[erledigt] seit 23.5.20 cul_hm warnings in rauhen mengen
Begonnen von the ratman, 23 Mai 2020, 09:34:45
the ratman
folgendes warning kommt seit dem heutigen update2020.05.23 09:29:19 1:  PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 4188.
2020.05.23 09:29:19 1:  stacktrace:
2020.05.23 09:29:19 1:      main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (4188)
2020.05.23 09:29:19 1:      main::CUL_HM_SetList                called by ./FHEM/10_CUL_HM.pm (4254)
2020.05.23 09:29:19 1:      main::CUL_HM_Set                    called by fhem.pl (3789)
2020.05.23 09:29:19 1:      main::CallFn                        called by fhem.pl (1897)
2020.05.23 09:29:19 1:      main::DoSet                         called by fhem.pl (1939)
2020.05.23 09:29:19 1:      main::CommandSet                    called by fhem.pl (2751)
2020.05.23 09:29:19 1:      main::getAllSets                    called by ./FHEM/01_FHEMWEB.pm (3203)
2020.05.23 09:29:19 1:      main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (1826)
2020.05.23 09:29:19 1:      main::FW_makeDeviceLine             called by ./FHEM/01_FHEMWEB.pm (1999)
2020.05.23 09:29:19 1:      main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (1165)
2020.05.23 09:29:19 1:      main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (590)
2020.05.23 09:29:19 1:      main::FW_Read                       called by fhem.pl (3789)
2020.05.23 09:29:19 1:      main::CallFn                        called by fhem.pl (760)
ein rückspielen der alten cul_hm löst das problem erst mal ...
→do↑p!dnʇs↓shit←
The-Holgi
bei mir auch:
2020.05.23 10:48:48.152 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/10_CUL_HM.pm line 4161.
2020.05.23 10:48:48.152 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 4188.
2020.05.23 10:48:48.152 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/10_CUL_HM.pm line 4188.
2020.05.23 10:48:48.160 1: PERL WARNING: Use of uninitialized value $peer in pattern match (m//) at ./FHEM/10_CUL_HM.pm line 8360.
2020.05.23 10:48:48.160 1: PERL WARNING: Use of uninitialized value $peer in string eq at ./FHEM/10_CUL_HM.pm line 8361.
2020.05.23 10:48:48.160 1: PERL WARNING: Use of uninitialized value $peer in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 8361.
2020.05.23 10:48:48.161 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 4195.
HP T610 Thin Client; Docker Fhem 5.9; 2X CUL V3 868mhz; Max Heizungssteuerung; FS20kse; FS20UWS; FS20S8-3; 2 FS20DI; HM-CFG-LAN,HM-LC-SW1-PL,HM-SEC-SD, HM-SE1PBU-FM;
Harmony Hub;Hue-Bridge mit Iris, E27 Bulb & FLS-PP
martinp876
Fix ist eingecheckt.
Sorry, für den Bug...
Ich habe keine errors/warnings mehr gesehen.
the ratman
→do↑p!dnʇs↓shit←
frank
moin,
die heutige version 22013 erzeugt mit hminfo configCheck noch folgende warning:
Zitat2020.05.23 13:08:04.505 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 8790.
2020.05.23 13:08:04.505 1: stacktrace:
2020.05.23 13:08:04.506 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (8790)
2020.05.23 13:08:04.506 1:     main::CUL_HM_getRegInfo             called by ./FHEM/10_CUL_HM.pm (3964)
2020.05.23 13:08:04.506 1:     main::CUL_HM_Get                    called by ./FHEM/98_HMinfo.pm (624)
2020.05.23 13:08:04.507 1:     main::HMinfo_burstCheck             called by ./FHEM/98_HMinfo.pm (2411)
2020.05.23 13:08:04.507 1:     main::HMinfo_configCheck            called by FHEM/Blocking.pm (194)
2020.05.23 13:08:04.507 1:     main::BlockingStart                 called by FHEM/Blocking.pm (107)
2020.05.23 13:08:04.507 1:     main::BlockingCall                  called by ./FHEM/98_HMinfo.pm (1324)
2020.05.23 13:08:04.508 1:     main::HMinfo_GetFn                  called by fhem.pl (3761)
2020.05.23 13:08:04.508 1:     main::CallFn                        called by fhem.pl (1964)
2020.05.23 13:08:04.508 1:     main::CommandGet                    called by fhem.pl (1245)
2020.05.23 13:08:04.509 1:     main::AnalyzeCommand                called by fhem.pl (1098)
2020.05.23 13:08:04.509 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2688)
2020.05.23 13:08:04.509 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (914)
2020.05.23 13:08:04.510 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (583)
2020.05.23 13:08:04.510 1:     main::FW_Read                       called by fhem.pl (3761)
2020.05.23 13:08:04.510 1:     main::CallFn                        called by fhem.pl (756)
FHEM: 6.0(SVN) => Pi3(buster)
The-Holgi
the ratman
die sache scheint noch ned ganz ausgestanden ... ne stunde nach dem update heute kommt einmalig:2020.05.24 08:18:23 1:  logfile wurde gelöscht
2020.05.24 09:19:39 1:  PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 3461.
2020.05.24 09:19:39 1:  stacktrace:
2020.05.24 09:19:39 1:      main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (3461)
2020.05.24 09:19:39 1:      main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1542)
2020.05.24 09:19:39 1:      main::CUL_HM_Parse                  called by fhem.pl (3985)
2020.05.24 09:19:39 1:      main::Dispatch                      called by ./FHEM/00_HMUARTLGW.pm (1463)
2020.05.24 09:19:39 1:      main::HMUARTLGW_Parse               called by ./FHEM/00_HMUARTLGW.pm (1566)
2020.05.24 09:19:39 1:      main::HMUARTLGW_Read                called by fhem.pl (3789)
2020.05.24 09:19:39 1:      main::CallFn                        called by fhem.pl (760)
2020.05.24 09:19:39 1:  waiting for: , got:RegisterRead # await msgNo:, rec:3
→do↑p!dnʇs↓shit←
martinp876
good catch.
Hatte nichts mit der Änderung zu tun, ist auch nur kosmetisch und schon sehr lange im Code.
Ist korrigiert und eingecheckt ( nicht einfsch zu testen...)
the ratman
na wunderbar - thx fürs schnelle reagieren.
ich mach das mal auf erledigt wieder und lass dann morgen auch so, sollt er wider erwarten noch einmal aufmucken ...
→do↑p!dnʇs↓shit←
Loki
Hatte den Fehler auch, danke für's schnelle fixen!  8)
