svn on macos issue (solved)
Begonnen von immi, 19 April 2020, 15:39:58
immi
Dear all
If you (like me) enconter issues with the standard macos OpenSSH_8.1p1, LibreSSL 2.7.3
install the brew version OpenSSH_8.2p1, OpenSSL 1.1.1f
and redirect svn with export SVN_SSH=/usr/local/bin/ssh
or just revert to an older version.
maybe it helps; I lost 3 hours today  8)
immi
betateilchen
~ % ssh -V
No problems here: macOS 10.15.4 (19E287).
But starting some macOS updates ago, I had to change access rights from 600 to 400 for fhem-ssh-keyfile to get ssh working again.
rudolfkoenig
I'm wondering what type of security issue should that requirement fix.
zap
Apple removed the svn utilities with the last MacOS / XCode update. That's why one needs to install svn from homebrew repository.
2xCCU3, Fenster, Rollläden, Themostate, Stromzähler, Steckdosen ...)
Entwicklung: FHEM auf AMD NUC (Ubuntu)
Maintainer: FULLY, Meteohub, HMCCU, AndroidDB
justme1968
#4
no. you have to install xcode and then the xcode commandline tools. svn ist still included there.
if you type svn there should even be a message about this.
