Begriff
Begonnen von Superposchi, 11 April 2021, 14:27:45
justme1968
Zitat von: KernSani am 13 April 2021, 18:43:32
Popcorn? :-D Sorry, konnte ich mir nicht verkneifen ;-)
das war bis jetzt der beste beitrag hier ;)
Superposchi
Hier das List des Lightstripes:
   .FhemMetaInternals 1
   DEF        16  IODev=Hue_Bridge
   FUUID      5fcd0e33-f33f-793a-c61b-1215639b2bab2534
   FVERSION   31_HUEDevice.pm:0.239120/2021-03-08
   ID         16
   INTERVAL
   IODev      Hue_Bridge
   NAME       wz_licht_fensterbrettbeleuchtung
   NR         120
   STATE      off
   TYPE       HUEDevice
   desired    0
   manufacturername _TZ3000_riwp3k79
   modelid    TS0505A
   name       Fensterlicht
   swversion
   type       Extended color light
   uniqueid   58:8e:81:ff:fe:e2:dd:20-01
   .attraggr:
   .attrminint:
     2021-04-12 23:23:17   alert           none
     2021-04-12 23:23:17   bri             254
     2021-04-13 20:15:01   colormode       xy
     2021-04-12 23:23:17   ct              162 (6172K)
     2021-04-12 23:23:17   effect          none
     2021-04-13 09:41:08   hue             5094
     2021-04-13 23:51:39   onoff           0
     2021-04-13 23:51:39   pct             0
     2021-04-14 07:25:19   reachable       1
     2021-04-13 22:00:01   rgb             2b56fb
     2021-04-13 09:43:17   sat             254
     2021-04-13 23:51:39   state           off
     2021-04-13 22:00:01   xy              0.1671,0.1873
   helper:
     alert      none
     battery    -1
     bri        254
     colormode  xy
     ct         162
     devtype
     effect     none
     hue        5094
     lastseen
     mode
     on         0
     pct        0
     reachable  1
     rgb        2b56fb
     sat        254
     update_timeout 1
     xy         0.1671,0.1873
     helper:
     json:
       modelid    TS0505A
       name       Fensterlicht
       productname Extended color light
       swversion
       capabilities:
         control:
           colorgamuttype other
           ct:
             max        65535
             min        0
         streaming:
       config:
         archetype  huelightstrip
         direction  omnidirectional
         function   mixed
       state:
         alert      none
         bri        254
         colormode  xy
         ct         162
         effect     none
         hue        5094
         mode       homeautomation
         sat        254
         xy:
           0.1671
           0.1873
       swupdate:
         lastinstall
         state      notupdatable
   IODev      Hue_Bridge
   alias      Fensterbrettbeleuchtung
   color-icons 2
   devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
   group      Lampen
   icon       hue_filled_lightstrip
   model      TS0505A
   room       HUEDevice,Wohnung->Wohnzimmer
   subType    extcolordimmer
   verbose    4
   webCmd     rgb:rgb ff0000:rgb DEFF26:rgb 0000ff:ct 490:ct 380:ct 270:ct 160:toggle:on:off
Aber eigentlich ist der Tread doch erledigt, das was im Moment hier besprochen wird hat ja mit der ursprünglichen Frage nichts mehr zu tun, oder?
Ich meine ist schon interessant warum es angezeigt wird wenn es nicht geht, aber die eigentliche Frage war ja was die Werte Bedeuten und welche Auswirkungen sie haben bzw. wie sie in Abhängigkeit zueinander stehen.
Das ist ja eigentlich beantwortet.
justme1968
welches kommando genau geht nicht?
Superposchi
set wz_licht_fensterbrettbeleuchtung sat xxx und set wz_licht_fensterbrettbeleuchtung hue xxx haben keine Auswirkungen.
rabehd
Ich zwar nicht Deine Hardware, trotzdem habe ich es mal probiert.
sat = Farbsättigug ändert sich
hue = wenn off, dann on mit letzter Einstellung; wenn on, dann keine Reaktion
Stört mich aber nicht, ich nutze rgb.
