hier das list
DEF 10
FUUID 5da1b663-f33f-e4b1-39cb-ce0518340fa31483
IODev MySensorGateway
NAME MYSENSOR_10
NR 1612
STATE 19.56
TYPE MYSENSORS_DEVICE
ack 0
radioId 10
repeater 0
2019-10-13 10:21:40 SKETCH_NAME NodeManager
2019-10-13 10:21:41 SKETCH_VERSION 1.0
2019-10-13 10:21:42 id6 28FF8EA871150321
2019-10-13 10:21:43 level202 -256
2019-10-13 10:21:38 parentId 0
2019-10-13 10:21:40 state received presentation
2019-10-13 10:31:44 temperature6 19.56
2019-10-12 16:59:27 tripped1 0
2019-10-12 16:59:07 tripped2 0
2019-10-12 17:00:06 tripped3 0
2019-10-12 18:07:15 tripped4 on
2019-10-13 10:22:28 tripped5 on
readingMappings:
1:
15:
name armed1
16:
name tripped1
24:
name value11
25:
name value21
26:
name value31
27:
name value41
28:
name value51
2:
15:
name armed2
16:
name tripped2
24:
name value12
25:
name value22
26:
name value32
27:
name value42
28:
name value52
202:
15:
name armed202
16:
name tripped202
37:
name level202
3:
15:
name armed3
16:
name tripped3
24:
name value13
25:
name value23
26:
name value33
27:
name value43
28:
name value53
4:
15:
name armed4
16:
name tripped4
5:
15:
name armed5
16:
name tripped5
6:
0:
name temperature6
42:
name id6
sensorMappings:
0:
receives:
sends:
16
15
1:
receives:
sends:
16
15
10:
receives:
sends:
6
7
11:
receives:
sends:
11
12:
receives:
sends:
12
14
13:
receives:
24
sends:
17
18
54
55
56
24
14:
receives:
sends:
45
21
0
2
15:
receives:
sends:
13
43
16:
receives:
sends:
23
37
17:
receives:
sends:
18:
receives:
sends:
19:
receives:
36
sends:
36
2:
receives:
sends:
16
15
20:
receives:
32
sends:
33
50
32
21:
receives:
24
sends:
34
35
24
22:
receives:
sends:
37
43
23:
receives:
24
25
26
27
28
sends:
24
25
26
27
28
24:
receives:
sends:
37
43
25:
receives:
sends:
19
20
26:
receives:
40
17
3
sends:
40
17
3
27:
receives:
41
17
3
sends:
41
17
3
28:
receives:
40
sends:
40
29:
receives:
sends:
2
0
45
44
21
46
22
3:
receives:
2
17
sends:
2
17
30:
receives:
sends:
38
39
14
31:
receives:
sends:
2
16
32:
receives:
sends:
16
15
33:
receives:
sends:
37
16
15
34:
receives:
sends:
37
16
15
35:
receives:
sends:
37
16
15
36:
receives:
47
sends:
47
37:
receives:
sends:
34
35
38:
receives:
sends:
49
39:
receives:
sends:
0
51
52
53
2
4:
receives:
2
3
17
sends:
2
3
17
5:
receives:
29
30
31
3
sends:
29
30
31
3
6:
receives:
sends:
0
42
7:
receives:
sends:
1
8:
receives:
sends:
4
5
9:
receives:
sends:
8
9
10
sets:
clear noArg
flash noArg
fwType
reboot noArg
time noArg
value11 1
value12 1
value13 1
value21 1
value22 1
value23 1
value31 1
value32 1
value33 1
value41 1
value42 1
value43 1
value51 1
value52 1
value53 1
typeMappings:
0:
type temperature
1:
type humidity
10:
type direction
11:
type uv
12:
type weight
13:
type distance
14:
type impedance
15:
type armed
val:
0 off
1 on
16:
type tripped
val:
0 off
1 on
17:
type power
18:
type energy
19:
type button_on
2:
type status
val:
0 off
1 on
20:
type button_off
21:
type hvacflowstate
22:
type hvacspeed
23:
type brightness
range:
max 100
min 0
step 1
24:
type value1
25:
type value2
26:
type value3
27:
type value4
28:
type value5
29:
type up
3:
type percentage
range:
max 100
min 0
step 1
30:
type down
31:
type stop
32:
type ir_send
33:
type ir_receive
34:
type flow
35:
type volume
36:
type lockstatus
val:
0 off
1 on
37:
type level
38:
type voltage
39:
type current
4:
type pressure
40:
type rgb
41:
type rgbw
42:
type id
43:
type unitprefix
44:
type hvacsetpointcool
45:
type hvacsetpointheat
46:
type hvacflowmode
47:
type text
48:
type custom
49:
type position
5:
type forecast
val:
0 stable
1 sunny
2 cloudy
3 unstable
4 thunderstorm
5 unknown
50:
type ir_record
51:
type ph
52:
type orp
53:
type ec
54:
type value
55:
type va
56:
type power_factor
6:
type rain
7:
type rainrate
8:
type wind
9:
type gust
mapReading_armed1 1 armed
mapReading_armed2 2 armed
mapReading_armed202 202 armed
mapReading_armed3 3 armed
mapReading_armed4 4 armed
mapReading_armed5 5 armed
mapReading_id6 6 id
mapReading_level202 202 level
mapReading_temperature6 6 temperature
mapReading_tripped1 1 tripped
mapReading_tripped2 2 tripped
mapReading_tripped202 202 tripped
mapReading_tripped3 3 tripped
mapReading_tripped4 4 tripped
mapReading_tripped5 5 tripped
mapReading_value11 1 value1
mapReading_value12 2 value1
mapReading_value13 3 value1
mapReading_value21 1 value2
mapReading_value22 2 value2
mapReading_value23 3 value2
mapReading_value31 1 value3
mapReading_value32 2 value3
mapReading_value33 3 value3
mapReading_value41 1 value4
mapReading_value42 2 value4
mapReading_value43 3 value4
mapReading_value51 1 value5
mapReading_value52 2 value5
mapReading_value53 3 value5
mode node
room MYSENSORS_DEVICE
setReading_value11 1
setReading_value12 1
setReading_value13 1
setReading_value21 1
setReading_value22 1
setReading_value23 1
setReading_value31 1
setReading_value32 1
setReading_value33 1
setReading_value41 1
setReading_value42 1
setReading_value43 1
setReading_value51 1
setReading_value52 1
setReading_value53 1
stateFormat temperature6
als Gateway verwende ich ein RF24 to WLAN - Gateway.
Was mir noch aufgefallen ist, dass zwar attr automatisch angelegt werden aber nicht auch alle zugehörigen readings.
Node ist derzeit ein Atmega2560 mit LDR, Bewegungsmelder, Fenster-Sensor, Temp-Sensor (DS18B20), 2 digitale Eingänge und 1 digitaler Ausgang.
Sketch ist der Node-Manager.
Frage resultiert vor allem aus der Problematik der in Teilen nicht automatisch angelegten attr und readings,
Andreas
