Double entry in docs for Eltako FUD12, FUD14, FUD61, FUD70, FSG14
Begonnen von Nestor, 22 März 2021, 13:38:54
Nestor
I think one can be removed, since it's not valid anymore (attr manufID missing?)
Keep the one that starts at L#22303.
@ -19219,37 +19219,6 @@
      </li>
      <br><br>
-     <li>Gateway (EEP A5-38-08)<br>
-         Dimming<br>
-         [Eltako FUD12, FUD14, FUD61, FUD70, FSG14, ...]<br>
-     <ul>
-      <code>set &lt;name&gt; &lt;value&gt;</code>
-      <br><br>
-      where <code>value</code> is
-        <li>dim/% [rampTime/s [lock|unlock]]<br>
-          issue dim command</li>
-        <li>teach<br>
-          initiate teach-in mode</li>
-        <li>on [lock|unlock]<br>
-          issue switch on command</li>
-        <li>off [lock|unlock]<br>
-          issue switch off command</li>
-        <li>dim dim/% [rampTime/s [lock|unlock]]<br>
-        <li>dimup dim/% [rampTime/s [lock|unlock]]<br>
-        <li>dimdown dim/% [rampTime/s [lock|unlock]]<br>
-        <li><a href="#setExtensions">set extensions</a> are supported.</li>
-     </ul><br>
-        rampTime Range: t = 1 s ... 255 s or 0 if no time specified,
-        for Eltako: t = 1 = fast dimming ... 255 = slow dimming or 0 = dimming speed on the dimmer used<br>
-        The attr subType must be gateway and gwCmd must be dimming. This is done if the device was
-        created by autocreate.<br>
-        For Eltako devices attributes must be set manually. Use the sensor type "PC/FVS" for Eltako devices.
-     </li>
-     <br><br>
         Dimming of fluorescent lamps<br>
         [Eltako FSG70, tested with Eltako FSG70 only]<br>
klaus.schauer
The texts are different. First, the set commands are listed, then the resulting events.
Nestor
I see but is this snippet still valid?
klaus.schauer
Why not? Unfortunately, Eltako changes the names in the instructions from time to time. In addition, the names in the English and German manuals are often different.
