Autor Thema: [gelöst] HANK HKZW-DWS01  (Gelesen 417 mal)
Offline tomspatz
  • Sr. Member
« am: 22 April 2021, 07:52:11 »
Moin
Hat schon jemand solch einen Sensor dran?
   CFGFN
   DEF        d0415cea 5
   FUUID      608088da-f33f-752b-ea8b-34dc23d600e27cad
   IODev      ZWDongle_0
   LASTInputDev ZWDongle_0
   MSGCNT     107
   NAME       BalkontuerWZ_5
   NR         601
   STATE      wakeupInterval 86400 1
   TYPE       ZWave
   ZWDongle_0_MSGCNT 107
   ZWDongle_0_RAWMSG 0004000503800336d000
   ZWDongle_0_TIME 2021-04-22 07:40:31
   ZWaveSubDevice no
   cmdsPending 0
   homeId     d0415cea
   isWakeUp   1
   lastMsgSent 1619036960.30595
   nodeIdHex  05
     2021-04-21 22:29:18   CMD             ZW_APPLICATION_UPDATE
     2021-04-22 07:40:31   alarm           AccessControl: Window/Door is open, arg 000
     2021-04-21 22:23:51   assocGroup_1    Max 5 Nodes ZWDongle_0
     2021-04-21 22:23:51   assocGroup_2    Max 5 Nodes
     2021-04-21 22:23:50   assocGroups     2
     2021-04-22 07:40:31   battery         54 %
     2021-04-22 07:40:31   batteryPercent  54
     2021-04-22 07:40:31   batteryState    ok
     2021-04-21 22:29:18   configBASICSETCommand Enabled
     2021-04-21 22:29:18   configLevelOfLowBattery 20
     2021-04-21 22:29:18   configValueOfTheBASICSET 255
     2021-04-21 22:23:51   model           HANK Electronics Ltd HKZW-DWS01 Door/Window Sensor
     2021-04-21 22:23:51   modelConfig     hank/hkzw-dws01.xml
     2021-04-21 22:23:51   modelId         0208-0200-0008
     2021-04-21 22:19:38   state           wakeupInterval 86400 1
     2021-04-21 22:29:20   timeToAck       0.031
     2021-04-21 22:29:20   transmit        OK
     2021-04-21 22:19:41   zwavePlusInfo    version:01 role:SleepingReportingSlave node:Z-Wave+Node installerIcon:0c00 userIcon:0c00
   IODev      ZWDongle_0
   alias      Balkontür WZ
   classes    ZWAVEPLUS_INFO VERSION MANUFACTURER_SPECIFIC ALARM ASSOCIATION_GRP_INFO ASSOCIATION BATTERY WAKE_UP POWERLEVEL CONFIGURATION FIRMWARE_UPDATE_MD DEVICE_RESET_LOCALLY
   devStateIcon open:fts_door_open@red .*:fts_door
   icon       fts_door
   room       Wohnzimmer
   vclasses   ALARM:5 ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 BATTERY:1 CONFIGURATION:1 DEVICE_RESET_LOCALLY:1 FIRMWARE_UPDATE_MD:2 MANUFACTURER_SPECIFIC:2 POWERLEVEL:1 VERSION:2 WAKE_UP:2 ZWAVEPLUS_INFO:2
Der schickt scheinbar in die assocGroup_1 nur so "komische Sachen:
2021-04-21 22:31:50 ZWave BalkontuerWZ_5 alarm: AccessControl: Window/Door is open, arg 000
2021-04-21 22:31:54 ZWave BalkontuerWZ_5 alarm: AccessControl: Window/Door is closed, arg 000
Halt nicht direkt open/ closed zum state, wie stellt man das den an?
« Letzte Änderung: 25 April 2021, 14:19:51 von tomspatz »
Offline krikan
Antw:HANK HKZW-DWS01
« Antwort #1 am: 22 April 2021, 19:05:21 »
Das ist bei den "aktuellen" Sensoren normal; sie nutzen die ALARM-Class zur Meldung statt wie früher üblich SENSOR_BINARY.
Lösungsansätze zum Anpassen:
stateFormat-Ansatz: https://wiki.fhem.de/wiki/Z-Wave-PHI_PST02-1A-T%C3%BCr-,_Bewegungs-,_Helligkeits-,_Temperatursensor#STATE_mit_open.2Fclosed_anzeigen
userReadings-Ansatz: https://forum.fhem.de/index.php/topic,74294.msg660361.html#msg660361
Gruß, Christian
Offline tomspatz
  • Sr. Member
« Antwort #2 am: 25 April 2021, 14:19:41 »
vielen dank
attr BalkontuerWZ_5 stateFormat {(split(/,|is /, ReadingsVal($name,"alarm_AccessControl","")))[1]}
« Letzte Änderung: 06 Juli 2021, 15:45:14 von tomspatz »
decade-submarginal
