Zwei Fragen zu Fibaro-Geräten
Begonnen von TomekWaw, 17 August 2019, 03:34:34
TomekWaw
Entschuldigen bitte dass mein Deutsch zu schlecht ist um über Technik zu sprechen.
So I'll ask my questions in English, I hope it's ok.
I successfully use FHEM as a gateway to Fibaro equipment (3 Dimmers, 2 Relays, 3 Wall Plugs, 3 Motions Sensor and a Window Sensors).
However, I have two problems I can't solve by myself and I have not found solution searching the internet.
1.
First problem is that Dimmers and Relays are not reporting any state change of S1 (.01) or S2 (.02) switches.
I am particularly interested in S2 which AFAIK is not permanently connected to main controller - I would like to trigger some home automation actions with it.
Unfortunately, if I connect physical monostable switch to S2, I always see state "off" in .02 Readings. The same applies to .01 switch by the way.
Is there a way make it report switch was pressed?
2.
Second problem is... strange. I have 3 Fibaro motion sensors.
1st - works fine.
2nd - works fine.
When I add 3rd - 1st and 3nd somehow couples in motion detection (only motion detection, temp and lux seem to be ok).
They behave like they were triggering themselves.
When I remove the 1st one - 3rd motion sensor starts to work fine.
When I remove 3rd one - 1st start to work fine.
I've tried to remove them all, reset their configuration, add again but nothing helps.
Any ideas? Where did I make mistake?
I attach device configuration and readings
ZitatFirst problem is that Dimmers and Relays are not reporting any state change of S1 (.01) or S2 (.02) switches.
Without knowing the device: it seems to me, that association, or more probably multi_channel_association (mcAdd) is missing or wrong.
Can you please show us the corresponding configuration (get XXX associationAll/mcaAll)?
ZitatSecond problem is... strange. I have 3 Fibaro motion sensors.
This also looks like a wrong association/multi_channel_association to me, although resetting the device should fix the problem.
P.S: Please report device configurations next time by Copy/Pasting the output of "Raw definition" (the link at the bottom of the device detail page) into a Quote or Code tag here, as this makes it easier to search it or put the definition into a test setup to debug your problem.
TomekWaw
#2
Ok, here is raw definition of my Fibaro Dimmer objects (main, S1 and S2):
defmod Fibaro_Dimmer_1 ZWave f1cfdf8a 14
attr Fibaro_Dimmer_1 IODev ZWDongle_0
attr Fibaro_Dimmer_1 classes ZWAVEPLUS_INFO BASIC VERSION MANUFACTURER_SPECIFIC SWITCH_MULTILEVEL DEVICE_RESET_LOCALLY ASSOCIATION_GRP_INFO ASSOCIATION POWERLEVEL SECURITY FIRMWARE_UPDATE_MD CRC_16_ENCAP CONFIGURATION SENSOR_MULTILEVEL METER MULTI_CHANNEL_ASSOCIATION MULTI_CHANNEL PROTECTION ALARM SWITCH_ALL APPLICATION_STATUS MARK SCENE_ACTIVATION
attr Fibaro_Dimmer_1 icon light_light_dim_100
attr Fibaro_Dimmer_1 mqttSubscribe dim:stopic=loxone/Fibaro_Dimmer_1/dim
attr Fibaro_Dimmer_1 room ZWave
attr Fibaro_Dimmer_1 vclasses ALARM:5 APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BASIC:1 CONFIGURATION:1 CRC_16_ENCAP:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:3 MANUFACTURER_SPECIFIC:2 METER:3 MULTI_CHANNEL:4 MULTI_CHANNEL_ASSOCIATION:3 POWERLEVEL:1 PROTECTION:2 SCENE_ACTIVATION:1 SECURITY:1 SENSOR_MULTILEVEL:4 SWITCH_ALL:1 SWITCH_MULTILEVEL:3 VERSION:2 ZWAVEPLUS_INFO:2
setstate Fibaro_Dimmer_1 off
setstate Fibaro_Dimmer_1 2019-08-12 04:32:04 CMD ZW_APPLICATION_UPDATE
setstate Fibaro_Dimmer_1 2019-08-14 21:54:28 alarm PowerManagement: Load error
setstate Fibaro_Dimmer_1 2019-08-17 12:38:26 assocGroup_1 Max 1 Nodes ZWDongle_0
setstate Fibaro_Dimmer_1 2019-08-17 12:38:26 assocGroup_2 Max 8 Nodes
setstate Fibaro_Dimmer_1 2019-08-17 12:38:26 assocGroup_3 Max 8 Nodes
setstate Fibaro_Dimmer_1 2019-08-17 12:38:27 assocGroup_4 Max 8 Nodes
setstate Fibaro_Dimmer_1 2019-08-17 12:38:27 assocGroup_5 Max 8 Nodes
setstate Fibaro_Dimmer_1 2019-08-17 12:38:26 assocGroups 5
setstate Fibaro_Dimmer_1 2019-08-16 22:45:40 associatedWith Fibaro_Dimmer_1_S1,Fibaro_Dimmer_1_S2
setstate Fibaro_Dimmer_1 2019-08-13 21:29:56 configAutoCalibrationStatus DimmerOperatesOnAutoCalibration1
setstate Fibaro_Dimmer_1 2019-08-12 04:29:46 configBrightnessLevelCorrectionFor38 255
setstate Fibaro_Dimmer_1 2019-08-13 21:29:56 configDimmabilityOfTheLoad LoadRecognizedAsDimmable
setstate Fibaro_Dimmer_1 2019-08-13 21:29:54 configForceAutoCalibration idle
setstate Fibaro_Dimmer_1 2019-08-13 23:09:16 configForcedSwitchOnBrightnessLevel 99
setstate Fibaro_Dimmer_1 2019-08-14 14:06:18 configInputsButtonSwitchConfiguration MonoStableInputButton
setstate Fibaro_Dimmer_1 2019-08-13 21:29:56 configLoadControlMode controlModeSelectedAutomatically2
setstate Fibaro_Dimmer_1 2019-08-13 21:29:56 configLoadControlModeRecognizedDuring31 trailingEdge
setstate Fibaro_Dimmer_1 2019-08-13 21:29:56 configMaximumBrightnessLevel 28
setstate Fibaro_Dimmer_1 2019-08-13 21:29:56 configMethodOfCalculatingTheActive58 powerMeasurementBasedOnThe0
setstate Fibaro_Dimmer_1 2019-08-13 21:29:56 configMinimumBrightnessLevel 1
setstate Fibaro_Dimmer_1 2019-08-13 21:27:26 configOnOffMode modeSelectedAutomatically
setstate Fibaro_Dimmer_1 2019-08-17 12:05:06 energy  0.76 kWh
setstate Fibaro_Dimmer_1 2019-08-12 03:50:38 mcCapability_01 ZWAVEPLUS_INFO BASIC VERSION SWITCH_MULTILEVEL ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION METER SENSOR_MULTILEVEL ALARM
setstate Fibaro_Dimmer_1 2019-08-12 03:50:38 mcCapability_02 ZWAVEPLUS_INFO BASIC VERSION SWITCH_MULTILEVEL ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION
setstate Fibaro_Dimmer_1 2019-08-12 03:50:38 mcEndpoints total 2, different
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 mcaGroups 5
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 mca_1 Max 1 Nodes ZWDongle_0
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 mca_2 Max 8
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 mca_3 Max 8
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 mca_4 Max 8
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 mca_5 Max 8
setstate Fibaro_Dimmer_1 2019-08-12 03:50:38 model FIBARO System FGD212 Dimmer 2
setstate Fibaro_Dimmer_1 2019-08-12 03:50:38 modelConfig fibaro/fgd212.xml
setstate Fibaro_Dimmer_1 2019-08-12 03:50:38 modelId 010f-0102-1000
setstate Fibaro_Dimmer_1 2019-08-17 12:18:45 power 0.0 W
setstate Fibaro_Dimmer_1 2019-08-17 06:16:39 reportedState off
setstate Fibaro_Dimmer_1 2019-08-17 06:16:39 state off
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 timeToAck 0.030
setstate Fibaro_Dimmer_1 2019-08-17 12:38:44 transmit OK
# S1
defmod Fibaro_Dimmer_1_S1 ZWave f1cfdf8a 3585
attr Fibaro_Dimmer_1_S1 IODev ZWDongle_0
attr Fibaro_Dimmer_1_S1 classes ZWAVEPLUS_INFO BASIC VERSION SWITCH_MULTILEVEL ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION METER SENSOR_MULTILEVEL ALARM
attr Fibaro_Dimmer_1_S1 icon control_on_off
attr Fibaro_Dimmer_1_S1 room ZWave
setstate Fibaro_Dimmer_1_S1 off
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:17 assocGroup_1 Max 0 Nodes
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:17 assocGroup_2 Max 8 Nodes
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:17 assocGroup_3 Max 8 Nodes
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:17 assocGroups 3
setstate Fibaro_Dimmer_1_S1 2019-08-16 22:45:40 associatedWith Fibaro_Dimmer_1
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:23 mcaGroups 3
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:23 mca_1 Max 0
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:23 mca_2 Max 8
setstate Fibaro_Dimmer_1_S1 2019-08-17 12:39:23 mca_3 Max 8
setstate Fibaro_Dimmer_1_S1 2019-08-12 14:05:12 state off
# S2
defmod Fibaro_Dimmer_1_S2 ZWave f1cfdf8a 3586
attr Fibaro_Dimmer_1_S2 IODev ZWDongle_0
attr Fibaro_Dimmer_1_S2 classes ZWAVEPLUS_INFO BASIC VERSION SWITCH_MULTILEVEL ASSOCIATION ASSOCIATION_GRP_INFO MULTI_CHANNEL_ASSOCIATION
attr Fibaro_Dimmer_1_S2 icon control_on_off
attr Fibaro_Dimmer_1_S2 room ZWave
setstate Fibaro_Dimmer_1_S2 off
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:39:58 assocGroup_1 Max 0 Nodes
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:39:58 assocGroup_2 Max 8 Nodes
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:39:59 assocGroup_3 Max 8 Nodes
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:39:58 assocGroups 3
setstate Fibaro_Dimmer_1_S2 2019-08-16 22:45:40 associatedWith Fibaro_Dimmer_1
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:40:02 mcaGroups 3
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:40:02 mca_1 Max 0
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:40:02 mca_2 Max 8
setstate Fibaro_Dimmer_1_S2 2019-08-17 12:40:02 mca_3 Max 8
setstate Fibaro_Dimmer_1_S2 2019-08-17 03:11:28 state off
And this is raw definition of Fibaro Relay object (main, S1, S2):
defmod Fibaro_Relay_1 ZWave f1cfdf8a 17
attr Fibaro_Relay_1 IODev ZWDongle_0
attr Fibaro_Relay_1 classes MANUFACTURER_SPECIFIC VERSION CONFIGURATION ASSOCIATION MULTI_CHANNEL_ASSOCIATION MULTI_CHANNEL SWITCH_BINARY SWITCH_ALL FIRMWARE_UPDATE_MD POWERLEVEL MARK SWITCH_BINARY MULTI_CHANNEL
attr Fibaro_Relay_1 icon dim100%
attr Fibaro_Relay_1 room ZWave
attr Fibaro_Relay_1 vclasses ASSOCIATION:2 CONFIGURATION:1 FIRMWARE_UPDATE_MD:1 MANUFACTURER_SPECIFIC:1 MULTI_CHANNEL:2 MULTI_CHANNEL_ASSOCIATION:1 POWERLEVEL:1 SWITCH_ALL:1 SWITCH_BINARY:1 VERSION:1
setstate Fibaro_Relay_1 off
setstate Fibaro_Relay_1 2019-08-14 13:38:49 CMD ZW_APPLICATION_UPDATE
setstate Fibaro_Relay_1 2019-08-17 12:40:44 assocGroup_1 Max 5 Nodes ZWDongle_0
setstate Fibaro_Relay_1 2019-08-17 12:40:45 assocGroup_2 Max 5 Nodes
setstate Fibaro_Relay_1 2019-08-17 12:40:45 assocGroup_3 Max 1 Nodes ZWDongle_0
setstate Fibaro_Relay_1 2019-08-17 12:40:44 assocGroups 3
setstate Fibaro_Relay_1 2019-08-16 22:45:40 associatedWith Fibaro_Relay_1_S1,Fibaro_Relay_1_S2
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configActiveFlashingAlarmTime 600
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configAutoOff 0
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configAutoOffRelayAfterSpecifiedTime 255
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configDimmerRollerShutterControl DisableDimmerRollerShutter0
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configEnableDisableALLONOFF ALLONActiveALLOFFActive
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configInputsBehaviour Toggle
setstate Fibaro_Relay_1 2019-08-14 13:49:47 configInputsButtonSwitchConfiguration MonoStableInputButton
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configRelayResponseToGeneralAlarm ALARMFLASHINGRelayWillTurnONAndO3
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configRelayResponseToSmokeCOCO2Alarm ALARMFLASHINGRelayWillTurnONAndO3
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configRelayResponseToTemperatureAlarm ALARMRELAYONRelayWillTurnONUpon1
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configRelayResponseToWaterFloodAlarm ALARMRELAYOFFRelayWillTurnOFF2
setstate Fibaro_Relay_1 2019-08-14 13:49:04 configSavingStateBeforePowerFailure StateSavedAtPowerFailureAll1
setstate Fibaro_Relay_1 2019-08-14 13:49:05 configSeparationOfAssociationSending6 MapStatusToAllDevicesInGroup10
setstate Fibaro_Relay_1 2019-08-14 13:25:16 mcCapability_01 SWITCH_BINARY
setstate Fibaro_Relay_1 2019-08-14 13:25:16 mcCapability_02 SWITCH_BINARY
setstate Fibaro_Relay_1 2019-08-14 13:25:16 mcEndpoints total 2, identical
setstate Fibaro_Relay_1 2019-08-17 12:40:54 mcaGroups 2
setstate Fibaro_Relay_1 2019-08-17 12:40:54 mca_1 Max 5 Nodes ZWDongle_0
setstate Fibaro_Relay_1 2019-08-17 12:40:54 mca_2 Max 5
setstate Fibaro_Relay_1 2019-08-14 13:25:16 model FIBARO System FGS212 Switch 3kW
setstate Fibaro_Relay_1 2019-08-14 13:25:16 modelConfig fibaro/fgs212.xml
setstate Fibaro_Relay_1 2019-08-14 13:25:16 modelId 010f-0402-1002
setstate Fibaro_Relay_1 2019-08-17 00:05:12 reportedState off
setstate Fibaro_Relay_1 2019-08-17 00:05:14 state off
setstate Fibaro_Relay_1 2019-08-17 12:40:54 timeToAck 0.044
setstate Fibaro_Relay_1 2019-08-17 12:40:54 transmit OK
# S1 (no function to get AssociationAll/mcaAll)
defmod Fibaro_Relay_1_S1 ZWave f1cfdf8a 4353
attr Fibaro_Relay_1_S1 IODev ZWDongle_0
attr Fibaro_Relay_1_S1 classes SWITCH_BINARY
attr Fibaro_Relay_1_S1 icon control_on_off
attr Fibaro_Relay_1_S1 room ZWave
setstate Fibaro_Relay_1_S1 off
setstate Fibaro_Relay_1_S1 2019-08-16 22:45:40 associatedWith Fibaro_Relay_1
setstate Fibaro_Relay_1_S1 2019-08-17 12:41:39 reportedState off
setstate Fibaro_Relay_1_S1 2019-08-17 12:41:39 state off
# S2
defmod Fibaro_Relay_1_S2 ZWave f1cfdf8a 4354
attr Fibaro_Relay_1_S2 IODev ZWDongle_0
attr Fibaro_Relay_1_S2 classes SWITCH_BINARY
attr Fibaro_Relay_1_S2 icon control_on_off
attr Fibaro_Relay_1_S2 room ZWave
setstate Fibaro_Relay_1_S2 off
setstate Fibaro_Relay_1_S2 2019-08-16 22:45:40 associatedWith Fibaro_Relay_1
setstate Fibaro_Relay_1_S2 2019-08-17 12:40:38 state off
(I will paste also Motion sensor definitions when they update after wakeup)
I do not see any multi channel associations. I am not sure, if they are necessary (you have to study the Fibaro documentation yourself), but this is the "usual" way to report data from multi channel devices.
Another strangeness is that S1/S2 is associated with the parent device, IMHO this makes no sense.
But it can also happen, that I am missing something: I am the Maintainer of the ZWave module, but I do not know the specialities of each device.
TomekWaw
This is all done by default inclusion, I didn't change anything association-related.
What commands should I try on this?
And here are raw definitions on my three motions sensors.
Motion_Sensor_1 and Motion_Sensor_3 seem to trigger themselves.
(With the 1st one I somehow can't get reading of mcaAll, other two have it)
defmod Fibaro_Motion_Sensor_1 ZWave f1cfdf8a 12
attr Fibaro_Motion_Sensor_1 IODev ZWDongle_0
attr Fibaro_Motion_Sensor_1 classes ZWAVEPLUS_INFO BASIC VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY ASSOCIATION_GRP_INFO ASSOCIATION POWERLEVEL WAKE_UP BATTERY ALARM CRC_16_ENCAP CONFIGURATION SENSOR_MULTILEVEL MULTI_CHANNEL_ASSOCIATION APPLICATION_STATUS SENSOR_BINARY SENSOR_ALARM SECURITY FIRMWARE_UPDATE_MD
attr Fibaro_Motion_Sensor_1 icon motion_detector
attr Fibaro_Motion_Sensor_1 room ZWave
attr Fibaro_Motion_Sensor_1 stateFormat Alarm: state | Temp: temperature | Light: luminance
attr Fibaro_Motion_Sensor_1 userReadings state:alarm.* {(ReadingsVal($name,"alarm","") =~ /^HomeSecurity:.Motion.Detection/)?"open":"closed"}
attr Fibaro_Motion_Sensor_1 vclasses ALARM:5 APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BASIC:1 BATTERY:1 CONFIGURATION:1 CRC_16_ENCAP:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:3 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL_ASSOCIATION:2 POWERLEVEL:1 SECURITY:1 SENSOR_ALARM:1 SENSOR_BINARY:1 SENSOR_MULTILEVEL:8 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
setstate Fibaro_Motion_Sensor_1 Alarm: open | Temp: 26.5 C | Light: 387 Lux
setstate Fibaro_Motion_Sensor_1 2019-08-08 16:19:02 UNPARSED SENSOR_BINARY 033003f7
setstate Fibaro_Motion_Sensor_1 2019-08-17 13:35:07 alarm HomeSecurity: Motion Detection - Unknown Location
setstate Fibaro_Motion_Sensor_1 2019-08-17 13:02:54 alarm_type_00 level 0 node 12 seconds 0
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:14 assocGroup_1 Max 1 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:15 assocGroup_2 Max 5 Nodes
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:16 assocGroup_3 Max 5 Nodes
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:17 assocGroup_4 Max 5 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:18 assocGroup_5 Max 5 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:13 assocGroups 5
setstate Fibaro_Motion_Sensor_1 2019-07-31 01:31:12 battery 100 %
setstate Fibaro_Motion_Sensor_1 2019-07-31 01:31:12 batteryPercent 100
setstate Fibaro_Motion_Sensor_1 2019-07-31 01:31:12 batteryState ok
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:28 configAssociationsInZWaveNetwork18 15
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configBASICCommandClassConfiguration BASICOnAndOFF
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configBASICOFFCommandFrameValue 0
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configBASICONCommandFrameValue 255
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configLuminanceReportThreshold 200
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configLuminanceReportsInterval 3600
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configMotionDetectionAlarmCancellation6 30
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configMotionDetectionBlindTime 15
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configMotionDetectionNightDay 200
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configMotionDetectionOperatingMode PIRSensorAlwaysActive
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configMotionDetectionPulseCounter 2Pulses
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configMotionDetectionSensitivity 15
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configMotionDetectionWindowTime 12Seconds
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTamperAlarmBroadcastMode TamperAlarmSentTo3rdAssociation0
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTamperAlarmCancellation SendTamperCancellationReport
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTamperAlarmCancellationDelay 30
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTamperBackwardCompatible29 BackwardCompatibleTamperAlarm0
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTamperOperatingModes TamperOnly
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTamperSensitivity 20
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTemperatureMeasuringInterval 900
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTemperatureOffset 0
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTemperatureReportInterval 0
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configTemperatureReportThreshold 10
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configVisualLEDIndicatorBrightness 50
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configVisualLEDIndicatorLuminanceFor82 100
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configVisualLEDIndicatorLuminanceFor83 1000
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:29 configVisualLEDIndicatorSignallingMode LongBlinkThenShortBlinkLEDColour10
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:30 configVisualLEDIndicatorTamperAlarm TamperAlarmIsIndicated
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:30 configVisualLEDIndicatorTemperatureFor86 18
setstate Fibaro_Motion_Sensor_1 2019-08-11 09:32:30 configVisualLEDIndicatorTemperatureFor87 28
setstate Fibaro_Motion_Sensor_1 2019-08-17 13:26:06 luminance 387 Lux
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:13 model FIBARO System FGMS001-ZW5 Motion Sensor
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:13 modelConfig fibaro/fgmszw5.xml
setstate Fibaro_Motion_Sensor_1 2019-08-17 08:04:13 modelId 010f-0801-1001
setstate Fibaro_Motion_Sensor_1 2019-08-17 13:35:07 reportedState open
setstate Fibaro_Motion_Sensor_1 2019-08-17 13:35:07 state open
setstate Fibaro_Motion_Sensor_1 2019-08-15 14:44:01 temperature 26.5 C
setstate Fibaro_Motion_Sensor_1 2019-08-17 12:01:40 timeToAck 0.063
setstate Fibaro_Motion_Sensor_1 2019-08-17 12:01:40 transmit OK
setstate Fibaro_Motion_Sensor_1 2019-08-17 12:01:38 wakeup notification
defmod Fibaro_Motion_Sensor_2 ZWave f1cfdf8a 8
attr Fibaro_Motion_Sensor_2 IODev ZWDongle_0
attr Fibaro_Motion_Sensor_2 classes ZWAVEPLUS_INFO BASIC VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY ASSOCIATION_GRP_INFO ASSOCIATION POWERLEVEL WAKE_UP BATTERY ALARM CRC_16_ENCAP CONFIGURATION SENSOR_MULTILEVEL MULTI_CHANNEL_ASSOCIATION APPLICATION_STATUS SENSOR_BINARY SENSOR_ALARM SECURITY FIRMWARE_UPDATE_MD
attr Fibaro_Motion_Sensor_2 icon motion_detector
attr Fibaro_Motion_Sensor_2 room ZWave
attr Fibaro_Motion_Sensor_2 stateFormat Alarm: state | Temp: temperature | Light: luminance
attr Fibaro_Motion_Sensor_2 userReadings state:alarm.* {(ReadingsVal($name,"alarm","") =~ /^HomeSecurity:.Motion.Detection/)?"open":"closed"}
attr Fibaro_Motion_Sensor_2 vclasses ALARM:5 APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BASIC:1 BATTERY:1 CONFIGURATION:1 CRC_16_ENCAP:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:3 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL_ASSOCIATION:2 POWERLEVEL:1 SECURITY:1 SENSOR_ALARM:1 SENSOR_BINARY:1 SENSOR_MULTILEVEL:8 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
setstate Fibaro_Motion_Sensor_2 Alarm: closed | Temp: 25.8 C | Light: 15 Lux
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:56:07 alarm HomeSecurity: Event cleared: Motion Detection - Unknown Location, arg 108
setstate Fibaro_Motion_Sensor_2 2019-08-17 04:07:25 alarm_type_00 level 0 node 8 seconds 0
setstate Fibaro_Motion_Sensor_2 2019-08-17 05:00:44 assocGroup_1 Max 1 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_2 2019-08-17 05:00:44 assocGroup_2 Max 5 Nodes
setstate Fibaro_Motion_Sensor_2 2019-08-17 05:00:44 assocGroup_3 Max 5 Nodes
setstate Fibaro_Motion_Sensor_2 2019-08-17 05:00:44 assocGroup_4 Max 5 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_2 2019-08-17 05:00:44 assocGroup_5 Max 5 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_2 2019-08-17 05:00:43 assocGroups 5
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:53 configAssociationsInZWaveNetwork18 15
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:53 configBASICCommandClassConfiguration BASICOnAndOFF
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:54 configBASICOFFCommandFrameValue 0
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:54 configBASICONCommandFrameValue 255
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:54 configLuminanceReportThreshold 200
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:55 configLuminanceReportsInterval 3600
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:55 configMotionDetectionAlarmCancellation6 30
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:55 configMotionDetectionBlindTime 15
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:56 configMotionDetectionNightDay 200
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:56 configMotionDetectionOperatingMode PIRSensorAlwaysActive
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:57 configMotionDetectionPulseCounter 2Pulses
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:57 configMotionDetectionSensitivity 15
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:57 configMotionDetectionWindowTime 12Seconds
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:58 configTamperAlarmBroadcastMode TamperAlarmSentTo3rdAssociation0
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:58 configTamperAlarmCancellation SendTamperCancellationReport
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:58 configTamperAlarmCancellationDelay 30
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:59 configTamperBackwardCompatible29 BackwardCompatibleTamperAlarm0
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:59 configTamperOperatingModes TamperOnly
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:00:59 configTamperSensitivity 20
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:00 configTemperatureMeasuringInterval 900
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:00 configTemperatureOffset 0
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:00 configTemperatureReportInterval 0
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:01 configTemperatureReportThreshold 10
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:01 configVisualLEDIndicatorBrightness 50
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:02 configVisualLEDIndicatorLuminanceFor82 100
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:02 configVisualLEDIndicatorLuminanceFor83 1000
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:02 configVisualLEDIndicatorSignallingMode LongBlinkThenShortBlinkLEDColour10
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:03 configVisualLEDIndicatorTamperAlarm TamperAlarmIsIndicated
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:03 configVisualLEDIndicatorTemperatureFor86 18
setstate Fibaro_Motion_Sensor_2 2019-08-11 10:01:03 configVisualLEDIndicatorTemperatureFor87 28
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:53:56 luminance 15 Lux
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:30 mcaGroups 5
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:31 mca_1 Max 1 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:31 mca_2 Max 10
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:32 mca_3 Max 10
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:32 mca_4 Max 10 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:33 mca_5 Max 10 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_2 2019-07-26 18:56:55 model FIBARO System FGMS001-ZW5 Motion Sensor
setstate Fibaro_Motion_Sensor_2 2019-07-26 18:56:55 modelConfig fibaro/fgmszw5.xml
setstate Fibaro_Motion_Sensor_2 2019-07-26 18:56:55 modelId 010f-0801-1001
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:56:07 reportedState closed
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:56:07 state closed
setstate Fibaro_Motion_Sensor_2 2019-08-17 11:13:16 temperature 25.8 C
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:35 timeToAck 0.053
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:35 transmit OK
setstate Fibaro_Motion_Sensor_2 2019-08-17 12:57:30 wakeup notification
defmod Fibaro_Motion_Sensor_3 ZWave f1cfdf8a 11
attr Fibaro_Motion_Sensor_3 IODev ZWDongle_0
attr Fibaro_Motion_Sensor_3 classes ZWAVEPLUS_INFO BASIC VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY ASSOCIATION_GRP_INFO ASSOCIATION POWERLEVEL WAKE_UP BATTERY ALARM CRC_16_ENCAP CONFIGURATION SENSOR_MULTILEVEL MULTI_CHANNEL_ASSOCIATION APPLICATION_STATUS SENSOR_BINARY SENSOR_ALARM SECURITY FIRMWARE_UPDATE_MD
attr Fibaro_Motion_Sensor_3 icon motion_detector
attr Fibaro_Motion_Sensor_3 room ZWave
attr Fibaro_Motion_Sensor_3 stateFormat Alarm: state | Temp: temperature | Light: luminance
attr Fibaro_Motion_Sensor_3 userReadings state:alarm.* {(ReadingsVal($name,"alarm","") =~ /^HomeSecurity:.Motion.Detection/)?"open":"closed"}
attr Fibaro_Motion_Sensor_3 vclasses ALARM:5 APPLICATION_STATUS:1 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BASIC:1 BATTERY:1 CONFIGURATION:1 CRC_16_ENCAP:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:3 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL_ASSOCIATION:2 POWERLEVEL:1 SECURITY:1 SENSOR_ALARM:1 SENSOR_BINARY:1 SENSOR_MULTILEVEL:8 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
setstate Fibaro_Motion_Sensor_3 Alarm: closed | Temp: 25.3 C | Light: 72 Lux
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:09 alarm HomeSecurity: Event cleared: Motion Detection - Unknown Location, arg 108
setstate Fibaro_Motion_Sensor_3 2019-08-17 06:17:42 alarm_type_00 level 0 node 11 seconds 0
setstate Fibaro_Motion_Sensor_3 2019-08-17 06:57:56 assocGroup_1 Max 1 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_3 2019-08-17 06:57:56 assocGroup_2 Max 5 Nodes
setstate Fibaro_Motion_Sensor_3 2019-08-17 06:57:56 assocGroup_3 Max 5 Nodes
setstate Fibaro_Motion_Sensor_3 2019-08-17 06:57:56 assocGroup_4 Max 5 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_3 2019-08-17 06:57:56 assocGroup_5 Max 5 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_3 2019-08-17 06:57:56 assocGroups 5
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:18 configAssociationsInZWaveNetwork18 15
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:19 configBASICCommandClassConfiguration BASICOnAndOFF
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:19 configBASICOFFCommandFrameValue 0
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:19 configBASICONCommandFrameValue 255
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:19 configLuminanceReportThreshold 200
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:19 configLuminanceReportsInterval 3600
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:19 configMotionDetectionAlarmCancellation6 30
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:19 configMotionDetectionBlindTime 15
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:20 configMotionDetectionNightDay 200
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:21 configMotionDetectionPulseCounter 2Pulses
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:21 configTamperAlarmBroadcastMode TamperAlarmSentTo3rdAssociation0
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:21 configTamperAlarmCancellation SendTamperCancellationReport
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:21 configTamperAlarmCancellationDelay 30
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:21 configTamperOperatingModes TamperOnly
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configTamperSensitivity 20
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configTemperatureMeasuringInterval 900
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configTemperatureOffset 0
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configTemperatureReportInterval 0
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configTemperatureReportThreshold 10
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configVisualLEDIndicatorBrightness 50
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configVisualLEDIndicatorLuminanceFor82 100
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configVisualLEDIndicatorLuminanceFor83 1000
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:22 configVisualLEDIndicatorSignallingMode LongBlinkThenShortBlinkLEDColour10
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:23 configVisualLEDIndicatorTamperAlarm TamperAlarmIsIndicated
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:23 configVisualLEDIndicatorTemperatureFor86 18
setstate Fibaro_Motion_Sensor_3 2019-08-11 10:04:23 configVisualLEDIndicatorTemperatureFor87 28
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:16:17 luminance 72 Lux
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:06 mcaGroups 5
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:06 mca_1 Max 1 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:06 mca_2 Max 10
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:06 mca_3 Max 10
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:06 mca_4 Max 10 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:06 mca_5 Max 10 Nodes ZWDongle_0
setstate Fibaro_Motion_Sensor_3 2019-07-31 00:16:27 model FIBARO System FGMS001-ZW5 Motion Sensor
setstate Fibaro_Motion_Sensor_3 2019-07-31 00:16:27 modelConfig fibaro/fgmszw5.xml
setstate Fibaro_Motion_Sensor_3 2019-07-31 00:16:27 modelId 010f-0801-1001
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:09 reportedState closed
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:09 state closed
setstate Fibaro_Motion_Sensor_3 2019-08-16 11:06:54 temperature 25.3 C
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:08 timeToAck 0.025
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:08 transmit OK
setstate Fibaro_Motion_Sensor_3 2019-08-17 12:55:05 wakeup notification
krikan
Please delete all associations:
set <MainDevice> associationDel 1 <ControllerNodeId>
set <MainDevice> associationDel 3 <ControllerNodeId>
Try multi-channel-associations instead (mcaAdd); for example:
set <MainDevice> mcaAdd 1 0 <ControllerNodeId> 0
TomekWaw
Sorry for being dumb about this, but it's really a black-magic for me.
Should I execute it on a Dimmer (id 14)?
I just issued commands:
set Fibaro_Dimmer_1_S1 associationDel 1 14
set Fibaro_Dimmer_1_S1 associationDel 3 14
set Fibaro_Dimmer_1_S1 mcaAdd 1 0 14 0
set Fibaro_Dimmer_1_S2 associationDel 1 14
set Fibaro_Dimmer_1_S2 associationDel 3 14
set Fibaro_Dimmer_1_S2 mcaAdd 1 0 14 0
Went with no errors, but don't see any difference
krikan
Try  it on dimmer and FGS.
14 is wrong in your commands. This must be the NodeId of the Controller (<controlerNodeId>); mostly this is 1.
krikan
Sorry, I overlooked it:
You should execute the commands on the MainDevices. That is Fibaro_Dimmer_1 and not Fibaro_Dimmer_1_S1.
TomekWaw
#9
This is exactly what I've found out also.
Previous commands did not help but when I issued:
set Fibaro_Dimmer_1 associationDel 1 1
set Fibaro_Dimmer_1 associationDel 3 1
set Fibaro_Dimmer_1 mcaAdd 1 0 1 0
then the magic finally happened!
Now I see change of state on S2 (switch triggers it between "off" or "dim 99")!
Can this somehow be achieved with Fibaro Relay also (the older one, FGS-212)?
I've tried:
set Fibaro_Relay_1 associationDel 1 1
set Fibaro_Relay_1 associationDel 3 1
set Fibaro_Relay_1 mcaAdd 1 0 1 0
It went with no errors but the outcome is different (no state change on S1 nor S2).
krikan
FGS-212: Please try this after you have deleted all previous associations:
set Fibaro_Relay_1 mcaAdd 1 0 1 1
set Fibaro_Relay_1 mcaAdd 2 0 1 2
set Fibaro_Relay_1 associationAdd 3 1
TomekWaw
#11
It works :) I would never figure it out by myself!
Thank you very much!
Would you be so kind and take a look also at the problem with self-triggering FGMS-001's?
Maybe it can also be solved with some black-magic mca commands?
krikan
I don't think that's a problem with associations. I also lack ideas what else it can be.
I would exclude both devices and then include them again. If it still occurs, please post a log with verbose 5 of the problem.
TomekWaw
I have found that I have not excluded these devices properly before:
ZWDongle_0 nodeList => ZWDongle_0 Fibaro_Wall_Plug_1 UNKNOWN_3 Hank_One_Button_1 Fibaro_Door_Sensor_1 Fibaro_Wall_Plug_2 Fibaro_Wall_Plug_3 Fibaro_Motion_Sensor_2 UNKNOWN_9 UNKNOWN_10 Fibaro_Motion_Sensor_3 Fibaro_Motion_Sensor_1 Fibaro_Dimmer_1 Fibaro_Dimmer_2 Fibaro_Dimmer_3 Fibaro_Relay_1 Fibaro_Relay_2
so I issued commandset:
set ZWDongle_0 sendNIF 3
get ZWDongle_0 isFailedNode 3
set ZWDongle_0 removeFailedNode 3
and for nodes 9 and 10 accordingly.
I got a clean list of connected nodes after that.
Then I properly excluded all three motion sensor, properly included them again and so far they seem to work fine!
Thanks!
tux75at
I am using Fibaro Dimmers as well and i have the same problem, that i dont get switch changes.
It is not neccessary to get the switch trigger. S1 is allways connected to the Dimmer itself. S2 is free to use.
If you want to switch any different device, then you have to associate it and it will switch directly (even when the FHEM server is down).
In the case that you want to switch something else, you might not need to get the switch trigger, i solved it using the state change message of the dimmer.
Fibaro gives these messages. I have a bigger problem with the Aeotec dimmer, which is silent and does not tell anything (I dont care anymore, i will use fibaro because of some features).
If you need the switch 2 for a trigger on the fhem server, maybe you need to add node 0 to the correct association (i did not try, but would also like to know how to be able to use it that way).
Multichannel Association ...
I dont remember right now, but i think i have seen several devices for z-wave devices e.g. ZWave_SEnsor_Binary_27, ZWave_SEnsor_Binary_27.01, ZWave_SEnsor_Binary_27.02, is this the multichannel part?
I want to get this things also right bevore i start including all devices  ... (i am in a development phase but will move soon and then i have to get it all working).
The next days i will research on multi-channel-associations (mcaAdd)
TomekWaw
#15
Thanks to @krikan suggestions I've already sorted that out.
I have Fibaro_Dimmer_1_S2 (.02) changing state between "dim 99" and "off" values on every [monostable] switch press.
This doesn't change dimmer (lamp) state at all and that's exactly what I wanted.
S2 state change is published to MQTT broker and then passed further to Loxone Miniserver over UDP, where it finally
triggers/switches lighting scenes (via Lighting Controller logic block, that controls other Dimmers also).
But to get even more out of this configuration, I'm figuring out how to detect single and double press.
I've enabled configSceneActivationFunctionality parameter and I'm already getting (in Dimmer readings) scene_26:0 and scene_24:0 occurance out of S2 single and double click.
Now I only need to create another single custom reading out of those two.
Still working on it :) I've posted help request on that matter here:
https://forum.fhem.de/index.php/topic,103089.0.html
I would appreciate if someone smarter then me could take a look
TomekWaw
#16
rudolfkoenig helped me (thank you again) and I have finally managed to get
a Loxone-standard compatible switch out of Fibaro dimmer! 8)
This is how it works in real life:
https://www.youtube.com/watch?v=HGnGsIrz7bI
