TelegramBot: FHEM crasht nach Update
Begonnen von justcallmeal, 18 November 2019, 11:27:37
justcallmeal
gestern habe ich mein Fhem mal wieder geupdatet und habe nun das Problem, dass mein fhem crasht und ich es nur wieder zum Laufen bringe, indem ich den Raspi via ssh neu boote.
Im Log stehen dann eine Menge Meldungen die augenscheinlich mit dem Telebot zu tun haben:
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2218.
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2227.
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2183.
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2175.
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2169.
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2242.
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2359.
2019.11.18 08:57:12 1: ERROR: empty name in readingsBeginUpdate
2019.11.18 08:57:12 1: stacktrace:
2019.11.18 08:57:12 1:     main::readingsBeginUpdate           called by ./FHEM/50_TelegramBot.pm (2397)
2019.11.18 08:57:12 1:     main::TelegramBot_Callback          called by FHEM/HttpUtils.pm (634)
2019.11.18 08:57:12 1:     main::__ANON__                      called by fhem.pl (751)
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 4772.
2019.11.18 08:57:12 1: readingsUpdate(,sentMsgResult,SUCCESS) missed to call readingsBeginUpdate first.
2019.11.18 08:57:12 1:     main::readingsBulkUpdate            called by ./FHEM/50_TelegramBot.pm (2398)
2019.11.18 08:57:12 1: readingsUpdate(,sentMsgId,15881) missed to call readingsBeginUpdate first.
2019.11.18 08:57:12 1:     main::readingsBulkUpdate            called by ./FHEM/50_TelegramBot.pm (2399)
2019.11.18 08:57:12 1: readingsUpdate(,sentMsgPeerId,) missed to call readingsBeginUpdate first.
2019.11.18 08:57:12 1:     main::readingsBulkUpdate            called by ./FHEM/50_TelegramBot.pm (2400)
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4525.
2019.11.18 08:57:12 1: PERL WARNING: Use of uninitialized value $dev in hash element at fhem.pl line 3626.
Can't use an undefined value as an ARRAY reference at ./FHEM/50_TelegramBot.pm line 2403.
2019.11.18 10:32:24 1: reload: Error:Modul 99_myUtilsTemplate deactivated:
Kann der Maintainer von TelegramBot mal bitte schauen, was da los ist?
Vielen Dank vorab!
LG,
al
HM-Sen-DB-PCB, HM-Sec-SCo, HM-MOD-Re-8, HM-SEC-SC-2, HM-Sen-MDIR-O, HM-LC-Sw1PBU-FM, HM-LC-RGBW-WM, HM-ES-PMSw1-SM, HM-LC-Sw1-DR
dt2510
Ich hab' das gleiche Problem, bei mir geht allerdings noch ein
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $ret in numeric le (<=) at FHEM/HttpUtils.pm line 646.
voraus
justcallmeal
...da ich ab heute Abend reisebedingt die nächsten 14 Tage unterwegs bin und mich nicht um fhem kümmern kann, hab ich das automatisierte fhem-Backup von gestern wieder reingefahren; - Otto's Blog und toller Beschreibung auf http://heinz-otto.blogspot.com/2015/12/backup-und-restore-von-fhem.html sei Dank!
Es wäre schön, wenn es bei meiner Rückkehr in 14 Tagen eine Lösung für das Problem gibt  :)
LG,
al
DS_Starter
Hi al,
dann noch schnell die Frage was du genau mit Telegram versendest ?
Konnte das Problem auf einem System bei mir beim Versand von Aufnahmen nachstellen. Allerdings sind die Versionen von Telegram und (sscam bei mir) auf allen Systemen identisch. Doch nur ein System hat das Problem. Telegram ist auch schon recht alt und wurde nicht upgedated. Es muss also irgendwo "dazwischen".
Auf meiner Seite (sscam) schaue ich heute Abend.
Grüße,
Heiko
ESXi@NUC+Debian+MariaDB, PV: SMA, Victron MPII+Pylontech+CerboGX
dt2510
Könnte es nicht an HttpUtils liegen ? Der Fehler geht bei mir immer voran ...
2019.11.16 23:56:35 3: D200 - Telegram message transaction "2202" successfully sent to "xxxxxxxxx" by "Telegram"
2019.11.16 23:56:35 3: D200 - Snapshot of Camera Eingang created. ID: 17
2019.11.16 23:56:35 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at ./FHEM/50_TelegramBot.pm line 2218.
D200 ist ein SSCam Device
justcallmeal
#5
Zitat von: DS_Starter am 18 November 2019, 14:06:27
...dann noch schnell die Frage was du genau mit Telegram versendest ?
Hallo Heiko,
ich versende Fotos von meiner IP-Cam mit Deinem SSCAM-Modul :-)
LG,
al
DS_Starter
Eher nicht, ist nur eine Warnung. Allerdings wahrscheinlich schon ein Hinweis auf einen fehlenden Wert. Der Absturz wird erst durch das Can't use an undefined value as an ARRAY reference at ./FHEM/50_TelegramBot.pm line 2403.
ausgelöst.
Danke al. Dann ist der Zusammenhang hergestellt, aber für mich noch nicht transparent. Ich schaue heute Abend.
Hat bisher ja auch einwandfrei funktioniert.
Lg,
Heiko
CoolTux
Eine zusätzliche Abfrage sollte hier Abhilfe schaffen
Zeile 2403
Aus
if ( scalar( @{ $hash->{sentQueue} } ) ) {
nach
if ( ref(@{ $hash->{sentQueue} }) eq 'ARRAY' and scalar( @{ $hash->{sentQueue} } ) ) {
Das TuxNet Wiki:
https://www.cooltux.net
DS_Starter
Hast du sicherlich nicht unrecht. Frage ist nur wieso es jetzt plötzlich auftritt und bei mir zum Beispiel nur auf einem System wobei alle den gleichen Stand bezüglich telegram und sscam haben. Mysterium ...  ::)
Wie gesagt, ich schaue heute Abend. Telegram pflegt aber Viegener. Ich muss es in Sscam abfabgen wenn ich dahinter gestiegen bin.
DS_Starter
Achso .... das kuriose ist ja auch, dass die Snaps bzw. Aufnahmen trotzdem erfolgreich versendet werden (bei mir).
Bei euch ebenfalls ?
justcallmeal
...ja, bei mir auch!
Happy Fhem User
Zeile 2403
Aus
nach
nenene, da wird ja wieder versucht ein Array zu machen. Da sollte wohl lieber heißen:
if ( ref( $hash->{sentQueue}) eq 'ARRAY' and scalar( @{ $hash->{sentQueue} } ) ) {
CoolTux
Das TuxNet Wiki:
DS_Starter
habe den Fehler gefunden und beseitigt.
Es war ein trivialer Kommentar, der eine Codezeile auskommentiert hatte zum Test.
Warum das allerdings auf meinem Prodsystem zu keinem Problem führte (auch dort war sie auskommentiert), hat sich mir bis jetzt nicht erschlossen.
Bis jetzt war es mir ja auf dem Testsystem auch nicht ausgefallen und auch dort war diese Version seit 04.11. im Einsatz.
Ich vermute ein Reihenfolgeproblem der Definition SSCam vs. TelegramBot.
Die Korrektur ist eingecheckt und morgen früh im Update.
Wer den Fehler sofort beseitigen möchte, kann die Korrektur aus meinem contrib laden. Bitte so komplett mit den Ausführungszeichen am Anfang und Ende eingeben:
"wget -qO ./FHEM/49_SSCam.pm https://svn.fhem.de/fhem/trunk/fhem/contrib/DS_Starter/49_SSCam.pm"
Grüße,
Heiko
dt2510
super ... probier' ich nachher gleich aus
