolpumpe setExtensionsEvent 1
attr   Poolpumpe setList off:noArg    cmnd/sonoff/POWER1 0\
  on:noArg     cmnd/sonoff/POWER1 1\
  toggle:noArg cmnd/sonoff/POWER1 2
attr   Poolpumpe setStateList on off toggle
attr   Poolpumpe stateFormat POWER1
   CID        DVES_B0B3EB
   DEF        DVES_B0B3EB
   DEVICETOPIC Poolpumpe
   FUUID      5d1f3d1b-f33f-8319-925c-56ca9dad6a973a49
   IODev      myBroker
   LASTInputDev myBroker
   MSGCNT     3
   NAME       Poolpumpe
   NR         808
   STATE      off
   STILLDONETIME 0
   TYPE       MQTT2_DEVICE
   myBroker_MSGCNT 3
   myBroker_TIME 2019-08-02 19:33:14
     2019-08-02 18:02:38   FallbackTopic   cmnd/DVES_331931_fb/
     2019-08-02 18:02:38   GroupTopic      sonoffs
     2019-08-02 19:33:14   Heap            15
     2019-08-02 18:02:38   Hostname        sonoff-6449
     2019-08-02 18:02:38   IPAddress       192.168.0.71
     2019-07-04 10:48:28   Key             on
     2019-08-02 19:27:59   LWT             Online
     2019-08-02 19:33:14   LoadAvg         26
     2019-08-02 18:02:38   Module          OBI Socket 2
     2019-07-14 18:57:42   OtaUrl          http://thehackbox.org/tasmota/release/sonoff-DE.bin
     2019-08-02 18:18:06   POWER           OFF
     2019-08-02 19:33:14   POWER1          off
     2019-08-02 09:00:00   PoolpumpeAusZeit 2019-08-02 16:01:00
     2019-08-02 09:00:00   PoolpumpeLaufZeit 07:01:00
     2019-08-02 09:00:00   PoolpumpeOnForTimer 25272
     2019-07-04 10:48:28   Relay           on
     2019-08-02 18:02:38   RestartReason   Power on
     2019-08-02 19:33:14   Sleep           50
     2019-08-02 19:33:14   SleepMode       Dynamic
     2019-08-02 19:33:14   Time            2019-08-02T18:33:14
     2019-07-14 18:57:43   Upgrade         Version 6.5.0 from http://thehackbox.org/tasmota/release/sonoff-DE.bin
     2019-08-02 19:33:14   Uptime          19T00:34:09
     2019-07-14 18:53:15   Vcc             3.159
     2019-08-02 18:02:38   Version         6.6.0(release-sonoff)
     2019-08-02 18:02:38   WebServerMode   Admin
     2019-08-02 19:33:14   Wifi_AP         1
     2019-08-02 19:33:14   Wifi_BSSId      38:10:D5:D7:EF:49
     2019-08-02 19:33:14   Wifi_Channel    6
     2019-08-02 19:33:14   Wifi_Downtime   4T07:45:17
     2019-08-02 19:33:14   Wifi_LinkCount  53
     2019-08-02 19:33:14   Wifi_RSSI       36
     2019-08-02 19:33:14   Wifi_SSId       Asterix
     2019-07-05 14:41:35   presence        absent
     2019-08-02 18:56:44   state           set_off
   IODev      myBroker
   autocreate 0
   group      Pool
   icon       scene_swimming
   room       Garten
   stateFormat POWER1
in Betrieb, welche auch mit FHEM wunderbar funktioniert.
Nun möchte ich eine 2. (zweite) Steckdose, diesmal Obi Typ 2, auch mit Tasmota Version 6.6.0(release-sonoff) in FHEM nutzen. Die Obi-Steckdose funktioniert in der Tasmota Oberfläche.
Auch für die Obi-Steckdose habe ich ein Device analog zur Sonoff-S20-Steckdose angelegt:
define  ObiSteckdose MQTT2_DEVICE DVES_331931
setuuid ObiSteckdose 5d41bb22-f33f-8319-23ac-2c71136f8b14fbee
attr    ObiSteckdose IODev myBroker
attr    ObiSteckdose autocreate 0
attr    ObiSteckdose devStateIcon .*on:on .*off:off on.(for.timer|till.*):on-#for-timer:off off.(for.timer|till.*):off-for-timer:on blink.*:light_toggle:off
attr    ObiSteckdose icon hue_filled_br30
attr    ObiSteckdose readingList tele/obi/LWT:.* LWT\
  tele/Obi1/STATE:.* { json2nameValue($EVENT) }\
  tele/Obi1/SENSOR:.* { json2nameValue($EVENT) }\
  tele/Obi1/INFO.:.* { json2nameValue($EVENT) }\
  stat/Obi1/RESULT:.* { json2nameValue($EVENT) }
attr   ObiSteckdose room Test
attr   ObiSteckdose setExtensionsEvent 1
attr   ObiSteckdose setList off:noArg    cmnd/Obi1/POWER1 0\
  on:noArg     cmnd/Obi1/POWER1 1\
  toggle:noArg cmnd/Obi1/POWER1 2
attr   ObiSteckdose setStateList on off toggle
attr   ObiSteckdose stateFormat POWER1
   CID        DVES_331931
   DEF        DVES_331931
   DEVICETOPIC ObiSteckdose
   FUUID      5d41bb22-f33f-8319-23ac-2c71136f8b14fbee
   IODev      myBroker
   MSGCNT     4
   NAME       ObiSteckdose
   NR         1184
   STATE      off
   TYPE       MQTT2_DEVICE
   myBroker_MSGCNT 4
   myBroker_TIME 2019-08-02 19:37:44
     2019-08-02 18:35:42   BASE            18
     2019-08-02 18:35:42   FLAG            15
     2019-08-02 18:35:54   FallbackTopic   cmnd/DVES_331931_fb/
     2019-08-02 18:35:42   GPIO_1          255
     2019-08-02 18:35:42   GPIO_10         255
     2019-08-02 18:35:42   GPIO_11         255
     2019-08-02 18:35:42   GPIO_12         255
     2019-08-02 18:35:42   GPIO_13         255
     2019-08-02 18:35:42   GPIO_2          255
     2019-08-02 18:35:42   GPIO_3          255
     2019-08-02 18:35:42   GPIO_4          255
     2019-08-02 18:35:42   GPIO_5          255
     2019-08-02 18:35:42   GPIO_6          255
     2019-08-02 18:35:42   GPIO_7          255
     2019-08-02 18:35:42   GPIO_8          255
     2019-08-02 18:35:42   GPIO_9          255
     2019-08-02 18:35:54   GroupTopic      sonoffs
     2019-08-02 19:37:44   Heap            14
     2019-08-02 18:35:54   Hostname        Obi1-6449
     2019-08-02 18:35:54   IPAddress       192.168.0.71
     2019-08-02 19:26:56   LWT             Online
     2019-08-02 19:37:44   LoadAvg         19
     2019-08-02 18:35:54   Module          OBI Socket 2
     2019-08-02 18:35:42   NAME            Generic
     2019-08-02 19:37:44   POWER           OFF
     2019-08-02 18:19:52   POWER1          off
     2019-08-02 18:35:54   RestartReason   Software/System restart
     2019-08-02 19:37:44   Sleep           50
     2019-08-02 19:37:44   SleepMode       Dynamic
     2019-08-02 19:37:44   Time            2019-08-02T18:37:44
     2019-08-02 19:37:44   Uptime          0T01:01:59
     2019-08-02 18:35:54   Version         6.6.0(release-sonoff)
     2019-08-02 18:35:54   WebServerMode   Admin
     2019-08-02 19:37:44   Wifi_AP         1
     2019-08-02 19:37:44   Wifi_BSSId      38:10:D5:D7:EF:49
     2019-08-02 19:37:44   Wifi_Channel    6
     2019-08-02 19:37:44   Wifi_Downtime   0T00:00:07
     2019-08-02 19:37:44   Wifi_LinkCount  1
     2019-08-02 19:37:44   Wifi_RSSI       100
     2019-08-02 19:37:44   Wifi_SSId       Asterix
     2019-08-02 18:45:12   off             set
     2019-08-02 18:45:10   on              set
     2019-08-02 19:29:22   state           set_off
   IODev      myBroker
   autocreate 0
   room       Test
   stateFormat POWER1
Die Obi-Steckdose lässt sich in der FHEM Oberfläche mit "on" bzw. "off" schalten.
Jedoch:
  • geht "toggle" nur von aus --> an aber nicht von an --> aus. Ausschalten läst sich die Obi-Dose nur mit Klick auf "off"
  • Weiterhin geht das Icon nicht auf "on" sondern ist immer auf aus, egal welchen Zustand die Steckdose hat
Die Fehler sind nur bei der Obi-Steckdose, nicht bei der Sonoff-Steckdose.
Was ist falsch?
Ich bitte um Hilfe, damit
A) das Icon-Symbol hin und her toggled und
B) via Klick auf das Icon-Symbol die Obi-Steckdose jeweils nach an bzw. aus toggelt.
Mit lieben Grüßen
Bracew
FHEM auf Raspberry Pi
für z.B. Lichtsteuerung, Temperaturmessung, Balkonkraftwerk,
Öltankfüllstandsmessung und für Hühnerstall Hühnerklappe
TomLee
#1
ZitatInternals:
   CID        DVES_331931
   DEF        DVES_331931
   IODev      myBroker
   MSGCNT     4
   NAME       ObiSteckdose
   NR         1184
   STATE      off
   TYPE       MQTT2_DEVICE
   myBroker_MSGCNT 4
   IODev      myBroker
   autocreate 0
   room       Test
   stateFormat POWER1
Da ist dir beim anlegen ein kleiner Fehler unterlaufen.   :)
Übrigens muss man das MQTT2_DEVICE nicht manuell erstellen, sind die MQTT-Einstellungen einmal vorgenommen reicht schon  die Spannungsversorgung der Steckdose das ein neues Device automatisch angelegt wird. Alternativ auch ein schalten aus der Oberfläche der Steckdose.
Auf dieses wendet man dann das entsprechende Template an, dann wäre dir das gar nicht passiert
Thomas
Bracew
Danke für den #-Fehlerhinweis. Habe ich korrigiert, jedoch keine Änderung im Schaltverhalten. Das Icon bleibt immer aus und ein Klick auf das Icon toggelt immer noch nur in eine Richtung.  :-\
Anfangs habe ich das MQTT2_DEVICE nicht manuell erstellt, sondern automatisch anlegen lassen. Ein schalten aus der Oberfläche der Steckdose funktioniert. Auch aus FHEM funktioniert AN bzw. AUS, aber nicht das Umschalten per Klick auf das Lämpchen-Icon.
Das "Problem" ist, dass du das Reading "state" setzt, aber die Rückmeldung auf "POWER1" kommt. stateFormat betreibt hier nur Kosmetik... Also entweder korrigierst du das an der Wurzel oder du schreibst eben explizit noch den Befehl hinter die Icons in devStateIcon (als 3. Argument, wie bei den on/off-for; die sehen m.E. auch nicht "sauber" aus).
Aber eigentlich ist die Logik dazu in den Templates drin, wie TomLee ja bereits angemerkt hat. Ggf. mußt du halt noch das zigbee-devStateIcon verwenden (Perl-Code, der in dem MQtt2_DEVICE-Modul enthalten ist; bitte selber suchen).
Server: HP-elitedesk@Debian 12, aktuelles FHEM@ConfigDB | CUL_HM (VCCU) | MQTT2: MiLight@ESP-GW, BT@OpenMQTTGw | MySensors: seriell, v.a. 2.3.1@RS485 | ZWave | ZigBee@deCONZ | SIGNALduino | MapleCUN | RHASSPY
Bracew
Also, die ohne 3. Argument habe ich von Dir:
https://forum.fhem.de/index.php?topic=99653.0  bzw. https://forum.fhem.de/index.php/topic,101687.msg955843.html#msg955843
Ok, aber auch wenn ich ergänze:
attr    ObiSteckdose devStateIcon .*on:on:off .*off:off:on on.(for.timer|till.*):on-for-timer:off off.(for.timer|till.*):off-for-timer:on blink.*:light_toggle:off
ändert sich am Verhalten nichts.
Bracew
Mit:
attr     ObiSteckdose devStateIcon {zigbee2mqtt_devStateIcon255($name,'hex',1)}
anstatt:
wechselt nun das Symbol beim Klick auf "on" und auch beim Klick auf "off" aber nicht beim Klick auf das Icon, obwohl auch dann die Steckdose schaltet.
Bracew
Mit
attr     ObiSteckdose devStateIcon {zigbee2mqtt_devStateIcon255($name,'',1)}
ist es "fast" gut. Nur beim Klick auf das Icon wenn es AN ist wechselt es nicht auf AUS. Andersrum schon.
Hmm, vermutlich ist und bleibt das "Problem", dass beim Auspacken des JSON der "Rückweg" nach POWER1 führt und nicht in "state". (Ist leider bei den Tasmotas etwas anders als bei anderen Device-Typen).
Kann mich leider grad nicht intensiver drum kümmern, aber versuche mal "toggle" als 3. Argument.
Bracew
Funktioniert schlechter.
Klick auf "on" und "off" geht. Klick auf toggle geht nicht. Anzeige des "Birnchen" schaltet nicht um.
Bracew
ich habe immer noch an meiner Obi Type2 Steckdose das Problem, dass beim toggeln die Anzeige immer nur "An" geht, aber nicht "Aus". Die Steckdose schaltet hin und her, das Birnchen bleibt an.
Beim Klick auf "on" bzw. "off" läuft alles richtig. Steckdose schaltet hin und her, Birnchen wechselt hin und her.
Jemand eine Idee?
Gruß Bracew
Sedikit
mit dem Status hatte ich auch Probleme. Das habe ich inzwischen so gelöst:
stateFormat {lc ReadingsVal($name, "POWER1", "")
VG
   (;-)Mi
Bracew
Hi, danke für Deinen Tipp.
Leider jedoch keine Änderung des Verhaltens. Wenn die Steckdose an ist und das Birnchen leuchtet, schaltet die Steckdose beim Klick auf das leuchtende Birnchen-Symbol zwar aus, das Birnchen-Symbol ändert sich aber nicht, es bleibt auf an bzw. gelb leuchtend. Nur mit dem Klick auf "off" geht die Steckdose aus und auch das Birnchen-Symbol auf grau bzw. aus.
Gruß Bracew
Bracew
ich habs nun gelöst bekommen.
# Obi-WLAN-Tasmota-MQTT-Funksteckdose schalten
# Auf Steckdosen eigener Oberflaeche: http://192.168.0.71/mq
# unter MQTT-Konfigurieren muss fuer jede Steckdose ein eigenes
# Topic konfiguriert werden, hier: Obi1
# Das Topic muss in den FHEM Attributen verwendet werden.
define  ObiSteckdose MQTT2_DEVICE DVES_33xxxx
setuuid ObiSteckdose 5d41bb22-f33f-yyyy
attr    ObiSteckdose readingList \
          DVES_33xxxx:tele/Obi1/STATE:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:tele/Obi1/LWT:.* LWT\
          DVES_33xxxx:cmnd/Obi1/POWER:.* POWER\
          DVES_33xxxx:tele/Obi1/UPTIME:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:tele/Obi1/SENSOR:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:tele/Obi1/INFO1:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:tele/Obi1/INFO2:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:tele/Obi1/INFO3:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:stat/Obi1/RESULT:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:stat/Obi1/STATE:.* { json2nameValue($EVENT) }\
          DVES_33xxxx:stat/Obi1/POWER:.* POWER
attr    ObiSteckdose setList \
           on cmnd/Obi1/POWER on\
          off cmnd/Obi1/POWER off
attr    ObiSteckdose webCmd on:off
Schalten und auch Lämpchen-Anzeige geht wunderbar!
Danke für alle Hilfe und mit lieben Grüßen Bracew
