Revision 20495: 22_HOMEMODE: prevent to execute empty HomeCMDs, fix blocking IP check ...
Begonnen von System, 11 November 2019, 21:15:33
System
22_HOMEMODE: prevent to execute empty HomeCMDs, fix blocking IP check if no internet connection is available, add missing name for logging 'executed CMDs'
Source: Revision 20495: 22_HOMEMODE: prevent to execute empty HomeCMDs, fix blocking IP check ...
