FHEM > English Corner
FHem connect to he853 made by Elro (homeeasy)
(1/1)
Schuif:
Hi there,
I am a totally new user of FHEM and am trying to connect my usb transmitter (he853) to FHEM.
what is the way to do that?
Eric
http://www.elro.eu/en/products/category/home_automation/home_easy/zenders2/pc_afstandsbediening_usb_dongle
andyclimb:
--- Zitat von: Schuif schrieb am Do, 28 Februar 2013 21:03 ---Hi there,
Eric
--- Ende Zitat ---
I'm not sure you will have any luck with this easily. It's not in the list of supported hardware...only the rfxcom devices support 433mhz as far as I can see.  I could well be wrong though.  I new to this stuff.
A
Schuif:
the following information is what i have been able to get from the usb-stick:
Willi:
--- Zitat von: Schuif schrieb am Fr, 01 März 2013 16:03 ---the following information is what i have been able to get from the usb-stick:
--- Ende Zitat ---
I think you have to find out how handshake and protocols work for this stick and write your own FHEM drivers.
Maybe you can get an SDK from HomeEasy? Try to contact the vendor.
Try google to find out if someone else has already archived to talk to this stick (As far as I know nobody is using it with FHEM wight now)
The first results point to a projects like
  http://he853control.sourceforge.net/
Maybe you can understand how it works looking at this source code,
Or you just buy a RFXtrx433 from RFXCOm which speaks most of the HomeEasy stuff. To be sure ask RFXCOM before you buy it.
Regards Willi
Navigation
[0] Themen-Index
Zur normalen Ansicht wechseln
