Autor Thema: svn on macos issue (solved)  (Gelesen 371 mal)
Offline immi
  • Sr. Member
« am: 19 April 2020, 15:39:58 »
Dear all
If you (like me) enconter issues with the standard macos OpenSSH_8.1p1, LibreSSL 2.7.3
install the brew version OpenSSH_8.2p1, OpenSSL 1.1.1f
and redirect svn with export SVN_SSH=/usr/local/bin/ssh
or just revert to an older version.
maybe it helps; I lost 3 hours today  8)
immi
Informativ Informativ x 1 Liste anzeigen
Offline betateilchen
  • s/fhem\.cfg/configDB/g
Antw:svn on macos issue (solved)
« Antwort #1 am: 19 April 2020, 16:41:26 »
~ % ssh -V
No problems here: macOS 10.15.4 (19E287).
But starting some macOS updates ago, I had to change access rights from 600 to 400 for fhem-ssh-keyfile to get ssh working again.
Unaufgeforderte Anfragen per email werden von mir nicht beantwortet. Dafür ist das Forum da.
Offline rudolfkoenig
  • Administrator
« Antwort #2 am: 19 April 2020, 16:59:41 »
I'm wondering what type of security issue should that requirement fix.
Offline zap
    • HMCCU
« Antwort #3 am: 21 April 2020, 18:58:58 »
Apple removed the svn utilities with the last MacOS / XCode update. That's why one needs to install svn from homebrew repository.
2xCCU3, diverse Komponenten (Fenster, Rolladen, Themostate, Stromzähler, Steckdosen ...)
FHEM mit Raspi für CCU Integration.
IOBroker für UI (VIS), Hue, Sonos usw.
Maintainer der Module FULLY, Meteohub und HMCCU (Schnittstelle CCU-FHEM = best of both worlds approach
Offline justme1968
« Antwort #4 am: 22 April 2020, 16:53:23 »
no. you have to install xcode and then the xcode commandline tools. svn ist still included there.
if you type svn there should even be a message about this.
« Letzte Änderung: 22 April 2020, 20:59:02 von justme1968 »
FS20:fs20as4,fs20bs,fs20di
AKCP:THS01,WS15
CUL_WS:S300TH
