Funk-Wassermelder HM-Sec-WDS-2 missing RegL_00
Begonnen von SHOFHEM, 10 April 2021, 15:29:36
SHOFHEM
Hallo Ansgar,
interpertiere ich richtig, dass ich die Datei aus der Mail von gestern verwenden soll, weil du sie dort aktualisiert hast? Ist mit leider immer noch nicht ganz klar: ???
   .triggerUsed 1
   DEF        3D3280
   FUUID      60942659-f33f-431b-b5e3-2f50ab8a7cc96fa1
   IODev      SCC
   LASTInputDev SCC
   MSGCNT     6
   NAME       Wassermelder_1
   NOTIFYDEV  global
   NR         73
   NTFY_ORDER 50-Wassermelder_1
   SCC_MSGCNT 6
   SCC_RAWMSG A0E8EA0103D3280F112340100000000::-59.5:SCC
   SCC_RSSI   -59.5
   SCC_TIME   2021-05-09 11:08:42
   STATE      dry
   TYPE       CUL_HM
   chanNo     01
   lastMsg    No:8E - t:10 s:3D3280 d:F11234 0100000000
   protLastRcv 2021-05-09 11:08:42
   protRcv    6 last_at:2021-05-09 11:08:42
   protResnd  2 last_at:2021-05-09 11:08:34
   protSnd    8 last_at:2021-05-09 11:08:42
   protState  CMDs_done
   rssi_at_SCC cnt:6 min:-59.5 max:-58.5 avg:-59.25 lst:-59.5
   .attraggr:
   .attrminint:
   CL:
     Authenticated 1
     AuthenticatedBy allowed_WEB
     AuthenticatedUser FHEMSHOHAUSEN
     BUF
     FD         48
     FW_ID      957
     LASTACCESS 1620552729
     NAME       WEB_93.232.90.27_52205
     NR         958
     PEER       93.232.90.27
     PORT       52205
     SNAME      WEB
     SSL        1
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-09 11:32:02   state           Connected
     2021-05-09 11:08:42   .D-devInfo      110101
     2021-05-09 11:08:42   .D-stc          80
     2021-05-09 11:08:42   .associatedWith Wassermelder_1,Wassermelder_1
     2021-05-09 11:08:42   .peerListRDate  2021-05-09 11:08:42
     2021-05-09 11:08:42   .protLastRcv    20210509110842
     2021-05-09 11:16:27   Activity        alive
     2021-05-07 23:04:51   CommandAccepted yes
     2021-05-09 11:08:42   D-firmware      1.4
     2021-05-09 11:08:42   D-serialNr      MEQ0590456
     2021-05-09 11:06:24   IODev           SCC
     2021-05-09 11:08:18   PairedTo        0xF11234
     2021-05-06 19:25:57   R-cyclicInfoMsg on
     2021-05-06 19:27:52   R-eventFilterTimeB 5 s
     2021-05-06 19:27:52   R-msgWdsPosA    dry
     2021-05-06 19:27:52   R-msgWdsPosB    wet
     2021-05-06 19:27:52   R-msgWdsPosC    water
     2021-05-07 23:04:51   R-pairCentral   0xF11234
     2021-05-06 19:27:52   R-sign          off
     2021-05-06 19:25:57   R-transmDevTryMax 6
     2021-05-06 19:27:52   R-transmitTryMax 6
     2021-05-09 11:08:18   RegL_00.         00:00 02:01 09:01 0A:F1 0B:12 0C:34 10:01 14:06
     2021-05-09 11:08:29   RegL_01.         00:00 08:00 20:78 22:64 23:05 30:06
     2021-05-08 22:51:52   alive           yes
     2021-05-09 10:02:07   battery         ok
     2021-05-09 11:09:42   cfgState        TrigUndef
     2021-05-09 11:08:42   commState       CMDs_done
     2021-05-09 10:02:07   contact         dry (to SCC)
     2021-05-08 22:51:52   cover           closed
     2021-05-08 22:51:52   recentStateType info
     2021-05-09 10:02:07   state           dry
     2021-05-09 10:02:07   trigDst_F11234  noConfig
     2021-05-09 10:02:07   trigger_cnt     69
   helper:
     HM_CMDNR   142
     cSnd       01F112343D32800103,01F112343D32800103
     mId        00B2
     peerFriend peerAct,peerVirt
     peerIDsRaw ,00000000
     peerIDsState complete
     peerOpt    4:threeStateSensor
     regLst     0,1,4p
     rxType     12
     supp_Pair_Rep 0
     tmplChg    0
     cfgChk:
       idPz05     F11234
     cmds:
       TmplKey    :no:1620551188.81165
       TmplTs     1620551188.81165
       cmdKey     1:1:0::Wassermelder_1:00B2:01:
       cmdLst:
         assignHmKey noArg
         clear      [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   -btnNumber- -actChn- [({single})] [({set}|unset)] [actor|remote|both]
         peerSmart  -peerOpt-
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- -addr2:data2-...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         trgEventL  -peer- -condition-
         trgEventS  -peer- -condition-
         trgPressL  [(-peer-|{all})]
         trgPressS  [(-peer-|{all})]
         unpair     noArg
       lst:
         condition  closed,damp,dry,open,tilted,wet
         peer
         peerOpt    Rauch_Team,Schalt1,Schalt_Trock_Sw,Schalt_Wasch_Sw,Schalt_Z_Sw,Schalter_Licht_Sw_01,Schalter_Licht_Sw_02,Sirene,Thermostat_WindowRec,Thermostat_remote,Ventil1_Wohn_WindowRec,Ventil1_Wohn_remote,Ventil2_Ess_WindowRec,Ventil2_Ess_remote,Ventil3_Schlaf_WindowRec,Ventil3_Schlaf_remote,Ventil4_Buero_WindowRec,Ventil4_Buero_remote
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +3D3280,00,00,00
       nextSend   1620551322.47234
       prefIO
       rxt        2
       vccu
       p:
         3D3280
         00
         00
         00
     mRssi:
       mNo        8E
       io:
         SCC:
           -53.5
           -53.5
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rpt:
       IO         SCC
       flg        A
       ts         1620551322.37374
       ack:
         HASH(0x2419958)
         8E8002F112343D328000
     rssi:
       at_SCC:
         avg        -59.25
         cnt        6
         lst        -59.5
         max        -58.5
         min        -59.5
     shadowReg:
     tmpl:
   .mId       00B2
   IODev      SCC
   actCycle   028:00
   actStatus  alive
   autoReadReg 4_reqStatus
   devStateIcon dry:weather_sun wet:weather_rain_heavy@red
   expert     defReg,allReg,rawReg
   firmware   1.4
   icon       weather_humidity
   model      HM-SEC-WDS-2
   peerIDs    00000000
   room       CUL_HM
   serialNr   MEQ0590456
   subType    threeStateSensor
noansi
Hallo Stefan,
Zitatinterpertiere ich richtig, dass ich die Datei aus der Mail von gestern verwenden soll, weil du sie dort aktualisiert hast?
ja.
Und es erscheint Dir sicherlich erst mal als Rückschritt, wieder 3 mal Knöpfchen drücken zu müssen.
Dafür solltest Du nur ein Wasserevent am Sensor auslösen müssen, um einen getConfig komplett abzuarbeiten, so ist jedenfalls das erhoffte Verhalten.
Damit wären wir beim nächsten Testwunsch mit letztem Stand CUL_HM Datei.
Bitte starte einen getConfig und dann triggere einmal Wasser am Sensor.
Das bitte auch nochmal mit Sniff und list.
Gruß, Ansgar.
SHOFHEM
#62
Hallo Ansgar,
ich verwende immer noch die CUL_HM_10 Version Update heute 10 Uhr, oder gibt es eine noch neuere Version? Will sicher stellen, dass die Testvoraussetzungen passen!
Das Verhalten durch einen Event am Wassermelder ist etwas anders als du erhofft hast. Ich stelle den Sensor ins Wasser nach der ersten Meldung "wet" ist nur 1 cmd von 3 abgearbeitet. Da der Sensor die Meldung wiederholt sendet werden nach 2 weiteren Events die CMDs als done angezeigt. Es fehlt aber wieder eine RegL.
Habe als Gegenprobe getConfig wieder mit 3 mal Knopfdruck abgearbeitet, dann ist RegL wieder da.
2021.05.09 14:17:04 1: Timeout for PRESENCE_DoLocalBluetoothScan reached, terminated process 12316
2021.05.09 14:17:04 2: PRESENCE (MarieBT) - device could not be checked (retrying in 10 seconds): Timeout: process terminated
2021.05.09 14:17:14 2: PRESENCE (MarieBT) - check returned a valid result after 1 unsuccesful retry
2021.05.09 14:53:16 5: CUL/RAW: /A0F
2021.05.09 14:53:16 5: CUL/RAW: A0F/A08610
2021.05.09 14:53:16 5: CUL/RAW: A0FA08610/6F3D
2021.05.09 14:53:16 5: CUL/RAW: A0FA086106F3D/08000
2021.05.09 14:53:16 5: CUL/RAW: A0FA086106F3D08000/0000
2021.05.09 14:53:16 5: CUL/RAW: A0FA086106F3D080000000/A98C
2021.05.09 14:53:16 5: CUL/RAW: A0FA086106F3D080000000A98C/10B0E
2021.05.09 14:53:16 5: CUL/RAW: A0FA086106F3D080000000A98C10B0E/4022
2021.05.09 14:53:16 5: CUL/RAW: A0FA086106F3D080000000A98C10B0E4022/
2021.05.09 14:53:16 4: CUL_Parse: SCC A 0F A0 8610 6F3D08 000000 0A98C10B0E4022 -57
2021.05.09 14:53:16 5: SCC: dispatch A0FA086106F3D080000000A98C10B0E40::-57:SCC
2021.05.09 14:53:21 5: CUL/RAW: /A146
2021.05.09 14:53:21 5: CUL/RAW: A146/4845E5B
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B/9A5900
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B9A5900/0000
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B9A59000000/80E64
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B9A5900000080E64/20000
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B9A5900000080E6420000/00000
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B9A5900000080E642000000000/00939
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B9A5900000080E64200000000000939/FE22
2021.05.09 14:53:21 5: CUL/RAW: A1464845E5B9A5900000080E64200000000000939FE22/
2021.05.09 14:53:21 4: CUL_Parse: SCC A 14 64 845E 5B9A59 000000 80E64200000000000939FE22 -57
2021.05.09 14:53:21 5: SCC: dispatch A1464845E5B9A5900000080E64200000000000939FE::-57:SCC
2021.05.09 14:53:33.950 5: CUL/RAW: /A0F
2021.05.09 14:53:33.951 5: CUL/RAW: A0F/D186105
2021.05.09 14:53:33.952 5: CUL/RAW: A0FD186105/D66B
2021.05.09 14:53:33.954 5: CUL/RAW: A0FD186105D66B/6000
2021.05.09 14:53:33.955 5: CUL/RAW: A0FD186105D66B6000/0000A
2021.05.09 14:53:33.956 5: CUL/RAW: A0FD186105D66B60000000A/58C5
2021.05.09 14:53:33.957 5: CUL/RAW: A0FD186105D66B60000000A58C5/0900
2021.05.09 14:53:33.958 5: CUL/RAW: A0FD186105D66B60000000A58C50900/401B
2021.05.09 14:53:33.959 5: CUL/RAW: A0FD186105D66B60000000A58C50900401B/
2021.05.09 14:53:33.960 4: CUL_Parse: SCC A 0F D1 8610 5D66B6 000000 0A58C50900401B -60.5
2021.05.09 14:53:33.961 5: SCC: dispatch A0FD186105D66B60000000A58C5090040::-60.5:SCC
2021.05.09 14:53:53.825 5: CUL/RAW: /A0C
2021.05.09 14:53:53.827 5: CUL/RAW: A0C/F5865
2021.05.09 14:53:53.827 5: CUL/RAW: A0CF5865/A34
2021.05.09 14:53:53.828 5: CUL/RAW: A0CF5865A34/D21
2021.05.09 14:53:53.829 5: CUL/RAW: A0CF5865A34D21/800
2021.05.09 14:53:53.830 5: CUL/RAW: A0CF5865A34D21800/000
2021.05.09 14:53:53.831 5: CUL/RAW: A0CF5865A34D21800000/0AC
2021.05.09 14:53:53.831 5: CUL/RAW: A0CF5865A34D218000000AC/DC2
2021.05.09 14:53:53.832 5: CUL/RAW: A0CF5865A34D218000000ACDC2/72
2021.05.09 14:53:53.833 5: CUL/RAW: A0CF5865A34D218000000ACDC272/5
2021.05.09 14:53:53.833 5: CUL/RAW: A0CF5865A34D218000000ACDC2725
2021.05.09 14:53:53.834 4: CUL_Parse: SCC A 0C F5 865A 34D218 000000 ACDC2725 -55.5
2021.05.09 14:53:53.835 5: SCC: dispatch A0CF5865A34D218000000ACDC27::-55.5:SCC
2021.05.09 14:54:13.825 5: CUL/RAW: /A0C
2021.05.09 14:54:13.827 5: CUL/RAW: A0C/F5847
2021.05.09 14:54:13.828 5: CUL/RAW: A0CF5847/034
2021.05.09 14:54:13.828 5: CUL/RAW: A0CF5847034/D21
2021.05.09 14:54:13.829 5: CUL/RAW: A0CF5847034D21/800
2021.05.09 14:54:13.830 5: CUL/RAW: A0CF5847034D21800/000
2021.05.09 14:54:13.831 5: CUL/RAW: A0CF5847034D21800000/000
2021.05.09 14:54:13.832 5: CUL/RAW: A0CF5847034D21800000000/DC2
2021.05.09 14:54:13.832 5: CUL/RAW: A0CF5847034D21800000000DC2/725
2021.05.09 14:54:13.833 5: CUL/RAW: A0CF5847034D21800000000DC2725/
2021.05.09 14:54:13.834 4: CUL_Parse: SCC A 0C F5 8470 34D218 000000 00DC2725 -55.5
2021.05.09 14:54:13.835 5: SCC: dispatch A0CF5847034D21800000000DC27::-55.5:SCC
2021.05.09 14:54:24.567 5: CUL/RAW: /A0
2021.05.09 14:54:24.568 5: CUL/RAW: A0/C67A64
2021.05.09 14:54:24.569 5: CUL/RAW: A0C67A64/13D
2021.05.09 14:54:24.570 5: CUL/RAW: A0C67A6413D/3280
2021.05.09 14:54:24.571 5: CUL/RAW: A0C67A6413D3280/F11
2021.05.09 14:54:24.572 5: CUL/RAW: A0C67A6413D3280F11/234
2021.05.09 14:54:24.573 5: CUL/RAW: A0C67A6413D3280F11234/014C
2021.05.09 14:54:24.574 5: CUL/RAW: A0C67A6413D3280F11234014C/C8F
2021.05.09 14:54:24.575 5: CUL/RAW: A0C67A6413D3280F11234014CC8F/B
2021.05.09 14:54:24.575 4: CUL_Parse: SCC A 0C 67 A641 3D3280 F11234 014CC8FB -76.5
2021.05.09 14:54:24.576 5: SCC: dispatch A0C67A6413D3280F11234014CC8::-76.5:SCC
2021.05.09 14:54:24.581 5: SCC sending As0A678102F112343D328000
2021.05.09 14:54:24.581 5: CUL 3D3280 dly:94ms
2021.05.09 14:54:24.676 5: SW: As0A678102F112343D328000
2021.05.09 14:54:24.679 5: SCC sending As1068A001F112343D328000040000000000
2021.05.09 14:54:24.680 5: SW: As1068A001F112343D328000040000000000
2021.05.09 14:54:24.684 5: SCC sending As0A678102F112343D328000
2021.05.09 14:54:24.685 5: SW: As0A678102F112343D328000
2021.05.09 14:54:24.688 5: SCC sending As0A678102F112343D328000
2021.05.09 14:54:24.688 5: SW: As0A678102F112343D328000
2021.05.09 14:54:34.604 5: CUL/RAW: /A0C6
2021.05.09 14:54:34.606 5: CUL/RAW: A0C6/8A6413D
2021.05.09 14:54:34.607 5: CUL/RAW: A0C68A6413D/3280F
2021.05.09 14:54:34.608 5: CUL/RAW: A0C68A6413D3280F/11234
2021.05.09 14:54:34.609 5: CUL/RAW: A0C68A6413D3280F11234/014D
2021.05.09 14:54:34.610 5: CUL/RAW: A0C68A6413D3280F11234014D/C8FC
2021.05.09 14:54:34.611 5: CUL/RAW: A0C68A6413D3280F11234014DC8FC/
2021.05.09 14:54:34.612 4: CUL_Parse: SCC A 0C 68 A641 3D3280 F11234 014DC8FC -76
2021.05.09 14:54:34.614 5: SCC: dispatch A0C68A6413D3280F11234014DC8::-76:SCC
2021.05.09 14:54:34.620 5: SCC sending As0A688102F112343D328000
2021.05.09 14:54:34.621 5: CUL 3D3280 dly:91ms
2021.05.09 14:54:34.713 5: SW: As0A688102F112343D328000
2021.05.09 14:54:34.718 5: SCC sending As1069A001F112343D328000040000000000
2021.05.09 14:54:34.719 5: SW: As1069A001F112343D328000040000000000
2021.05.09 14:54:34.725 5: SCC sending As0A688102F112343D328000
2021.05.09 14:54:34.726 5: SW: As0A688102F112343D328000
2021.05.09 14:54:34.729 5: SCC sending As0A688102F112343D328000
2021.05.09 14:54:34.729 5: SW: As0A688102F112343D328000
2021.05.09 14:54:42.866 5: CUL/RAW: /A0
2021.05.09 14:54:42.867 5: CUL/RAW: A0/F9D8
2021.05.09 14:54:42.868 5: CUL/RAW: A0F9D8/61
2021.05.09 14:54:42.868 5: CUL/RAW: A0F9D861/05E
2021.05.09 14:54:42.869 5: CUL/RAW: A0F9D86105E/AA
2021.05.09 14:54:42.869 5: CUL/RAW: A0F9D86105EAA/D6
2021.05.09 14:54:42.870 5: CUL/RAW: A0F9D86105EAAD6/00
2021.05.09 14:54:42.870 5: CUL/RAW: A0F9D86105EAAD600/00
2021.05.09 14:54:42.871 5: CUL/RAW: A0F9D86105EAAD60000/00
2021.05.09 14:54:42.872 5: CUL/RAW: A0F9D86105EAAD6000000/0AA
2021.05.09 14:54:42.872 5: CUL/RAW: A0F9D86105EAAD60000000AA/CD
2021.05.09 14:54:42.873 5: CUL/RAW: A0F9D86105EAAD60000000AACD/C0
2021.05.09 14:54:42.873 5: CUL/RAW: A0F9D86105EAAD60000000AACDC0/B0
2021.05.09 14:54:42.874 5: CUL/RAW: A0F9D86105EAAD60000000AACDC0B0/000
2021.05.09 14:54:42.874 5: CUL/RAW: A0F9D86105EAAD60000000AACDC0B0000/35
2021.05.09 14:54:42.875 5: CUL/RAW: A0F9D86105EAAD60000000AACDC0B000035/
2021.05.09 14:54:42.875 4: CUL_Parse: SCC A 0F 9D 8610 5EAAD6 000000 0AACDC0B000035 -47.5
2021.05.09 14:54:42.876 5: SCC: dispatch A0F9D86105EAAD60000000AACDC0B0000::-47.5:SCC
2021.05.09 14:54:44.600 5: CUL/RAW: /A0C
2021.05.09 14:54:44.602 5: CUL/RAW: A0C/69A641
2021.05.09 14:54:44.603 5: CUL/RAW: A0C69A641/3D32
2021.05.09 14:54:44.604 5: CUL/RAW: A0C69A6413D32/80F11
2021.05.09 14:54:44.605 5: CUL/RAW: A0C69A6413D3280F11/2340
2021.05.09 14:54:44.607 5: CUL/RAW: A0C69A6413D3280F112340/14EC
2021.05.09 14:54:44.608 5: CUL/RAW: A0C69A6413D3280F11234014EC/8FA
2021.05.09 14:54:44.608 4: CUL_Parse: SCC A 0C 69 A641 3D3280 F11234 014EC8FA -77
2021.05.09 14:54:44.609 5: SCC: dispatch A0C69A6413D3280F11234014EC8::-77:SCC
2021.05.09 14:54:44.613 5: SCC sending As0A698102F112343D328000
2021.05.09 14:54:44.614 5: CUL 3D3280 dly:95ms
2021.05.09 14:54:44.709 5: SW: As0A698102F112343D328000
2021.05.09 14:54:44.713 5: SCC sending As106AA001F112343D328000040000000000
2021.05.09 14:54:44.714 5: SW: As106AA001F112343D328000040000000000
2021.05.09 14:54:44.719 5: SCC sending As0A698102F112343D328000
2021.05.09 14:54:44.720 5: SW: As0A698102F112343D328000
2021.05.09 14:54:44.723 5: SCC sending As0A698102F112343D328000
2021.05.09 14:54:44.724 5: SW: As0A698102F112343D328000
2021.05.09 14:54:52.096 5: CUL/RAW: /A1
2021.05.09 14:54:52.098 5: CUL/RAW: A1/458845E
2021.05.09 14:54:52.099 5: CUL/RAW: A1458845E/653B
2021.05.09 14:54:52.100 5: CUL/RAW: A1458845E653B/E000
2021.05.09 14:54:52.101 5: CUL/RAW: A1458845E653BE000/00008
2021.05.09 14:54:52.102 5: CUL/RAW: A1458845E653BE00000008/0AD8
2021.05.09 14:54:52.104 5: CUL/RAW: A1458845E653BE000000080AD8/D000
2021.05.09 14:54:52.105 5: CUL/RAW: A1458845E653BE000000080AD8D000/12500
2021.05.09 14:54:52.106 5: CUL/RAW: A1458845E653BE000000080AD8D00012500/1A09
2021.05.09 14:54:52.107 5: CUL/RAW: A1458845E653BE000000080AD8D000125001A09/3C01
2021.05.09 14:54:52.108 5: CUL/RAW: A1458845E653BE000000080AD8D000125001A093C01/21
2021.05.09 14:54:52.109 4: CUL_Parse: SCC A 14 58 845E 653BE0 000000 80AD8D000125001A093C0121 -57.5
2021.05.09 14:54:52.110 5: SCC: dispatch A1458845E653BE000000080AD8D000125001A093C01::-57.5:SCC
2021.05.09 14:54:54.598 5: CUL/RAW: /A0C6
2021.05.09 14:54:54.600 5: CUL/RAW: A0C6/AA6413D3
2021.05.09 14:54:54.601 5: CUL/RAW: A0C6AA6413D3/280F11
2021.05.09 14:54:54.603 5: CUL/RAW: A0C6AA6413D3280F11/23401
2021.05.09 14:54:54.604 5: CUL/RAW: A0C6AA6413D3280F1123401/4FC8FC
2021.05.09 14:54:54.606 5: CUL/RAW: A0C6AA6413D3280F11234014FC8FC/
2021.05.09 14:54:54.607 4: CUL_Parse: SCC A 0C 6A A641 3D3280 F11234 014FC8FC -76
2021.05.09 14:54:54.610 5: SCC: dispatch A0C6AA6413D3280F11234014FC8::-76:SCC
2021.05.09 14:54:54.620 5: SCC sending As0A6A8102F112343D328000
2021.05.09 14:54:54.621 5: CUL 3D3280 dly:87ms
2021.05.09 14:54:54.709 5: SW: As0A6A8102F112343D328000
2021.05.09 14:54:54.712 5: SCC sending As106BA001F112343D328000040000000000
2021.05.09 14:54:54.712 5: SW: As106BA001F112343D328000040000000000
2021.05.09 14:54:54.718 5: SCC sending As0A6A8102F112343D328000
2021.05.09 14:54:54.718 5: SW: As0A6A8102F112343D328000
2021.05.09 14:54:54.720 5: SCC sending As0A6A8102F112343D328000
2021.05.09 14:54:54.721 5: SW: As0A6A8102F112343D328000
2021.05.09 14:55:04.597 5: CUL/RAW: /A0
2021.05.09 14:55:04.598 5: CUL/RAW: A0/C6BA
2021.05.09 14:55:04.599 5: CUL/RAW: A0C6BA/641
2021.05.09 14:55:04.600 5: CUL/RAW: A0C6BA641/3D
2021.05.09 14:55:04.600 5: CUL/RAW: A0C6BA6413D/328
2021.05.09 14:55:04.601 5: CUL/RAW: A0C6BA6413D328/0F
2021.05.09 14:55:04.601 5: CUL/RAW: A0C6BA6413D3280F/11
2021.05.09 14:55:04.602 5: CUL/RAW: A0C6BA6413D3280F11/234
2021.05.09 14:55:04.603 5: CUL/RAW: A0C6BA6413D3280F11234/01
2021.05.09 14:55:04.603 5: CUL/RAW: A0C6BA6413D3280F1123401/50C
2021.05.09 14:55:04.604 5: CUL/RAW: A0C6BA6413D3280F112340150C/8F
2021.05.09 14:55:04.604 5: CUL/RAW: A0C6BA6413D3280F112340150C8F/B
2021.05.09 14:55:04.605 5: CUL/RAW: A0C6BA6413D3280F112340150C8FB
2021.05.09 14:55:04.605 4: CUL_Parse: SCC A 0C 6B A641 3D3280 F11234 0150C8FB -76.5
2021.05.09 14:55:04.606 5: SCC: dispatch A0C6BA6413D3280F112340150C8::-76.5:SCC
2021.05.09 14:55:04.610 5: SCC sending As0A6B8002F112343D328000
2021.05.09 14:55:04.611 5: CUL 3D3280 dly:95ms
2021.05.09 14:55:04.706 5: SW: As0A6B8002F112343D328000
2021.05.09 14:55:04.709 5: SCC sending As0A6B8002F112343D328000
2021.05.09 14:55:04.710 5: SW: As0A6B8002F112343D328000
2021.05.09 14:55:07.681 5: CUL/RAW: /A0
2021.05.09 14:55:07.683 5: CUL/RAW: A0/FEC8
2021.05.09 14:55:07.683 5: CUL/RAW: A0FEC8/6105
2021.05.09 14:55:07.684 5: CUL/RAW: A0FEC86105/EAA6
2021.05.09 14:55:07.685 5: CUL/RAW: A0FEC86105EAA6/600
2021.05.09 14:55:07.686 5: CUL/RAW: A0FEC86105EAA6600/000
2021.05.09 14:55:07.687 5: CUL/RAW: A0FEC86105EAA6600000/00A
2021.05.09 14:55:07.688 5: CUL/RAW: A0FEC86105EAA660000000A/ACDC
2021.05.09 14:55:07.689 5: CUL/RAW: A0FEC86105EAA660000000AACDC/0F0
2021.05.09 14:55:07.689 5: CUL/RAW: A0FEC86105EAA660000000AACDC0F0/000
2021.05.09 14:55:07.690 5: CUL/RAW: A0FEC86105EAA660000000AACDC0F0000/2D
2021.05.09 14:55:07.691 5: CUL/RAW: A0FEC86105EAA660000000AACDC0F00002D
2021.05.09 14:55:07.692 4: CUL_Parse: SCC A 0F EC 8610 5EAA66 000000 0AACDC0F00002D -51.5
2021.05.09 14:55:07.693 5: SCC: dispatch A0FEC86105EAA660000000AACDC0F0000::-51.5:SCC
2021.05.09 14:55:11.085 5: CUL/RAW: /A0F
2021.05.09 14:55:11.086 5: CUL/RAW: A0F/72865E7
2021.05.09 14:55:11.088 5: CUL/RAW: A0F72865E7/1DA76
2021.05.09 14:55:11.089 5: CUL/RAW: A0F72865E71DA76/00000
2021.05.09 14:55:11.090 5: CUL/RAW: A0F72865E71DA7600000/00B2
2021.05.09 14:55:11.091 5: CUL/RAW: A0F72865E71DA760000000B2/C6A00
2021.05.09 14:55:11.093 5: CUL/RAW: A0F72865E71DA760000000B2C6A00/70802
2021.05.09 14:55:11.094 5: CUL/RAW: A0F72865E71DA760000000B2C6A0070802/1
2021.05.09 14:55:11.094 4: CUL_Parse: SCC A 0F 72 865E 71DA76 000000 0B2C6A00708021 -57.5
2021.05.09 14:55:11.096 5: SCC: dispatch A0F72865E71DA760000000B2C6A007080::-57.5:SCC
2021.05.09 14:55:25.220 5: CUL/RAW: /A1
2021.05.09 14:55:25.221 5: CUL/RAW: A1/46684
2021.05.09 14:55:25.222 5: CUL/RAW: A146684/5E3
2021.05.09 14:55:25.223 5: CUL/RAW: A1466845E3/3D
2021.05.09 14:55:25.223 5: CUL/RAW: A1466845E33D/FB2
2021.05.09 14:55:25.224 5: CUL/RAW: A1466845E33DFB2/000
2021.05.09 14:55:25.225 5: CUL/RAW: A1466845E33DFB2000/00
2021.05.09 14:55:25.225 5: CUL/RAW: A1466845E33DFB200000/08
2021.05.09 14:55:25.226 5: CUL/RAW: A1466845E33DFB20000008/0F6
2021.05.09 14:55:25.227 5: CUL/RAW: A1466845E33DFB200000080F6/6C
2021.05.09 14:55:25.227 5: CUL/RAW: A1466845E33DFB200000080F66C/000
2021.05.09 14:55:25.228 5: CUL/RAW: A1466845E33DFB200000080F66C000/00
2021.05.09 14:55:25.228 5: CUL/RAW: A1466845E33DFB200000080F66C00000/500
2021.05.09 14:55:25.229 5: CUL/RAW: A1466845E33DFB200000080F66C00000500/00
2021.05.09 14:55:25.230 5: CUL/RAW: A1466845E33DFB200000080F66C0000050000/094
2021.05.09 14:55:25.230 5: CUL/RAW: A1466845E33DFB200000080F66C0000050000094/40
2021.05.09 14:55:25.231 5: CUL/RAW: A1466845E33DFB200000080F66C000005000009440/215
2021.05.09 14:55:25.232 5: CUL/RAW: A1466845E33DFB200000080F66C000005000009440215/
2021.05.09 14:55:25.232 4: CUL_Parse: SCC A 14 66 845E 33DFB2 000000 80F66C000005000009440215 -63.5
2021.05.09 14:55:25.233 5: SCC: dispatch A1466845E33DFB200000080F66C0000050000094402::-63.5:SCC
2021.05.09 14:55:39.201 5: CUL/RAW: /A0FD
2021.05.09 14:55:39.205 5: CUL/RAW: A0FD/286105D66B60000000
2021.05.09 14:55:39.207 5: CUL/RAW: A0FD286105D66B60000000/A58C50
2021.05.09 14:55:39.208 5: CUL/RAW: A0FD286105D66B60000000A58C50/900401
2021.05.09 14:55:39.210 5: CUL/RAW: A0FD286105D66B60000000A58C50900401/B
2021.05.09 14:55:39.210 4: CUL_Parse: SCC A 0F D2 8610 5D66B6 000000 0A58C50900401B -60.5
2021.05.09 14:55:39.213 5: SCC: dispatch A0FD286105D66B60000000A58C5090040::-60.5:SCC
2021.05.09 14:55:39.260 5: CUL/RAW: /A0F
2021.05.09 14:55:39.261 5: CUL/RAW: A0F/A186106
2021.05.09 14:55:39.263 5: CUL/RAW: A0FA186106/F3D080
2021.05.09 14:55:39.265 5: CUL/RAW: A0FA186106F3D080/000000A
2021.05.09 14:55:39.266 5: CUL/RAW: A0FA186106F3D080000000A/98C00B
2021.05.09 14:55:39.268 5: CUL/RAW: A0FA186106F3D080000000A98C00B/0E4023
2021.05.09 14:55:39.269 5: CUL/RAW: A0FA186106F3D080000000A98C00B0E4023/
2021.05.09 14:55:39.270 4: CUL_Parse: SCC A 0F A1 8610 6F3D08 000000 0A98C00B0E4023 -56.5
2021.05.09 14:55:39.271 5: SCC: dispatch A0FA186106F3D080000000A98C00B0E40::-56.5:SCC
2021.05.09 14:55:40.680 5: CUL/RAW: /A1
2021.05.09 14:55:40.681 5: CUL/RAW: A1/4658
2021.05.09 14:55:40.682 5: CUL/RAW: A14658/45E
2021.05.09 14:55:40.683 5: CUL/RAW: A1465845E/5B
2021.05.09 14:55:40.683 5: CUL/RAW: A1465845E5B/9A
2021.05.09 14:55:40.684 5: CUL/RAW: A1465845E5B9A/590
2021.05.09 14:55:40.685 5: CUL/RAW: A1465845E5B9A590/00
2021.05.09 14:55:40.685 5: CUL/RAW: A1465845E5B9A59000/00
2021.05.09 14:55:40.686 5: CUL/RAW: A1465845E5B9A5900000/08
2021.05.09 14:55:40.686 5: CUL/RAW: A1465845E5B9A590000008/0E
2021.05.09 14:55:40.687 5: CUL/RAW: A1465845E5B9A5900000080E/642
2021.05.09 14:55:40.687 5: CUL/RAW: A1465845E5B9A5900000080E642/00
2021.05.09 14:55:40.688 5: CUL/RAW: A1465845E5B9A5900000080E64200/00
2021.05.09 14:55:40.689 5: CUL/RAW: A1465845E5B9A5900000080E6420000/00
2021.05.09 14:55:40.689 5: CUL/RAW: A1465845E5B9A5900000080E642000000/00
2021.05.09 14:55:40.690 5: CUL/RAW: A1465845E5B9A5900000080E64200000000/000
2021.05.09 14:55:40.690 5: CUL/RAW: A1465845E5B9A5900000080E64200000000000/93
2021.05.09 14:55:40.691 5: CUL/RAW: A1465845E5B9A5900000080E6420000000000093/A0
2021.05.09 14:55:40.691 5: CUL/RAW: A1465845E5B9A5900000080E6420000000000093A0/12
2021.05.09 14:55:40.692 5: CUL/RAW: A1465845E5B9A5900000080E6420000000000093A012/2
2021.05.09 14:55:40.692 5: CUL/RAW: A1465845E5B9A5900000080E6420000000000093A0122
2021.05.09 14:55:40.693 4: CUL_Parse: SCC A 14 65 845E 5B9A59 000000 80E6420000000000093A0122 -57
2021.05.09 14:55:40.694 5: SCC: dispatch A1465845E5B9A5900000080E6420000000000093A01::-57:SCC
2021.05.09 14:55:42.485 5: CUL/RAW: /A0
2021.05.09 14:55:42.486 5: CUL/RAW: A0/C6CA
2021.05.09 14:55:42.487 5: CUL/RAW: A0C6CA/64
2021.05.09 14:55:42.488 5: CUL/RAW: A0C6CA64/13
2021.05.09 14:55:42.488 5: CUL/RAW: A0C6CA6413/D32
2021.05.09 14:55:42.489 5: CUL/RAW: A0C6CA6413D32/80
2021.05.09 14:55:42.489 5: CUL/RAW: A0C6CA6413D3280/F1
2021.05.09 14:55:42.490 5: CUL/RAW: A0C6CA6413D3280F1/12
2021.05.09 14:55:42.490 5: CUL/RAW: A0C6CA6413D3280F112/34
2021.05.09 14:55:42.491 5: CUL/RAW: A0C6CA6413D3280F11234/01
2021.05.09 14:55:42.492 5: CUL/RAW: A0C6CA6413D3280F1123401/510
2021.05.09 14:55:42.492 5: CUL/RAW: A0C6CA6413D3280F1123401510/00
2021.05.09 14:55:42.493 5: CUL/RAW: A0C6CA6413D3280F112340151000/C
2021.05.09 14:55:42.493 5: CUL/RAW: A0C6CA6413D3280F112340151000C
2021.05.09 14:55:42.494 4: CUL_Parse: SCC A 0C 6C A641 3D3280 F11234 0151000C -68
2021.05.09 14:55:42.494 5: SCC: dispatch A0C6CA6413D3280F11234015100::-68:SCC
2021.05.09 14:55:42.497 5: SCC sending As0A6C8002F112343D328000
2021.05.09 14:55:42.497 5: CUL 3D3280 dly:96ms
2021.05.09 14:55:42.594 5: SW: As0A6C8002F112343D328000
2021.05.09 14:55:42.596 5: SCC sending As0A6C8002F112343D328000
2021.05.09 14:55:42.597 5: SW: As0A6C8002F112343D328000
List
   .triggerUsed 1
   DEF        3D3280
   IODev      SCC
   LASTInputDev SCC
   MSGCNT     18
   NAME       Wassermelder_1
   NOTIFYDEV  global
   NR         73
   SCC_MSGCNT 18
   SCC_RAWMSG A0C72A6413D3280F11234015700::-65.5:SCC
   SCC_RSSI   -65.5
   SCC_TIME   2021-05-09 15:01:19
   STATE      dry
   TYPE       CUL_HM
   chanNo     01
   lastMsg    No:72 - t:41 s:3D3280 d:F11234 015700
   protCmdDel 6
   protLastRcv 2021-05-09 15:01:19
   protRcv    18 last_at:2021-05-09 15:01:19
   protResnd  8 last_at:2021-05-09 15:00:51
   protResndFail 2 last_at:2021-05-09 15:01:01
   protSnd    48 last_at:2021-05-09 15:01:19
   protState  CMDs_done
   rssi_at_SCC cnt:18 min:-77.5 max:-58.5 avg:-69.77 lst:-65.5
   .attraggr:
   .attrminint:
   CL:
     Authenticated 1
     BUF
     FD         49
     FW_ID      5304
     LASTACCESS 1620565292
     NAME       WEB_93.232.90.27_49757
     NR         5304
     PEER       93.232.90.27
     PORT       49757
     SNAME      WEB
     SSL        1
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-09 15:00:12   state           Connected
     2021-05-09 15:01:19   .protLastRcv    20210509150119
     2021-05-09 15:01:19   battery         ok
     2021-05-09 15:00:17   cfgState        updating
     2021-05-09 15:01:19   commState       CMDs_done
     2021-05-09 15:01:19   contact         dry (to SCC)
     2021-05-09 15:01:19   state           dry
     2021-05-09 15:01:19   trigDst_F11234  noConfig
     2021-05-09 15:01:19   trigger_cnt     87
     RegL_00.:
       VAL
   helper:
     HM_CMDNR   114
     cSnd       01F112343D328000040000000000,01F112343D328000040000000000
     getCfgList all
     getCfgListNo ,4
     mId        00B2
     regLst     0,1,4p
     rxType     12
     supp_Pair_Rep 0
     tmplChg    0
     cfgChk:
       idPz05     F11234
     cmds:
       cmdLst:
         assignHmKey noArg
         getConfig  noArg
         getDevInfo noArg
         peerSmart  -peerOpt-
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        0
     io:
       flgs       0
       nextSend   1620565279.71066
       prefIO
       rxt        2
       vccu
       p:
         3D3280
         00
         00
         00
     mRssi:
       mNo        72
       io:
         SCC:
           -61.5
           -61.5
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rpt:
       IO         SCC
       flg        A
       ts         1620565279.61235
       ack:
         HASH(0x2419958)
         728002F112343D328000
         HASH(0x2419958)
     rssi:
       at_SCC:
         avg        -69.7777777777778
         cnt        18
         lst        -65.5
         max        -58.5
         min        -77.5
     shadowReg:
     tmpl:
   .mId       00B2
   IODev      SCC
   actCycle   028:00
   actStatus  alive
   firmware   1.4
   model      HM-SEC-WDS-2
   peerIDs    00000000
   room       CUL_HM
   serialNr   MEQ0590456
noansi
Hallo Stefan,
danke, war schon richtig mit der Version.
Da sind also noch Acks zu viel, damit noch eine andere Baustelle.
Gruß, Ansgar.
SHOFHEM
Guten Morgen Ansgar,
falls du noch mal was änderst teste ich es gerne. Ich kann aber auch mit dem jetztigen Stand sehr gut leben. Das liegt es jetzt an deinem Ehrgeiz!!  ;D ;D ;D
Vielen herzlichen Dank für deinen Support.
VG und eine schöne Woche
Stefan
frank
hallo ansgar,
hier mal ein sniff mit meinem sc.
zunächst ein getconfig mit IODev=hmuart, dann zum cul gewechselt und erneut ein getconfig.
kommunikation hat jeweils perfekt mit einmal knöpchen drücken funktioniert.
lediglich erfolgt das präparieren der io beim umswitchen auch hier zu spät, wodurch kostbare zeit verschwendet wird.
eigentlich müsste es bereits beim absetzen des cmds erfolgen.
2021.05.10 10:06:53.617 3: CUL_HM set Tuer.SZ getConfig noArg
2021.05.10 10:07:04.945 4: CUL_Parse: cul868 A 1A 9E 8400 1DE620 000000 20002F4A455130363434383238808101011F -58.5
2021.05.10 10:07:04.984 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D0EC9AE d:FF r:FFCF     m:9E 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 10:07:04.988 0: HMUARTLGW hmuart1 recv: 01 05 00 00 35 msg: 9E 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 10:07:05.048 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: C6 A0 01 1ACE1F 1DE620 00040000000000
2021.05.10 10:07:05.089 4: CUL_Parse: cul868 A 10 C6 A001 1ACE1F 1DE620 0004000000000067 -22.5
2021.05.10 10:07:05.100 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ECA3F d:FF r:FFCD     m:C6 A001 1ACE1F 1DE620 00040000000000
2021.05.10 10:07:05.221 4: CUL_Parse: cul868 A 1A C6 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600001F -58.5
2021.05.10 10:07:05.234 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D0ECAC3 d:FF r:FFD0     m:C6 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 10:07:05.237 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 10:07:05.239 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 10:07:05.240 0: HMUARTLGW hmuart1 recv: 01 05 01 00 33 msg: C6 A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 10:07:05.320 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: D6 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 10:07:05.326 0: HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.10 10:07:05.328 0: HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.10 10:07:05.333 4: CUL_Parse: cul868 A 0A C6 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 10:07:05.342 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ECB32 d:FF r:FFCE     m:C6 8002 1ACE1F 1DE620 00
2021.05.10 10:07:05.536 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: D6 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 10:07:05.568 4: CUL_Parse: cul868 A 10 D6 A001 1ACE1F 1DE620 0104000000000167 -22.5
2021.05.10 10:07:05.578 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ECC1D d:FF r:FFCD     m:D6 A001 1ACE1F 1DE620 01040000000001
2021.05.10 10:07:05.698 4: CUL_Parse: cul868 A 16 D6 A010 1DE620 1ACE1F 020800206021002264300600001F -58.5
2021.05.10 10:07:05.723 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D0ECC9E d:FF r:FFCE     m:D6 A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 10:07:05.727 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 10:07:05.728 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 10:07:05.731 0: HMUARTLGW hmuart1 recv: 01 05 01 00 34 msg: D6 A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 10:07:05.795 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: E6 A0 01 1ACE1F 1DE620 0103
2021.05.10 10:07:05.801 0: HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.10 10:07:05.802 0: HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.10 10:07:05.811 4: CUL_Parse: cul868 A 0A D6 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 10:07:05.821 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ECD11 d:FF r:FFCD     m:D6 8002 1ACE1F 1DE620 00
2021.05.10 10:07:06.025 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: E6 A0 01 1ACE1F 1DE620 0103
2021.05.10 10:07:06.051 4: CUL_Parse: cul868 A 0B E6 A001 1ACE1F 1DE620 010367 -22.5
2021.05.10 10:07:06.062 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ECE02 d:FF r:FFCD     m:E6 A001 1ACE1F 1DE620 0103
2021.05.10 10:07:06.181 4: CUL_Parse: cul868 A 12 E6 A010 1DE620 1ACE1F 011A164B01000000001F -58.5
2021.05.10 10:07:06.193 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D0ECE83 d:FF r:FFD0     m:E6 A010 1DE620 1ACE1F 011A164B0100000000
2021.05.10 10:07:06.197 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 10:07:06.198 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 10:07:06.200 0: HMUARTLGW hmuart1 recv: 01 05 01 00 34 msg: E6 A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.10 10:07:06.280 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: F6 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 10:07:06.286 0: HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.10 10:07:06.288 0: HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.10 10:07:06.298 4: CUL_Parse: cul868 A 0A E6 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 10:07:06.309 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ECEF9 d:FF r:FFCD     m:E6 8002 1ACE1F 1DE620 00
2021.05.10 10:07:06.495 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: F6 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 10:07:06.527 4: CUL_Parse: cul868 A 10 F6 A001 1ACE1F 1DE620 01041A164B010467 -22.5
2021.05.10 10:07:06.537 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ECFDD d:FF r:FFCD     m:F6 A001 1ACE1F 1DE620 01041A164B0104
2021.05.10 10:07:06.649 4: CUL_Parse: cul868 A 0E F6 A010 1DE620 1ACE1F 020100000020 -58
2021.05.10 10:07:06.687 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D0ED057 d:FF r:FFD1     m:F6 A010 1DE620 1ACE1F 0201000000
2021.05.10 10:07:06.691 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 10:07:06.692 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 10:07:06.693 0: HMUARTLGW hmuart1 recv: 01 05 01 00 35 msg: F6 A0 10 1DE620 1ACE1F 0201000000
2021.05.10 10:07:06.770 4: CUL_Parse: cul868 A 0A F6 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 10:07:06.780 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D0ED0D0 d:FF r:FFCE     m:F6 8002 1ACE1F 1DE620 00
2021-05-10 10:19:20.478 Global global ATTR Tuer.SZ IOgrp ccu:cul868
2021.05.10 10:19:32.767 3: CUL_HM set Tuer.SZ getConfig noArg
2021.05.10 10:19:40.180 4: CUL_Parse: cul868 A 1A 9F 8400 1DE620 000000 20002F4A455130363434383238808101011D -59.5
2021.05.10 10:19:40.185 0: HMUARTLGW hmuart1 send: 01 071DE620
2021.05.10 10:19:40.312 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D1A5038 d:FF r:FFD7     m:9F 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 10:19:40.316 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: 9F 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 10:19:40.319 0: HMUARTLGW hmuart1 recv: 01 040701010007, state 90
2021.05.10 10:19:40.320 0: HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.10 10:19:40.321 0: HMUARTLGW hmuart1 remove peer: 1DE620
2021.05.10 10:19:40.324 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: C7 A0 01 1ACE1F 1DE620 00040000000000
2021.05.10 10:19:40.329 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A50C0 d:FF r:FFD9     m:C7 A001 1ACE1F 1DE620 00040000000000
2021.05.10 10:19:40.448 4: CUL_Parse: cul868 A 1A C7 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600001D -59.5
2021.05.10 10:19:40.557 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: C7 A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 10:19:40.580 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: C7 80 02 1ACE1F 1DE620 00
2021.05.10 10:19:40.587 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A51C6 d:FF r:FFD9     m:C7 8002 1ACE1F 1DE620 00
2021.05.10 10:19:40.610 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D7 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 10:19:40.617 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A51E4 d:FF r:FFD9     m:D7 A001 1ACE1F 1DE620 01040000000001
2021.05.10 10:19:40.738 4: CUL_Parse: cul868 A 16 D7 A010 1DE620 1ACE1F 020800206021002264300600001C -60
2021.05.10 10:19:40.846 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D1A5265 d:FF r:FFD7     m:D7 A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 10:19:40.850 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D7 A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 10:19:40.869 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D7 80 02 1ACE1F 1DE620 00
2021.05.10 10:19:40.878 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A52E8 d:FF r:FFD9     m:D7 8002 1ACE1F 1DE620 00
2021.05.10 10:19:40.895 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: E7 A0 01 1ACE1F 1DE620 0103
2021.05.10 10:19:40.904 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A5302 d:FF r:FFD9     m:E7 A001 1ACE1F 1DE620 0103
2021.05.10 10:19:41.024 4: CUL_Parse: cul868 A 12 E7 A010 1DE620 1ACE1F 011A164B01000000001B -60.5
2021.05.10 10:19:41.133 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D1A5384 d:FF r:FFD7     m:E7 A010 1DE620 1ACE1F 011A164B0100000000
2021.05.10 10:19:41.137 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: E7 A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.10 10:19:41.156 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: E7 80 02 1ACE1F 1DE620 00
2021.05.10 10:19:41.164 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A5406 d:FF r:FFD9     m:E7 8002 1ACE1F 1DE620 00
2021.05.10 10:19:41.187 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: F7 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 10:19:41.193 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A5424 d:FF r:FFD9     m:F7 A001 1ACE1F 1DE620 01041A164B0104
2021.05.10 10:19:41.305 4: CUL_Parse: cul868 A 0E F7 A010 1DE620 1ACE1F 02010000001A -61
2021.05.10 10:19:41.435 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D1A549F d:FF r:FFD7     m:F7 A010 1DE620 1ACE1F 0201000000
2021.05.10 10:19:41.439 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: F7 A0 10 1DE620 1ACE1F 0201000000
2021.05.10 10:19:41.442 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: F7 80 02 1ACE1F 1DE620 00
2021.05.10 10:19:41.448 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D1A5520 d:FF r:FFD9     m:F7 8002 1ACE1F 1DE620 00
   .triggerUsed 1
   DEF        1DE620
   FUUID      5c4ce2e9-f33f-09c4-0cb4-ff17181d27954a49
   IODev      cul868
   LASTInputDev hmuart1
   MSGCNT     53
   NAME       Tuer.SZ
   NOTIFYDEV  global
   NR         292
   NTFY_ORDER 50-Tuer.SZ
   STATE      Tuer:closed (to SwitchPBU05), Status:closed, Sabotage:on, Bat:ok
   TYPE       CUL_HM
   chanNo     01
   cul868_MSGCNT 18
   cul868_RAWMSG A0EF7A0101DE6201ACE1F0201000000::-61:cul868
   cul868_RSSI -61
   cul868_TIME 2021-05-10 10:19:41
   hmlan1_MSGCNT 17
   hmlan1_RAWMSG E1DE620,0000,4D1A549F,FF,FFD7,F7A0101DE6201ACE1F0201000000
   hmlan1_RSSI -41
   hmlan1_TIME 2021-05-10 10:19:41
   hmuart1_MSGCNT 18
   hmuart1_RAWMSG 0500003BF7A0101DE6201ACE1F0201000000
   hmuart1_RSSI -59
   hmuart1_TIME 2021-05-10 10:19:41
   lastMsg    No:F7 - t:10 s:1DE620 d:1ACE1F 0201000000
   peerList   SwitchPBU05
   protLastRcv 2021-05-10 10:19:41
   protRcv    18 last_at:2021-05-10 10:19:41
   protSnd    20 last_at:2021-05-10 10:19:41
   protState  CMDs_done
   rssi_at_cul868 cnt:18 min:-61 max:-57.5 avg:-59.11 lst:-61
   rssi_at_hmlan1 cnt:17 min:-63 max:-41 avg:-47.35 lst:-41
   rssi_at_hmuart1 cnt:18 min:-70 max:-51 avg:-59.5 lst:-59
   .attraggr:
   .attreocr:
   .attrminint:
   CL:
     Authenticated 0
     BUF
     FD         81
     FW_ID      889
     LASTACCESS 1620636948
     NAME       WEB_192.168.1.31_49846
     NR         1663
     PEER       192.168.1.31
     PORT       49846
     SNAME      WEB
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-10 10:54:40   state           Connected
     2021-05-10 10:19:40   .D-devInfo      810101
     2021-05-10 10:19:40   .D-stc          80
     2021-05-10 10:19:41   .associatedWith Tuer.SZ,Tuer.SZ,SwitchPBU05
     2021-05-10 10:19:41   .peerListRDate  2021-05-10 10:19:41
     2021-05-10 10:19:41   .protLastRcv    20210510101941
     2021-05-10 09:58:26   Activity        alive
     2021-04-07 14:26:54   CommandAccepted yes
     2021-05-10 10:19:40   D-firmware      2.0
     2021-05-10 10:19:40   D-serialNr      JEQ0644828
     2021-05-10 09:53:41   IODev           hmuart1
     2021-05-10 10:19:40   PairedTo        0x1ACE1F
     2021-05-07 12:01:39   R-SwitchPBU05_chn-01-expectAES off
     2021-05-07 12:01:39   R-SwitchPBU05_chn-01-peerNeedsBurst off
     2021-05-07 12:01:39   R-cyclicInfoMsg on
     2021-05-07 12:01:39   R-eventDlyTime  0 s
     2021-05-07 12:01:39   R-ledOnTime     0.5 s
     2021-05-07 12:01:39   R-msgScPosA     closed
     2021-05-07 12:01:39   R-msgScPosB     open
     2021-05-07 12:01:39   R-pairCentral   0x1ACE1F
     2021-05-07 12:01:39   R-sabotageMsg   on
     2021-05-07 12:01:39   R-sign          off
     2021-05-07 12:01:39   R-transmDevTryMax 6
     2021-05-07 12:01:39   R-transmitTryMax 6
     2021-05-10 10:19:40   RegL_00.         00:00 02:00 09:01 0A:1A 0B:CE 0C:1F 10:01 14:06
     2021-05-10 10:19:40   RegL_01.         00:00 08:00 20:60 21:00 22:64 30:06
     2021-05-10 10:19:41   RegL_04.SwitchPBU05_chn-01  00:00 01:00
     2021-04-07 14:20:01   aesCommToDev    ok
     2021-04-07 14:20:01   aesKeyNbr       00
     2021-03-29 12:11:35   aesReqTo        ccu
     2021-05-09 18:14:04   alive           yes
     2021-05-10 10:01:34   battery         ok
     2021-05-10 10:20:41   cfgState        ok
     2021-05-10 10:19:41   commState       CMDs_done
     2021-05-10 10:01:34   contact         closed (to SwitchPBU05)
     2021-05-10 10:19:41   peerList        SwitchPBU05
     2021-03-29 12:11:34   powerOn         2021-03-29 12:11:34
     2021-05-09 18:14:04   recentStateType info
     2021-05-09 18:14:04   sabotageError   on
     2021-05-10 10:01:34   state           closed
     2021-05-10 10:01:34   trigger_cnt     33
   helper:
     HM_CMDNR   247
     cSnd       011ACE1F1DE6200103,011ACE1F1DE62001041A164B0104
     mId        002F
     peerIDsRaw ,1A164B01,00000000
     regLst     0,1,4p
     rxType     4
     supp_Pair_Rep 0
     tmplChg    0
     ack:
     cmds:
       TmplKey    SwitchPBU05:1620633229.79916:1620633229.88849
       TmplTs     1620633229.88849
       cmdKey     1:1:0::Tuer.SZ:002F:01:SwitchPBU05
       cmdLst:
         assignHmKey noArg
         getConfig  noArg
         getDevInfo noArg
         peerSmart  -peerOpt-
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         tplSet_SwitchPBU05 -tplPeer-
         unpair     noArg
       lst:
         condition  closed,open,tilted
         peer       SwitchPBU05
         peerOpt    DimPBU01_Dim,DimPBU01_Dim_V_01,DimPBU01_Dim_V_02,DimUP01,SDTeam_Btn1,SwitchES01_Sw,SwitchPBU01_Sw_01,SwitchPBU01_Sw_02,SwitchPBU02_Sw_01,SwitchPBU02_Sw_02,SwitchPBU03,SwitchPBU05,SwitchPBU06,SwitchUP01,SwitchUP02,VentilControler.AZ.Nord_Btn1,VentilControler.AZ.West_Btn1,VentilControler.Bad_Btn1,VentilControler.Kueche_Btn1,VentilControler.SZ_Btn1,VentilControler.WZ_Btn1,ccu_Btn1,ccu_Btn2,ccu_Btn3,ccu_Btn4,ccu_Btn5,rssi_hmuart_Btn1,virtAktorAlarmOff_Btn1
         tplChan    single-chn-sensor-device
         tplDel
         tplPeer    single-chn-sensor-peer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     io:
       flgs       0
       newChn     +1DE620,00,00,00
       nextSend   1620634781.73535
       rxt        0
       vccu       ccu
       p:
         1DE620
         00
         00
         00
       prefIO:
         cul868
     mRssi:
       mNo        F7
       io:
         cul868:
           -57
           -57
         hmlan1:
           -41
           -41
         hmuart1:
           -59
           -59
         hmusb1:
     peerIDsH:
       00000000   broadcast
       1A164B01   SwitchPBU05_chn-01
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rpt:
       IO         cul868
       flg        A
       ts         1620634781.30735
       ack:
         HASH(0x49c1378)
         F780021ACE1F1DE62000
     rssi:
       at_cul868:
         avg        -59.1111111111111
         cnt        18
         lst        -61
         max        -57.5
         min        -61
       at_hmlan1:
         avg        -47.3529411764706
         cnt        17
         lst        -41
         max        -41
         min        -63
       at_hmuart1:
         avg        -59.5
         cnt        18
         lst        -59
         max        -51
         min        -70
     shadowReg:
     tmpl:
   .mId       002F
   IODev      cul868
   IOgrp      ccu:cul868
   actCycle   028:00
   actStatus  alive
   autoReadReg 5_readMissing
   event-on-change-reading .*
   expert     defReg,allReg,rawReg,templ
   firmware   2.0
   group      Alarmmelder
   model      HM-SEC-SC
   peerIDs    00000000,1A164B01
   room       01_ALARM,50_SZ
   serialNr   JEQ0644828
   stateFormat Tuer:contact, Status:state, Sabotage:sabotageError, Bat:battery
   webCmd     getConfig:clear msgEvents
gruss frank
FHEM: 6.0(SVN) => Pi3(buster)
frank
hi ansgar,
es gibt doch noch ein gewaltiges problem, weshalb SHOFHEM nun wahrscheinlich mehrmals das knöpfchen drücken musste.
im vorherigen post hatte mein sc rxt=4, also config mode => alles bestens mit einmal knöpfchen drücken.
nun habe ich rxt=12 gestzt, also config und wakeup mode => jetzt muss ich auch jeden befehl einzeln holen (io=cul).
ausserdem wurde auf die erste anlernmessage gar nicht reagiert.
das liegt scheinbar an den falschen ACKs. mit wakeup mode kommt nun 8102 anstatt 8002 wie bei SHOFHEM.
mit hmuart kommen weiterhin 8002 ACKs und alles funktioniert mit einer configmessage. auch hier natürlich immer noch das zu späte präparieren des io.
2021.05.10 11:38:17.437 3: CUL_HM set Tuer.SZ getConfig noArg
2021.05.10 11:38:22.753 4: CUL_Parse: cul868 A 1A A7 8400 1DE620 000000 20002F4A455130363434383238808101011F -58.5
2021.05.10 11:38:22.759 0: HMUARTLGW hmuart1 recv: 01 05 00 00 37 msg: A7 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:38:22.763 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D626252 d:FF r:FFD5     m:A7 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:38:48.466 4: CUL_Parse: cul868 A 1A A8 8400 1DE620 000000 20002F4A4551303634343832388081010118 -62
2021.05.10 11:38:48.598 0: HMUARTLGW hmuart1 recv: 01 05 00 00 37 msg: A8 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:38:48.602 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D62C6C6 d:FF r:FFD6     m:A8 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:38:48.606 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D0 A0 01 1ACE1F 1DE620 00040000000000
2021.05.10 11:38:48.639 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D62C74D d:FF r:FFD9     m:D0 A001 1ACE1F 1DE620 00040000000000
2021.05.10 11:38:48.736 4: CUL_Parse: cul868 A 1A D0 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600001B -60.5
2021.05.10 11:38:48.854 0: HMUARTLGW hmuart1 recv: 01 05 00 00 37 msg: D0 A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 11:38:48.869 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D0 81 02 1ACE1F 1DE620 00
2021.05.10 11:38:48.876 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D62C857 d:FF r:FFD9     m:D0 8102 1ACE1F 1DE620 00
2021.05.10 11:38:48.900 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: E0 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 11:38:48.906 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D62C875 d:FF r:FFD9     m:E0 A001 1ACE1F 1DE620 01040000000001
2021.05.10 11:39:59.539 4: CUL_Parse: cul868 A 1A A9 8400 1DE620 000000 20002F4A4551303634343832388081010114 -64
2021.05.10 11:39:59.679 0: HMUARTLGW hmuart1 recv: 01 05 00 00 44 msg: A9 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:39:59.682 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D1 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 11:39:59.686 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D63DC70 d:FF r:FFD3     m:A9 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:39:59.689 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D63DCF9 d:FF r:FFD9     m:D1 A001 1ACE1F 1DE620 01040000000001
2021.05.10 11:39:59.804 4: CUL_Parse: cul868 A 16 D1 A010 1DE620 1ACE1F 0208002060210022643006000017 -62.5
2021.05.10 11:39:59.913 0: HMUARTLGW hmuart1 recv: 01 05 00 00 47 msg: D1 A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 11:39:59.916 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D63DD7A d:FF r:FFCF     m:D1 A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 11:39:59.936 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D1 81 02 1ACE1F 1DE620 00
2021.05.10 11:39:59.944 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D63DDFC d:FF r:FFD9     m:D1 8102 1ACE1F 1DE620 00
2021.05.10 11:39:59.962 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: E1 A0 01 1ACE1F 1DE620 0103
2021.05.10 11:39:59.970 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D63DE16 d:FF r:FFD9     m:E1 A001 1ACE1F 1DE620 0103
2021.05.10 11:40:28.875 4: CUL_Parse: cul868 A 1A AA 8400 1DE620 000000 20002F4A455130363434383238808101010D -67.5
2021.05.10 11:40:29.009 0: HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: AA 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:40:29.013 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D2 A0 01 1ACE1F 1DE620 0103
2021.05.10 11:40:29.017 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D644F0C d:FF r:FFC9     m:AA 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:40:29.020 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D644F90 d:FF r:FFD9     m:D2 A001 1ACE1F 1DE620 0103
2021.05.10 11:40:29.136 4: CUL_Parse: cul868 A 12 D2 A010 1DE620 1ACE1F 011A164B01000000000E -67
2021.05.10 11:40:29.245 0: HMUARTLGW hmuart1 recv: 01 05 00 00 35 msg: D2 A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.10 11:40:29.248 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D645011 d:FF r:FFCC     m:D2 A010 1DE620 1ACE1F 011A164B0100000000
2021.05.10 11:40:29.268 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D2 81 02 1ACE1F 1DE620 00
2021.05.10 11:40:29.276 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D645094 d:FF r:FFD9     m:D2 8102 1ACE1F 1DE620 00
2021.05.10 11:40:29.299 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: E2 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 11:40:29.306 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D6450B2 d:FF r:FFD9     m:E2 A001 1ACE1F 1DE620 01041A164B0104
2021.05.10 11:40:55.400 4: CUL_Parse: cul868 A 1A AB 8400 1DE620 000000 20002F4A4551303634343832388081010109 -69.5
2021.05.10 11:40:55.540 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D64B6AD d:FF r:FFD4     m:AB 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:40:55.544 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: AB 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 11:40:55.548 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D3 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 11:40:55.553 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D64B735 d:FF r:FFD9     m:D3 A001 1ACE1F 1DE620 01041A164B0104
2021.05.10 11:40:55.658 4: CUL_Parse: cul868 A 0E D3 A010 1DE620 1ACE1F 02010000000A -69
2021.05.10 11:40:55.794 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D64B7AF d:FF r:FFD4     m:D3 A010 1DE620 1ACE1F 0201000000
2021.05.10 11:40:55.798 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: D3 A0 10 1DE620 1ACE1F 0201000000
2021.05.10 11:40:55.802 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D3 80 02 1ACE1F 1DE620 00
2021.05.10 11:40:55.807 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D64B831 d:FF r:FFD9     m:D3 8002 1ACE1F 1DE620 00
2021.05.10 12:03:28.291 3: CUL_HM set Tuer.SZ getConfig noArg
2021.05.10 12:03:37.528 4: CUL_Parse: cul868 A 1A AC 8400 1DE620 000000 20002F4A455130363434383238808101012E -51
2021.05.10 12:03:37.533 0: HMUARTLGW hmuart1 send: 01 061DE620000100
2021.05.10 12:03:37.565 0: HMUARTLGW hmuart1 recv: 01 05 00 00 32 msg: AC 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 12:03:37.569 0: HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.10 12:03:37.570 0: HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.10 12:03:37.571 0: HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.10 12:03:37.573 0: HMUARTLGW hmuart1 send: 01 061DE620000100
2021.05.10 12:03:37.577 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D798036 d:FF r:FFCC     m:AC 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 12:03:37.581 0: HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.10 12:03:37.582 0: HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.10 12:03:37.583 0: HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.10 12:03:37.627 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: D4 A0 01 1ACE1F 1DE620 00040000000000
2021.05.10 12:03:37.673 4: CUL_Parse: cul868 A 10 D4 A001 1ACE1F 1DE620 0004000000000067 -22.5
2021.05.10 12:03:37.684 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D7980C8 d:FF r:FFCD     m:D4 A001 1ACE1F 1DE620 00040000000000
2021.05.10 12:03:37.806 4: CUL_Parse: cul868 A 1A D4 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600002D -51.5
2021.05.10 12:03:37.816 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 12:03:37.818 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 12:03:37.820 0: HMUARTLGW hmuart1 recv: 01 05 01 00 31 msg: D4 A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 12:03:37.823 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D79814C d:FF r:FFD1     m:D4 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 12:03:37.909 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: E4 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 12:03:37.915 0: HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.10 12:03:37.916 0: HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.10 12:03:37.919 4: CUL_Parse: cul868 A 0A D4 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 12:03:37.927 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D7981BC d:FF r:FFCD     m:D4 8002 1ACE1F 1DE620 00
2021.05.10 12:03:37.969 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: E4 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 12:03:38.061 4: CUL_Parse: cul868 A 10 E4 A001 1ACE1F 1DE620 0104000000000167 -22.5
2021.05.10 12:03:38.070 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D79824B d:FF r:FFCE     m:E4 A001 1ACE1F 1DE620 01040000000001
2021.05.10 12:03:38.191 4: CUL_Parse: cul868 A 16 E4 A010 1DE620 1ACE1F 0208002060210022643006000028 -54
2021.05.10 12:03:38.201 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 12:03:38.202 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 12:03:38.204 0: HMUARTLGW hmuart1 recv: 01 05 01 00 31 msg: E4 A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 12:03:38.207 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D7982CD d:FF r:FFD0     m:E4 A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 12:03:38.294 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: F4 A0 01 1ACE1F 1DE620 0103
2021.05.10 12:03:38.300 0: HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.10 12:03:38.301 0: HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.10 12:03:38.305 4: CUL_Parse: cul868 A 0A E4 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 12:03:38.315 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D798340 d:FF r:FFCD     m:E4 8002 1ACE1F 1DE620 00
2021.05.10 12:03:38.353 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: F4 A0 01 1ACE1F 1DE620 0103
2021.05.10 12:03:38.444 4: CUL_Parse: cul868 A 0B F4 A001 1ACE1F 1DE620 010367 -22.5
2021.05.10 12:03:38.454 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D7983CB d:FF r:FFCD     m:F4 A001 1ACE1F 1DE620 0103
2021.05.10 12:03:38.575 4: CUL_Parse: cul868 A 12 F4 A010 1DE620 1ACE1F 011A164B010000000027 -54.5
2021.05.10 12:03:38.586 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 12:03:38.587 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 12:03:38.589 0: HMUARTLGW hmuart1 recv: 01 05 01 00 31 msg: F4 A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.10 12:03:38.592 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D79844D d:FF r:FFD1     m:F4 A010 1DE620 1ACE1F 011A164B0100000000
2021.05.10 12:03:38.678 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 04 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 12:03:38.684 0: HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.10 12:03:38.686 0: HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.10 12:03:38.693 4: CUL_Parse: cul868 A 0A F4 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 12:03:38.703 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D7984C4 d:FF r:FFCE     m:F4 8002 1ACE1F 1DE620 00
2021.05.10 12:03:38.738 0: HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 04 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 12:03:38.837 4: CUL_Parse: cul868 A 10 04 A001 1ACE1F 1DE620 01041A164B010467 -22.5
2021.05.10 12:03:38.846 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D798553 d:FF r:FFCE     m:04 A001 1ACE1F 1DE620 01041A164B0104
2021.05.10 12:03:38.959 4: CUL_Parse: cul868 A 0E 04 A010 1DE620 1ACE1F 020100000028 -54
2021.05.10 12:03:38.991 0: HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.10 12:03:38.992 0: HMUARTLGW hmuart1 Ack: 02
2021.05.10 12:03:38.993 0: HMUARTLGW hmuart1 send: 01 061DE620000000
2021.05.10 12:03:38.996 0: HMUARTLGW hmuart1 recv: 01 05 01 00 31 msg: 04 A0 10 1DE620 1ACE1F 0201000000
2021.05.10 12:03:39.000 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D7985CF d:FF r:FFCF     m:04 A010 1DE620 1ACE1F 0201000000
2021.05.10 12:03:39.004 0: HMUARTLGW hmuart1 recv: 01 0408, state 90
2021.05.10 12:03:39.005 0: HMUARTLGW hmuart1 GetSet Ack: 08, state 90
2021.05.10 12:03:39.081 4: CUL_Parse: cul868 A 0A 04 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 12:03:39.090 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D798647 d:FF r:FFCD     m:04 8002 1ACE1F 1DE620 00
2021.05.10 12:03:39.321 4: CUL_Parse: cul868 A 0C E0 8670 206219 000000 008751E3 -88.5
2021.05.10 12:03:39.508 0: HMUARTLGW hmuart1 send: 01 061DE620000000
2021.05.10 12:03:39.514 0: HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.10 12:03:39.516 0: HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.10 12:03:39.516 0: HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.10 12:03:39.519 0: HMUARTLGW hmuart1 send: 01 061DE620000000
2021.05.10 12:03:39.526 0: HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.10 12:03:39.527 0: HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.10 12:03:39.527 0: HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
gruss frank
frank
hi ansgar,
und nun kommt das absolute chaos.  ;)
IOgrp wieder auf cul als prefered io umgestellt => getconfig => knöpfchen drücken:
jetzt funkt scheinbar der hmuart dazwischen, da er nicht unassigned wurde.
jetzt gibt es A112, 8102 und 8002 und zusätzlich werden die cmds doppelt mit unterschiedlichen msgnummern gesendet.
2021-05-10 12:34:13.060 Global global ATTR Tuer.SZ IOgrp ccu:cul868
2021.05.10 12:36:40.389 3 : CUL_HM set Tuer.SZ getConfig noArg
2021-05-10 12:36:40.409 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.10 12:36:40.415 0 : HMUARTLGW hmuart1 send: 01 061DE620000100
2021-05-10 12:36:40.437 CUL_HM Tuer.SZ cfgState: updating
2021.05.10 12:36:40.447 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.10 12:36:40.448 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.10 12:36:40.449 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.10 12:36:40.451 0 : HMUARTLGW hmuart1 send: 01 061DE620000100
2021.05.10 12:36:40.458 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.10 12:36:40.459 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.10 12:36:40.460 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.10 12:36:49.158 4 : CUL_Parse: cul868 A 1A AF 8400 1DE620 000000 20002F4A455130363434383238808101012C -52
2021.05.10 12:36:49.169 0 : HMUARTLGW hmuart1 send: 01 071DE620
2021.05.10 12:36:49.328 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D97E581 d:FF r:FFCD     m:09 A112 1ACE1F 1DE620
2021.05.10 12:36:49.332 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D97E59F d:FF r:FFD9     m:D7 A001 1ACE1F 1DE620 00040000000000
2021.05.10 12:36:49.337 4 : CUL_Parse: cul868 A 09 09 A112 1ACE1F 1DE620 67 -22.5
2021.05.10 12:36:49.343 0 : HMUARTLGW hmuart1 recv: 01 0408, state 90
2021.05.10 12:36:49.344 0 : HMUARTLGW hmuart1 GetSet Ack: 08, state 90
2021.05.10 12:36:49.430 4 : CUL_Parse: cul868 A 1A D7 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600002C -52
2021.05.10 12:36:49.542 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D97E625 d:FF r:FFC3     m:D7 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 12:36:49.554 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: AF 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 12:36:49.688 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D97E69E d:FF r:FFCD     m:D7 8002 1ACE1F 1DE620 00
2021.05.10 12:36:49.693 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D97E6B7 d:FF r:FFD9     m:D7 8102 1ACE1F 1DE620 00
2021.05.10 12:36:49.697 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D97E6D6 d:FF r:FFD9     m:E7 A001 1ACE1F 1DE620 01040000000001
2021.05.10 12:36:49.701 4 : CUL_Parse: cul868 A 0A D7 8002 1ACE1F 1DE620 0067 -22.5
2021.05.10 12:36:49.707 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: E7 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 12:36:49.712 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: D7 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 12:36:49.717 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D97E723 d:FF r:FFD9     m:D7 A001 1ACE1F 1DE620 01040000000001
2021.05.10 12:36:49.847 0 : HMUARTLGW hmuart1 send: 01 071DE620
2021.05.10 12:36:49.853 0 : HMUARTLGW hmuart1 recv: 01 0408, state 90
2021.05.10 12:36:49.855 0 : HMUARTLGW hmuart1 GetSet Ack: 08, state 90
2021.05.10 12:36:49.868 4 : CUL_Parse: cul868 A 09 09 A112 1ACE1F 1DE620 66 -23
2021.05.10 12:36:49.879 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D97E7DB d:FF r:FFCD     m:09 A112 1ACE1F 1DE620
2021.05.10 12:36:50.358 0 : HMUARTLGW hmuart1 send: 01 071DE620
2021.05.10 12:36:50.363 0 : HMUARTLGW hmuart1 recv: 01 040701010007, state 90
2021.05.10 12:36:50.364 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.10 12:36:50.365 0 : HMUARTLGW hmuart1 remove peer: 1DE620
2021.05.10 12:36:54.538 0 : HMUARTLGW hmuart1 send: 00 08
2021.05.10 12:36:54.542 0 : HMUARTLGW hmuart1 recv: 00 040207, state 98
2021.05.10 12:36:54.544 0 : HMUARTLGW hmuart1 GetSet Ack: 02, state 98
2021.05.10 12:36:54.544 0 : HMUARTLGW hmuart1 roundtrip delay: 0.0031
2021.05.10 12:37:03.205 4 : CUL_Parse: cul868 A 1A B0 8400 1DE620 000000 20002F4A455130363434383238808101012B -52.5
2021.05.10 12:37:03.215 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: B0 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 12:37:03.219 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D981BF5 d:FF r:FFC7     m:B0 8400 1DE620 000000 20002F4A45513036343438323880810101
obwohl pending cmds angezeigt wurden, wurde auf die 2. configmessage nicht reagiert.
hier noch ein list nach der 2. configmsg:
   .cfgStateUpdateTmr 1
   .triggerUsed 1
   DEF        1DE620
   IODev      cul868
   LASTInputDev hmlan1
   MSGCNT     79
   NAME       Tuer.SZ
   NOTIFYDEV  global
   NR         292
   STATE      Tuer:closed (to ccu), Status:closed, Sabotage:on, Bat:ok
   TYPE       CUL_HM
   chanNo     01
   cul868_MSGCNT 28
   cul868_RAWMSG A1AB084001DE62000000020002F4A45513036343438323880810101::-52.5:cul868
   cul868_RSSI -52.5
   cul868_TIME 2021-05-10 12:37:03
   hmlan1_MSGCNT 24
   hmlan1_RAWMSG E1DE620,0000,4D981BF5,FF,FFC7,B084001DE62000000020002F4A45513036343438323880810101
   hmlan1_RSSI -57
   hmlan1_TIME 2021-05-10 12:37:03
   hmuart1_MSGCNT 27
   hmuart1_RAWMSG 05000039B084001DE62000000020002F4A45513036343438323880810101
   hmuart1_RSSI -57
   hmuart1_TIME 2021-05-10 12:37:03
   lastMsg    No:B0 - t:00 s:1DE620 d:000000 20002F4A45513036343438323880810101
   protCmdDel 3
   protCmdPend 2 CMDs_pending
   protLastRcv 2021-05-10 12:37:03
   protRcv    29 last_at:2021-05-10 12:37:03
   protResnd  8 last_at:2021-05-10 12:36:55
   protResndFail 1 last_at:2021-05-10 11:33:45
   protSnd    38 last_at:2021-05-10 12:36:49
   protState  CMDs_pending
   rssi_at_cul868 cnt:28 min:-69.5 max:-51 avg:-59.98 lst:-52.5
   rssi_at_hmlan1 cnt:24 min:-64 max:-42 avg:-52.12 lst:-57
   rssi_at_hmuart1 cnt:27 min:-71 max:-49 avg:-54.55 lst:-57
   .attraggr:
   .attreocr:
   .attrminint:
   CL:
     Authenticated 0
     BUF
     FD         77
     FW_ID      889
     LASTACCESS 1620644182
     NAME       WEB_192.168.1.31_50442
     NR         2232
     PEER       192.168.1.31
     PORT       50442
     SNAME      WEB
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-10 12:56:19   state           Connected
     2021-05-10 12:36:49   .D-devInfo      810101
     2021-05-10 12:36:49   .D-stc          80
     2021-05-10 12:22:52   .associatedWith Tuer.SZ,Tuer.SZ,SwitchPBU05
     2021-05-10 12:22:52   .peerListRDate  2021-05-10 12:22:52
     2021-05-10 12:37:03   .protLastRcv    20210510123703
     2021-05-10 11:29:42   Activity        alive
     2021-05-10 12:36:49   D-firmware      2.0
     2021-05-10 12:36:49   D-serialNr      JEQ0644828
     2021-05-10 11:24:44   IODev           cul868
     2021-05-10 12:36:49   PairedTo        0x1ACE1F
     2021-05-10 11:40:55   R-SwitchPBU05_chn-01-expectAES off
     2021-05-10 11:40:55   R-SwitchPBU05_chn-01-peerNeedsBurst off
     2021-05-10 11:25:04   R-cyclicInfoMsg on
     2021-05-10 11:25:04   R-eventDlyTime  0 s
     2021-05-10 11:25:04   R-ledOnTime     0.5 s
     2021-05-10 11:25:04   R-msgScPosA     closed
     2021-05-10 11:25:04   R-msgScPosB     open
     2021-05-10 11:25:04   R-pairCentral   0x1ACE1F
     2021-05-10 11:25:04   R-sabotageMsg   on
     2021-05-10 11:25:04   R-sign          off
     2021-05-10 11:25:04   R-transmDevTryMax 6
     2021-05-10 11:25:04   R-transmitTryMax 6
     2021-05-10 12:36:49   RegL_00.         00:00 02:00 09:01 0A:1A 0B:CE 0C:1F 10:01 14:06
     2021-05-10 12:22:59   alive           yes
     2021-05-10 12:22:59   battery         ok
     2021-05-10 12:36:40   cfgState        updating
     2021-05-10 12:36:55   commState       CMDs_pending
     2021-05-10 12:22:59   contact         closed (to ccu)
     2021-05-10 12:22:52   peerList        SwitchPBU05
     2021-05-10 12:22:59   recentStateType info
     2021-05-10 12:22:59   sabotageError   on
     2021-05-10 12:22:59   state           closed
     RegL_01.:
       VAL
   cmdStack:
     ++A0011ACE1F1DE62001040000000001
     ##A0011ACE1F1DE6200103
   helper:
     HM_CMDNR   176
     cSnd       011ACE1F1DE62001040000000001,011ACE1F1DE62001040000000001
     getCfgList all
     getCfgListNo ,4
     mId        002F
     peerFriend peerAct,peerVirt
     peerIDsState complete
     peerOpt    4:threeStateSensor
     regLst     0,1,4p
     rxType     12
     supp_Pair_Rep 0
     tmplChg    0
     ack:
     cmds:
       TmplKey    SwitchPBU05:1620638704.57644:1620638705.88853
       TmplTs     1620638705.88853
       cmdLst:
         assignHmKey noArg
         clear      [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   -btnNumber- -actChn- [({single})] [({set}|unset)] [actor|remote|both]
         peerSmart  -peerOpt-
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- -addr2:data2-...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         trgEventL  -peer- -condition-
         trgEventS  -peer- -condition-
         trgPressL  [(-peer-|{all})]
         trgPressS  [(-peer-|{all})]
         unpair     noArg
       lst:
         peer       SwitchPBU05
         peerOpt    DimPBU01_Dim,DimPBU01_Dim_V_01,DimPBU01_Dim_V_02,DimUP01,SDTeam_Btn1,SwitchES01_Sw,SwitchPBU01_Sw_01,SwitchPBU01_Sw_02,SwitchPBU02_Sw_01,SwitchPBU02_Sw_02,SwitchPBU03,SwitchPBU05,SwitchPBU06,SwitchUP01,SwitchUP02,VentilControler.AZ.Nord_Btn1,VentilControler.AZ.West_Btn1,VentilControler.Bad_Btn1,VentilControler.Kueche_Btn1,VentilControler.SZ_Btn1,VentilControler.WZ_Btn1,ccu_Btn1,ccu_Btn2,ccu_Btn3,ccu_Btn4,ccu_Btn5,rssi_hmuart_Btn1,virtAktorAlarmOff_Btn1,virt_vd_Btn1
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     io:
       flgs       2
       newChn     +1DE620,02,00,00
       nextSend   1620643023.30495
       rxt        2
       vccu       ccu
       p:
         1DE620
         00
         00
         00
       prefIO:
         cul868
     mRssi:
       mNo        B0
       io:
         cul868:
           -46.5
           -46.5
         hmlan1:
           -57
           -57
         hmuart1:
           -57
           -57
         hmusb1:
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      2
       wuReSent   3
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rssi:
       at_cul868:
         avg        -59.9821428571429
         cnt        28
         lst        -52.5
         max        -51
         min        -69.5
       at_hmlan1:
         avg        -52.125
         cnt        24
         lst        -57
         max        -42
         min        -64
       at_hmuart1:
         avg        -54.5555555555556
         cnt        27
         lst        -57
         max        -49
         min        -71
     shadowReg:
     tmpl:
   .mId       002F
   IODev      cul868
   IOgrp      ccu:cul868
   actCycle   028:00
   actStatus  alive
   firmware   2.0
   group      Alarmmelder
   model      HM-SEC-SC
   room       01_ALARM,50_SZ
   serialNr   JEQ0644828
   subType    threeStateSensor
gruss frank
noansi
#68
Hallo Frank, hallo Stefan,
im Anhang wieder was zum Testen (same procedure wie beim letzten mal)
getConfig Knöpfchen Drücken sollte nun in einem Rutsch gehen können, so denn das Timing passt und nichts dazwischen funkt.
Bei Triggern hängt viel am Timing und Wiederholungen durch die IOs (was CUL ja nicht macht).
@Frank: Das Problem der IO Zuweisung sollten wir separat im Anschluss angehen.
Es sind schon jetzt wieder viele Änderungen, die erst mal hinreichend zu testen sind + die Fragestellung, was oder wie Martin übernimmt.
Also wenn Du mit verschiedenen IOs testest, dann bitte erst mal den IO Wechsel via Trigger anstoßen.
Gruß, Ansgar.
frank
hi ansgar,
jetzt funktioniert getconfig auch mit rxt=12 und cul mit nur einem druck aufs knöpfchen. danke.
2021.05.10 21:59:35.224 4 : CUL_Parse: cul868 A 1A B5 8400 1DE620 000000 20002F4A4551303634343832388081010126 -55
2021-05-10 21:59:35.351 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.10 21:59:35.353 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: B5 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 21:59:35.356 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4F9B31F0 d:FF r:FFD4     m:B5 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.10 21:59:35.362 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: DD A0 01 1ACE1F 1DE620 00040000000000
2021.05.10 21:59:35.369 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B3279 d:FF r:FFD9     m:DD A001 1ACE1F 1DE620 00040000000000
2021.05.10 21:59:35.491 4 : CUL_Parse: cul868 A 1A DD A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F10011406000029 -53.5
2021.05.10 21:59:35.600 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: DD A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 21:59:35.603 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4F9B32FD d:FF r:FFD5     m:DD A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 21:59:35.623 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: DD 80 02 1ACE1F 1DE620 00
2021.05.10 21:59:35.631 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B337F d:FF r:FFD8     m:DD 8002 1ACE1F 1DE620 00
2021.05.10 21:59:35.654 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: ED A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 21:59:35.661 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B339D d:FF r:FFD8     m:ED A001 1ACE1F 1DE620 01040000000001
2021.05.10 21:59:35.780 4 : CUL_Parse: cul868 A 16 ED A010 1DE620 1ACE1F 0208002060210022643006000029 -53.5
2021.05.10 21:59:35.889 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: ED A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 21:59:35.892 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4F9B341E d:FF r:FFD5     m:ED A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.10 21:59:35.912 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: ED 80 02 1ACE1F 1DE620 00
2021.05.10 21:59:35.920 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B34A0 d:FF r:FFD8     m:ED 8002 1ACE1F 1DE620 00
2021.05.10 21:59:35.938 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: FD A0 01 1ACE1F 1DE620 0103
2021.05.10 21:59:35.945 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B34BA d:FF r:FFD8     m:FD A001 1ACE1F 1DE620 0103
2021.05.10 21:59:36.065 4 : CUL_Parse: cul868 A 12 FD A010 1DE620 1ACE1F 011A164B010000000029 -53.5
2021.05.10 21:59:36.174 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 37 msg: FD A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.10 21:59:36.176 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4F9B353C d:FF r:FFD5     m:FD A010 1DE620 1ACE1F 011A164B0100000000
2021.05.10 21:59:36.197 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: FD 80 02 1ACE1F 1DE620 00
2021.05.10 21:59:36.204 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B35BD d:FF r:FFD9     m:FD 8002 1ACE1F 1DE620 00
2021.05.10 21:59:36.228 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 0D A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.10 21:59:36.235 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B35DB d:FF r:FFD8     m:0D A001 1ACE1F 1DE620 01041A164B0104
2021.05.10 21:59:36.348 4 : CUL_Parse: cul868 A 0E 0D A010 1DE620 1ACE1F 020100000029 -53.5
2021-05-10 21:59:36.474 CUL_HM Tuer.SZ commState: CMDs_done
2021.05.10 21:59:36.477 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 37 msg: 0D A0 10 1DE620 1ACE1F 0201000000
2021.05.10 21:59:36.480 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4F9B3656 d:FF r:FFD5     m:0D A010 1DE620 1ACE1F 0201000000
2021.05.10 21:59:36.485 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 0D 80 02 1ACE1F 1DE620 00
2021.05.10 21:59:36.490 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4F9B36D8 d:FF r:FFD8     m:0D 8002 1ACE1F 1DE620 00
ZitatDas Problem der IO Zuweisung sollten wir separat im Anschluss angehen.
schon klar, kein problem.
wenn mir probleme auffallen, sprech ich sie halt an, damit sie möglichst nicht untergehen.
noansi
#70
Hallo Frank,
der Testparcour ist noch umfangreicher.  ;) Mit den anderen IOs muss es auch noch klappen.
+ die Variante mit Trigger Fenster auf/zu + Sabotage Taster
Und beim CUL ist auch noch die Gegenprobe ohne Logging für Überraschungen gut, weil FHEM weniger zu tun hat...
Gruß, Ansgar.
SHOFHEM
#71
Guten Morgen Frank,
getconfig mit Wasserevent, nach Abarbeitung der CMDs durch mehrfache Triggerung mittels Wasser fehlt RegL_00
2021.05.11 06:58:14 5: CUL/RAW: /A0
2021.05.11 06:58:14 5: CUL/RAW: A0/DEDA6
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6/10
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA610/4
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104/60
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA610460/7
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607/E3F1
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607E3F1/123
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607E3F1123/406
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607E3F1123406/01
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607E3F112340601/00
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607E3F11234060100/00
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607E3F1123406010000/ED
2021.05.11 06:58:14 5: CUL/RAW: A0DEDA6104607E3F1123406010000ED/
2021.05.11 06:58:14 4: CUL_Parse: SCC A 0D ED A610 4607E3 F11234 06010000ED -83.5
2021.05.11 06:58:14 5: SCC: dispatch A0DEDA6104607E3F1123406010000::-83.5:SCC
2021.05.11 06:58:14 5: SCC sending As0AED8002F112344607E300
2021.05.11 06:58:14 5: CUL 4607E3 dly:89ms
2021.05.11 06:58:14 5: SW: As0AED8002F112344607E300
2021.05.11 06:58:18 5: CUL/RAW: /A
2021.05.11 06:58:18 5: CUL/RAW: A/141
2021.05.11 06:58:18 5: CUL/RAW: A141/D8
2021.05.11 06:58:18 5: CUL/RAW: A141D8/4
2021.05.11 06:58:18 5: CUL/RAW: A141D84/5E
2021.05.11 06:58:18 5: CUL/RAW: A141D845E/33
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33/D
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33D/FB
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB/2
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB2/00
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200/00
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB20000/0
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000/08
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB20000008/0F
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F/6
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F6/7D
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D/00
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D00/0
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D000/00
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D00000/40
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D0000040/0000
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D00000400000/94C
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D0000040000094C/FD
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D0000040000094CFD/13
2021.05.11 06:58:18 5: CUL/RAW: A141D845E33DFB200000080F67D0000040000094CFD13
2021.05.11 06:58:18 4: CUL_Parse: SCC A 14 1D 845E 33DFB2 000000 80F67D0000040000094CFD13 -64.5
2021.05.11 06:58:18 5: SCC: dispatch A141D845E33DFB200000080F67D0000040000094CFD::-64.5:SCC
2021.05.11 06:58:25 5: CUL/RAW: /A0F
2021.05.11 06:58:25 5: CUL/RAW: A0F/3C86
2021.05.11 06:58:25 5: CUL/RAW: A0F3C86/5E7
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E7/1D
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71D/A7
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA7/60
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA760/00
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA76000/00
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA7600000/00C
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA760000000C/A7
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA760000000CA7/9
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA760000000CA79/500
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA760000000CA79500/99E8
2021.05.11 06:58:25 5: CUL/RAW: A0F3C865E71DA760000000CA7950099E8/1F
2021.05.11 06:58:25 4: CUL_Parse: SCC A 0F 3C 865E 71DA76 000000 0CA7950099E81F -58.5
2021.05.11 06:58:25 5: SCC: dispatch A0F3C865E71DA760000000CA7950099E8::-58.5:SCC
2021.05.11 06:58:26 5: CUL/RAW: /A0
2021.05.11 06:58:26 5: CUL/RAW: A0/F5286
2021.05.11 06:58:26 5: CUL/RAW: A0F5286/105
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105/EAA
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAA/D600
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAAD600/000
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAAD600000/00A
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAAD60000000A/B0D
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAAD60000000AB0D/E0B
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAAD60000000AB0DE0B/000
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAAD60000000AB0DE0B000/039
2021.05.11 06:58:26 5: CUL/RAW: A0F5286105EAAD60000000AB0DE0B000039/
2021.05.11 06:58:26 4: CUL_Parse: SCC A 0F 52 8610 5EAAD6 000000 0AB0DE0B000039 -45.5
2021.05.11 06:58:26 5: SCC: dispatch A0F5286105EAAD60000000AB0DE0B0000::-45.5:SCC
2021.05.11 06:58:27 5: CUL/RAW: /A0
2021.05.11 06:58:27 5: CUL/RAW: A0/F5886
2021.05.11 06:58:27 5: CUL/RAW: A0F5886/106
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106/F3D
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106F3D/080
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106F3D080/0000
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106F3D0800000/00AA
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106F3D080000000AA/CB80
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106F3D080000000AACB80/B644
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106F3D080000000AACB80B644/023
2021.05.11 06:58:27 5: CUL/RAW: A0F5886106F3D080000000AACB80B644023
2021.05.11 06:58:27 4: CUL_Parse: SCC A 0F 58 8610 6F3D08 000000 0AACB80B644023 -56.5
2021.05.11 06:58:27 5: SCC: dispatch A0F5886106F3D080000000AACB80B6440::-56.5:SCC
2021.05.11 06:58:56.866 5: CUL/RAW: /A0F
2021.05.11 06:58:56.868 5: CUL/RAW: A0F/888610
2021.05.11 06:58:56.869 5: CUL/RAW: A0F888610/5D66
2021.05.11 06:58:56.870 5: CUL/RAW: A0F8886105D66/B600
2021.05.11 06:58:56.871 5: CUL/RAW: A0F8886105D66B600/000
2021.05.11 06:58:56.872 5: CUL/RAW: A0F8886105D66B600000/00A5
2021.05.11 06:58:56.873 5: CUL/RAW: A0F8886105D66B60000000A5/8B90
2021.05.11 06:58:56.874 5: CUL/RAW: A0F8886105D66B60000000A58B90/9004
2021.05.11 06:58:56.875 5: CUL/RAW: A0F8886105D66B60000000A58B909004/013
2021.05.11 06:58:56.876 5: CUL/RAW: A0F8886105D66B60000000A58B909004013/
2021.05.11 06:58:56.876 4: CUL_Parse: SCC A 0F 88 8610 5D66B6 000000 0A58B909004013 -64.5
2021.05.11 06:58:56.878 5: SCC: dispatch A0F8886105D66B60000000A58B9090040::-64.5:SCC
2021.05.11 06:59:13.473 5: CUL/RAW: /A0
2021.05.11 06:59:13.474 5: CUL/RAW: A0/FA186
2021.05.11 06:59:13.475 5: CUL/RAW: A0FA186/10
2021.05.11 06:59:13.475 5: CUL/RAW: A0FA18610/5E
2021.05.11 06:59:13.476 5: CUL/RAW: A0FA186105E/A
2021.05.11 06:59:13.476 5: CUL/RAW: A0FA186105EA/A6
2021.05.11 06:59:13.477 5: CUL/RAW: A0FA186105EAA6/60
2021.05.11 06:59:13.477 5: CUL/RAW: A0FA186105EAA660/00
2021.05.11 06:59:13.478 5: CUL/RAW: A0FA186105EAA66000/0
2021.05.11 06:59:13.478 5: CUL/RAW: A0FA186105EAA660000/00
2021.05.11 06:59:13.478 5: CUL/RAW: A0FA186105EAA66000000/0A
2021.05.11 06:59:13.479 5: CUL/RAW: A0FA186105EAA660000000A/B
2021.05.11 06:59:13.479 5: CUL/RAW: A0FA186105EAA660000000AB/0D
2021.05.11 06:59:13.480 5: CUL/RAW: A0FA186105EAA660000000AB0D/E0
2021.05.11 06:59:13.480 5: CUL/RAW: A0FA186105EAA660000000AB0DE0/F
2021.05.11 06:59:13.481 5: CUL/RAW: A0FA186105EAA660000000AB0DE0F/00
2021.05.11 06:59:13.481 5: CUL/RAW: A0FA186105EAA660000000AB0DE0F00/00
2021.05.11 06:59:13.482 5: CUL/RAW: A0FA186105EAA660000000AB0DE0F0000/2D
2021.05.11 06:59:13.482 5: CUL/RAW: A0FA186105EAA660000000AB0DE0F00002D/
2021.05.11 06:59:13.483 4: CUL_Parse: SCC A 0F A1 8610 5EAA66 000000 0AB0DE0F00002D -51.5
2021.05.11 06:59:13.484 5: SCC: dispatch A0FA186105EAA660000000AB0DE0F0000::-51.5:SCC
2021.05.11 06:59:20.487 5: CUL/RAW: /A0
2021.05.11 06:59:20.488 5: CUL/RAW: A0/CAC8
2021.05.11 06:59:20.488 5: CUL/RAW: A0CAC8/65A
2021.05.11 06:59:20.489 5: CUL/RAW: A0CAC865A/3
2021.05.11 06:59:20.489 5: CUL/RAW: A0CAC865A3/4D
2021.05.11 06:59:20.490 5: CUL/RAW: A0CAC865A34D/21
2021.05.11 06:59:20.490 5: CUL/RAW: A0CAC865A34D21/80
2021.05.11 06:59:20.491 5: CUL/RAW: A0CAC865A34D2180/00
2021.05.11 06:59:20.491 5: CUL/RAW: A0CAC865A34D218000/00
2021.05.11 06:59:20.492 5: CUL/RAW: A0CAC865A34D21800000/0B
2021.05.11 06:59:20.492 5: CUL/RAW: A0CAC865A34D218000000B/0
2021.05.11 06:59:20.493 5: CUL/RAW: A0CAC865A34D218000000B0/DE
2021.05.11 06:59:20.493 5: CUL/RAW: A0CAC865A34D218000000B0DE/2E
2021.05.11 06:59:20.494 5: CUL/RAW: A0CAC865A34D218000000B0DE2E/2A
2021.05.11 06:59:20.494 5: CUL/RAW: A0CAC865A34D218000000B0DE2E2A/
2021.05.11 06:59:20.495 4: CUL_Parse: SCC A 0C AC 865A 34D218 000000 B0DE2E2A -53
2021.05.11 06:59:20.496 5: SCC: dispatch A0CAC865A34D218000000B0DE2E::-53:SCC
2021.05.11 06:59:29.023 5: CUL/RAW: /A140
2021.05.11 06:59:29.025 5: CUL/RAW: A140/D845E6
2021.05.11 06:59:29.026 5: CUL/RAW: A140D845E6/53BE
2021.05.11 06:59:29.027 5: CUL/RAW: A140D845E653BE/000
2021.05.11 06:59:29.028 5: CUL/RAW: A140D845E653BE000/0000
2021.05.11 06:59:29.029 5: CUL/RAW: A140D845E653BE0000000/80B
2021.05.11 06:59:29.029 5: CUL/RAW: A140D845E653BE000000080B/AC9
2021.05.11 06:59:29.030 5: CUL/RAW: A140D845E653BE000000080BAC9/0005
2021.05.11 06:59:29.031 5: CUL/RAW: A140D845E653BE000000080BAC90005/520
2021.05.11 06:59:29.032 5: CUL/RAW: A140D845E653BE000000080BAC90005520/050
2021.05.11 06:59:29.033 5: CUL/RAW: A140D845E653BE000000080BAC90005520050/094
2021.05.11 06:59:29.034 5: CUL/RAW: A140D845E653BE000000080BAC90005520050094/9FE2
2021.05.11 06:59:29.035 5: CUL/RAW: A140D845E653BE000000080BAC900055200500949FE2/7
2021.05.11 06:59:29.035 4: CUL_Parse: SCC A 14 0D 845E 653BE0 000000 80BAC900055200500949FE27 -54.5
2021.05.11 06:59:29.037 5: SCC: dispatch A140D845E653BE000000080BAC900055200500949FE::-54.5:SCC
2021.05.11 06:59:38.526 5: CUL/RAW: /A1
2021.05.11 06:59:38.527 5: CUL/RAW: A1/41C8
2021.05.11 06:59:38.527 5: CUL/RAW: A141C8/45
2021.05.11 06:59:38.528 5: CUL/RAW: A141C845/E5
2021.05.11 06:59:38.528 5: CUL/RAW: A141C845E5/B9
2021.05.11 06:59:38.528 5: CUL/RAW: A141C845E5B9/A
2021.05.11 06:59:38.529 5: CUL/RAW: A141C845E5B9A/59
2021.05.11 06:59:38.529 5: CUL/RAW: A141C845E5B9A59/00
2021.05.11 06:59:38.530 5: CUL/RAW: A141C845E5B9A5900/00
2021.05.11 06:59:38.530 5: CUL/RAW: A141C845E5B9A590000/0
2021.05.11 06:59:38.531 5: CUL/RAW: A141C845E5B9A5900000/08
2021.05.11 06:59:38.531 5: CUL/RAW: A141C845E5B9A590000008/0E
2021.05.11 06:59:38.532 5: CUL/RAW: A141C845E5B9A5900000080E/64
2021.05.11 06:59:38.532 5: CUL/RAW: A141C845E5B9A5900000080E64/2
2021.05.11 06:59:38.533 5: CUL/RAW: A141C845E5B9A5900000080E642/00
2021.05.11 06:59:38.533 5: CUL/RAW: A141C845E5B9A5900000080E64200/00
2021.05.11 06:59:38.533 5: CUL/RAW: A141C845E5B9A5900000080E6420000/00
2021.05.11 06:59:38.534 5: CUL/RAW: A141C845E5B9A5900000080E642000000/0
2021.05.11 06:59:38.534 5: CUL/RAW: A141C845E5B9A5900000080E6420000000/00
2021.05.11 06:59:38.535 5: CUL/RAW: A141C845E5B9A5900000080E642000000000/00
2021.05.11 06:59:38.535 5: CUL/RAW: A141C845E5B9A5900000080E64200000000000/95
2021.05.11 06:59:38.536 5: CUL/RAW: A141C845E5B9A5900000080E6420000000000095/0
2021.05.11 06:59:38.536 5: CUL/RAW: A141C845E5B9A5900000080E64200000000000950/FE
2021.05.11 06:59:38.537 5: CUL/RAW: A141C845E5B9A5900000080E64200000000000950FE/23
2021.05.11 06:59:38.537 5: CUL/RAW: A141C845E5B9A5900000080E64200000000000950FE23/
2021.05.11 06:59:38.538 5: CUL/RAW: A141C845E5B9A5900000080E64200000000000950FE23
2021.05.11 06:59:38.538 4: CUL_Parse: SCC A 14 1C 845E 5B9A59 000000 80E64200000000000950FE23 -56.5
2021.05.11 06:59:38.539 5: SCC: dispatch A141C845E5B9A5900000080E64200000000000950FE::-56.5:SCC
2021.05.11 06:59:40.487 5: CUL/RAW: /A0
2021.05.11 06:59:40.487 5: CUL/RAW: A0/CAC
2021.05.11 06:59:40.488 5: CUL/RAW: A0CAC/84
2021.05.11 06:59:40.488 5: CUL/RAW: A0CAC84/70
2021.05.11 06:59:40.489 5: CUL/RAW: A0CAC8470/3
2021.05.11 06:59:40.489 5: CUL/RAW: A0CAC84703/4D
2021.05.11 06:59:40.490 5: CUL/RAW: A0CAC847034D/21
2021.05.11 06:59:40.490 5: CUL/RAW: A0CAC847034D21/80
2021.05.11 06:59:40.491 5: CUL/RAW: A0CAC847034D2180/0
2021.05.11 06:59:40.491 5: CUL/RAW: A0CAC847034D21800/00
2021.05.11 06:59:40.492 5: CUL/RAW: A0CAC847034D2180000/00
2021.05.11 06:59:40.492 5: CUL/RAW: A0CAC847034D218000000/0
2021.05.11 06:59:40.492 5: CUL/RAW: A0CAC847034D2180000000/0D
2021.05.11 06:59:40.493 5: CUL/RAW: A0CAC847034D21800000000D/E2
2021.05.11 06:59:40.493 5: CUL/RAW: A0CAC847034D21800000000DE2/E2
2021.05.11 06:59:40.494 5: CUL/RAW: A0CAC847034D21800000000DE2E2/A
2021.05.11 06:59:40.494 5: CUL/RAW: A0CAC847034D21800000000DE2E2A
2021.05.11 06:59:40.495 4: CUL_Parse: SCC A 0C AC 8470 34D218 000000 00DE2E2A -53
2021.05.11 06:59:40.495 5: SCC: dispatch A0CAC847034D21800000000DE2E::-53:SCC
2021.05.11 07:00:27.847 5: CUL/RAW: /A0D
2021.05.11 07:00:27.848 5: CUL/RAW: A0D/8E84102
2021.05.11 07:00:27.849 5: CUL/RAW: A0D8E84102/F2BA
2021.05.11 07:00:27.850 5: CUL/RAW: A0D8E84102F2BA/2F1
2021.05.11 07:00:27.851 5: CUL/RAW: A0D8E84102F2BA2F1/1234
2021.05.11 07:00:27.852 5: CUL/RAW: A0D8E84102F2BA2F11234/0601
2021.05.11 07:00:27.853 5: CUL/RAW: A0D8E84102F2BA2F112340601/2100
2021.05.11 07:00:27.854 5: CUL/RAW: A0D8E84102F2BA2F1123406012100/30
2021.05.11 07:00:27.855 4: CUL_Parse: SCC A 0D 8E 8410 2F2BA2 F11234 0601210030 -50
2021.05.11 07:00:27.857 5: SCC: dispatch A0D8E84102F2BA2F1123406012100::-50:SCC
2021.05.11 07:00:31.287 5: CUL/RAW: /A0C
2021.05.11 07:00:31.289 5: CUL/RAW: A0C/77A6413
2021.05.11 07:00:31.290 5: CUL/RAW: A0C77A6413/D3280
2021.05.11 07:00:31.291 5: CUL/RAW: A0C77A6413D3280/F112
2021.05.11 07:00:31.292 5: CUL/RAW: A0C77A6413D3280F112/3401
2021.05.11 07:00:31.293 5: CUL/RAW: A0C77A6413D3280F1123401/5BC8
2021.05.11 07:00:31.294 5: CUL/RAW: A0C77A6413D3280F11234015BC8/03
2021.05.11 07:00:31.295 4: CUL_Parse: SCC A 0C 77 A641 3D3280 F11234 015BC803 -72.5
2021.05.11 07:00:31.297 5: SCC: dispatch A0C77A6413D3280F11234015BC8::-72.5:SCC
2021.05.11 07:00:31.304 5: SCC sending As0A778102F112343D328000
2021.05.11 07:00:31.305 5: CUL 3D3280 dly:91ms
2021.05.11 07:00:31.396 5: SW: As0A778102F112343D328000
2021.05.11 07:00:31.400 5: SCC sending As1078A001F112343D328000040000000000
2021.05.11 07:00:31.400 5: SW: As1078A001F112343D328000040000000000
2021.05.11 07:00:41.227 5: CUL/RAW: /A0C
2021.05.11 07:00:41.229 5: CUL/RAW: A0C/78A6413
2021.05.11 07:00:41.231 5: CUL/RAW: A0C78A6413/D3280F11
2021.05.11 07:00:41.232 5: CUL/RAW: A0C78A6413D3280F11/2340
2021.05.11 07:00:41.233 5: CUL/RAW: A0C78A6413D3280F112340/15C
2021.05.11 07:00:41.234 5: CUL/RAW: A0C78A6413D3280F11234015C/C806
2021.05.11 07:00:41.235 5: CUL/RAW: A0C78A6413D3280F11234015CC806/
2021.05.11 07:00:41.235 4: CUL_Parse: SCC A 0C 78 A641 3D3280 F11234 015CC806 -71
2021.05.11 07:00:41.237 5: SCC: dispatch A0C78A6413D3280F11234015CC8::-71:SCC
2021.05.11 07:00:41.242 5: SCC sending As0A788102F112343D328000
2021.05.11 07:00:41.242 5: CUL 3D3280 dly:93ms
2021.05.11 07:00:41.337 5: SW: As0A788102F112343D328000
2021.05.11 07:00:41.340 5: SCC sending As1079A001F112343D328000040000000000
2021.05.11 07:00:41.341 5: SW: As1079A001F112343D328000040000000000
2021.05.11 07:00:43.160 5: CUL/RAW: /A0D0D84103DCDDDF11234060122005B
2021.05.11 07:00:43.162 4: CUL_Parse: SCC A 0D 0D 8410 3DCDDD F11234 060122005B -28.5
2021.05.11 07:00:43.163 5: SCC: dispatch A0D0D84103DCDDDF1123406012200::-28.5:SCC
2021.05.11 07:00:50.897 5: CUL/RAW: /A0
2021.05.11 07:00:50.898 5: CUL/RAW: A0/F3D86
2021.05.11 07:00:50.899 5: CUL/RAW: A0F3D86/5E7
2021.05.11 07:00:50.900 5: CUL/RAW: A0F3D865E7/1D
2021.05.11 07:00:50.900 5: CUL/RAW: A0F3D865E71D/A7
2021.05.11 07:00:50.901 5: CUL/RAW: A0F3D865E71DA7/600
2021.05.11 07:00:50.901 5: CUL/RAW: A0F3D865E71DA7600/00
2021.05.11 07:00:50.902 5: CUL/RAW: A0F3D865E71DA760000/00
2021.05.11 07:00:50.903 5: CUL/RAW: A0F3D865E71DA76000000/0CA
2021.05.11 07:00:50.903 5: CUL/RAW: A0F3D865E71DA760000000CA/81
2021.05.11 07:00:50.904 5: CUL/RAW: A0F3D865E71DA760000000CA81/A0
2021.05.11 07:00:50.904 5: CUL/RAW: A0F3D865E71DA760000000CA81A0/09C
2021.05.11 07:00:50.905 5: CUL/RAW: A0F3D865E71DA760000000CA81A009C/A4
2021.05.11 07:00:50.906 5: CUL/RAW: A0F3D865E71DA760000000CA81A009CA4/1F
2021.05.11 07:00:50.906 5: CUL/RAW: A0F3D865E71DA760000000CA81A009CA41F/
2021.05.11 07:00:50.907 4: CUL_Parse: SCC A 0F 3D 865E 71DA76 000000 0CA81A009CA41F -58.5
2021.05.11 07:00:50.908 5: SCC: dispatch A0F3D865E71DA760000000CA81A009CA4::-58.5:SCC
2021.05.11 07:00:51.225 5: CUL/RAW: /A0
2021.05.11 07:00:51.226 5: CUL/RAW: A0/C79A
2021.05.11 07:00:51.227 5: CUL/RAW: A0C79A/64
2021.05.11 07:00:51.227 5: CUL/RAW: A0C79A64/13D
2021.05.11 07:00:51.228 5: CUL/RAW: A0C79A6413D/32
2021.05.11 07:00:51.228 5: CUL/RAW: A0C79A6413D32/80
2021.05.11 07:00:51.229 5: CUL/RAW: A0C79A6413D3280/F1
2021.05.11 07:00:51.230 5: CUL/RAW: A0C79A6413D3280F1/123
2021.05.11 07:00:51.230 5: CUL/RAW: A0C79A6413D3280F1123/40
2021.05.11 07:00:51.231 5: CUL/RAW: A0C79A6413D3280F112340/15
2021.05.11 07:00:51.231 5: CUL/RAW: A0C79A6413D3280F11234015/DC
2021.05.11 07:00:51.232 5: CUL/RAW: A0C79A6413D3280F11234015DC/807
2021.05.11 07:00:51.233 5: CUL/RAW: A0C79A6413D3280F11234015DC807/
2021.05.11 07:00:51.233 4: CUL_Parse: SCC A 0C 79 A641 3D3280 F11234 015DC807 -70.5
2021.05.11 07:00:51.234 5: SCC: dispatch A0C79A6413D3280F11234015DC8::-70.5:SCC
2021.05.11 07:00:51.236 5: SCC sending As0A798102F112343D328000
2021.05.11 07:00:51.236 5: CUL 3D3280 dly:96ms
2021.05.11 07:00:51.334 5: SW: As0A798102F112343D328000
2021.05.11 07:00:51.336 5: SCC sending As107AA001F112343D328000040000000000
2021.05.11 07:00:51.337 5: SW: As107AA001F112343D328000040000000000
2021.05.11 07:00:56.291 5: CUL/RAW: /A0F
2021.05.11 07:00:56.293 5: CUL/RAW: A0F/5386105
2021.05.11 07:00:56.296 5: CUL/RAW: A0F5386105/EAAD60000000
2021.05.11 07:00:56.297 5: CUL/RAW: A0F5386105EAAD60000000/AB0DE
2021.05.11 07:00:56.298 5: CUL/RAW: A0F5386105EAAD60000000AB0DE/0B000
2021.05.11 07:00:56.300 5: CUL/RAW: A0F5386105EAAD60000000AB0DE0B000/039
2021.05.11 07:00:56.300 4: CUL_Parse: SCC A 0F 53 8610 5EAAD6 000000 0AB0DE0B000039 -45.5
2021.05.11 07:00:56.302 5: SCC: dispatch A0F5386105EAAD60000000AB0DE0B0000::-45.5:SCC
2021.05.11 07:01:01.224 5: CUL/RAW: /A0C
2021.05.11 07:01:01.226 5: CUL/RAW: A0C/7AA6413
2021.05.11 07:01:01.227 5: CUL/RAW: A0C7AA6413/D3280
2021.05.11 07:01:01.228 5: CUL/RAW: A0C7AA6413D3280/F112
2021.05.11 07:01:01.230 5: CUL/RAW: A0C7AA6413D3280F112/34015E
2021.05.11 07:01:01.232 5: CUL/RAW: A0C7AA6413D3280F11234015E/C806
2021.05.11 07:01:01.232 4: CUL_Parse: SCC A 0C 7A A641 3D3280 F11234 015EC806 -71
2021.05.11 07:01:01.234 5: SCC: dispatch A0C7AA6413D3280F11234015EC8::-71:SCC
2021.05.11 07:01:01.239 5: SCC sending As0A7A8102F112343D328000
2021.05.11 07:01:01.240 5: CUL 3D3280 dly:93ms
2021.05.11 07:01:01.334 5: SW: As0A7A8102F112343D328000
2021.05.11 07:01:01.337 5: SCC sending As107BA001F112343D328000040000000000
2021.05.11 07:01:01.337 5: SW: As107BA001F112343D328000040000000000
2021.05.11 07:01:05.532 5: CUL/RAW: /A0F
2021.05.11 07:01:05.534 5: CUL/RAW: A0F/598610
2021.05.11 07:01:05.535 5: CUL/RAW: A0F598610/6F3D
2021.05.11 07:01:05.536 5: CUL/RAW: A0F5986106F3D/080
2021.05.11 07:01:05.537 5: CUL/RAW: A0F5986106F3D080/0000
2021.05.11 07:01:05.538 5: CUL/RAW: A0F5986106F3D0800000/00A
2021.05.11 07:01:05.539 5: CUL/RAW: A0F5986106F3D080000000A/ACB9
2021.05.11 07:01:05.540 5: CUL/RAW: A0F5986106F3D080000000AACB9/0B6
2021.05.11 07:01:05.540 5: CUL/RAW: A0F5986106F3D080000000AACB90B6/440
2021.05.11 07:01:05.541 5: CUL/RAW: A0F5986106F3D080000000AACB90B6440/24
2021.05.11 07:01:05.542 4: CUL_Parse: SCC A 0F 59 8610 6F3D08 000000 0AACB90B644024 -56
2021.05.11 07:01:05.543 5: SCC: dispatch A0F5986106F3D080000000AACB90B6440::-56:SCC
2021.05.11 07:01:11.223 5: CUL/RAW: /A0C
2021.05.11 07:01:11.225 5: CUL/RAW: A0C/7BA6413D3
2021.05.11 07:01:11.227 5: CUL/RAW: A0C7BA6413D3/280F11
2021.05.11 07:01:11.228 5: CUL/RAW: A0C7BA6413D3280F11/23401
2021.05.11 07:01:11.229 5: CUL/RAW: A0C7BA6413D3280F1123401/5FC80
2021.05.11 07:01:11.231 5: CUL/RAW: A0C7BA6413D3280F11234015FC80/6
2021.05.11 07:01:11.231 4: CUL_Parse: SCC A 0C 7B A641 3D3280 F11234 015FC806 -71
2021.05.11 07:01:11.233 5: SCC: dispatch A0C7BA6413D3280F11234015FC8::-71:SCC
2021.05.11 07:01:11.239 5: SCC sending As0A7B8002F112343D328000
2021.05.11 07:01:11.239 5: CUL 3D3280 dly:92ms
2021.05.11 07:01:11.332 5: SW: As0A7B8002F112343D328000
2021.05.11 07:01:11.335 5: SCC sending As0A7B8002F112343D328000
2021.05.11 07:01:11.335 5: SW: As0A7B8002F112343D328000
2021.05.11 07:01:18.857 5: CUL/RAW: /A14
2021.05.11 07:01:18.859 5: CUL/RAW: A14/1E845E
2021.05.11 07:01:18.860 5: CUL/RAW: A141E845E/33DFB
2021.05.11 07:01:18.862 5: CUL/RAW: A141E845E33DFB/200000
2021.05.11 07:01:18.863 5: CUL/RAW: A141E845E33DFB200000/080F
2021.05.11 07:01:18.864 5: CUL/RAW: A141E845E33DFB200000080F/67D000
2021.05.11 07:01:18.865 5: CUL/RAW: A141E845E33DFB200000080F67D000/0050
2021.05.11 07:01:18.867 5: CUL/RAW: A141E845E33DFB200000080F67D0000050/00009
2021.05.11 07:01:18.868 5: CUL/RAW: A141E845E33DFB200000080F67D000005000009/45021
2021.05.11 07:01:18.869 5: CUL/RAW: A141E845E33DFB200000080F67D00000500000945021/3
2021.05.11 07:01:18.870 4: CUL_Parse: SCC A 14 1E 845E 33DFB2 000000 80F67D000005000009450213 -64.5
2021.05.11 07:01:18.871 5: SCC: dispatch A141E845E33DFB200000080F67D0000050000094502::-64.5:SCC
2021.05.11 07:01:20.738 5: CUL/RAW: /A0C
2021.05.11 07:01:20.739 5: CUL/RAW: A0C/AD865
2021.05.11 07:01:20.740 5: CUL/RAW: A0CAD865/A34D
2021.05.11 07:01:20.741 5: CUL/RAW: A0CAD865A34D/2180
2021.05.11 07:01:20.742 5: CUL/RAW: A0CAD865A34D2180/0000
2021.05.11 07:01:20.743 5: CUL/RAW: A0CAD865A34D21800000/0B0
2021.05.11 07:01:20.744 5: CUL/RAW: A0CAD865A34D218000000B0/DE2E
2021.05.11 07:01:20.745 5: CUL/RAW: A0CAD865A34D218000000B0DE2E/2A
2021.05.11 07:01:20.745 4: CUL_Parse: SCC A 0C AD 865A 34D218 000000 B0DE2E2A -53
2021.05.11 07:01:20.746 5: SCC: dispatch A0CAD865A34D218000000B0DE2E::-53:SCC
2021.05.11 07:01:22.639 5: CUL/RAW: /A0C7
2021.05.11 07:01:22.641 5: CUL/RAW: A0C7/CA6413
2021.05.11 07:01:22.642 5: CUL/RAW: A0C7CA6413/D3280F
2021.05.11 07:01:22.644 5: CUL/RAW: A0C7CA6413D3280F/1123401
2021.05.11 07:01:22.646 5: CUL/RAW: A0C7CA6413D3280F1123401/60000C
2021.05.11 07:01:22.648 5: CUL/RAW: A0C7CA6413D3280F112340160000C/
2021.05.11 07:01:22.648 4: CUL_Parse: SCC A 0C 7C A641 3D3280 F11234 0160000C -68
2021.05.11 07:01:22.650 5: SCC: dispatch A0C7CA6413D3280F11234016000::-68:SCC
2021.05.11 07:01:22.654 5: SCC sending As0A7C8002F112343D328000
2021.05.11 07:01:22.655 5: CUL 3D3280 dly:93ms
2021.05.11 07:01:22.750 5: SW: As0A7C8002F112343D328000
2021.05.11 07:01:22.752 5: SCC sending As0A7C8002F112343D328000
2021.05.11 07:01:22.753 5: SW: As0A7C8002F112343D328000
2021.05.11 07:01:27.744 5: CUL/RAW: /A0C7
2021.05.11 07:01:27.745 5: CUL/RAW: A0C7/DA6413
2021.05.11 07:01:27.746 5: CUL/RAW: A0C7DA6413/D3280
2021.05.11 07:01:27.747 5: CUL/RAW: A0C7DA6413D3280/F11
2021.05.11 07:01:27.748 5: CUL/RAW: A0C7DA6413D3280F11/2340
2021.05.11 07:01:27.749 5: CUL/RAW: A0C7DA6413D3280F112340/161C
2021.05.11 07:01:27.750 5: CUL/RAW: A0C7DA6413D3280F112340161C/805
2021.05.11 07:01:27.751 5: CUL/RAW: A0C7DA6413D3280F112340161C805
2021.05.11 07:01:27.752 4: CUL_Parse: SCC A 0C 7D A641 3D3280 F11234 0161C805 -71.5
2021.05.11 07:01:27.753 5: SCC: dispatch A0C7DA6413D3280F112340161C8::-71.5:SCC
2021.05.11 07:01:27.760 5: SCC sending As0A7D8002F112343D328000
2021.05.11 07:01:27.761 5: CUL 3D3280 dly:91ms
2021.05.11 07:01:27.853 5: SW: As0A7D8002F112343D328000
2021.05.11 07:01:27.856 5: SCC sending As0A7D8002F112343D328000
2021.05.11 07:01:27.857 5: SW: As0A7D8002F112343D328000
2021.05.11 07:01:31.117 5: CUL/RAW: /A0
2021.05.11 07:01:31.118 5: CUL/RAW: A0/F898
2021.05.11 07:01:31.118 5: CUL/RAW: A0F898/61
2021.05.11 07:01:31.119 5: CUL/RAW: A0F89861/05
2021.05.11 07:01:31.120 5: CUL/RAW: A0F8986105/D66
2021.05.11 07:01:31.120 5: CUL/RAW: A0F8986105D66/B6
2021.05.11 07:01:31.121 5: CUL/RAW: A0F8986105D66B6/00
2021.05.11 07:01:31.121 5: CUL/RAW: A0F8986105D66B600/000
2021.05.11 07:01:31.122 5: CUL/RAW: A0F8986105D66B600000/00
2021.05.11 07:01:31.123 5: CUL/RAW: A0F8986105D66B60000000/A5
2021.05.11 07:01:31.123 5: CUL/RAW: A0F8986105D66B60000000A5/8B
2021.05.11 07:01:31.124 5: CUL/RAW: A0F8986105D66B60000000A58B/909
2021.05.11 07:01:31.124 5: CUL/RAW: A0F8986105D66B60000000A58B909/00
2021.05.11 07:01:31.125 5: CUL/RAW: A0F8986105D66B60000000A58B90900/40
2021.05.11 07:01:31.126 5: CUL/RAW: A0F8986105D66B60000000A58B9090040/13
2021.05.11 07:01:31.126 5: CUL/RAW: A0F8986105D66B60000000A58B909004013/
2021.05.11 07:01:31.126 4: CUL_Parse: SCC A 0F 89 8610 5D66B6 000000 0A58B909004013 -64.5
2021.05.11 07:01:31.127 5: SCC: dispatch A0F8986105D66B60000000A58B9090040::-64.5:SCC
2021.05.11 07:01:35.475 5: CUL/RAW: /A0
2021.05.11 07:01:35.476 5: CUL/RAW: A0/FA286
2021.05.11 07:01:35.477 5: CUL/RAW: A0FA286/105E
2021.05.11 07:01:35.478 5: CUL/RAW: A0FA286105E/AA6
2021.05.11 07:01:35.478 5: CUL/RAW: A0FA286105EAA6/600
2021.05.11 07:01:35.479 5: CUL/RAW: A0FA286105EAA6600/0000
2021.05.11 07:01:35.480 5: CUL/RAW: A0FA286105EAA66000000/0AB
2021.05.11 07:01:35.481 5: CUL/RAW: A0FA286105EAA660000000AB/0DE
2021.05.11 07:01:35.482 5: CUL/RAW: A0FA286105EAA660000000AB0DE/0F00
2021.05.11 07:01:35.483 5: CUL/RAW: A0FA286105EAA660000000AB0DE0F00/002
2021.05.11 07:01:35.484 5: CUL/RAW: A0FA286105EAA660000000AB0DE0F00002/D
2021.05.11 07:01:35.484 4: CUL_Parse: SCC A 0F A2 8610 5EAA66 000000 0AB0DE0F00002D -51.5
2021.05.11 07:01:35.485 5: SCC: dispatch A0FA286105EAA660000000AB0DE0F0000::-51.5:SCC
2021.05.11 07:01:40.738 5: CUL/RAW: /A0C
2021.05.11 07:01:40.740 5: CUL/RAW: A0C/AD84703
2021.05.11 07:01:40.741 5: CUL/RAW: A0CAD84703/4D21
2021.05.11 07:01:40.742 5: CUL/RAW: A0CAD847034D21/800
2021.05.11 07:01:40.743 5: CUL/RAW: A0CAD847034D21800/0000
2021.05.11 07:01:40.744 5: CUL/RAW: A0CAD847034D218000000/00DE
2021.05.11 07:01:40.745 5: CUL/RAW: A0CAD847034D21800000000DE/2E2A
2021.05.11 07:01:40.746 5: CUL/RAW: A0CAD847034D21800000000DE2E2A/
2021.05.11 07:01:40.746 4: CUL_Parse: SCC A 0C AD 8470 34D218 000000 00DE2E2A -53
2021.05.11 07:01:40.747 5: SCC: dispatch A0CAD847034D21800000000DE2E::-53:SCC
jump to the top
getconfig nach Knopfdruck. Musste nur einmal die Anlerntast drücken RegL_00 und RegL_01 sind wieder da!
2021.05.11 07:04:04.857 5: CUL/RAW: /A1
2021.05.11 07:04:04.858 5: CUL/RAW: A1/41F8
2021.05.11 07:04:04.859 5: CUL/RAW: A141F8/45E
2021.05.11 07:04:04.860 5: CUL/RAW: A141F845E/33
2021.05.11 07:04:04.860 5: CUL/RAW: A141F845E33/DF
2021.05.11 07:04:04.861 5: CUL/RAW: A141F845E33DF/B2
2021.05.11 07:04:04.861 5: CUL/RAW: A141F845E33DFB2/00
2021.05.11 07:04:04.862 5: CUL/RAW: A141F845E33DFB200/00
2021.05.11 07:04:04.862 5: CUL/RAW: A141F845E33DFB20000/00
2021.05.11 07:04:04.863 5: CUL/RAW: A141F845E33DFB2000000/80
2021.05.11 07:04:04.864 5: CUL/RAW: A141F845E33DFB200000080/F6
2021.05.11 07:04:04.864 5: CUL/RAW: A141F845E33DFB200000080F6/7D0
2021.05.11 07:04:04.865 5: CUL/RAW: A141F845E33DFB200000080F67D0/00
2021.05.11 07:04:04.865 5: CUL/RAW: A141F845E33DFB200000080F67D000/00
2021.05.11 07:04:04.866 5: CUL/RAW: A141F845E33DFB200000080F67D00000/50
2021.05.11 07:04:04.866 5: CUL/RAW: A141F845E33DFB200000080F67D0000050/00
2021.05.11 07:04:04.867 5: CUL/RAW: A141F845E33DFB200000080F67D000005000/00
2021.05.11 07:04:04.867 5: CUL/RAW: A141F845E33DFB200000080F67D00000500000/94
2021.05.11 07:04:04.868 5: CUL/RAW: A141F845E33DFB200000080F67D0000050000094/30
2021.05.11 07:04:04.868 5: CUL/RAW: A141F845E33DFB200000080F67D000005000009430/21
2021.05.11 07:04:04.869 5: CUL/RAW: A141F845E33DFB200000080F67D00000500000943021/3
2021.05.11 07:04:04.869 5: CUL/RAW: A141F845E33DFB200000080F67D000005000009430213
2021.05.11 07:04:04.870 4: CUL_Parse: SCC A 14 1F 845E 33DFB2 000000 80F67D000005000009430213 -64.5
2021.05.11 07:04:04.871 5: SCC: dispatch A141F845E33DFB200000080F67D0000050000094302::-64.5:SCC
2021.05.11 07:04:10.489 5: CUL/RAW: /A0
2021.05.11 07:04:10.490 5: CUL/RAW: A0/CAE8
2021.05.11 07:04:10.494 5: CUL/RAW: A0CAE8/65A34D218000000
2021.05.11 07:04:10.495 5: CUL/RAW: A0CAE865A34D218000000/B0D
2021.05.11 07:04:10.495 5: CUL/RAW: A0CAE865A34D218000000B0D/E2E
2021.05.11 07:04:10.496 5: CUL/RAW: A0CAE865A34D218000000B0DE2E/2A
2021.05.11 07:04:10.497 5: CUL/RAW: A0CAE865A34D218000000B0DE2E2A/
2021.05.11 07:04:10.497 4: CUL_Parse: SCC A 0C AE 865A 34D218 000000 B0DE2E2A -53
2021.05.11 07:04:10.498 5: SCC: dispatch A0CAE865A34D218000000B0DE2E::-53:SCC
2021.05.11 07:04:12.846 5: CUL/RAW: /A0D
2021.05.11 07:04:12.848 5: CUL/RAW: A0D/26A61
2021.05.11 07:04:12.848 5: CUL/RAW: A0D26A61/046
2021.05.11 07:04:12.849 5: CUL/RAW: A0D26A61046/09E
2021.05.11 07:04:12.850 5: CUL/RAW: A0D26A6104609E/9F1
2021.05.11 07:04:12.850 5: CUL/RAW: A0D26A6104609E9F1/12
2021.05.11 07:04:12.851 5: CUL/RAW: A0D26A6104609E9F112/340
2021.05.11 07:04:12.852 5: CUL/RAW: A0D26A6104609E9F112340/601
2021.05.11 07:04:12.853 5: CUL/RAW: A0D26A6104609E9F112340601/00
2021.05.11 07:04:12.853 5: CUL/RAW: A0D26A6104609E9F11234060100/002
2021.05.11 07:04:12.854 5: CUL/RAW: A0D26A6104609E9F11234060100002/8
2021.05.11 07:04:12.855 4: CUL_Parse: SCC A 0D 26 A610 4609E9 F11234 0601000028 -54
2021.05.11 07:04:12.856 5: SCC: dispatch A0D26A6104609E9F1123406010000::-54:SCC
2021.05.11 07:04:12.863 5: SCC sending As0A268002F112344609E900
2021.05.11 07:04:12.864 5: CUL 4609E9 dly:91ms
2021.05.11 07:04:12.956 5: SW: As0A268002F112344609E900
2021.05.11 07:04:30.489 5: CUL/RAW: /A0C
2021.05.11 07:04:30.494 5: CUL/RAW: A0C/AE847034D21800000
2021.05.11 07:04:30.495 5: CUL/RAW: A0CAE847034D21800000/000DE2
2021.05.11 07:04:30.497 5: CUL/RAW: A0CAE847034D21800000000DE2/E2A
2021.05.11 07:04:30.497 4: CUL_Parse: SCC A 0C AE 8470 34D218 000000 00DE2E2A -53
2021.05.11 07:04:30.499 5: SCC: dispatch A0CAE847034D21800000000DE2E::-53:SCC
2021.05.11 07:04:31.026 5: CUL/RAW: /A1
2021.05.11 07:04:31.028 5: CUL/RAW: A1/41E845E5
2021.05.11 07:04:31.029 5: CUL/RAW: A141E845E5/B9A59
2021.05.11 07:04:31.031 5: CUL/RAW: A141E845E5B9A59/0000
2021.05.11 07:04:31.032 5: CUL/RAW: A141E845E5B9A590000/0080E
2021.05.11 07:04:31.033 5: CUL/RAW: A141E845E5B9A5900000080E/64200
2021.05.11 07:04:31.034 5: CUL/RAW: A141E845E5B9A5900000080E64200/00000
2021.05.11 07:04:31.036 5: CUL/RAW: A141E845E5B9A5900000080E6420000000/0000
2021.05.11 07:04:31.037 5: CUL/RAW: A141E845E5B9A5900000080E64200000000000/94902
2021.05.11 07:04:31.038 5: CUL/RAW: A141E845E5B9A5900000080E6420000000000094902/23
2021.05.11 07:04:31.039 4: CUL_Parse: SCC A 14 1E 845E 5B9A59 000000 80E642000000000009490223 -56.5
2021.05.11 07:04:31.040 5: SCC: dispatch A141E845E5B9A5900000080E6420000000000094902::-56.5:SCC
2021.05.11 07:04:41.651 5: CUL/RAW: /A0C7
2021.05.11 07:04:41.653 5: CUL/RAW: A0C7/EA6413D3
2021.05.11 07:04:41.655 5: CUL/RAW: A0C7EA6413D3/280F11
2021.05.11 07:04:41.656 5: CUL/RAW: A0C7EA6413D3280F11/2340
2021.05.11 07:04:41.657 5: CUL/RAW: A0C7EA6413D3280F112340/16200
2021.05.11 07:04:41.658 5: CUL/RAW: A0C7EA6413D3280F11234016200/1A
2021.05.11 07:04:41.659 4: CUL_Parse: SCC A 0C 7E A641 3D3280 F11234 0162001A -61
2021.05.11 07:04:41.661 5: SCC: dispatch A0C7EA6413D3280F11234016200::-61:SCC
2021.05.11 07:04:41.672 5: SCC sending As0A7E8002F112343D328000
2021.05.11 07:04:41.674 5: CUL 3D3280 dly:86ms
2021.05.11 07:04:41.761 5: SW: As0A7E8002F112343D328000
2021.05.11 07:04:41.764 5: SCC sending As0A7E8002F112343D328000
2021.05.11 07:04:41.765 5: SW: As0A7E8002F112343D328000
2021.05.11 07:04:51.147 5: CUL/RAW: /A0D
2021.05.11 07:04:51.149 5: CUL/RAW: A0D/0E84103D
2021.05.11 07:04:51.151 5: CUL/RAW: A0D0E84103D/CDDDF
2021.05.11 07:04:51.152 5: CUL/RAW: A0D0E84103DCDDDF/1123
2021.05.11 07:04:51.153 5: CUL/RAW: A0D0E84103DCDDDF1123/40601
2021.05.11 07:04:51.154 5: CUL/RAW: A0D0E84103DCDDDF112340601/2300
2021.05.11 07:04:51.155 5: CUL/RAW: A0D0E84103DCDDDF1123406012300/5B
2021.05.11 07:04:51.156 4: CUL_Parse: SCC A 0D 0E 8410 3DCDDD F11234 060123005B -28.5
2021.05.11 07:04:51.157 5: SCC: dispatch A0D0E84103DCDDDF1123406012300::-28.5:SCC
2021.05.11 07:04:58.525 5: CUL/RAW: /A14
2021.05.11 07:04:58.527 5: CUL/RAW: A14/0F845E6
2021.05.11 07:04:58.528 5: CUL/RAW: A140F845E6/53BE
2021.05.11 07:04:58.528 5: CUL/RAW: A140F845E653BE/0000
2021.05.11 07:04:58.529 5: CUL/RAW: A140F845E653BE0000/000
2021.05.11 07:04:58.530 5: CUL/RAW: A140F845E653BE0000000/80B
2021.05.11 07:04:58.531 5: CUL/RAW: A140F845E653BE000000080B/AD10
2021.05.11 07:04:58.532 5: CUL/RAW: A140F845E653BE000000080BAD10/0037
2021.05.11 07:04:58.533 5: CUL/RAW: A140F845E653BE000000080BAD100037/C00
2021.05.11 07:04:58.534 5: CUL/RAW: A140F845E653BE000000080BAD100037C00/4609
2021.05.11 07:04:58.535 5: CUL/RAW: A140F845E653BE000000080BAD100037C004609/390326
2021.05.11 07:04:58.537 5: CUL/RAW: A140F845E653BE000000080BAD100037C004609390326/
2021.05.11 07:04:58.537 4: CUL_Parse: SCC A 14 0F 845E 653BE0 000000 80BAD100037C004609390326 -55
2021.05.11 07:04:58.539 5: SCC: dispatch A140F845E653BE000000080BAD100037C0046093903::-55:SCC
2021.05.11 07:05:12.043 5: CUL/RAW: /A0F
2021.05.11 07:05:12.045 5: CUL/RAW: A0F/5586105E
2021.05.11 07:05:12.046 5: CUL/RAW: A0F5586105E/AAD60
2021.05.11 07:05:12.047 5: CUL/RAW: A0F5586105EAAD60/0000
2021.05.11 07:05:12.048 5: CUL/RAW: A0F5586105EAAD600000/00AB
2021.05.11 07:05:12.049 5: CUL/RAW: A0F5586105EAAD60000000AB/0DE0
2021.05.11 07:05:12.051 5: CUL/RAW: A0F5586105EAAD60000000AB0DE0/B0000
2021.05.11 07:05:12.052 5: CUL/RAW: A0F5586105EAAD60000000AB0DE0B0000/38
2021.05.11 07:05:12.052 4: CUL_Parse: SCC A 0F 55 8610 5EAAD6 000000 0AB0DE0B000038 -46
2021.05.11 07:05:12.054 5: SCC: dispatch A0F5586105EAAD60000000AB0DE0B0000::-46:SCC
2021.05.11 07:05:37.788 5: CUL/RAW: /A0
2021.05.11 07:05:37.789 5: CUL/RAW: A0/F5B861
2021.05.11 07:05:37.790 5: CUL/RAW: A0F5B861/06F
2021.05.11 07:05:37.791 5: CUL/RAW: A0F5B86106F/3D0
2021.05.11 07:05:37.792 5: CUL/RAW: A0F5B86106F3D0/800
2021.05.11 07:05:37.792 5: CUL/RAW: A0F5B86106F3D0800/000
2021.05.11 07:05:37.793 5: CUL/RAW: A0F5B86106F3D0800000/00A
2021.05.11 07:05:37.794 5: CUL/RAW: A0F5B86106F3D080000000A/ACB
2021.05.11 07:05:37.795 5: CUL/RAW: A0F5B86106F3D080000000AACB/B0
2021.05.11 07:05:37.795 5: CUL/RAW: A0F5B86106F3D080000000AACBB0/B64
2021.05.11 07:05:37.796 5: CUL/RAW: A0F5B86106F3D080000000AACBB0B64/402
2021.05.11 07:05:37.797 5: CUL/RAW: A0F5B86106F3D080000000AACBB0B64402/3
2021.05.11 07:05:37.797 4: CUL_Parse: SCC A 0F 5B 8610 6F3D08 000000 0AACBB0B644023 -56.5
2021.05.11 07:05:37.798 5: SCC: dispatch A0F5B86106F3D080000000AACBB0B6440::-56.5:SCC
2021.05.11 07:05:48.889 5: CUL/RAW: /A1A
2021.05.11 07:05:48.891 5: CUL/RAW: A1A/7F84003D
2021.05.11 07:05:48.893 5: CUL/RAW: A1A7F84003D/32800
2021.05.11 07:05:48.894 5: CUL/RAW: A1A7F84003D32800/000001
2021.05.11 07:05:48.895 5: CUL/RAW: A1A7F84003D32800000001/400B
2021.05.11 07:05:48.896 5: CUL/RAW: A1A7F84003D32800000001400B/24D45
2021.05.11 07:05:48.898 5: CUL/RAW: A1A7F84003D32800000001400B24D45/51303
2021.05.11 07:05:48.899 5: CUL/RAW: A1A7F84003D32800000001400B24D4551303/5393
2021.05.11 07:05:48.900 5: CUL/RAW: A1A7F84003D32800000001400B24D45513035393/03435
2021.05.11 07:05:48.901 5: CUL/RAW: A1A7F84003D32800000001400B24D4551303539303435/36801
2021.05.11 07:05:48.903 5: CUL/RAW: A1A7F84003D32800000001400B24D455130353930343536801/1010
2021.05.11 07:05:48.904 5: CUL/RAW: A1A7F84003D32800000001400B24D4551303539303435368011010/108
2021.05.11 07:05:48.904 4: CUL_Parse: SCC A 1A 7F 8400 3D3280 000000 1400B24D4551303539303435368011010108 -70
2021.05.11 07:05:48.906 5: SCC: dispatch A1A7F84003D32800000001400B24D45513035393034353680110101::-70:SCC
2021.05.11 07:05:48.911 5: SCC sending As10A7A001F112343D328000040000000000
2021.05.11 07:05:48.912 5: CUL 3D3280 dly:93ms
2021.05.11 07:05:49.006 5: SW: As10A7A001F112343D328000040000000000
2021.05.11 07:05:49.179 5: CUL/RAW: /A1A
2021.05.11 07:05:49.181 5: CUL/RAW: A1A/A7A0103D3
2021.05.11 07:05:49.183 5: CUL/RAW: A1AA7A0103D3/280F11
2021.05.11 07:05:49.185 5: CUL/RAW: A1AA7A0103D3280F11/23402020
2021.05.11 07:05:49.187 5: CUL/RAW: A1AA7A0103D3280F1123402020/109010AF1
2021.05.11 07:05:49.189 5: CUL/RAW: A1AA7A0103D3280F1123402020109010AF1/0B120
2021.05.11 07:05:49.190 5: CUL/RAW: A1AA7A0103D3280F1123402020109010AF10B120/C3410
2021.05.11 07:05:49.191 5: CUL/RAW: A1AA7A0103D3280F1123402020109010AF10B120C3410/01140
2021.05.11 07:05:49.192 5: CUL/RAW: A1AA7A0103D3280F1123402020109010AF10B120C341001140/60000
2021.05.11 07:05:49.194 5: CUL/RAW: A1AA7A0103D3280F1123402020109010AF10B120C34100114060000/F0
2021.05.11 07:05:49.194 4: CUL_Parse: SCC A 1A A7 A010 3D3280 F11234 02020109010AF10B120C34100114060000F0 -82
2021.05.11 07:05:49.196 5: SCC: dispatch A1AA7A0103D3280F1123402020109010AF10B120C34100114060000::-82:SCC
2021.05.11 07:05:49.204 5: SCC sending As0AA78002F112343D328000
2021.05.11 07:05:49.205 5: CUL 3D3280 dly:89ms
2021.05.11 07:05:49.296 5: SW: As0AA78002F112343D328000
2021.05.11 07:05:49.298 5: SCC sending As10B7A001F112343D328001040000000001
2021.05.11 07:05:49.298 5: SW: As10B7A001F112343D328001040000000001
2021.05.11 07:05:49.488 5: CUL/RAW: /A
2021.05.11 07:05:49.488 5: CUL/RAW: A/16B
2021.05.11 07:05:49.489 5: CUL/RAW: A16B/7A0
2021.05.11 07:05:49.490 5: CUL/RAW: A16B7A0/10
2021.05.11 07:05:49.490 5: CUL/RAW: A16B7A010/3D
2021.05.11 07:05:49.491 5: CUL/RAW: A16B7A0103D/32
2021.05.11 07:05:49.491 5: CUL/RAW: A16B7A0103D32/80
2021.05.11 07:05:49.492 5: CUL/RAW: A16B7A0103D3280/F1
2021.05.11 07:05:49.492 5: CUL/RAW: A16B7A0103D3280F1/12
2021.05.11 07:05:49.493 5: CUL/RAW: A16B7A0103D3280F112/34
2021.05.11 07:05:49.493 5: CUL/RAW: A16B7A0103D3280F11234/020
2021.05.11 07:05:49.494 5: CUL/RAW: A16B7A0103D3280F11234020/80
2021.05.11 07:05:49.495 5: CUL/RAW: A16B7A0103D3280F1123402080/02
2021.05.11 07:05:49.495 5: CUL/RAW: A16B7A0103D3280F112340208002/07
2021.05.11 07:05:49.496 5: CUL/RAW: A16B7A0103D3280F11234020800207/82
2021.05.11 07:05:49.496 5: CUL/RAW: A16B7A0103D3280F1123402080020782/26
2021.05.11 07:05:49.497 5: CUL/RAW: A16B7A0103D3280F112340208002078226/42
2021.05.11 07:05:49.497 5: CUL/RAW: A16B7A0103D3280F11234020800207822642/30
2021.05.11 07:05:49.498 5: CUL/RAW: A16B7A0103D3280F1123402080020782264230/53
2021.05.11 07:05:49.498 5: CUL/RAW: A16B7A0103D3280F112340208002078226423053/006
2021.05.11 07:05:49.499 5: CUL/RAW: A16B7A0103D3280F112340208002078226423053006/00
2021.05.11 07:05:49.500 5: CUL/RAW: A16B7A0103D3280F11234020800207822642305300600/00
2021.05.11 07:05:49.500 5: CUL/RAW: A16B7A0103D3280F1123402080020782264230530060000/0E
2021.05.11 07:05:49.501 5: CUL/RAW: A16B7A0103D3280F11234020800207822642305300600000E/
2021.05.11 07:05:49.501 4: CUL_Parse: SCC A 16 B7 A010 3D3280 F11234 020800207822642305300600000E -67
2021.05.11 07:05:49.502 5: SCC: dispatch A16B7A0103D3280F1123402080020782264230530060000::-67:SCC
2021.05.11 07:05:49.506 5: SCC sending As0AB78002F112343D328000
2021.05.11 07:05:49.506 5: CUL 3D3280 dly:94ms
2021.05.11 07:05:49.601 5: SW: As0AB78002F112343D328000
2021.05.11 07:05:49.603 5: SCC sending As0BC7A001F112343D32800103
2021.05.11 07:05:49.604 5: SW: As0BC7A001F112343D32800103
2021.05.11 07:05:49.786 5: CUL/RAW: /A0
2021.05.11 07:05:49.787 5: CUL/RAW: A0/EC7A
2021.05.11 07:05:49.787 5: CUL/RAW: A0EC7A/01
2021.05.11 07:05:49.788 5: CUL/RAW: A0EC7A01/03
2021.05.11 07:05:49.788 5: CUL/RAW: A0EC7A0103/D3
2021.05.11 07:05:49.789 5: CUL/RAW: A0EC7A0103D3/28
2021.05.11 07:05:49.789 5: CUL/RAW: A0EC7A0103D328/0F
2021.05.11 07:05:49.790 5: CUL/RAW: A0EC7A0103D3280F/11
2021.05.11 07:05:49.791 5: CUL/RAW: A0EC7A0103D3280F11/23
2021.05.11 07:05:49.791 5: CUL/RAW: A0EC7A0103D3280F1123/40
2021.05.11 07:05:49.792 5: CUL/RAW: A0EC7A0103D3280F112340/10
2021.05.11 07:05:49.792 5: CUL/RAW: A0EC7A0103D3280F11234010/000
2021.05.11 07:05:49.793 5: CUL/RAW: A0EC7A0103D3280F11234010000/00
2021.05.11 07:05:49.793 5: CUL/RAW: A0EC7A0103D3280F1123401000000/00
2021.05.11 07:05:49.794 5: CUL/RAW: A0EC7A0103D3280F112340100000000/0F
2021.05.11 07:05:49.794 5: CUL/RAW: A0EC7A0103D3280F1123401000000000F/
2021.05.11 07:05:49.795 4: CUL_Parse: SCC A 0E C7 A010 3D3280 F11234 01000000000F -66.5
2021.05.11 07:05:49.795 5: SCC: dispatch A0EC7A0103D3280F112340100000000::-66.5:SCC
2021.05.11 07:05:49.799 5: SCC sending As0AC78002F112343D328000
2021.05.11 07:05:49.800 5: CUL 3D3280 dly:95ms
2021.05.11 07:05:49.895 5: SW: As0AC78002F112343D328000
2021.05.11 07:05:56.119 5: CUL/RAW: /A0F
2021.05.11 07:05:56.122 5: CUL/RAW: A0F/8B86105D66
2021.05.11 07:05:56.124 5: CUL/RAW: A0F8B86105D66/B600000
2021.05.11 07:05:56.125 5: CUL/RAW: A0F8B86105D66B600000/00A58B
2021.05.11 07:05:56.127 5: CUL/RAW: A0F8B86105D66B60000000A58B/90900401
2021.05.11 07:05:56.129 5: CUL/RAW: A0F8B86105D66B60000000A58B90900401/4
2021.05.11 07:05:56.130 4: CUL_Parse: SCC A 0F 8B 8610 5D66B6 000000 0A58B909004014 -64
2021.05.11 07:05:56.132 5: SCC: dispatch A0F8B86105D66B60000000A58B9090040::-64:SCC
2021.05.11 07:06:01.446 5: CUL/RAW: /A0
2021.05.11 07:06:01.450 5: CUL/RAW: A0/F3F865E71DA760000
2021.05.11 07:06:01.451 5: CUL/RAW: A0F3F865E71DA760000/000C
2021.05.11 07:06:01.452 5: CUL/RAW: A0F3F865E71DA760000000C/AB
2021.05.11 07:06:01.452 5: CUL/RAW: A0F3F865E71DA760000000CAB/C0
2021.05.11 07:06:01.453 5: CUL/RAW: A0F3F865E71DA760000000CABC0/00F
2021.05.11 07:06:01.454 5: CUL/RAW: A0F3F865E71DA760000000CABC000F/61
2021.05.11 07:06:01.454 5: CUL/RAW: A0F3F865E71DA760000000CABC000F61/81
2021.05.11 07:06:01.455 5: CUL/RAW: A0F3F865E71DA760000000CABC000F6181/F
2021.05.11 07:06:01.455 5: CUL/RAW: A0F3F865E71DA760000000CABC000F6181F
2021.05.11 07:06:01.456 4: CUL_Parse: SCC A 0F 3F 865E 71DA76 000000 0CABC000F6181F -58.5
2021.05.11 07:06:01.456 5: SCC: dispatch A0F3F865E71DA760000000CABC000F618::-58.5:SCC
jump to the top
List Wassermelder_1
   .triggerUsed 1
   DEF        3D3280
   FUUID      60942659-f33f-431b-b5e3-2f50ab8a7cc96fa1
   IODev      SCC
   LASTInputDev SCC
   MSGCNT     12
   NAME       Wassermelder_1
   NOTIFYDEV  global
   NR         73
   NTFY_ORDER 50-Wassermelder_1
   SCC_MSGCNT 12
   SCC_RAWMSG A0EC7A0103D3280F112340100000000::-66.5:SCC
   SCC_RSSI   -66.5
   SCC_TIME   2021-05-11 07:05:49
   STATE      dry
   TYPE       CUL_HM
   chanNo     01
   lastMsg    No:C7 - t:10 s:3D3280 d:F11234 0100000000
   protCmdDel 3
   protLastRcv 2021-05-11 07:05:49
   protRcv    12 last_at:2021-05-11 07:05:49
   protResnd  3 last_at:2021-05-11 07:00:56
   protResndFail 1 last_at:2021-05-11 07:01:05
   protSnd    22 last_at:2021-05-11 07:05:49
   protState  CMDs_done
   rssi_at_SCC cnt:12 min:-82 max:-61 avg:-70.16 lst:-66.5
   .attraggr:
   .attrminint:
   CL:
     Authenticated 1
     AuthenticatedBy allowed_WEB
     AuthenticatedUser FHEMSHOHAUSEN
     BUF
     FD         53
     FW_ID      682
     LASTACCESS 1620709732
     NAME       WEB_93.207.30.90_60247
     NR         683
     PEER       93.207.30.90
     PORT       60247
     SNAME      WEB
     SSL        1
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-11 07:08:45   state           Connected
     2021-05-11 07:05:49   .D-devInfo      110101
     2021-05-11 07:05:49   .D-stc          80
     2021-05-11 07:05:49   .associatedWith Wassermelder_1,Wassermelder_1
     2021-05-11 07:05:49   .peerListRDate  2021-05-11 07:05:49
     2021-05-11 07:05:49   .protLastRcv    20210511070549
     2021-05-11 07:07:13   Activity        alive
     2021-05-07 23:04:51   CommandAccepted yes
     2021-05-11 07:05:49   D-firmware      1.4
     2021-05-11 07:05:49   D-serialNr      MEQ0590456
     2021-05-11 06:57:10   IODev           SCC
     2021-05-11 07:05:49   PairedTo        0xF11234
     2021-05-06 19:25:57   R-cyclicInfoMsg on
     2021-05-06 19:27:52   R-eventFilterTimeB 5 s
     2021-05-06 19:27:52   R-msgWdsPosA    dry
     2021-05-06 19:27:52   R-msgWdsPosB    wet
     2021-05-06 19:27:52   R-msgWdsPosC    water
     2021-05-07 23:04:51   R-pairCentral   0xF11234
     2021-05-06 19:27:52   R-sign          off
     2021-05-06 19:25:57   R-transmDevTryMax 6
     2021-05-06 19:27:52   R-transmitTryMax 6
     2021-05-11 07:05:49   RegL_00.         00:00 02:01 09:01 0A:F1 0B:12 0C:34 10:01 14:06
     2021-05-11 07:05:49   RegL_01.         00:00 08:00 20:78 22:64 23:05 30:06
     2021-05-10 14:51:50   alive           yes
     2021-05-11 07:04:41   battery         ok
     2021-05-11 07:06:49   cfgState        TrigUndef
     2021-05-11 07:05:49   commState       CMDs_done
     2021-05-11 07:04:41   contact         dry (to SCC)
     2021-05-10 14:51:50   cover           closed
     2021-05-10 14:51:50   recentStateType info
     2021-05-11 07:04:41   state           dry
     2021-05-11 07:04:41   trigDst_F11234  noConfig
     2021-05-11 07:04:41   trigger_cnt     98
   helper:
     HM_CMDNR   199
     cSnd       01F112343D328001040000000001,01F112343D32800103
     mId        00B2
     peerIDsRaw ,00000000
     regLst     0,1,4p
     rxType     12
     supp_Pair_Rep 0
     tmplChg    0
     cfgChk:
       idPz05     F11234
     cmds:
       TmplKey    :no:1620709034.85842
       TmplTs     1620709034.85842
       cmdKey     1:1:0::Wassermelder_1:00B2:01:
       cmdLst:
         assignHmKey noArg
         getConfig  noArg
         getDevInfo noArg
         peerSmart  -peerOpt-
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         condition  closed,damp,dry,open,tilted,wet
         peer
         peerOpt    Rauch_Team,Schalt1,Schalt_Trock_Sw,Schalt_Wasch_Sw,Schalt_Z_Sw,Schalter_Licht_Sw_01,Schalter_Licht_Sw_02,Sirene,Thermostat_WindowRec,Thermostat_remote,Ventil1_Wohn_WindowRec,Ventil1_Wohn_remote,Ventil2_Ess_WindowRec,Ventil2_Ess_remote,Ventil3_Schlaf_WindowRec,Ventil3_Schlaf_remote,Ventil4_Buero_WindowRec,Ventil4_Buero_remote
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +3D3280,00,00,00
       nextSend   1620709549.89539
       prefIO
       rxt        2
       vccu
       p:
         3D3280
         00
         00
         00
     mRssi:
       mNo        C7
       io:
         SCC:
           -62.5
           -62.5
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       sleeping   1
       rspWait:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rpt:
       IO         SCC
       flg        A
       ts         1620709549.79632
       ack:
         HASH(0x2d97d68)
     rssi:
       at_SCC:
         avg        -70.1666666666667
         cnt        12
         lst        -66.5
         max        -61
         min        -82
     shadowReg:
     tmpl:
   .mId       00B2
   IODev      SCC
   actCycle   028:00
   actStatus  alive
   autoReadReg 4_reqStatus
   devStateIcon dry:weather_sun wet:weather_rain_heavy@red
   expert     defReg,allReg,rawReg
   firmware   1.4
   icon       weather_humidity
   model      HM-SEC-WDS-2
   peerIDs    00000000
   room       CUL_HM
   serialNr   MEQ0590456
frank
#72
ich fürchte, dass das zähe und ermüdende bug fixing auf meine motivation einfluss hat.  ;)
es fühlt sich an wie 1 schritt vor und 2 schritte zurück.
getconfig durch tastendruck: (hmlan, hmuart)
hmuart und hmlan schaffen weiterhin ein getconfig mit einem einzigen tastendruck.
############################ hmlan, config
2021.05.11 10:16:15.089 3 : CUL_HM set Tuer.SZ getConfig noArg
2021-05-11 10:16:15.122 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:16:15.129 0 : HMLAN_Send:  hmlan1 I:+1DE620,02,00,00
2021-05-11 10:16:15.149 CUL_HM Tuer.SZ cfgState: updating
2021.05.11 10:16:21.420 4 : CUL_Parse: cul868 A 1A C3 8400 1DE620 000000 20002F4A4551303634343832388081010127 -54.5
2021.05.11 10:16:21.424 0 : HMLAN_Send:  hmlan1 I:+1DE620,00,00,00
2021.05.11 10:16:21.522 0 : HMLAN_Send:  hmlan1 S:S5A7F972A stat:  00 t:00000000 d:01 r:5A7F972A m:EB A001 1ACE1F 1DE620 00040000000000
2021-05-11 10:16:21.543 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 10:16:21.550 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: C3 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.11 10:16:21.553 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:523DD23E d:FF r:FFD0     m:C3 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.11 10:16:21.557 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: EB A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 10:16:21.561 4 : CUL_Parse: cul868 A 10 EB A001 1ACE1F 1DE620 000400000000003D -43.5
2021.05.11 10:16:21.686 4 : CUL_Parse: cul868 A 1A EB A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F10011406000028 -54
2021-05-11 10:16:21.712 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:16:21.719 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3E msg: EB A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 10:16:21.722 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:523DD347 d:FF r:FFCE     m:EB A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 10:16:21.801 4 : CUL_Parse: cul868 A 0A EB 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:16:21.806 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: EB 80 02 1ACE1F 1DE620 00
2021.05.11 10:16:21.809 0 : HMLAN_Parse: hmlan1 R:R5A7F972A stat:0001 t:523DD34C d:FF r:FFCE     m:EB A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 10:16:21.812 0 : HMLAN_Send:  hmlan1 S:S5A7F98AC stat:  00 t:00000000 d:01 r:5A7F98AC m:FB A001 1ACE1F 1DE620 01040000000001
2021-05-11 10:16:21.832 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 10:16:22.076 4 : CUL_Parse: cul868 A 10 FB A001 1ACE1F 1DE620 010400000000013D -43.5
2021.05.11 10:16:22.081 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: FB A0 01 1ACE1F 1DE620 01040000000001
2021.05.11 10:16:22.205 4 : CUL_Parse: cul868 A 16 FB A010 1DE620 1ACE1F 0208002060210022643006000028 -54
2021-05-11 10:16:22.231 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:16:22.238 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: FB A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 10:16:22.241 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:523DD54F d:FF r:FFCE     m:FB A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 10:16:22.324 4 : CUL_Parse: cul868 A 0A FB 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:16:22.329 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: FB 80 02 1ACE1F 1DE620 00
2021.05.11 10:16:22.331 0 : HMLAN_Parse: hmlan1 R:R5A7F98AC stat:0001 t:523DD554 d:FF r:FFCE     m:FB A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 10:16:22.335 0 : HMLAN_Send:  hmlan1 S:S5A7F9AB7 stat:  00 t:00000000 d:01 r:5A7F9AB7 m:0B A001 1ACE1F 1DE620 0103
2021-05-11 10:16:22.355 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 10:16:22.595 4 : CUL_Parse: cul868 A 0B 0B A001 1ACE1F 1DE620 01033D -43.5
2021.05.11 10:16:22.600 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 0B A0 01 1ACE1F 1DE620 0103
2021.05.11 10:16:22.725 4 : CUL_Parse: cul868 A 12 0B A010 1DE620 1ACE1F 011A164B010000000023 -56.5
2021-05-11 10:16:22.752 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:16:22.781 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: 0B A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.11 10:16:22.784 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:523DD757 d:FF r:FFCF     m:0B A010 1DE620 1ACE1F 011A164B0100000000
2021.05.11 10:16:22.846 4 : CUL_Parse: cul868 A 0A 0B 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:16:22.852 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 0B 80 02 1ACE1F 1DE620 00
2021.05.11 10:16:22.854 0 : HMLAN_Parse: hmlan1 R:R5A7F9AB7 stat:0001 t:523DD75C d:FF r:FFCF     m:0B A010 1DE620 1ACE1F 011A164B0100000000
2021.05.11 10:16:22.858 0 : HMLAN_Send:  hmlan1 S:S5A7F9CC2 stat:  00 t:00000000 d:01 r:5A7F9CC2 m:1B A001 1ACE1F 1DE620 01041A164B0104
2021-05-11 10:16:22.877 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 10:16:23.122 4 : CUL_Parse: cul868 A 10 1B A001 1ACE1F 1DE620 01041A164B01043D -43.5
2021.05.11 10:16:23.126 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 1B A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 10:16:23.244 4 : CUL_Parse: cul868 A 0E 1B A010 1DE620 1ACE1F 020100000024 -56
2021-05-11 10:16:23.269 CUL_HM Tuer.SZ commState: CMDs_done
2021.05.11 10:16:23.276 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 1B A0 10 1DE620 1ACE1F 0201000000
2021.05.11 10:16:23.322 4 : CUL_Parse: cul868 A 10 1B A001 1ACE1F 1DE620 01041A164B01043D -43.5
2021.05.11 10:16:23.326 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 1B A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 10:16:23.522 4 : CUL_Parse: cul868 A 10 1B A001 1ACE1F 1DE620 01041A164B01043D -43.5
2021.05.11 10:16:23.526 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 1B A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 10:16:23.643 4 : CUL_Parse: cul868 A 0E 1B A010 1DE620 1ACE1F 020100000025 -55.5
2021.05.11 10:16:23.649 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 1B A0 10 1DE620 1ACE1F 0201000000
2021.05.11 10:16:23.653 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:523DDAEE d:FF r:FFD0     m:1B A010 1DE620 1ACE1F 0201000000
2021.05.11 10:16:23.767 4 : CUL_Parse: cul868 A 0A 1B 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:16:23.772 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 1B 80 02 1ACE1F 1DE620 00
2021.05.11 10:16:23.775 0 : HMLAN_Parse: hmlan1 R:R5A7F9CC2 stat:0001 t:523DDAF3 d:FF r:FFD0     m:1B A010 1DE620 1ACE1F 0201000000
########################### hmuart, config
2021.05.11 09:37:08.157 3 : CUL_HM set Tuer.SZ getConfig noArg
2021-05-11 09:37:08.195 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 09:37:17.238 4 : CUL_Parse: cul868 A 1A BA 8400 1DE620 000000 20002F4A4551303634343832388081010115 -63.5
2021.05.11 09:37:17.242 0 : HMUARTLGW hmuart1 send: 01 061DE620000000
2021-05-11 09:37:17.267 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 09:37:17.274 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521A0C06 d:FF r:FFCD     m:BA 8400 1DE620 000000 20002F4A45513036343438323880810101
2021.05.11 09:37:17.278 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 34 msg: BA 84 00 1DE620 000000 20002F4A45513036343438323880810101
2021.05.11 09:37:17.281 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.11 09:37:17.282 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.11 09:37:17.283 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 09:37:17.286 0 : HMUARTLGW hmuart1 send: 01 061DE620000000
2021.05.11 09:37:17.292 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.11 09:37:17.294 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.11 09:37:17.294 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 09:37:17.374 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: E2 A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 09:37:17.406 4 : CUL_Parse: cul868 A 10 E2 A001 1ACE1F 1DE620 0004000000000067 -22.5
2021.05.11 09:37:17.416 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A0CAE d:FF r:FFCF     m:E2 A001 1ACE1F 1DE620 00040000000000
2021.05.11 09:37:17.540 4 : CUL_Parse: cul868 A 1A E2 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600000D -67.5
2021.05.11 09:37:17.551 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:37:17.552 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:37:17.554 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 38 msg: E2 A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 09:37:17.557 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521A0D33 d:FF r:FFCE     m:E2 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 09:37:17.642 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: F2 A0 01 1ACE1F 1DE620 01040000000001
2021.05.11 09:37:17.649 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 09:37:17.650 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 09:37:17.652 4 : CUL_Parse: cul868 A 0A E2 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:37:17.660 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A0DA2 d:FF r:FFCF     m:E2 8002 1ACE1F 1DE620 00
2021.05.11 09:37:17.702 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: F2 A0 01 1ACE1F 1DE620 01040000000001
2021.05.11 09:37:17.793 4 : CUL_Parse: cul868 A 10 F2 A001 1ACE1F 1DE620 0104000000000167 -22.5
2021.05.11 09:37:17.804 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A0E32 d:FF r:FFCF     m:F2 A001 1ACE1F 1DE620 01040000000001
2021.05.11 09:37:17.924 4 : CUL_Parse: cul868 A 16 F2 A010 1DE620 1ACE1F 020800206021002264300600000A -69
2021.05.11 09:37:17.934 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:37:17.935 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:37:17.937 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 39 msg: F2 A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 09:37:18.026 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 02 A0 01 1ACE1F 1DE620 0103
2021.05.11 09:37:18.032 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 09:37:18.034 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 09:37:18.037 4 : CUL_Parse: cul868 A 0A F2 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:37:18.048 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A0F26 d:FF r:FFCF     m:F2 8002 1ACE1F 1DE620 00
2021.05.11 09:37:18.231 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 02 A0 01 1ACE1F 1DE620 0103
2021.05.11 09:37:18.258 4 : CUL_Parse: cul868 A 0B 02 A001 1ACE1F 1DE620 010367 -22.5
2021.05.11 09:37:18.267 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A1002 d:FF r:FFCF     m:02 A001 1ACE1F 1DE620 0103
2021.05.11 09:37:18.388 4 : CUL_Parse: cul868 A 12 02 A010 1DE620 1ACE1F 011A164B01000000000A -69
2021.05.11 09:37:18.399 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:37:18.400 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:37:18.402 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 39 msg: 02 A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.11 09:37:18.405 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521A1085 d:FF r:FFCE     m:02 A010 1DE620 1ACE1F 011A164B0100000000
2021.05.11 09:37:18.490 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 12 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 09:37:18.497 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 09:37:18.498 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 09:37:18.505 4 : CUL_Parse: cul868 A 0A 02 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:37:18.515 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A10FA d:FF r:FFCF     m:02 8002 1ACE1F 1DE620 00
2021.05.11 09:37:18.551 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 12 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 09:37:18.649 4 : CUL_Parse: cul868 A 10 12 A001 1ACE1F 1DE620 01041A164B010467 -22.5
2021.05.11 09:37:18.660 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A118A d:FF r:FFCF     m:12 A001 1ACE1F 1DE620 01041A164B0104
2021.05.11 09:37:18.772 4 : CUL_Parse: cul868 A 0E 12 A010 1DE620 1ACE1F 02010000000A -69
2021-05-11 09:37:18.796 CUL_HM Tuer.SZ commState: CMDs_done
2021.05.11 09:37:18.803 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:37:18.804 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:37:18.806 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 39 msg: 12 A0 10 1DE620 1ACE1F 0201000000
2021.05.11 09:37:18.808 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521A1205 d:FF r:FFCD     m:12 A010 1DE620 1ACE1F 0201000000
2021.05.11 09:37:18.893 4 : CUL_Parse: cul868 A 0A 12 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:37:18.903 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521A127E d:FF r:FFCF     m:12 8002 1ACE1F 1DE620 00
getconfig nach sabotagemsg A610 (cul, hmuart, hmlan):
cul funktioniert nicht, wie beim lazyconfig bei SHOFHEM.
hmlan und hmuart schaffen es nur, weil der erste cmd (read list0) scheinbar autonom durch das io wiederholt wird.
########################### A610, cul
2021.05.11 09:29:34.781 3 : CUL_HM set Tuer.SZ getConfig noArg
2021-05-11 09:29:34.806 CUL_HM Tuer.SZ commState: CMDs_pending
2021-05-11 09:29:34.829 CUL_HM Tuer.SZ cfgState: updating
2021.05.11 09:29:40.323 4 : CUL_Parse: cul868 A 0D B6 A610 1DE620 1ACE1F 0601000020 -58
2021-05-11 09:29:40.456 CUL_HM Tuer.SZ commState: CMDs_processing...
2021-05-11 09:29:40.456 CUL_HM Tuer.SZ sabotageError: off
2021.05.11 09:29:40.458 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: B6 A6 10 1DE620 1ACE1F 06010000
2021.05.11 09:29:40.461 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B6 81 02 1ACE1F 1DE620 00
2021.05.11 09:29:40.466 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:52131376 d:FF r:FFD8     m:B6 8102 1ACE1F 1DE620 00
2021.05.11 09:29:40.485 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B7 A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 09:29:40.492 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:52131394 d:FF r:FFD8     m:B7 A001 1ACE1F 1DE620 00040000000000
2021-05-11 09:29:46.246 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 09:29:51.574 4 : CUL_Parse: cul868 A 0D B7 A610 1DE620 1ACE1F 0601000E1F -58.5
2021-05-11 09:29:51.708 CUL_HM Tuer.SZ commState: CMDs_processing...
2021-05-11 09:29:51.708 CUL_HM Tuer.SZ sabotageError: on
2021.05.11 09:29:51.709 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:52133EEA d:FF r:FFCD     m:B7 A610 1DE620 1ACE1F 0601000E
2021.05.11 09:29:51.714 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: B7 A6 10 1DE620 1ACE1F 0601000E
2021.05.11 09:29:51.717 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B7 81 02 1ACE1F 1DE620 00
2021.05.11 09:29:51.721 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:52133F6B d:FF r:FFD8     m:B7 8102 1ACE1F 1DE620 00
2021.05.11 09:29:51.738 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B8 A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 09:29:51.744 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:52133F89 d:FF r:FFD8     m:B8 A001 1ACE1F 1DE620 00040000000000
2021-05-11 09:29:55.770 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 09:30:01.575 4 : CUL_Parse: cul868 A 0D B8 A610 1DE620 1ACE1F 060100001C -60
2021-05-11 09:30:01.714 CUL_HM Tuer.SZ commState: CMDs_processing...
2021-05-11 09:30:01.714 CUL_HM Tuer.SZ sabotageError: off
2021.05.11 09:30:01.716 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3F msg: B8 A6 10 1DE620 1ACE1F 06010000
2021.05.11 09:30:01.720 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B8 81 02 1ACE1F 1DE620 00
2021.05.11 09:30:01.725 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5213667F d:FF r:FFD8     m:B8 8102 1ACE1F 1DE620 00
2021.05.11 09:30:01.738 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B9 A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 09:30:01.746 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5213669D d:FF r:FFD8     m:B9 A001 1ACE1F 1DE620 00040000000000
2021-05-11 09:30:06.203 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 09:30:12.325 4 : CUL_Parse: cul868 A 0D B9 A610 1DE620 1ACE1F 0601000E1E -59
2021-05-11 09:30:12.456 CUL_HM Tuer.SZ commState: CMDs_processing...
2021-05-11 09:30:12.456 CUL_HM Tuer.SZ sabotageError: on
2021.05.11 09:30:12.459 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:52138FFC d:FF r:FFB1     m:B9 A610 1DE620 1ACE1F 0601000E
2021.05.11 09:30:12.463 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: B9 A6 10 1DE620 1ACE1F 0601000E
2021.05.11 09:30:12.466 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B9 81 02 1ACE1F 1DE620 00
2021.05.11 09:30:12.471 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5213907E d:FF r:FFD8     m:B9 8102 1ACE1F 1DE620 00
2021.05.11 09:30:12.488 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: BA A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 09:30:12.495 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5213909C d:FF r:FFD8     m:BA A001 1ACE1F 1DE620 00040000000000
######################### A610, hmuart
2021.05.11 09:40:14.360 3 : CUL_HM set Tuer.SZ getConfig noArg
2021-05-11 09:40:14.396 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 09:40:14.405 0 : HMUARTLGW hmuart1 send: 01 061DE620000100
2021-05-11 09:40:14.427 CUL_HM Tuer.SZ cfgState: updating
2021.05.11 09:40:14.437 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.11 09:40:14.439 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.11 09:40:14.440 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 09:40:14.443 0 : HMUARTLGW hmuart1 send: 01 061DE620000100
2021.05.11 09:40:14.450 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.11 09:40:14.451 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.11 09:40:14.451 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 09:40:19.610 4 : CUL_Parse: cul868 A 0D BB A610 1DE620 1ACE1F 060100001E -59
2021-05-11 09:40:19.641 CUL_HM Tuer.SZ commState: CMDs_processing...
2021-05-11 09:40:19.641 CUL_HM Tuer.SZ sabotageError: off
2021-05-11 09:40:19.641 CUL_HM Tuer.SZ closed
2021.05.11 09:40:19.649 0 : HMUARTLGW hmuart1 recv: 01 05 11 00 41 msg: BB A6 10 1DE620 1ACE1F 06010000
2021.05.11 09:40:19.713 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: BC A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 09:40:19.720 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 09:40:19.721 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 09:40:19.732 4 : CUL_Parse: cul868 A 0A BB 8102 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:40:19.742 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CD4FD d:FF r:FFCF     m:BB 8102 1ACE1F 1DE620 00
2021.05.11 09:40:19.946 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: BC A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 09:40:19.978 4 : CUL_Parse: cul868 A 10 BC A001 1ACE1F 1DE620 0004000000000067 -22.5
2021.05.11 09:40:19.988 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CD5F3 d:FF r:FFCF     m:BC A001 1ACE1F 1DE620 00040000000000
2021.05.11 09:40:20.259 4 : CUL_Parse: cul868 A 10 BC A001 1ACE1F 1DE620 0004000000000067 -22.5
2021.05.11 09:40:20.269 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CD70C d:FF r:FFCF     m:BC A001 1ACE1F 1DE620 00040000000000
2021.05.11 09:40:20.392 4 : CUL_Parse: cul868 A 1A BC A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600001E -59
2021.05.11 09:40:20.402 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:40:20.404 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:40:20.405 0 : HMUARTLGW hmuart1 send: 00 08
2021.05.11 09:40:20.407 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 42 msg: BC A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 09:40:20.411 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521CD790 d:FF r:FFCE     m:BC A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 09:40:20.414 0 : HMUARTLGW hmuart1 recv: 00 040206, state 98
2021.05.11 09:40:20.415 0 : HMUARTLGW hmuart1 GetSet Ack: 02, state 98
2021.05.11 09:40:20.492 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: CC A0 01 1ACE1F 1DE620 01040000000001
2021.05.11 09:40:20.499 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 09:40:20.500 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 09:40:20.503 4 : CUL_Parse: cul868 A 0A BC 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:40:20.513 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CD800 d:FF r:FFCF     m:BC 8002 1ACE1F 1DE620 00
2021.05.11 09:40:20.552 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: CC A0 01 1ACE1F 1DE620 01040000000001
2021.05.11 09:40:20.646 4 : CUL_Parse: cul868 A 10 CC A001 1ACE1F 1DE620 0104000000000166 -23
2021.05.11 09:40:20.656 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CD88F d:FF r:FFCF     m:CC A001 1ACE1F 1DE620 01040000000001
2021.05.11 09:40:20.775 4 : CUL_Parse: cul868 A 16 CC A010 1DE620 1ACE1F 020800206021002264300600001E -59
2021.05.11 09:40:20.785 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:40:20.786 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:40:20.788 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 42 msg: CC A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 09:40:20.792 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521CD910 d:FF r:FFCE     m:CC A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 09:40:20.877 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: DC A0 01 1ACE1F 1DE620 0103
2021.05.11 09:40:20.883 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 09:40:20.885 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 09:40:20.890 4 : CUL_Parse: cul868 A 0A CC 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:40:20.900 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CD983 d:FF r:FFCF     m:CC 8002 1ACE1F 1DE620 00
2021.05.11 09:40:20.937 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: DC A0 01 1ACE1F 1DE620 0103
2021.05.11 09:40:21.029 4 : CUL_Parse: cul868 A 0B DC A001 1ACE1F 1DE620 010367 -22.5
2021.05.11 09:40:21.039 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CDA0E d:FF r:FFCF     m:DC A001 1ACE1F 1DE620 0103
2021.05.11 09:40:21.159 4 : CUL_Parse: cul868 A 12 DC A010 1DE620 1ACE1F 011A164B01000000001D -59.5
2021.05.11 09:40:21.169 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:40:21.171 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:40:21.172 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 42 msg: DC A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.11 09:40:21.175 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521CDA90 d:FF r:FFCD     m:DC A010 1DE620 1ACE1F 011A164B0100000000
2021.05.11 09:40:21.261 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: EC A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 09:40:21.268 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 09:40:21.269 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 09:40:21.277 4 : CUL_Parse: cul868 A 0A DC 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:40:21.287 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CDB06 d:FF r:FFCF     m:DC 8002 1ACE1F 1DE620 00
2021.05.11 09:40:21.322 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: EC A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 09:40:21.420 4 : CUL_Parse: cul868 A 10 EC A001 1ACE1F 1DE620 01041A164B010467 -22.5
2021.05.11 09:40:21.431 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CDB95 d:FF r:FFCF     m:EC A001 1ACE1F 1DE620 01041A164B0104
2021.05.11 09:40:21.543 4 : CUL_Parse: cul868 A 0E EC A010 1DE620 1ACE1F 02010000001C -60
2021-05-11 09:40:21.568 CUL_HM Tuer.SZ commState: CMDs_done
2021.05.11 09:40:21.575 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 09:40:21.576 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 09:40:21.577 0 : HMUARTLGW hmuart1 send: 01 061DE620000000
2021.05.11 09:40:21.580 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 43 msg: EC A0 10 1DE620 1ACE1F 0201000000
2021.05.11 09:40:21.583 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521CDC10 d:FF r:FFCD     m:EC A010 1DE620 1ACE1F 0201000000
2021.05.11 09:40:21.587 0 : HMUARTLGW hmuart1 recv: 01 0408, state 90
2021.05.11 09:40:21.588 0 : HMUARTLGW hmuart1 GetSet Ack: 08, state 90
2021.05.11 09:40:21.665 4 : CUL_Parse: cul868 A 0A EC 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:40:21.675 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CDC8A d:FF r:FFCF     m:EC 8002 1ACE1F 1DE620 00
2021.05.11 09:40:22.091 0 : HMUARTLGW hmuart1 send: 01 061DE620000000
2021.05.11 09:40:22.097 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.11 09:40:22.098 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.11 09:40:22.099 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 09:40:22.102 0 : HMUARTLGW hmuart1 send: 01 061DE620000000
2021.05.11 09:40:22.108 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.11 09:40:22.109 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.11 09:40:22.110 0 : HMUARTLGW hmuart1 added peer: 1DE620, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 09:40:26.611 4 : CUL_Parse: cul868 A 0D BC A610 1DE620 1ACE1F 0601000E1D -59.5
2021-05-11 09:40:26.639 CUL_HM Tuer.SZ sabotageError: on
2021.05.11 09:40:26.646 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:521CEFDD d:FF r:FFCC     m:BC A610 1DE620 1ACE1F 0601000E
2021.05.11 09:40:26.650 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 4D msg: BC A6 10 1DE620 1ACE1F 0601000E
2021.05.11 09:40:26.732 4 : CUL_Parse: cul868 A 0A BC 8002 1ACE1F 1DE620 0067 -22.5
2021.05.11 09:40:26.743 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:521CF057 d:FF r:FFCF     m:BC 8002 1ACE1F 1DE620 00
######################### A610, hmlan
2021.05.11 10:05:25.215 3 : CUL_HM set Tuer.SZ getConfig noArg
2021-05-11 10:05:25.252 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:05:25.260 0 : HMLAN_Send:  hmlan1 I:+1DE620,02,00,00
2021-05-11 10:05:25.279 CUL_HM Tuer.SZ cfgState: updating
2021.05.11 10:05:32.698 4 : CUL_Parse: cul868 A 0D C1 A610 1DE620 1ACE1F 0601000018 -62
2021.05.11 10:05:32.800 0 : HMLAN_Send:  hmlan1 S:S5A75B117 stat:  00 t:00000000 d:01 r:5A75B117 m:C2 A001 1ACE1F 1DE620 00040000000000
2021-05-11 10:05:32.829 CUL_HM Tuer.SZ commState: CMDs_processing...
2021-05-11 10:05:32.829 CUL_HM Tuer.SZ contact: closed (to ccu)
2021-05-11 10:05:32.829 CUL_HM Tuer.SZ sabotageError: off
2021.05.11 10:05:32.837 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: C1 A6 10 1DE620 1ACE1F 06010000
2021.05.11 10:05:32.840 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: C1 81 02 1ACE1F 1DE620 00
2021.05.11 10:05:32.844 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:5233EBD4 d:FF r:FFD2     m:C1 A610 1DE620 1ACE1F 06010000
2021.05.11 10:05:32.847 4 : CUL_Parse: cul868 A 0A C1 8102 1ACE1F 1DE620 003D -43.5
2021.05.11 10:05:33.095 4 : CUL_Parse: cul868 A 10 C2 A001 1ACE1F 1DE620 000400000000003D -43.5
2021.05.11 10:05:33.100 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: C2 A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 10:05:33.295 4 : CUL_Parse: cul868 A 10 C2 A001 1ACE1F 1DE620 000400000000003D -43.5
2021.05.11 10:05:33.299 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: C2 A0 01 1ACE1F 1DE620 00040000000000
2021.05.11 10:05:33.428 4 : CUL_Parse: cul868 A 1A C2 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F10011406000018 -62
2021-05-11 10:05:33.461 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:05:33.469 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: C2 A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 10:05:33.472 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:5233EEAC d:FF r:FFD2     m:C2 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 10:05:33.543 4 : CUL_Parse: cul868 A 0A C2 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:05:33.548 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: C2 80 02 1ACE1F 1DE620 00
2021.05.11 10:05:33.551 0 : HMLAN_Parse: hmlan1 R:R5A75B117 stat:0001 t:5233EEB1 d:FF r:FFD2     m:C2 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.11 10:05:33.555 0 : HMLAN_Send:  hmlan1 S:S5A75B46B stat:  00 t:00000000 d:01 r:5A75B46B m:D2 A001 1ACE1F 1DE620 01040000000001
2021-05-11 10:05:33.576 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 10:05:33.817 4 : CUL_Parse: cul868 A 10 D2 A001 1ACE1F 1DE620 010400000000013D -43.5
2021.05.11 10:05:33.822 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: D2 A0 01 1ACE1F 1DE620 01040000000001
2021.05.11 10:05:33.947 4 : CUL_Parse: cul868 A 16 D2 A010 1DE620 1ACE1F 0208002060210022643006000018 -62
2021-05-11 10:05:33.975 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:05:33.982 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: D2 A0 10 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 10:05:33.985 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:5233F0B5 d:FF r:FFD2     m:D2 A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 10:05:34.066 4 : CUL_Parse: cul868 A 0A D2 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:05:34.072 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: D2 80 02 1ACE1F 1DE620 00
2021.05.11 10:05:34.075 0 : HMLAN_Parse: hmlan1 R:R5A75B46B stat:0001 t:5233F0BA d:FF r:FFD2     m:D2 A010 1DE620 1ACE1F 02080020602100226430060000
2021.05.11 10:05:34.078 0 : HMLAN_Send:  hmlan1 S:S5A75B676 stat:  00 t:00000000 d:01 r:5A75B676 m:E2 A001 1ACE1F 1DE620 0103
2021-05-11 10:05:34.099 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 10:05:34.336 4 : CUL_Parse: cul868 A 0B E2 A001 1ACE1F 1DE620 01033D -43.5
2021.05.11 10:05:34.341 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: E2 A0 01 1ACE1F 1DE620 0103
2021.05.11 10:05:34.466 4 : CUL_Parse: cul868 A 12 E2 A010 1DE620 1ACE1F 011A164B010000000016 -63
2021-05-11 10:05:34.494 CUL_HM Tuer.SZ commState: CMDs_pending
2021.05.11 10:05:34.524 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: E2 A0 10 1DE620 1ACE1F 011A164B0100000000
2021.05.11 10:05:34.528 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:5233F2BD d:FF r:FFD2     m:E2 A010 1DE620 1ACE1F 011A164B0100000000
2021.05.11 10:05:34.589 4 : CUL_Parse: cul868 A 0A E2 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:05:34.594 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: E2 80 02 1ACE1F 1DE620 00
2021.05.11 10:05:34.597 0 : HMLAN_Parse: hmlan1 R:R5A75B676 stat:0001 t:5233F2C2 d:FF r:FFD2     m:E2 A010 1DE620 1ACE1F 011A164B0100000000
2021.05.11 10:05:34.601 0 : HMLAN_Send:  hmlan1 S:S5A75B881 stat:  00 t:00000000 d:01 r:5A75B881 m:F2 A001 1ACE1F 1DE620 01041A164B0104
2021-05-11 10:05:34.622 CUL_HM Tuer.SZ commState: CMDs_processing...
2021.05.11 10:05:34.862 4 : CUL_Parse: cul868 A 10 F2 A001 1ACE1F 1DE620 01041A164B01043D -43.5
2021.05.11 10:05:34.868 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: F2 A0 01 1ACE1F 1DE620 01041A164B0104
2021.05.11 10:05:34.985 4 : CUL_Parse: cul868 A 0E F2 A010 1DE620 1ACE1F 020100000015 -63.5
2021.05.11 10:05:34.992 0 : HMLAN_Send:  hmlan1 I:+1DE620,00,00,00
2021-05-11 10:05:35.012 CUL_HM Tuer.SZ commState: CMDs_done
2021.05.11 10:05:35.020 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3C msg: F2 A0 10 1DE620 1ACE1F 0201000000
2021.05.11 10:05:35.024 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:5233F4C4 d:FF r:FFD2     m:F2 A010 1DE620 1ACE1F 0201000000
2021.05.11 10:05:35.110 4 : CUL_Parse: cul868 A 0A F2 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:05:35.116 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: F2 80 02 1ACE1F 1DE620 00
2021.05.11 10:05:35.119 0 : HMLAN_Parse: hmlan1 R:R5A75B881 stat:0001 t:5233F4C9 d:FF r:FFD2     m:F2 A010 1DE620 1ACE1F 0201000000
2021.05.11 10:05:39.448 4 : CUL_Parse: cul868 A 0D C2 A610 1DE620 1ACE1F 0601000E16 -63
2021-05-11 10:05:39.475 CUL_HM Tuer.SZ sabotageError: on
2021.05.11 10:05:39.482 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: C2 A6 10 1DE620 1ACE1F 0601000E
2021.05.11 10:05:39.486 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:52340634 d:FF r:FFD2     m:C2 A610 1DE620 1ACE1F 0601000E
2021.05.11 10:05:39.569 4 : CUL_Parse: cul868 A 0A C2 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:05:39.575 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: C2 80 02 1ACE1F 1DE620 00
2021.05.11 10:05:42.188 4 : CUL_Parse: cul868 A 0D C2 A610 1DE620 1ACE1F 0601000E20 -58
2021.05.11 10:05:42.194 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: C2 A6 10 1DE620 1ACE1F 0601000E
2021.05.11 10:05:42.198 0 : HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:523410E9 d:FF r:FFCF     m:C2 A610 1DE620 1ACE1F 0601000E
2021.05.11 10:05:42.310 4 : CUL_Parse: cul868 A 0A C2 8002 1ACE1F 1DE620 003D -43.5
2021.05.11 10:05:42.314 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: C2 80 02 1ACE1F 1DE620 00
wenn ich mir die timestamps zwischen den msgs 8102 und A001 anschaue, die jeweils als erstes im log auftauchen, braucht es scheinbar mehr wie 246/255 ms. die wiederholung nach 527/455 ms ist dann erfolgreich.
die ca 250 ms bis zum A001 cmd finde ich schon bemerkenswert lange. und noch bemerkenswerter, das dem sc das noch nicht lang genug zu sein scheint.
ist das präparieren vom autonomen 8102 besonders aufwendig?
beim cul ist der abstand zwischen 8102 und A001 natürlich extrem kurz mit guten 20 ms. bei SHOFHEM sind es sogar nur 4 ms.
wenn der cul ebenfalls wiederholen würde, würde es sicherlich auch mit cul funktionieren.
hier noch ein vergleich von gestern, wo durch rxt=4 falsch mit 8002 vom cul geantwortet wird.
allerdings ist hier das timing sehr viel besser, sodass zumindestens bis zum einschlafen geantwortet wird.
2021.05.10 11:13:09.017 3: CUL_HM set Tuer.SZ getConfig noArg
2021.05.10 11:13:17.187 4: CUL_Parse: cul868 A 0D A0 A610 1DE620 1ACE1F 060100001F -58.5
2021.05.10 11:13:17.320 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D4B685E d:FF r:FFD4     m:A0 A610 1DE620 1ACE1F 06010000
2021.05.10 11:13:17.324 0: HMUARTLGW hmuart1 recv: 01 05 00 00 34 msg: A0 A6 10 1DE620 1ACE1F 06010000
2021.05.10 11:13:17.328 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: A0 80 02 1ACE1F 1DE620 00
2021.05.10 11:13:17.332 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D4B68DF d:FF r:FFD9     m:A0 8002 1ACE1F 1DE620 00
2021.05.10 11:13:17.528 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: A1 A0 01 1ACE1F 1DE620 00040000000000
2021.05.10 11:13:17.535 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D4B69B0 d:FF r:FFD9     m:A1 A001 1ACE1F 1DE620 00040000000000
2021.05.10 11:13:17.657 4: CUL_Parse: cul868 A 1A A1 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F1001140600001F -58.5
2021.05.10 11:13:17.765 0: HMLAN_Parse: hmlan1 R:E1DE620   stat:0000 t:4D4B6A34 d:FF r:FFD4     m:A1 A010 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 11:13:17.769 0: HMUARTLGW hmuart1 recv: 01 05 00 00 33 msg: A1 A0 10 1DE620 1ACE1F 02020009010A1A0BCE0C1F100114060000
2021.05.10 11:13:17.789 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: A1 80 02 1ACE1F 1DE620 00
2021.05.10 11:13:17.797 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D4B6AB6 d:FF r:FFD9     m:A1 8002 1ACE1F 1DE620 00
2021.05.10 11:13:17.820 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: B1 A0 01 1ACE1F 1DE620 01040000000001
2021.05.10 11:13:17.826 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:4D4B6AD3 d:FF r:FFD9     m:B1 A001 1ACE1F 1DE620 01040000000001
das falsche antworten auf WAKEMEUP ist natürlich überhaupt nicht schön.
edit:
meinem homebrew universalsensor gefällt das ultra schnelle cul timing zb sehr gut.
mit dem timing von hmlan, hmuart kann er in der regel nichts anfangen, da sind scheinbar die 250 ms zu lang.
allerdings sind mit cul noch 8102 Acks bei multi-message-antworten zu sehen anstatt 8002.
############## A270, cul
2021.05.11 16:33:13.389 3: CUL_HM set Wetter.Sued getConfig noArg
2021.05.11 16:35:11.606 4: CUL_Parse: cul868 A 14 43 A270 6869B6 1ACE1F 80C93F2ACC0000FA5908FC2A -53
2021.05.11 16:35:11.768 0: HMUARTLGW hmuart1 recv: 01 05 00 00 30 msg: 43 A2 70 6869B6 1ACE1F 80C93F2ACC0000FA5908FC
2021.05.11 16:35:11.772 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 43 81 02 1ACE1F 6869B6 00
2021.05.11 16:35:11.776 0: HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:5398B44C d:FF r:FFD8     m:43 A270 6869B6 1ACE1F 80C93F2ACC0000FA5908FC
2021.05.11 16:35:11.779 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5398B4CE d:FF r:FFD9     m:43 8102 1ACE1F 6869B6 00
2021.05.11 16:35:11.782 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5398B4EC d:FF r:FFD9     m:44 A001 1ACE1F 6869B6 00040000000000
2021.05.11 16:35:11.787 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 44 A0 01 1ACE1F 6869B6 00040000000000
2021.05.11 16:35:11.804 4: CUL_Parse: cul868 A 1A 44 A010 6869B6 1ACE1F 02010005240A1A0BCE0C1F1218140324002A -53
2021.05.11 16:35:11.910 0: HMUARTLGW hmuart1 recv: 01 05 00 00 30 msg: 44 A0 10 6869B6 1ACE1F 02010005240A1A0BCE0C1F121814032400
2021.05.11 16:35:11.913 0: HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:5398B511 d:FF r:FFD8     m:44 A010 6869B6 1ACE1F 02010005240A1A0BCE0C1F121814032400
2021.05.11 16:35:11.936 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 44 81 02 1ACE1F 6869B6 00
2021.05.11 16:35:11.943 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5398B594 d:FF r:FFD9     m:44 8102 1ACE1F 6869B6 00
2021.05.11 16:35:11.959 4: CUL_Parse: cul868 A 0E 45 A010 6869B6 1ACE1F 02254E00002A -53
2021.05.11 16:35:12.070 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2F msg: 45 A0 10 6869B6 1ACE1F 02254E0000
2021.05.11 16:35:12.090 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 45 81 02 1ACE1F 6869B6 00
2021.05.11 16:35:12.098 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5398B62E d:FF r:FFD9     m:45 8102 1ACE1F 6869B6 00
2021.05.11 16:35:12.116 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 55 A0 01 1ACE1F 6869B6 0103
2021.05.11 16:35:12.124 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5398B648 d:FF r:FFD9     m:55 A001 1ACE1F 6869B6 0103
2021.05.11 16:35:12.140 4: CUL_Parse: cul868 A 0E 55 A010 6869B6 1ACE1F 01000000002A -53
2021.05.11 16:35:12.270 0: HMUARTLGW hmuart1 recv: 01 05 00 00 30 msg: 55 A0 10 6869B6 1ACE1F 0100000000
2021.05.11 16:35:12.273 0: HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:5398B662 d:FF r:FFD8     m:55 A010 6869B6 1ACE1F 0100000000
2021.05.11 16:35:12.277 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 55 80 02 1ACE1F 6869B6 00
2021.05.11 16:35:12.282 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5398B6E4 d:FF r:FFD9     m:55 8002 1ACE1F 6869B6 00
############## A270, hmuart
2021.05.11 17:26:18.364 3 : CUL_HM set Wetter.Sued getConfig noArg
2021.05.11 17:26:18.389 0 : HMUARTLGW hmuart1 send: 01 066869B6000100
2021.05.11 17:26:18.420 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 4D msg: BC 86 70 206278 000000 80B938
2021.05.11 17:26:18.423 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.11 17:26:18.424 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.11 17:26:18.425 0 : HMUARTLGW hmuart1 added peer: 6869B6, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 17:26:18.428 0 : HMUARTLGW hmuart1 send: 01 066869B6000100
2021.05.11 17:26:18.431 0 : HMLAN_Parse: hmlan1 R:E206278   stat:0000 t:53C780BC d:FF r:FFBA     m:BC 8670 206278 000000 80B938
2021.05.11 17:26:18.436 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.11 17:26:18.437 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.11 17:26:18.438 0 : HMUARTLGW hmuart1 added peer: 6869B6, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 17:27:33.208 4 : CUL_Parse: cul868 A 14 56 A270 6869B6 1ACE1F 80C2402ACB0001577008FC1E -59
2021.05.11 17:27:33.344 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 57 A0 01 1ACE1F 6869B6 00040000000000
2021.05.11 17:27:33.347 4 : CUL_Parse: cul868 A 0A 56 8102 1ACE1F 6869B6 0067 -22.5
2021.05.11 17:27:33.351 0 : HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:53C8A5E3 d:FF r:FFD8     m:56 A270 6869B6 1ACE1F 80C2402ACB0001577008FC
2021.05.11 17:27:33.354 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53C8A657 d:FF r:FFCF     m:56 8102 1ACE1F 6869B6 00
2021.05.11 17:27:33.357 0 : HMUARTLGW hmuart1 recv: 01 05 11 00 2F msg: 56 A2 70 6869B6 1ACE1F 80C2402ACB0001577008FC
2021.05.11 17:27:33.468 4 : CUL_Parse: cul868 A 10 57 A001 1ACE1F 6869B6 0004000000000067 -22.5
2021.05.11 17:27:33.478 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53C8A6E7 d:FF r:FFD0     m:57 A001 1ACE1F 6869B6 00040000000000
2021.05.11 17:27:33.505 4 : CUL_Parse: cul868 A 1A 57 A010 6869B6 1ACE1F 02010005240A1A0BCE0C1F1218140324001E -59
2021.05.11 17:27:33.511 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 17:27:33.512 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 17:27:33.513 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 2F msg: 57 A0 10 6869B6 1ACE1F 02010005240A1A0BCE0C1F121814032400
2021.05.11 17:27:33.517 0 : HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:53C8A70B d:FF r:FFD9     m:57 A010 6869B6 1ACE1F 02010005240A1A0BCE0C1F121814032400
2021.05.11 17:27:33.615 4 : CUL_Parse: cul868 A 0A 57 8002 1ACE1F 6869B6 0067 -22.5
2021.05.11 17:27:33.625 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53C8A77A d:FF r:FFCF     m:57 8002 1ACE1F 6869B6 00
2021.05.11 17:27:33.642 4 : CUL_Parse: cul868 A 0E 58 A010 6869B6 1ACE1F 02254E00001E -59
2021.05.11 17:27:33.653 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 2F msg: 58 A0 10 6869B6 1ACE1F 02254E0000
2021.05.11 17:27:33.744 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 68 A0 01 1ACE1F 6869B6 0103
2021.05.11 17:27:33.750 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 17:27:33.751 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 17:27:33.762 4 : CUL_Parse: cul868 A 0A 58 8002 1ACE1F 6869B6 0067 -22.5
2021.05.11 17:27:33.773 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53C8A80E d:FF r:FFCF     m:58 8002 1ACE1F 6869B6 00
2021.05.11 17:27:33.951 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 68 A0 01 1ACE1F 6869B6 0103
2021.05.11 17:27:33.978 4 : CUL_Parse: cul868 A 0B 68 A001 1ACE1F 6869B6 010367 -22.5
2021.05.11 17:27:33.988 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53C8A8E5 d:FF r:FFD0     m:68 A001 1ACE1F 6869B6 0103
2021.05.11 17:27:34.345 4 : CUL_Parse: cul868 A 0B 68 A001 1ACE1F 6869B6 010367 -22.5
2021.05.11 17:27:34.355 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53C8AA54 d:FF r:FFCF     m:68 A001 1ACE1F 6869B6 0103
2021.05.11 17:27:34.645 4 : CUL_Parse: cul868 A 0B 68 A001 1ACE1F 6869B6 010367 -22.5
2021.05.11 17:27:34.655 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53C8AB80 d:FF r:FFCF     m:68 A001 1ACE1F 6869B6 0103
2021.05.11 17:27:34.897 0 : HMUARTLGW hmuart1 recv: 01 0404, state 100
2021.05.11 17:27:34.898 0 : HMUARTLGW hmuart1 can't send due to unknown problem (no response?)
2021.05.11 17:30:04.686 4 : CUL_Parse: cul868 A 14 57 A270 6869B6 1ACE1F 80C2402ACB00017CEC08FC1C -60
2021.05.11 17:30:04.741 0 : HMUARTLGW hmuart1 recv: 01 05 11 00 2E msg: 57 A2 70 6869B6 1ACE1F 80C2402ACB00017CEC08FC
2021.05.11 17:30:04.744 0 : HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:53CAF5AD d:FF r:FFD8     m:57 A270 6869B6 1ACE1F 80C2402ACB00017CEC08FC
2021.05.11 17:30:04.788 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 58 A0 01 1ACE1F 6869B6 0103
2021.05.11 17:30:04.794 0 : HMUARTLGW hmuart1 recv: 01 0408, state 100
2021.05.11 17:30:04.796 0 : HMUARTLGW hmuart1 IO currently busy, trying again in a bit
2021.05.11 17:30:04.801 4 : CUL_Parse: cul868 A 0A 57 8102 1ACE1F 6869B6 0067 -22.5
2021.05.11 17:30:04.812 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53CAF621 d:FF r:FFCF     m:57 8102 1ACE1F 6869B6 00
2021.05.11 17:30:04.848 0 : HMUARTLGW hmuart1 send: 01 02 00 00 00 msg: 58 A0 01 1ACE1F 6869B6 0103
2021.05.11 17:30:04.941 4 : CUL_Parse: cul868 A 0B 58 A001 1ACE1F 6869B6 010367 -22.5
2021.05.11 17:30:04.951 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53CAF6AC d:FF r:FFCF     m:58 A001 1ACE1F 6869B6 0103
2021.05.11 17:30:04.967 4 : CUL_Parse: cul868 A 0E 58 A010 6869B6 1ACE1F 01000000001C -60
2021.05.11 17:30:04.998 0 : HMUARTLGW hmuart1 recv: 01 0402, state 100
2021.05.11 17:30:05.000 0 : HMUARTLGW hmuart1 Ack: 02
2021.05.11 17:30:05.001 0 : HMUARTLGW hmuart1 send: 01 066869B6000000
2021.05.11 17:30:05.004 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 2E msg: 58 A0 10 6869B6 1ACE1F 0100000000
2021.05.11 17:30:05.007 0 : HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:53CAF6C6 d:FF r:FFD8     m:58 A010 6869B6 1ACE1F 0100000000
2021.05.11 17:30:05.026 0 : HMUARTLGW hmuart1 recv: 01 0408, state 90
2021.05.11 17:30:05.027 0 : HMUARTLGW hmuart1 GetSet Ack: 08, state 90
2021.05.11 17:30:05.087 4 : CUL_Parse: cul868 A 0A 58 8002 1ACE1F 6869B6 0067 -22.5
2021.05.11 17:30:05.098 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:53CAF73F d:FF r:FFCF     m:58 8002 1ACE1F 6869B6 00
2021.05.11 17:30:05.530 0 : HMUARTLGW hmuart1 send: 01 066869B6000000
2021.05.11 17:30:05.537 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 90
2021.05.11 17:30:05.538 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 90
2021.05.11 17:30:05.539 0 : HMUARTLGW hmuart1 added peer: 6869B6, aesChannels: FFFFFFFFFFFFFFFF
2021.05.11 17:30:05.542 0 : HMUARTLGW hmuart1 send: 01 066869B6000000
2021.05.11 17:30:05.548 0 : HMUARTLGW hmuart1 recv: 01 040701010008FFFFFFFFFFFFFFFF, state 93
2021.05.11 17:30:05.549 0 : HMUARTLGW hmuart1 GetSet Ack: 07, state 93
2021.05.11 17:30:05.550 0 : HMUARTLGW hmuart1 added peer: 6869B6, aesChannels: FFFFFFFFFFFFFFFF
   .lastTimebatVoltage 1620737563.23467
   .lastTimebattery 1620676217.68229
   .triggerUsed 1
   DEF        6869B6
   FUUID      5c4ce2eb-f33f-09c4-4dec-70db0da4a026d89f
   IODev      cul868
   LASTInputDev hmlan1
   MSGCNT     1273
   NAME       Wetter.Sued
   NOTIFYDEV  global
   NR         425
   NTFY_ORDER 50-Wetter.Sued
   STATE      T: 19.4 H: 63 L: 828 P: 1095.5
   TYPE       CUL_HM
   chanNo     01
   cul868_MSGCNT 450
   cul868_RAWMSG A144FA2706869B61ACE1F80C23F2ACB0001437108FC::-60:cul868
   cul868_RSSI -60
   cul868_TIME 2021-05-11 17:07:13
   hmlan1_MSGCNT 376
   hmlan1_RAWMSG E6869B6,0000,53B609A0,FF,FFD8,4FA2706869B61ACE1F80C23F2ACB0001437108FC
   hmlan1_RSSI -40
   hmlan1_TIME 2021-05-11 17:07:13
   hmuart1_MSGCNT 447
   hmuart1_RAWMSG 0500002F4FA2706869B61ACE1F80C23F2ACB0001437108FC
   hmuart1_RSSI -47
   hmuart1_TIME 2021-05-11 17:07:13
   lastMsg    No:4F - t:70 s:6869B6 d:1ACE1F 80C23F2ACB0001437108FC
   protCmdDel 1
   protLastRcv 2021-05-11 17:07:13
   protRcv    162 last_at:2021-05-11 17:07:13
   protResnd  7 last_at:2021-05-11 15:31:49
   protResndFail 1 last_at:2021-05-11 14:23:05
   protSnd    174 last_at:2021-05-11 17:07:13
   protState  CMDs_done
   rssi_at_cul868 cnt:450 min:-62.5 max:-52 avg:-54.63 lst:-60
   rssi_at_hmlan1 cnt:376 min:-44 max:-39 avg:-40.83 lst:-40
   rssi_at_hmuart1 cnt:447 min:-50 max:-45 avg:-47.19 lst:-47
   .attraggr:
   .attreocr:
   .attrminint:
     batVoltage:86400
     battery:86400
   .attrtocr:
   .userReadings:
     HASH(0x477da40)
     HASH(0x477a1c0)
   CL:
     Authenticated 0
     BUF
     FD         92
     FW_ID      18124
     LASTACCESS 1620745731
     NAME       WEB_192.168.1.31_52010
     NR         18128
     PEER       192.168.1.31
     PORT       52010
     SNAME      WEB
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-11 17:08:46   state           Connected
     from archivexx        .D-devInfo      030100
     from archivexx        .D-stc          70
     2021-05-11 16:35:12   .associatedWith Wetter.Sued,Wetter.Sued
     2021-05-11 16:35:12   .peerListRDate  2021-05-11 16:35:12
     2021-05-11 17:07:13   .protLastRcv    20210511170713
     2021-03-23 13:08:49   Activity        alive
     2021-05-03 13:06:48   CommandAccepted yes
     from archivexx        D-firmware      0.14
     from archivexx        D-serialNr      UWS3621504
     2021-05-10 21:49:54   IODev           cul868
     2021-03-23 14:43:53   PairedTo        0x1ACE1F
     2021-05-10 11:25:04   R-altitude      78 m
     2021-05-10 11:25:04   R-burstRx       off
     2021-05-10 11:25:04   R-ledMode       off
     2021-05-10 11:25:04   R-lowBatLimitTHPL 2.4 V
     2021-05-10 11:25:04   R-pairCentral   0x1ACE1F
     2021-05-10 11:25:04   R-transmDevTryMax 3
     2021-05-11 16:35:11   RegL_00.         00:00 01:00 05:24 0A:1A 0B:CE 0C:1F 12:18 14:03 24:00 25:4E
     2021-05-11 17:04:55   absFeuchte      10.5
     2021-05-10 21:50:19   batNotOkCtr     66
     2021-04-02 13:30:02   batNotOkFirstTime 2021-04-02 13:30:02
     2021-05-11 14:52:43   batVoltage      2.30
     2021-05-10 21:50:17   battery         low
     2021-05-11 16:36:12   cfgState        ok
     2021-05-11 16:35:12   commState       CMDs_done
     2021-05-11 17:04:55   dewpoint        12.2
     2021-05-11 17:04:55   humidity        63
     2021-05-11 17:04:55   humidityAbsolut 10.5
     2021-05-11 17:07:13   luminosity      828
     2021-05-11 17:04:55   measured-temp   19.4
     2021-04-08 19:19:41   powerOn         2021-04-08 19:19:41
     2021-05-11 16:42:57   pressure        1095.5
     2021-03-23 14:52:19   recentStateType info
     2021-05-11 17:07:13   state           T: 19.4 H: 63 L: 828 P: 1095.5
     2021-05-11 17:04:55   temperature     19.4
     -                     tmpl_0          THPL_00_default,
     2021-03-23 23:59:59   x_sd            0
   helper:
     HM_CMDNR   79
     cSnd       011ACE1F6869B600040000000000,011ACE1F6869B60103
     mId        F101
     peerFriend peerRecT
     peerIDsState complete
     peerOpt    p:THPLSensor
     regLst     0
     rxType     140
     supp_Pair_Rep 0
     tmplChg    0
     ack:
     cmds:
       TmplKey    :1620676212.25637:1620676212.34679
       TmplTs     1620676212.34679
       cmdKey     1:1:0::Wetter.Sued:F101:01:
       cmdLst:
         assignHmKey noArg
         burstXmit  noArg
         clear      [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
         deviceRename -newName-
         fwUpdate     ...
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         getSerial  noArg
         getVersion noArg
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   0  ... single [set|unset] [actor|remote|both]
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- -addr2:data2-...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         statusRequest noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         condition  slider,0,1,255
         peer
         peerOpt
         tplChan    THPL_00_default
         tplDel     0>THPL_00_default
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     io:
       flgs       0
       newChn     +6869B6,00,00,00
       nextSend   1620745634.15547
       rxt        2
       vccu       ccu
       p:
         6869B6
         00
         00
         00
       prefIO:
         cul868
     mRssi:
       mNo        4F
       io:
         cul868:
           -56
           -56
         hmlan1:
           -40
           -40
         hmuart1:
           -47
           -47
         hmusb1:
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       sleeping   1
       rspWait:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rpt:
       IO         cul868
       flg        A
       ts         1620745633.72655
       ack:
         HASH(0x47269d8)
         4F80021ACE1F6869B600
     rssi:
       at_cul868:
         avg        -54.6377777777778
         cnt        450
         lst        -60
         max        -52
         min        -62.5
       at_hmlan1:
         avg        -40.8377659574468
         cnt        376
         lst        -40
         max        -39
         min        -44
       at_hmuart1:
         avg        -47.1968680089485
         cnt        447
         lst        -47
         max        -45
         min        -50
     shadowReg:
     tmpl:
       0>THPL_00_default
   .mId       F101
   IODev      cul868
   IOgrp      ccu:cul868
   actCycle   000:10
   actStatus  alive
   autoReadReg 5_readMissing
   comment    batChange: 2020-09-11 20:34:12 (oldBat: low since 2020-08-14 04:14:43)
batChange: 2020-10-05 11:21:18 (oldBat: low since 2020-09-20 04:57:15)
batChange: 2020-11-27 14:17:02 (oldBat: low since 2020-11-07 08:10:57)
batChange: 2021-01-17 12:17:37 (oldBat: low since 2021-01-10 04:48:18)
reparatur: 2021-01-19 14:13:40 (configtaster defekt)
   event-min-interval batVoltage:86400,battery:86400
   event-on-change-reading .*
   expert     defReg,allReg,rawReg,templ
   firmware   0.15
   model      HB-UW-Sen-THPL-I
   peerIDs    00000000
   room       65_Flur.OG,70_Garten
   serialNr   UWS3621504
   subType    THPLSensor
   timestamp-on-change-reading .*
   userReadings measured-temp:temperature:.* {
return ReadingsVal($name,"temperature",0);
humidityAbsolut:(temperature|humidity):.* {
return AbsoluteFeuchte(ReadingsVal($name,"temperature",0),ReadingsVal($name,"humidity",0));
edit2:
hast du eigentlich einen trigger für hminfo configcheck entsorgt?
jetzt wirkt scheinbar nur noch der "nottrigger" nach vielleicht 60s.
FHEM: 6.0(SVN) => Pi3(buster)
SHOFHEM
Hallo Ansgar,
Hallo Frank,
ich verstehe im Moment nur das ich euch beiden eine riesige Arbeit mache. Sorry dafür!
Bin ich der einzige der einen Wassermelder betreibt und Probleme hat? Ist das Problem größerer Natur? Wenn ihr Zeit und Lust habt bitte ich um ein paar erklärende Worte.
Beste Grüße
Stefan
frank
dein sensor ist nichts wirklich besonderes, die "probleme" gibt es mit vielen sensoren.
mit "besserem" io und/oder fw, hättest du vielleicht nie etwas bemerkt.
