[Gelöst] Fehler im Log bei Nutzung 83_KLF200
Begonnen von Hans-Ulrich Tag, 14 September 2019, 12:56:39
Hans-Ulrich Tag
nachdem gestern das Velux-Interface KLF200 bei mir eingetroffen ist, habe ich mich heute mal an die Anbindung in FHEM gesetzt.
Die Einrichtung war problemlos, Login hat mit dem WLAN-Passwort funktioniert.
Jedoch werden die Nodes nicht angelegt und im Log wiederholt sich folgende Fehlermeldung:
2019.09.14 12:22:21 1: PERL WARNING: Use of uninitialized value $klf200Address in string eq at ./FHEM/83_KLF200.pm line 500.
2019.09.14 12:22:21 1:     main::__ANON__                      called by ./FHEM/83_KLF200.pm (500)
2019.09.14 12:22:21 1:     main::KLF200_getControlName         called by ./FHEM/83_KLF200Node.pm (970)
2019.09.14 12:22:21 1:     main::KLF200Node_GW_STATUS_REQUEST_NTF called by ./FHEM/83_KLF200Node.pm (488)
2019.09.14 12:22:21 1:     main::KLF200Node_Parse              called by fhem.pl (3948)
2019.09.14 12:22:21 1:     main::Dispatch                      called by ./FHEM/83_KLF200.pm (392)
2019.09.14 12:22:21 1:     main::KLF200_DispatchToNode         called by ./FHEM/83_KLF200.pm (189)
2019.09.14 12:22:21 1:     main::KLF200_Read                   called by fhem.pl (3747)
Hier das List vom Device:
   .sceneIDUsage
   .sceneUsage
   DEF        192.168.xx.yy
   DeviceName 192.168.xx.yy:51200
   FD         44
   FUUID      5d7cbed7-f33f-062d-0467-1242d6dc55ad68d5
   Host       192.168.xx.yy
   NAME       Velux
   NR         333
   PARTIAL
   SCENES
   SSL        1
   STATE      Logged in
   TIMEOUT    10
   TYPE       KLF200
   .Const:
     CommandOriginator:
       1          User Remote control
       11         Electric load shed
       12         Local light sensor
       13         Unknown sensor
       2          Rain sensor
       255        Emergency or security commands
       3          Timer controlled
       5          UPS unit
       8          Stand Alone Automatic Controls
       9          Wind sensor
     ErrorNumber:
       0          Not further defined error.
       1          Unknown Command or command is not accepted at this state.
       12         Not authenticated.
       2          ERROR on Frame Structure.
       7          Busy. Try again later.
       8          Bad system table index.
     Status:
       0          OK - Request accepted
       1          Error - Invalid parameter
       2          Error - Request rejected
     SubState:
       0          Idle state
       1          Performing task in Configuration Service handler
       128        Performing task in Command Handler
       129        Performing task in Activate Group Handler
       130        Performing task in Activate Scene Handler
       2          Performing Scene Configuration
       3          Performing Information Service Configuration
       4          Performing Contact input Configuration
     Velocity:
       0          DEFAULT
       1          SILENT
       2          FAST
       255        VELOCITY NOT AVAILABLE
   .attraggr:
   .attrminint:
   .clientArray:
     KLF200Node
   .idToScene:
   .queue:
   .sceneToID:
     2019-09-14 12:20:12   connectionBroken 0
     2019-09-14 12:35:36   connectionsAfterBoot 1
     2019-09-14 12:20:13   hardwareVersion 6
     2019-09-14 12:21:49   lastError
     2019-09-14 12:20:13   model           0.2.0.0.71.0
     2019-09-14 12:41:51   queueSize       0
     2019-09-14 12:37:45   sessionID       4
     2019-09-14 12:20:13   softwareVersion 0.2.0.0.71.0
     2019-09-14 12:35:36   state           Logged in
     2019-09-14 12:51:53   subState        Idle state
   alias      Velux
   icon       fts_window_roof_shutter
   room       Dachboden,Kinderzimmer,Schlafzimmer.OG
   velocity   SILENT
Die 3 Rollläden sind in der Box angelernt.
Die lt. WIKI benötigten Bibliotheken, FHEM und das System (VM auf einer Synology DS-718+ mit Ubuntu 19.04) sind jeweils aktuell.
Wo kann ich nach der Fehlerquelle forschen?
Hans-Ulrich
Hans-Ulrich Tag
Inzwischen habe ich im Interface Szenen angelegt. Diese werden von FHEM übernommen. Aber leider noch immer nicht die Nodes.
@buennerbernd: hast Du eine Idee, was ich noch prüfen kann?
Hans-Ulrich
buennerbernd
Hallo Hans-Ulrich,
eine schnelle Antwort habe ich darauf auch nicht.
Irgendwo in FHEM kann man autocreate ein- und ausschalten. Kann es sein, dass es bei dir abgeschaltet ist?
Ansonsten setze mal auf der KLF200 das Attr verbose auf 5.
Dann rufe
set velux updateAll
auf und davon schicke mir mal die Logs. Vielleicht sehe ich da, was nicht geklappt hat.
Falls dabei nichts herauskommt, vielleicht hilft es, das Device zu löschen und noch einmal anzulegen.
Gruß, Stefan.
Modulentwickler von KLF200 und KLF200Node
buennerbernd
Ich habe mal schnell noch ein Update gebaut, was gegen den Fehler
helfen sollte, aber ich vermute, das war nicht die Ursache.
Also erst einmal das Update machen, neu starten, und falls die Nodes nicht kommen,  mal das von meinem letzten Post machen.
Gruß, Stefan.
Hans-Ulrich Tag
Hallo Stefan,
jetzt hat es geklappt und die Nodes wurden angelegt.
Danke für das Modul 👍🏻.
Hans-Ulrich
