Setting home page in FHEMWEB
Begonnen von nottledim, 28 Januar 2013, 21:21:15
nottledim
Hello,
        Could somebody tell me how to configure what is displayed on the FHEMWEB home page i.e http://<host>/fhem
I have changed all the room name attributes and it all works as expected except that the home page is now blank.  I would like to set it so it shows the same as /fhem?room=xyz but I don't know how to do this.
Many thanks
UliM
you can't change this.
Just set a shortcut-button in your browser and configure it such that it points to your preferred room.
Best, Uli
nottledim
Best, Uli
OK, thanks.  But what does it display by default?
Cheers
UliM
fhem-menu on the left, on the right nothing but the text you state in the 'motd' attribute.
Cheers, Uli
nottledim
Ah yes!  Now you mention it that's how it used to work. Doh!
Many thanks for your help.
brmpfl
Maybe this helps:
It's possible to use HTML-Code for motd.
attr global motd <a href="myFhem:8083/fhem">Click me</a>
Hajo
Sturi2011
Lösung:
attr global motd <script type="text/javascript">window.location = "/fhem?room=Info"</script>
Gruß Andreas
Christian72D
Dieser Trick hatte bei mir bis gestern funktioniert, nach einem Update nicht mehr.
Jetzt steht da nur noch "$motd".
Jemand eine Idee was da passiert ist?
Mitch
why not using defaultRoom?
This is, what I have done. Just setting the attribut defaultRoom to your fhemweb instance.
FHEM im Proxmox Container
https://ts.la/markus34522
Christian72D
Because i did´t know this attribute until yesterday.
Thanks.
MB_User
Hi @ll,
Any idea how to set a floorplan as default page? Default room does not work.
Thanks & best regards
MB
minierm
Zitat von: Sturi2011 am 01 Februar 2013, 18:23:56
Lösung:
Gruß Andreas
Funktioniert auch super mit einem Dashboard:
attr global motd <script type="text/javascript">window.location = "/fhem/dashboard/Dash_xxx"</script>
