Revision 20717: mqtt2.template: tasmota: add template for switch+rgb-led; shelly: ...
Begonnen von System, 12 Dezember 2019, 16:30:24
System
mqtt2.template: tasmota: add template for switch+rgb-led; shelly: bugfix in washer example
Source: Revision 20717: mqtt2.template: tasmota: add template for switch+rgb-led; shelly: ...
