gelöst: Update scheint nicht zu klappen
Begonnen von FHEM-User22, 12 Juli 2020, 09:39:54
FHEM-User22
Hallo an alle,
ich versuche meinen FHEM zu updaten.
Die Ausgabe:
2020.07.12 08:53:57 2 : backup include:
2020.07.12 08:53:57 2 : Backup with command: tar czf ./backup/FHEM-20200712_085357.tar.gz "./2020.ics" "./ZWDongle_0.bin" "./unused" "./AlarmFILE" "./db.conf" "./CHANGED" "./configDB.pm" "./YAAHMFILE" "./Abfall-2020.ics" "./docs" "./contrib" "./fhem.cfg.demo" "./restoreDir" "./README_DEMO.txt" "./demolog" "./credentials" "./fhem.pl" "./MAINTAINER.txt" "./fhem.cfg" "./fhem.cfg-old" "./www" "./log" "./FHEM"
2020.07.12 08:54:09 1 : backup tar: ./log/SB_PLAYER_Zero01-2020.log: file changed as we read it
2020.07.12 08:54:09 1 : backup done: FHEM-20200712_085357.tar.gz (89912317 Bytes)
2020.07.12 08:54:09 1 : fhem
2020.07.12 08:54:09 1 : RMDIR: ./restoreDir/update/2020-06-22
2020.07.12 08:54:09 1 : UPD ./CHANGED
2020.07.12 08:54:09 1 : UPD ./MAINTAINER.txt
2020.07.12 08:54:09 1 : UPD ./configDB.pm
2020.07.12 08:54:09 1 : UPD ./fhem.pl
2020.07.12 08:54:09 1 : UPD FHEM/00_CUL.pm
2020.07.12 08:54:09 1 : UPD FHEM/00_FHZ.pm
2020.07.12 08:54:09 1 : UPD FHEM/00_KNXTUL.pm
2020.07.12 08:54:09 1 : UPD FHEM/00_MQTT.pm
2020.07.12 08:54:09 1 : UPD FHEM/00_MQTT2_CLIENT.pm
2020.07.12 08:54:09 1 : UPD FHEM/00_MQTT2_SERVER.pm
2020.07.12 08:54:10 1 : UPD FHEM/00_MYSENSORS.pm
2020.07.12 08:54:10 1 : UPD FHEM/00_SIGNALduino.pm
2020.07.12 08:54:10 1 : UPD FHEM/00_SONOS.pm
2020.07.12 08:54:10 1 : UPD FHEM/00_THZ.pm
2020.07.12 08:54:10 1 : UPD FHEM/00_ZWDongle.pm
2020.07.12 08:54:10 1 : UPD FHEM/01_FHEMWEB.pm
Danach mache ich wieder ein Update:
2020.07.12 09:09:59 2 : backup include:
2020.07.12 09:09:59 2 : Backup with command: tar czf ./backup/FHEM-20200712_090959.tar.gz "./docs" "./Abfall-2020.ics" "./YAAHMFILE" "./configDB.pm" "./contrib" "./unused" "./ZWDongle_0.bin" "./2020.ics" "./CHANGED" "./db.conf" "./AlarmFILE" "./FHEM" "./log" "./www" "./fhem.cfg-old" "./demolog" "./README_DEMO.txt" "./restoreDir" "./fhem.cfg.demo" "./fhem.cfg" "./MAINTAINER.txt" "./credentials" "./fhem.pl"
2020.07.12 09:10:01 1 : v2202002113764108479.happysrv.de:1883 disconnected, waiting to reappear (mqtt2c)
2020.07.12 09:10:01 1 : v2202002113764108479.happysrv.de:1883 reappeared (mqtt2c)
2020.07.12 09:10:01 2 : SIP_ISG, cant find listen process 30860 in process list !
2020.07.12 09:10:11 1 : backup done: FHEM-20200712_090959.tar.gz (90047987 Bytes)
2020.07.12 09:10:11 1 : fhem
2020.07.12 09:10:11 1 : UPD ./CHANGED
2020.07.12 09:10:11 1 : UPD ./MAINTAINER.txt
2020.07.12 09:10:11 1 : UPD ./configDB.pm
2020.07.12 09:10:11 1 : UPD ./fhem.pl
2020.07.12 09:10:11 1 : UPD FHEM/00_CUL.pm
2020.07.12 09:10:11 1 : UPD FHEM/00_FHZ.pm
2020.07.12 09:10:11 1 : UPD FHEM/00_KNXTUL.pm
2020.07.12 09:10:11 1 : UPD FHEM/00_MQTT.pm
2020.07.12 09:10:11 1 : UPD FHEM/00_MQTT2_CLIENT.pm
2020.07.12 09:10:12 1 : UPD FHEM/00_MQTT2_SERVER.pm
2020.07.12 09:10:12 1 : UPD FHEM/00_MYSENSORS.pm
2020.07.12 09:10:12 1 : UPD FHEM/00_SIGNALduino.pm
2020.07.12 09:10:12 1 : UPD FHEM/00_SONOS.pm
2020.07.12 09:10:12 1 : UPD FHEM/00_THZ.pm
2020.07.12 09:10:12 1 : UPD FHEM/00_ZWDongle.pm
2020.07.12 09:10:12 1 : UPD FHEM/01_FHEMWEB.pm
Für mich sieht es so aus, als hätte er nichts gemacht. Sollte nicht "nothing to do" kommen? Auch finde ich den Hinweis auf "shutdown restart" nicht.
Wo könnte der Fehler sein?
Mein FHEM läuft auf Proxmox. Vor einiger Zeit musste ich mal ein komplettes restore im Proxmox mit FHEM machen.  Danach war die fhem.cfg nicht speicherbar. Nachdem ich sie wieder auf fhem und dialout gesetzt hatte ging es wieder.
Könnte es auch hier der Fehler sein? Und wenn ja, bräuchte ich dazu Hilfe.
Dankeschön und einen schönen Sonntag.
FHEM auf Raspberry Pi und Proxmox und... und.... und....
MadMax-FHEM
Poste doch mal:
ls -la /opt/fhem
Und:
ls -la /opt/fhem/FHEM
Vielleicht sind weitere Rechte/Besitzverhältnisse "durcheinander"...
"Schnellschuss" ohne "Analyse" wäre:
sudo chown -R fhem:dialout /opt/fhem
Gruß, Joachim
FHEM PI3 Buster (Test)
FHEM-User22
Hallo Joachim,
Gruß, Joachim
Super, Danke für den Schnellschuß. Jetzt scheint es zu funktionieren!
Dankeschön und einen schönen Sonntag!
MadMax-FHEM
Gerne!
Nächstes mal beim "Rumbasteln" (mit Besitzverhältnissen) aufpassen ;)
Dann kannst du ja ein [gelöst] vorne dran setzen, danke.
Gruß, Joachim
FHEM-User22
Hallo Joachim,
Gruß, Joachim
Mit Proxmox-Bordmitteln einfach eine Sicherung von gestern wiederherstellen kommt mir nicht vor wie rumbasteln. Bei allen anderen VM-Maschinen klappt es ja auch ohne Probleme. Keine Ahnung, warum hier nicht.
