Hallo Martin,
anbei ein paar Messages.
a) bei Aktion
[code]
## Aktor/sensor Log
2013-03-28_21:02:36 Test4Martin contact: closed (to broadcast)
2013-03-28_21:34:39 Test4Martin open
2013-03-28_21:34:39 Test4Martin contact: open (to FL_Thermostat)
2013-03-28_21:34:43 Test4Martin closed
2013-03-28_21:34:43 Test4Martin contact: closed (to FL_Thermostat)
2013-03-28_21:34:51 Test4Martin open
2013-03-28_21:34:51 Test4Martin contact: open (to FL_Thermostat)
2013-03-28_21:35:02 Test4Martin closed
2013-03-28_21:35:02 Test4Martin contact: closed (to FL_Thermostat)
## FHEM Log
2013.03.28 21:02:35 5: HMLAN/RAW: /E1E3145,0000,05226B4B,FF,FFB8,5E96101E314500000006010000
2013.03.28 21:02:35 5: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:05226B4B d:FF r:FFB8 m:5E96101E314500000006010000
2013.03.28 21:02:35 5: HMLANAMA dispatch A0D5E96101E314500000006010000::-72:HMLANAMA
2013.03.28 21:02:35 5: Triggering Test4Martin (5 changes)
2013.03.28 21:02:35 5: Notify loop for Test4Martin alive: yes
2013.03.28 21:34:39 5: HMLAN/RAW: /E1E3145,0000,053FC7A2,FF,FFB9,5FB4411E31451D2AA1013FC8
2013.03.28 21:34:39 5: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:053FC7A2 d:FF r:FFB9 m:5FB4411E31451D2AA1013FC8
2013.03.28 21:34:39 5: HMLANAMA dispatch A0C5FB4411E31451D2AA1013FC8::-71:HMLANAMA
2013.03.28 21:34:39 5: Triggering Test4Martin (2 changes)
2013.03.28 21:34:39 5: Notify loop for Test4Martin open
2013.03.28 21:34:40 5: HMLAN/RAW: /E1D2AA1,0000,053FC822,FF,FFBC,5F80021D2AA11E314500
2013.03.28 21:34:40 5: HMLAN_Parse: HMLANAMA S:E1D2AA1 stat:0000 t:053FC822 d:FF r:FFBC m:5F80021D2AA11E314500
2013.03.28 21:34:40 5: HMLANAMA dispatch A0A5F80021D2AA11E314500::-68:HMLANAMA
2013.03.28 21:34:43 5: HMLAN/RAW: /E1E3145,0000,053FD456,FF,FFB2,60B4411E31451D2AA1014000
2013.03.28 21:34:43 5: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:053FD456 d:FF r:FFB2 m:60B4411E31451D2AA1014000
2013.03.28 21:34:43 5: HMLANAMA dispatch A0C60B4411E31451D2AA1014000::-78:HMLANAMA
2013.03.28 21:34:43 5: Triggering Test4Martin (2 changes)
2013.03.28 21:34:43 5: Notify loop for Test4Martin closed
2013.03.28 21:34:43 5: HMLAN/RAW: /E1D2AA1,0000,053FD4D7,FF,FFBD,6080021D2AA11E314500
2013.03.28 21:34:43 5: HMLAN_Parse: HMLANAMA S:E1D2AA1 stat:0000 t:053FD4D7 d:FF r:FFBD m:6080021D2AA11E314500
2013.03.28 21:34:43 5: HMLANAMA dispatch A0A6080021D2AA11E314500::-67:HMLANAMA
2013.03.28 21:34:51 5: HMLAN/RAW: /E1E3145,0000,053FF684,FF,FFBE,61B4411E31451D2AA10141C8
2013.03.28 21:34:51 5: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:053FF684 d:FF r:FFBE m:61B4411E31451D2AA10141C8
2013.03.28 21:34:51 5: HMLANAMA dispatch A0C61B4411E31451D2AA10141C8::-66:HMLANAMA
2013.03.28 21:34:51 5: Triggering Test4Martin (2 changes)
2013.03.28 21:34:51 5: Notify loop for Test4Martin open
2013.03.28 21:34:52 5: HMLAN/RAW: /E1D2AA1,0000,053FF705,FF,FFBB,6180021D2AA11E314500
2013.03.28 21:34:52 5: HMLAN_Parse: HMLANAMA S:E1D2AA1 stat:0000 t:053FF705 d:FF r:FFBB m:6180021D2AA11E314500
2013.03.28 21:34:52 5: HMLANAMA dispatch A0A6180021D2AA11E314500::-69:HMLANAMA
2013.03.28 21:35:00 5: HMLAN_Send: K
2013.03.28 21:35:00 5: HMLAN/RAW: /HHM-LAN-IF,03C1,0123456789,1ACA40,D496B0,05401850,000B
2013.03.28 21:35:00 5: HMLAN_Parse: HMLANAMA V:03C1 sNo:0123456789 d:1ACA40 O:D496B0 m:05401850 IDcnt:000B
2013.03.28 21:35:02 5: HMLAN/RAW: /E1E3145,0000,05401E92,FF,FFBE,62B4411E31451D2AA1014200
2013.03.28 21:35:02 5: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:05401E92 d:FF r:FFBE m:62B4411E31451D2AA1014200
2013.03.28 21:35:02 5: HMLANAMA dispatch A0C62B4411E31451D2AA1014200::-66:HMLANAMA
2013.03.28 21:35:02 5: Triggering Test4Martin (2 changes)
2013.03.28 21:35:02 5: Notify loop for Test4Martin closed
2013.03.28 21:35:02 5: HMLAN/RAW: /E1D2AA1,0000,05401F13,FF,FFBD,6280021D2AA11E314500
2013.03.28 21:35:02 5: HMLAN_Parse: HMLANAMA S:E1D2AA1 stat:0000 t:05401F13 d:FF r:FFBD m:6280021D2AA11E314500
2013.03.28 21:35:02 5: HMLANAMA dispatch A0A6280021D2AA11E314500::-67:HMLANAMA
2013.03.28 21:35:13 5: HMLAN/RAW: /E1D2AA1,0000,05404C2D,FF,FFBC,E886701D2AA100000000D830
2013.03.28 21:35:13 5: HMLAN_Parse: HMLANAMA S:E1D2AA1 stat:0000 t:05404C2D d:FF r:FFBC m:E886701D2AA100000000D830
2013.03.28 21:35:13 5: HMLANAMA dispatch A0CE886701D2AA100000000D830::-68:HMLANAMA
[/code]
b) zyklisch (cyclicInfoMsg "on")
[code]
## Aktor/sensor Log
2013-03-20_22:16:49 Test4Martin alive: yes
2013-03-20_22:16:49 Test4Martin battery: ok
2013-03-20_22:16:49 Test4Martin cover: closed
2013-03-20_22:16:49 Test4Martin closed
2013-03-20_22:16:49 Test4Martin contact: closed (to broadcast)
## FHEM Log
2013.03.20 22:16:49 1: HMLAN/RAW: /E1E3145,0000,17677BBE,FF,FFBA,5696101E314500000006010000
2013.03.20 22:16:49 1: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:17677BBE d:FF r:FFBA m:5696101E314500000006010000
2013.03.20 22:16:49 5: HMLANAMA dispatch A0D5696101E314500000006010000::-70:HMLANAMA
2013.03.20 22:16:49 1: RCV L:0D N:56 F:96 CMD:10 SRC:1E3145 DST:broadcast 06010000 (INFO_ACTUATOR_STATUS) (,WAKEMEUP,CFG,BURST,RPTEN)
2013.03.20 22:16:49 5: Triggering Test4Martin (5 changes)
2013.03.20 22:16:49 5: Notify loop for Test4Martin alive: yes
## Aktor/sensor Log
2013-03-21_22:07:26 Test4Martin alive: yes
2013-03-21_22:07:26 Test4Martin battery: ok
2013-03-21_22:07:26 Test4Martin cover: closed
2013-03-21_22:07:26 Test4Martin closed
2013-03-21_22:07:26 Test4Martin contact: closed (to broadcast)
## FHEM Log
2013.03.21 22:07:26 1: HMLAN/RAW: /E1E3145,0000,1C8569B9,FF,FFBF,5796101E314500000006010000
2013.03.21 22:07:26 1: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:1C8569B9 d:FF r:FFBF m:5796101E314500000006010000
2013.03.21 22:07:26 5: HMLANAMA dispatch A0D5796101E314500000006010000::-65:HMLANAMA
2013.03.21 22:07:26 1: RCV L:0D N:57 F:96 CMD:10 SRC:1E3145 DST:broadcast 06010000 (INFO_ACTUATOR_STATUS) (,WAKEMEUP,CFG,BURST,RPTEN)
2013.03.21 22:07:26 5: Triggering Test4Martin (5 changes)
2013.03.21 22:07:26 5: Notify loop for Test4Martin alive: yes
## Aktor/sensor Log
2013-03-22_21:57:50 Test4Martin alive: yes
2013-03-22_21:57:50 Test4Martin battery: ok
2013-03-22_21:57:50 Test4Martin cover: closed
2013-03-22_21:57:50 Test4Martin closed
2013-03-22_21:57:50 Test4Martin contact: closed (to broadcast)
## FHEM Log
2013.03.22 21:57:50 5: HMLAN/RAW: /E1E3145,0000,21A31D75,FF,FFBF,5896101E314500000006010000
2013.03.22 21:57:50 5: HMLAN_Parse: HMLANAMA S:E1E3145 stat:0000 t:21A31D75 d:FF r:FFBF m:5896101E314500000006010000
2013.03.22 21:57:50 5: HMLANAMA dispatch A0D5896101E314500000006010000::-65:HMLANAMA
2013.03.22 21:57:50 5: Triggering Test4Martin (5 changes)
2013.03.22 21:57:50 5: Notify loop for Test4Martin alive: yes
[/code]
Vielleicht auch interessant - die zyklischen Messages kommen nach ca. 23:50h
2013-03-23_21:48:56 Test4Martin alive: yes
2013-03-23_21:48:56 Test4Martin battery: ok
2013-03-23_21:48:56 Test4Martin cover: closed
2013-03-23_21:48:56 Test4Martin closed
2013-03-23_21:48:56 Test4Martin contact: closed (to broadcast)
2013-03-24_21:39:49 Test4Martin alive: yes
2013-03-24_21:39:49 Test4Martin battery: ok
2013-03-24_21:39:49 Test4Martin cover: closed
2013-03-24_21:39:49 Test4Martin closed
2013-03-24_21:39:49 Test4Martin contact: closed (to broadcast)
2013-03-25_21:30:29 Test4Martin alive: yes
2013-03-25_21:30:29 Test4Martin battery: ok
2013-03-25_21:30:29 Test4Martin cover: closed
2013-03-25_21:30:29 Test4Martin closed
2013-03-25_21:30:29 Test4Martin contact: closed (to broadcast)
2013-03-26_21:21:05 Test4Martin alive: yes
2013-03-26_21:21:05 Test4Martin battery: ok
2013-03-26_21:21:05 Test4Martin cover: closed
2013-03-26_21:21:05 Test4Martin closed
2013-03-26_21:21:05 Test4Martin contact: closed (to broadcast)
2013-03-27_21:11:28 Test4Martin alive: yes
2013-03-27_21:11:28 Test4Martin battery: ok
2013-03-27_21:11:28 Test4Martin cover: closed
2013-03-27_21:11:28 Test4Martin closed
2013-03-27_21:11:28 Test4Martin contact: closed (to broadcast)
2013-03-28_21:02:36 Test4Martin alive: yes
2013-03-28_21:02:36 Test4Martin battery: ok
2013-03-28_21:02:36 Test4Martin cover: closed
2013-03-28_21:02:36 Test4Martin closed
Weiterhin anzumerken ist, dass der HM-Sec-SC mit HM-CC-TC gepairt ist.
Ich hoffe es hilft bei der Aufklärung.
Arthur
