Autor Thema: Add support for Elko Wireless  (Gelesen 3288 mal)
ubernoob
  • Gast
« am: 19 März 2013, 10:11:43 »
Hi!
ELKO (elko.no) is the largest manufacturer of electrical products in Norway. Unfortunately they don't have any good system for controlling it from a computer or a mobile. So I would like to try to add support for Elko wireless in FHEM.
I know they use:
Frequency 868 MHz
GFSK modulation
Data rate 2,4 kbps
I have bought a CUL v3.2 device from busware.de Uploaded firmware to the device from http://culfw.de/culfw.html
I have also installed FHEM on a Raspberry Pi, so I should be all set to go.
But now I'm stuck. I need to set the device to listen to 868Mhz, and try to reverse engineer the protocol or try to record and duplicate the signals so I can control my lights from the machine.
Any suggestions where to go from here?
ubernoob
  • Gast
Aw: Add support for Elko Wireless
« Antwort #1 am: 20 März 2013, 22:40:49 »
Would it help if you could get ssh access to the raspberry pi?
Offline rudolfkoenig
  • Administrator
« Antwort #2 am: 26 März 2013, 13:53:20 »
Hi ubernoob.
Warning: this is most probably hard work, and it is possible that the CUL is not able to decode the signals correctly.
If you still want to try:
- try to find a CC11xx parameter configuration for the protocol on the web. Since there are no obvious OpenSource projects, I think you wont find any.
Gathering as much information as possible will help you for the next tasks.
- Read the CC1101.pdf from TI, and try out the freely available Windows SmartRF-Studio software.
- Configure the CC1101 like SlowRF in culfw does, but with 2.4kHz datarate and GFSK, so your code will receive an interrupt for each signal-level-change
- If this works, then you'll get an "edge-stream". Create a log for some telegrams, and figure out how a bit is coded, how many preambel and sync-bits there are, what is the parity/checksum.
- If this is understood, and you're lucky (and know the CC1101 configuration well), then configure the CC1101 to packet mode, so you'll get readily analyzed bytes from the CC1101.
- Probably you wont be lucky, and have to analyze the bits in C-Code, like it is done in the SlowRF part of culfw for FS20/EM/TX/etc. 2.4 kHz should be manageable for the 8MHz CUL.
In the meantime I would try some social engineering with Elko :)
Regards,
  Rudi
