Autor Thema: Fritz Dect 440 in fhem einbinden  (Gelesen 6276 mal)
Offline Bucklew
  • New Member
Antw:Fritz Dect 440 in fhem einbinden
« Antwort #30 am: 21 April 2021, 10:46:30 »
Hallo Rudolf,
habe perl 5.30 (Ubuntu 20.04.2 LTS):
This is perl 5, version 30, subversion 0 (v5.30.0) built for x86_64-linux-gnu-thread-multi
Hab jetzt diesen Code:
    450   if($h{lastpressedtimestamp}) { # Dect400/#94700, 440/#118303
    451     sub dp($$;$);
    452     sub dp($$;$) {
    453       my ($txt,$h,$ln) = (@_);
Und leider wieder einen Fehler:
2021.04.21 10:45:04 1: PERL WARNING: Prototype mismatch: sub main::dp ($$$) vs ($$;$) at ./FHEM/10_FBDECT.pm line 451, <$fh> line 131.
2021.04.21 10:45:04 1: reload: Error:Modul 10_FBDECT deactivated:
 Not enough arguments for main::dp at ./FHEM/10_FBDECT.pm line 460, near "$h) "
Not enough arguments for main::dp at ./FHEM/10_FBDECT.pm line 463, near "%h)"
2021.04.21 10:45:04 0: Not enough arguments for main::dp at ./FHEM/10_FBDECT.pm line 460, near "$h) "
2021.04.21 10:45:04 1: PERL WARNING: Subroutine FBDECT_Initialize redefined at ./FHEM/10_FBDECT.pm line 41, <$fh> line 144.
2021.04.21 10:45:04 1: PERL WARNING: Subroutine FBDECT_Define redefined at ./FHEM/10_FBDECT.pm line 65, <$fh> line 144.
2021.04.21 10:45:04 1: PERL WARNING: Subroutine FBDECT_SetHttp redefined at ./FHEM/10_FBDECT.pm line 91, <$fh> line 144.
2021.04.21 10:45:04 1: PERL WARNING: Subroutine FBDECT_Set redefined at ./FHEM/10_FBDECT.pm line 300, <$fh> line 144.
2021.04.21 10:45:04 1: PERL WARNING: Subroutine FBDECT_Get redefined at ./FHEM/10_FBDECT.pm line 342, <$fh> line 144.
Offline rudolfkoenig
  • Administrator
« Antwort #31 am: 21 April 2021, 14:31:05 »
Merkwuerdig. Kannst Du es bitte mit der angehaengten Version nochmal testen?
Offline Bucklew
  • New Member
« Antwort #32 am: 21 April 2021, 15:01:45 »
Ja ist auch merkwürdig, funktioniert leider immer noch nicht:
2021.04.21 15:00:47 1: reload: Error:Modul 10_FBDECT deactivated:
2021.04.21 15:00:47 0: Not enough arguments for main::dp at ./FHEM/10_FBDECT.pm line 460, near "$h) "
2021.04.21 15:00:47 1: PERL WARNING: Subroutine FBDECT_Initialize redefined at ./FHEM/10_FBDECT.pm line 41, <$fh> line 131.
2021.04.21 15:00:47 1: PERL WARNING: Subroutine FBDECT_Define redefined at ./FHEM/10_FBDECT.pm line 65, <$fh> line 131.
2021.04.21 15:00:47 1: PERL WARNING: Subroutine FBDECT_SetHttp redefined at ./FHEM/10_FBDECT.pm line 91, <$fh> line 131.
2021.04.21 15:00:47 1: PERL WARNING: Subroutine FBDECT_Set redefined at ./FHEM/10_FBDECT.pm line 300, <$fh> line 131.
2021.04.21 15:00:47 1: PERL WARNING: Subroutine FBDECT_Get redefined at ./FHEM/10_FBDECT.pm line 342, <$fh> line 131.
  • Administrator
« Antwort #33 am: 21 April 2021, 16:49:04 »
Bin einigermassen ratlos.
Was passiert, wenn man dp und die zwei Aufrufe in was sicher Eindeutiges wie parsePressedTimestamp umbenennt?
Nachtrag: bitte nicht reload, sondern "shutdown restart", da bei reload der Interpreter bleibt, und die alte Deklaration merkt.
Offline Bucklew
  • New Member
« Antwort #34 am: 21 April 2021, 17:33:10 »
Mache immer shutdown restart.
Die Änderung von dp hat immerhin die Fehler im Logfile behoben.
Nur wird aber jeder Wert aktualisiert auf den DECT200 Geräten  - außer der "Power" Wert:
mode manuell 2021-04-21 17:32:35
power 94.91 W 2021-04-21 17:32:17
present yes 2021-04-21 17:32:35[7quote]
Wäre es sinnvoll die Geräte neu anzulegen?
  • Administrator
« Antwort #35 am: 21 April 2021, 20:40:54 »
Ich glaub ich habs: in deiner Installation wird irgendwo eine dp Funktion definiert. Ich habe sowas in den "offiziellen" Modulen nicht gefunden, es muss also entweder von "aussen" kommen, oder selbstdefiniert sein (in 99_myUtils.pm).
Ich habe die Funktion jetzt umbenannt und das Modul eingecheckt.
Wg. power: das ist eine ganz andere Baustelle. Wenn ich die <device> Zeile aus deinem Beitrag vom gestern bei mir mit Dispatch() einspiele, dann bekomme ich ein power Event.
Offline Bucklew
  • New Member
« Antwort #36 am: 21 April 2021, 21:04:07 »
Ich hab jetzt zwar auf die Schnelle nix gefunden, aber könnte natürlich sein.
Vielen Dank :)
Power hat sich erledigt, wird wohl - unabhängig vom Pollingzyklus der Fritzbox - nur alle 5 Minuten aktualisiert.
Offline Udomatic
  • Full Member
« Antwort #37 am: 30 Juni 2021, 22:43:57 »
Ich habe es als "rel_humidity $val %" hinzugefuegt.
Wie muss ich das im Device ansprechen, um die Luftfeuchte angezeigt zu bekommen?
2x Raspberry 3B+, 1x Raspberry 4, Signalduino 433 (Somfy), CUL_HM (HM-MOD-RPI-PCB), MQTT, Hue, ConBee 2, Sonos, AVM DECT, Netatmo, eufy, Nuki,
  • Administrator
« Antwort #38 am: 02 Juli 2021, 09:30:12 »
Jenachdem, was mit "Device" gemeint ist:
in FHEM gar nicht, wenn die Daten vom FritzBox gemeldet werden, dann wird ein Reading angelegt.
In der FritzBox bzw. Hardware: weiss nicht genau, ich tippe auf einen alten Firmware, was man erneuern muesste.
Offline Udomatic
  • Full Member
« Antwort #39 am: 03 Juli 2021, 23:44:22 »
Ja stimmt leider, die FB Firmware ist wohl zu alt und zeigt die Luftfeuchtigkeit nicht an. Nur der Taster.
