Autor Thema: Modul 98_NSPC - Nintendo Switch Parental Control - alpha Version  (Gelesen 5160 mal)
Offline HeikoE
  • Full Member
Antw:Modul 98_NSPC - Nintendo Switch Parental Control - alpha Version
« Antwort #15 am: 05 September 2021, 21:45:04 »
Hallo KernSani,
ich habe heute Deim Modul gefunden und wollte es direkt mal probieren.
Ich bekomme ein Session Token und es wird zumindest teilweise akzeptiert. Das Reading "account_nick" zeigt zum Beispiel den korrekten Namen.
Ansonsten gibt es aber folgende Meldung:
error  not_found
error_description  HTTP 404 Not Found
Im Log (verbose = 5) findet sich:
2021.09.05 21:19:40 4: [NintendoSwitch] Processing Queue: NSPC_getDevices
2021.09.05 21:19:40 5: [NintendoSwitch] GetDevice - Starting Blocking Call
2021.09.05 21:19:41 5: [NintendoSwitch] GetDevice - received {"type":"https://moon.nintendo.com/errors/v1/400/update_required","status":400,"errorCode":"update_required","title":"UpdateRequiredException","detail":"","instance":"https://api-lp1.pctl.srv.nintendo.net/moon/v1/users/xxxxxxxxxxxxxxxxx/devices"}
2021.09.05 21:19:41 5: [NintendoSwitch] GetDevice - JSON is: $VAR1 = {
          'detail' => '',
          'errorCode' => 'update_required',
          'instance' => 'https://api-lp1.pctl.srv.nintendo.net/moon/v1/users/xxxxxxxxxxxxxxxxx/devices',
          'status' => 400,
          'title' => 'UpdateRequiredException',
          'type' => 'https://moon.nintendo.com/errors/v1/400/update_required'
2021.09.05 21:19:41 4: [NintendoSwitch] Processing Queue: NSPC_getDailySummary
2021.09.05 21:19:41 5: [NintendoSwitch] Get DailySummary - received {"type":"https://moon.nintendo.com/errors/v1/404/not_found","status":404,"errorCode":"not_found","title":"NotFoundException","detail":"HTTP 404 Not Found","instance":"https://api-lp1.pctl.srv.nintendo.net/moon/v1/devices//daily_summaries"}
2021.09.05 21:19:41 5: [NintendoSwitch] Get DailySummary - JSON is: $VAR1 = {
          'detail' => 'HTTP 404 Not Found',
          'errorCode' => 'not_found',
          'instance' => 'https://api-lp1.pctl.srv.nintendo.net/moon/v1/devices//daily_summaries',
          'status' => 404,
          'title' => 'NotFoundException',
          'type' => 'https://moon.nintendo.com/errors/v1/404/not_found'
2021.09.05 21:19:41 4: [NintendoSwitch] Processing Queue: NSPC_getPCSettings
2021.09.05 21:19:41 5: [NintendoSwitch] Get PCSettings - received {"type":"https://moon.nintendo.com/errors/v1/404/not_found","status":404,"errorCode":"not_found","title":"NotFoundException","detail":"HTTP 404 Not Found","instance":"https://api-lp1.pctl.srv.nintendo.net/moon/v1/devices//parental_control_setting"}
2021.09.05 21:19:41 5: [NintendoSwitch] Get PCSettings - JSON is: $VAR1 = {
          'instance' => 'https://api-lp1.pctl.srv.nintendo.net/moon/v1/devices//parental_control_setting',
          'status' => 404,
Ein unterschied zu Deiner Erklärung fällt mir auf: Du schreibst
mit der rechten Maustaste auf "Diesen Account verwenden" klicken und die Link Adresse kopieren.
Bei mir steht da "Diese Person auswählen". Auf dem Handy wird mit diesem Link die Nintendo App geöffnet.
Gibts noch irgendwas zu wissen?
Viele Grüße,
Heiko
Offline wolfram
  • Full Member
« Antwort #16 am: 14 September 2021, 10:42:31 »
Hallo HeikoE,
ich habe genau das gleiche Problem wie Du. Ich bekomme auch ein "Update required".
Hast Du schon eine Lösung dafür gefunden?
wolf
