FHEM > English Corner
New module: DaikinAC
eisman:
Problem:
--- Code: ---2022.03.30 10:34:21 1: PERL WARNING: Prototype mismatch: sub main::sum: none vs (@) at /usr/lib/x86_64-linux-gnu/perl-base/Exporter.pm line 66, <$fh> line 4742.
2022.03.30 10:34:21 1: stacktrace:
2022.03.30 10:34:21 1: main::__ANON__ called by /usr/lib/x86_64-linux-gnu/perl-base/Exporter.pm (66)
2022.03.30 10:34:21 1: Exporter::import called by ./FHEM/58_HVAC_DaikinAC.pm (23)
2022.03.30 10:34:21 1: main::BEGIN called by ./FHEM/58_HVAC_DaikinAC.pm (23)
2022.03.30 10:34:21 1: (eval) called by ./FHEM/58_HVAC_DaikinAC.pm (23)
2022.03.30 10:34:21 1: (eval) called by fhem.pl (2728)
2022.03.30 10:34:21 1: (eval) called by fhem.pl (2727)
2022.03.30 10:34:21 1: main::CommandReload called by fhem.pl (2057)
2022.03.30 10:34:21 1: main::LoadModule called by fhem.pl (2122)
2022.03.30 10:34:21 1: main::CommandDefine called by fhem.pl (1275)
2022.03.30 10:34:21 1: main::AnalyzeCommand called by fhem.pl (1126)
2022.03.30 10:34:21 1: main::AnalyzeCommandChain called by fhem.pl (1415)
2022.03.30 10:34:21 1: main::CommandInclude called by fhem.pl (626)
--- Ende Code ---
Device:
--- Code: ---Internals:
DEF 192.168.xxx.xxx
FUUID 6118a7a8-f33f-793a-8010-e618bf1b6b5695fa
HOST 192.168.xxx.xxx
INITIALIZED 1
INTERVAL 60
INTERVAL_PWRD 10
LASTUPDATE 30.03.2022 / 10:37:40
NAME Daikin
NR 373
STATE off-cool
TYPE HVAC_DaikinAC
VERSION 1.0.9
HELPER:
FAULTS 1
2022-03-30 10:35:35 basic_info ret=OK,type=aircon,reg=eu,dst=1,ver=1_2_54,rev=203DE8C,pow=0,err=0,location=0,name=%44%61%69%6b%69%6e%45%53,icon=0,method=home only,port=30050,id=,pw=,lpw_flag=0,adp_kind=3,pv=3.20,cpv=3,cpv_minor=20,led=1,en_setzone=1,mac=DCF5059CB000,adp_mode=run,en_hol=0,ssid1=MABRAP01,radio1=-57,grp_name=,en_grp=0
2022-01-23 08:43:24 cmpfreq 0
2022-01-23 08:43:24 control_info ret=OK,pow=0,mode=3,adv=,stemp=18.0,shum=0,dt1=25.0,dt2=M,dt3=18.0,dt4=25.0,dt5=25.0,dt7=25.0,dh1=AUTO,dh2=50,dh3=0,dh4=0,dh5=0,dh7=AUTO,dhh=50,b_mode=3,b_stemp=18.0,b_shum=0,alert=255,f_rate=A,f_dir=0,b_f_rate=A,b_f_dir=0,dfr1=5,dfr2=5,dfr3=A,dfr4=5,dfr5=5,dfr6=5,dfr7=5,dfrh=5,dfd1=0,dfd2=0,dfd3=0,dfd4=0,dfd5=0,dfd6=0,dfd7=0,dfdh=0,dmnd_run=0,en_demand=0
2022-01-23 08:43:24 dh1 AUTO
2022-01-23 08:43:24 dh3 0
2022-01-23 08:43:24 dh4 0
2022-01-23 08:43:24 dt1 25.0
2022-01-23 08:43:24 dt3 18.0
2022-01-23 08:43:24 dt4 25.0
2022-01-23 08:43:24 econo off
2022-01-23 08:43:24 f_dir 0
2022-01-23 08:43:24 f_mode 3
2022-01-23 08:43:24 f_rate A
2022-03-30 10:37:40 hhum -
2022-01-23 08:43:24 hhum_ifchanged -
2022-03-30 10:37:40 htemp 17.0
2022-03-30 10:06:28 htemp_ifchanged 17.0
2022-01-23 08:43:24 mac DCF5059CB000
2022-01-23 08:43:24 method home only
2022-01-23 08:43:24 mode cool
2022-01-23 08:43:24 model 0D75
2022-01-23 08:43:24 model_info ret=OK,model=0D75,type=N,pv=3.20,cpv=3,cpv_minor=20,mid=NA,humd=0,s_humd=0,acled=0,land=0,elec=1,temp=1,temp_rng=0,m_dtct=1,ac_dst=--,disp_dry=0,dmnd=1,en_scdltmr=1,en_frate=1,en_fdir=1,s_fdir=3,en_rtemp_a=0,en_spmode=3,en_ipw_sep=1,en_mompow=1,hmlmt_l=10.0
2022-01-23 08:43:24 mompow 0
2022-01-23 08:43:24 name DaikinES
2022-03-30 10:37:40 otemp 8.0
2022-03-30 09:33:54 otemp_ifchanged 8.0
2022-01-23 08:43:24 port 30050
2022-01-23 08:43:24 pow 0
2022-01-23 08:43:24 power off
2022-01-23 08:43:24 powerful off
2022-03-28 00:00:26 pwr_day_cur 0
2022-03-29 00:00:03 pwr_day_last 0
2022-01-23 08:43:24 pwr_history_daily_dec 0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0.1,0,0,0,0.1,0,0,0
2022-02-28 06:00:55 pwr_history_daily_feb 0.1,0,0,0,0.1,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,,,
2022-01-28 11:00:30 pwr_history_daily_jan 0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0
2022-03-27 06:00:53 pwr_history_daily_mar 0,0,0,0.1,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0.1,0,0,0,0
2022-03-28 00:00:26 pwr_history_hourly_today 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
2022-03-29 00:00:03 pwr_history_hourly_yesterday 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
2022-01-23 08:43:24 pwr_history_monthly_2021 0,0,0,0,0,0,0,0,1.2,0.8,0.8,0.8
2022-03-27 06:00:53 pwr_history_monthly_2022 0.8,0.8,0.7,0,0,0,0,0,0,0,0,0
2022-01-23 08:43:24 pwr_hour_cur 0
2022-03-27 07:00:45 pwr_hour_last 0
2022-03-27 06:00:53 pwr_month_cur 0.7
2022-01-23 08:43:24 pwr_month_last 0.8
2022-03-27 06:00:53 pwr_year_cur 2.3
2022-01-23 08:43:24 pwr_year_last 3.6
2022-01-23 08:43:24 rate auto
2022-01-23 08:43:24 reg eu
2022-01-23 08:43:24 rev 203DE8C
2022-03-30 10:06:28 sensor_info ret=OK,htemp=17.0,hhum=-,otemp=8.0,err=0,cmpfreq=0,mompow=1
2022-01-23 08:43:24 shum 0
2022-01-23 08:43:24 state off
2022-01-23 08:43:24 stemp 18.0
2022-01-23 08:43:24 streamer off
2022-01-23 08:43:24 swing none
2022-01-23 08:43:24 type N
2022-03-30 10:37:40 unit_date 2022/03/30 10:37:41
2022-01-23 08:43:24 ver 1_2_54
alias Klimaanlage
comment xxx
devStateIcon off.*:control_standby@gray:on
on-cool:frost@blue:off
on-heat:sani_heating@red:off
on-dehumidify:humidity@blue:off
on-vent:vent_ventilation@green:off
on-auto:temp_temperature@red:off
fp_Floorplan 17,1069,0,Daikin,
icon frost@blue
interval 60
interval_powered 10
pwrconsumption 1
rawdata 1
room Heizung,Schlafzimmer
stateFormat [$name:state]-[$name:mode]
verbose 0
widgetOverride stemp:18.0,19.0,20.0,21.0,22.0,23.0,24.0,25.0,26.0,27.0,28.0,29.0,30.0
--- Ende Code ---
mfg
roelb:
Hey folks. I've been extremely busy lately, so no time for maintenance on this module. I understand that Daikin has changed some things in newer software versions. I will try to have a look at this in the near future.
pifs:
Found some useful info to control the Daikin via cloud https://github.com/Apollon77/daikin-controller-cloud
Gr. Paul.
GodVatter:
Hi Mike,
do you have any updates or information to that issue that mompow and mompow_max doesn't exist within the FTXA?
BR
GV
--- Zitat von: MikeR am 18 Mai 2021, 22:13:09 ---Hello,
a few days ago i got my new Daikin Multisplit System installed. Today i tried this model for fhem and it works like a charm. Perfect.
Congratulations, superb job.
One thing: the two readings "mompow" and "mompow_max" didn't appear in my module. I have the indoor unit Stylish (aka: FTXA) with build in wifi adapter. I have activated the "pwrconsumption" attribute.
Any idea?
Greetings from Germany
Mike
--- Ende Zitat ---
Navigation
[0] Themen-Index
[*] Vorherige Sete
Zur normalen Ansicht wechseln
