gestern hatte ich folgende Meldungen im Logfile:
2019.11.06 09:04:31 2: KGN36HI33 event channel received an http error: HTTP/1.1 503 Service Temporarily Unavailable
2019.11.06 09:09:41 2: KGN36HI33 event channel received an http error: HTTP/1.1 503 Service Temporarily Unavailable
2019.11.06 09:18:10 3: hcconn refreshing token
2019.11.06 09:18:10 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:19:10 3: hcconn refreshing token
2019.11.06 09:19:11 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:19:51 2: KGN36HI33 event channel received an http error: HTTP/1.1 503 Service Temporarily Unavailable
2019.11.06 09:20:11 3: hcconn refreshing token
2019.11.06 09:20:11 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:21:11 3: hcconn refreshing token
2019.11.06 09:21:11 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:22:11 3: hcconn refreshing token
2019.11.06 09:22:11 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:23:11 3: hcconn refreshing token
2019.11.06 09:23:12 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:24:12 3: hcconn refreshing token
2019.11.06 09:24:12 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:25:12 3: hcconn refreshing token
2019.11.06 09:25:13 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:26:13 3: hcconn refreshing token
2019.11.06 09:26:13 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:27:13 3: hcconn refreshing token
2019.11.06 09:27:13 2: hcconn: invalid json detected: >><!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>503 Service Temporarily Unavailable</title></head><body><h1>Service Temporarily Unavailable</h1><p>The server is temporarily unable to service yourrequest due to maintenance downtime or capacityproblems. Please try again later.</p></body></html><<
2019.11.06 09:27:13 2: hcconn: Refreshing token failed too many times, stopping
2019.11.06 09:35:01 2: KGN36HI33 event channel received an http error: HTTP/1.1 503 Service Temporarily Unavailable
Wenn ich nun an meinem Kühlschrank die Temperatur einstellen möchte, erhalte ich folgende Meldung:
"error": {
"key": "invalid_token",
"description": "The access token expired"
Nachdem ich fhem neugestartet habe, sieht "hcconn" wie folgt aus:
DEF 35391B8B36BE356D714647DC06BAFC86CF80B29B2578981C7CB02F82282C6BA9 https://xxx.xxx.xxx.xxx:8083/fhem?cmd.Test=set%20hcconn%20auth%20 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
FUUID 5db19986-f33f-5dcf-3403-4ee32e22b5000c49
NAME hcconn
NR 485
STATE Login necessary
TYPE HomeConnectConnection
api_uri https://api.home-connect.com
client_id xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
client_secret xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
expires_at
redirect_uri https://xxx.xxx.xxx.xxx:8083/fhem?cmd.Test=set%20hcconn%20auth%20
2019-11-07 09:03:01 state Login necessary
2019-11-05 15:18:10 tokenExpiry Wed Nov 6 15:18:10 2019
room Hersteller->HomeConnect
Anschließend habe ich nochmal auf den Link "Home Connect Login" am hcconn Device geklickt und mich erneut eingeloggt. Danach ging wieder alles.
Ist dieses Verhalten normal?
Gruß Hoppel
