FHEM > English Corner
How to use an "at" command with a "Perl" command?
(1/2) > >>
Fonz:
I would like to use the Twilight module.
I know its working because I can type...
--- Zitat ---get myTwilight ss_indoor
--- Ende Zitat ---
Into the Fhem web interface, and it returns a time.
However I am unsure of the syntax to use with a "at" command as...
--- Zitat ---define b6 at *{myTwilight ss_indoor} set Lamp on
--- Ende Zitat ---
Does not work.
Could anyone help me with the syntax for this please?
Many thanks,
Fonz
Guido:
Hello Fonz,
for me it works as follows
define b6 at *{ReadingsVal("myTwilight","ss_indoor","00:00:00")} set Lamp on;;set Rolos off
Fonz:
Thank you!
That worked...
One more question if you its not too much trouble.
How could I then add or subtract a few minuets to this time, to get my lights exactly when I want them?
Thank you again,
Fonz
jhohn:
Maybe http://fhem.de/commandref.html#SUNRISE_EL is what you are looking for?
Fonz:
Thank You Jhohn.
I was more looking to take 7 minuets away from the weather calculated Twilight time.
I find the time is very accurate, but due to a large tree my room gets dark 7 minuets before hand.
Regards,
Fonz
Navigation
[0] Themen-Index
[#] Nächste Seite
Zur normalen Ansicht wechseln
