Autor Thema: SYSMOn mit weblink Performance  (Gelesen 153 mal)
Offline JamBay
  • New Member
« am: 09 April 2020, 15:22:23 »
eins vorab, ist kein kritisches Problem zur Not lasse ich den Weblink einfach weg.
Gegeben sei folgender SYSMON:
   DEF        ssh:peter@192.168.168.25 5 5 5 30
   FUUID      5e8d9e00-f33f-1b22-c491-ce164fa20da8e872
   HOST       192.168.168.25
   INTERVAL_BASE 60
   INTERVAL_MULTIPLIERS 5 5 5 30
   MODE       ssh
   NAME       sysmon_MP
   NR         15
   PORT       22
   STATE      Active
   TYPE       SYSMON
   USER       peter
     2020-04-09 15:05:22   cpu0_freq       1509
     2020-04-09 15:05:22   cpu0_freq_stat  948.00 1597.00 1538.91
     2020-04-09 15:05:22   cpu0_idle_stat  52.35 84.03 73.49
     2020-04-09 15:05:22   cpu1_freq       1474
     2020-04-09 15:05:22   cpu1_freq_stat  812.00 1597.00 1524.10
     2020-04-09 15:05:22   cpu1_idle_stat  46.85 83.66 73.25
     2020-04-09 15:05:22   cpu_core_count  8192
     2020-04-09 15:05:22   cpu_freq        1509
     2020-04-09 15:05:22   cpu_freq_stat   948.00 1597.00 1538.91
     2020-04-09 15:05:22   cpu_idle_stat   52.50 83.54 73.37
     2020-04-09 13:18:19   cpu_model_name  AMD E-350D APU with Radeon(tm) HD Graphics
     2020-04-09 15:05:22   cpu_temp        38.00
     2020-04-09 15:05:22   cpu_temp_avg    40.1
     2020-04-09 15:05:22   cpu_temp_stat   35.00 44.00 40.23
     2020-04-09 15:05:22   eth0            RX: 2129.52 MB, TX: 320.67 MB, Total: 2450.19 MB
     2020-04-09 15:05:22   eth0_diff       RX: 40.06 MB, TX: 2.98 MB, Total: 43.04 MB
     2020-04-09 15:05:22   eth0_ip         192.168.168.25
     2020-04-09 15:05:22   eth0_rx         2232962881
     2020-04-09 15:05:22   eth0_speed      1000
     2020-04-09 15:05:22   eth0_tx         336248067
     2020-04-09 14:31:27   fs_home         Total: 238640 MB, Used: 128411 MB, 57 %, Available: 98084 MB at /home
     2020-04-09 14:31:27   fs_root         Total: 98345 MB, Used: 10991 MB, 12 %, Available: 82337 MB at /
     2020-04-09 15:09:06   idletime        16 0.02 %
     2020-04-09 15:09:06   idletime_text   0 days, 00 hours, 00 minutes (0.02 %)
     2020-04-09 15:05:22   loadavg         0.39 0.72 0.83
     2020-04-09 15:05:22   ram             Total: 3551.02 MB, Used: 910.74 MB, 25.65 %, Free: 108.15 MB
     2020-04-09 15:05:22   ram_used_stat   875.86 1096.15 913.68
     2020-04-09 15:09:06   starttime       1586356078
     2020-04-09 15:09:06   starttime_text  08.04.2020 16:27:58
     2020-04-09 15:05:22   stat_cpu        2231034 48273 667964 13144542 10327 0 8765
     2020-04-09 15:05:22   stat_cpu0       1118375 24244 322354 6576416 2332 0 6515
     2020-04-09 15:05:22   stat_cpu0_diff  11085 128 3102 39067 13 0 95
     2020-04-09 15:05:22   stat_cpu0_percent 20.72 0.24 5.80 73.04 0.02 0.00 0.18
     2020-04-09 15:05:22   stat_cpu0_text  user: 20.72 %, nice: 0.24 %, sys: 5.80 %, idle: 73.04 %, io: 0.02 %, irq: 0.00 %, sirq: 0.18 %
     2020-04-09 15:05:22   stat_cpu1       1112658 24029 345609 6568125 7995 0 2250
     2020-04-09 15:05:22   stat_cpu1_diff  11130 39 3317 39033 52 0 18
     2020-04-09 15:05:22   stat_cpu1_percent 20.77 0.07 6.19 72.84 0.10 0.00 0.03
     2020-04-09 15:05:22   stat_cpu1_text  user: 20.77 %, nice: 0.07 %, sys: 6.19 %, idle: 72.84 %, io: 0.10 %, irq: 0.00 %, sirq: 0.03 %
     2020-04-09 15:05:22   stat_cpu_diff   22215 167 6420 78101 64 0 112
     2020-04-09 15:05:22   stat_cpu_percent 20.75 0.16 6.00 72.94 0.06 0.00 0.10
     2020-04-09 15:05:22   stat_cpu_text   user: 20.75 %, nice: 0.16 %, sys: 6.00 %, idle: 72.94 %, io: 0.06 %, irq: 0.00 %, sirq: 0.10 %
     2020-04-09 15:05:22   swap            Total: 8167.00 MB, Used: 16.50 MB,  0.20 %, Free: 8150.50 MB
     2020-04-09 15:05:22   swap_used_stat  0.50 16.50 16.45
     2020-04-09 15:09:06   uptime          81667
     2020-04-09 15:09:06   uptime_text     0 days, 22 hours, 41 minutes
   helper:
     net_eth0_stat_class 1
     proc_fs    1
     sys_cpu0_freq 1
     sys_cpu0_temp 0
     sys_cpu1_freq 1
     sys_cpu1_temp 0
     sys_cpu2_freq 0
     sys_cpu2_temp 0
     sys_cpu3_freq 0
     sys_cpu3_temp 0
     sys_cpu4_freq 0
     sys_cpu4_temp 0
     sys_cpu5_freq 0
     sys_cpu5_temp 0
     sys_cpu6_freq 0
     sys_cpu6_temp 0
     sys_cpu7_freq 0
     sys_cpu7_temp 0
     sys_cpu_core_num 8192
     sys_cpu_freq_rpi_bbb 1
     sys_cpu_num 1
     sys_cpu_temp_bbb 0
     sys_cpu_temp_rpi 1
     sys_fb     0
     sys_power_ac 0
     sys_power_bat 0
     sys_power_usb 0
     u_first_mark 1
     cur_readings_map:
       cpu0_freq  CPU frequency (core 0)
       cpu0_freq_stat CPU frequency (core 0) stat
       cpu0_idle_stat CPU0 min/max/avg (idle)
       cpu1_freq  CPU frequency (core 1)
       cpu1_freq_stat CPU frequency (core 1) stat
       cpu1_idle_stat CPU1 min/max/avg (idle)
       cpu2_idle_stat CPU2 min/max/avg (idle)
       cpu3_idle_stat CPU3 min/max/avg (idle)
       cpu4_idle_stat CPU4 min/max/avg (idle)
       cpu5_idle_stat CPU5 min/max/avg (idle)
       cpu6_idle_stat CPU6 min/max/avg (idle)
       cpu7_idle_stat CPU7 min/max/avg (idle)
       cpu_bogomips BogoMIPS
       cpu_core_count Number of CPU cores
       cpu_freq   CPU frequency
       cpu_freq_stat CPU frequency stat
       cpu_idle_stat CPU min/max/avg (idle)
       cpu_model_name CPU model name
       cpu_temp   CPU temperature
       cpu_temp_avg Average CPU temperature
       cpu_temp_stat CPU temperature stat
       date       Date
       eth0       Ethernet
       eth0_diff  Ethernet (diff)
       eth0_ip    Ethernet (IP)
       eth0_ip6   Ethernet (IP6)
       eth0_rx    Ethernet (RX)
       eth0_speed Ethernet (speed)
       eth0_tx    Ethernet (TX)
       fhemstarttime Fhem start time
       fhemstarttime_text Fhem start time
       fhemuptime System up time
       fhemuptime_text FHEM up time
       fs_home    Home
       fs_home_free Home (free)
       fs_home_used Home (used)
       fs_home_used_percent Home (used %)
       fs_root    Root
       fs_root_free Root (free)
       fs_root_used Root (used)
       fs_root_used_percent Root (used %)
       idletime   Idle time
       idletime_text Idle time
       io_sda     TEST
       io_sda_diff TEST
       io_sda_raw TEST
       loadavg    Load average
       loadavg_1  Load average 1
       loadavg_15 Load average 15
       loadavg_5  Load average 5
       ram        RAM
       ram_free   RAM free
       ram_free_percent RAM free %
       ram_total  RAM total
       ram_used   RAM used
       ram_used_stat RAM used stat
       starttime  System start time
       starttime_text System start time
       stat_cpu   CPU statistics
       stat_cpu0  CPU0 statistics
       stat_cpu0_diff CPU0 statistics (diff)
       stat_cpu0_percent CPU0 statistics (diff, percent)
       stat_cpu0_text CPU0 statistics (text)
       stat_cpu1  CPU1 statistics
       stat_cpu1_diff CPU1 statistics (diff)
       stat_cpu1_percent CPU1 statistics (diff, percent)
       stat_cpu1_text CPU1 statistics (text)
       stat_cpu2  CPU2 statistics
       stat_cpu2_diff CPU2 statistics (diff)
       stat_cpu2_percent CPU2 statistics (diff, percent)
       stat_cpu2_text CPU2 statistics (text)
       stat_cpu3  CPU3 statistics
       stat_cpu3_diff CPU3 statistics (diff)
       stat_cpu3_percent CPU3 statistics (diff, percent)
       stat_cpu3_text CPU3 statistics (text)
       stat_cpu4  CPU4 statistics
       stat_cpu4_diff CPU4 statistics (diff)
       stat_cpu4_percent CPU4 statistics (diff, percent)
       stat_cpu4_text CPU4 statistics (text)
       stat_cpu5  CPU5 statistics
       stat_cpu5_diff CPU5 statistics (diff)
       stat_cpu5_percent CPU5 statistics (diff, percent)
       stat_cpu5_text CPU5 statistics (text)
       stat_cpu6  CPU6 statistics
       stat_cpu6_diff CPU6 statistics (diff)
       stat_cpu6_percent CPU6 statistics (diff, percent)
       stat_cpu6_text CPU6 statistics (text)
       stat_cpu7  CPU7 statistics
       stat_cpu7_diff CPU7 statistics (diff)
       stat_cpu7_percent CPU7 statistics (diff, percent)
       stat_cpu7_text CPU7 statistics (text)
       stat_cpu_diff CPU statistics (diff)
       stat_cpu_idle_percent CPU statistics idle %
       stat_cpu_io_percent CPU statistics io %
       stat_cpu_irq_percent CPU statistics irq %
       stat_cpu_nice_percent CPU statistics nice %
       stat_cpu_percent CPU statistics (diff, percent)
       stat_cpu_sirq_percent CPU statistics sirq %
       stat_cpu_sys_percent CPU statistics sys %
       stat_cpu_text CPU statistics (text)
       stat_cpu_user_percent CPU statistics user %
       swap       swap
       swap_free  swap free
       swap_total swap total
       swap_used  swap used
       swap_used_percent swap used %
       swap_used_stat swap used stat
       uptime_text System up time
     excludes:
     shadow_map:
       cpu0_freq  1400
       cpu0_freq_stat 948.00 1597.00 1511.66
       cpu0_idle_stat 52.35 84.03 72.60
       cpu1_freq  1428
       cpu1_freq_stat 812.00 1597.00 1512.60
       cpu1_idle_stat 46.85 83.66 72.45
       cpu_core_count 8192
       cpu_freq   1400
       cpu_freq_stat 948.00 1597.00 1511.66
       cpu_idle_stat 52.50 83.54 72.53
       cpu_temp   38.00
       cpu_temp_avg 40.1
       eth0       RX: 2114.42 MB, TX: 319.60 MB, Total: 2434.02 MB
       eth0_diff  RX: 24.96 MB, TX: 1.91 MB, Total: 26.87 MB
       eth0_rx    2217125590
       eth0_speed 1000
       eth0_tx    335130094
       fs_home    Total: 238640 MB, Used: 128536 MB, 57 %, Available: 97959 MB at /home
       fs_root    Total: 98345 MB, Used: 11008 MB, 12 %, Available: 82319 MB at /
       idletime   16 0.02 %
       loadavg    1.77 1.06 0.94
       ram        Total: 3551.02 MB, Used: 910.64 MB, 25.64 %, Free: 124.20 MB
       ram_used_stat 875.86 1096.15 913.66
       stat_cpu   2224375 48271 666090 13113050 10305 0 8731
       stat_cpu0  1115099 24243 321456 6560610 2328 0 6484
       stat_cpu0_diff 7809 127 2204 23261 9 0 64
       stat_cpu0_percent 23.33 0.38 6.58 69.49 0.03 0.00 0.19
       stat_cpu0_text user: 23.33 %, nice: 0.38 %, sys: 6.58 %, idle: 69.49 %, io: 0.03 %, irq: 0.00 %, sirq: 0.19 %
       stat_cpu1  1109276 24028 344634 6552440 7976 0 2246
       stat_cpu1_diff 7748 38 2342 23348 33 0 14
       stat_cpu1_percent 23.11 0.11 6.99 69.65 0.10 0.00 0.04
       stat_cpu1_text user: 23.11 %, nice: 0.11 %, sys: 6.99 %, idle: 69.65 %, io: 0.10 %, irq: 0.00 %, sirq: 0.04 %
       stat_cpu_diff 15556 165 4546 46609 42 0 78
       stat_cpu_percent 23.22 0.25 6.79 69.57 0.06 0.00 0.12
       stat_cpu_text user: 23.22 %, nice: 0.25 %, sys: 6.79 %, idle: 69.57 %, io: 0.06 %, irq: 0.00 %, sirq: 0.12 %
       uptime     81224
       uptime_text 0 days, 22 hours, 33 minutes
   disable    0
   event-on-update-reading cpu_temp,cpu_temp_avg,cpu_freq,eth0_diff,loadavg,ram,fs_.*
   filesystems fs_root:/:Root,fs_home:/home:Home
   group      PC
   icon       ubuntu
   network-interfaces eth0:eth0:Ethernet
   room       RZ
Ist ein entfernter Kubuntu 18.04.4 PC, also nicht der, auf dem FHEM läuft.
Dazu gehörend ist folgender weblink:
   DEF        htmlCode {SYSMON_ShowValuesHTML('sysmon_MP')}
   FUUID      5e8dbe87-f33f-1b22-9e97-a580882e8d3a70ec
   LINK       {SYSMON_ShowValuesHTML('sysmon_MP')}
   NAME       sysv1
   NR         17
   STATE      initialized
   TYPE       weblink
   WLTYPE     htmlCode
   disable    0
   group      PC
   room       RZ
Wenn ich nun in FHEM den Raum RZ 'betrete' (aufrufe) oder auch nur den Weblink aufrufe, dauert es bis zu 15 Sekunden bis die Seite aufgebaut ist.
Solange rotiert der entsprechende BrowserTab, wobei die CPU vom FHEM Rechner nicht irgendwie besonders belastet wird.
Wenn ich einen SYMON mit weblink für den FHEM PC selbst, also lokal, benutze, tritt keine Verzögerung auf.
Ich hatte den SYSMON auch schon mit telnet am Laufen, aber da gefiel mir nicht, dass der entfernte PC ca. 150-200 DNS Abfragen für dem FHEM Rechner innerhalb von 10 Minuten 'abfeuert' und dies dauerhaft (lässt sich mit einem Pi-hole gut verfolgen).
Ich würde nun gerne wissen, was die Verzögerung verursacht, ob ich das abstellen kann, oder ob ich ohne den weblink auskommen muss.
decade-submarginal
