Autor Thema: [gelöst] warnings bei "set select" in 98_HMtemplate.pm  (Gelesen 786 mal)
Offline frank
hallo martin,
hmtemplate wirft immer warnings bei "set select". zb bei deinem template autoOff:
2021.05.07 09:57:24.201 1 : PERL WARNING: Use of uninitialized value in string eq at ./FHEM/98_HMtemplate.pm line 395.
2021.05.07 09:57:24.203 1 : stacktrace:
2021.05.07 09:57:24.203 1 :     main::__ANON__                      called by ./FHEM/98_HMtemplate.pm (395)
2021.05.07 09:57:24.204 1 :     main::HMtemplate_SetFn              called by fhem.pl (3842)
2021.05.07 09:57:24.204 1 :     main::CallFn                        called by fhem.pl (1937)
2021.05.07 09:57:24.205 1 :     main::DoSet                         called by fhem.pl (1969)
2021.05.07 09:57:24.205 1 :     main::CommandSet                    called by fhem.pl (1265)
2021.05.07 09:57:24.205 1 :     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2762)
2021.05.07 09:57:24.206 1 :     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1005)
2021.05.07 09:57:24.206 1 :     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (597)
2021.05.07 09:57:24.207 1 :     main::FW_Read                       called by fhem.pl (3847)
2021.05.07 09:57:24.207 1 :     main::CallFn                        called by fhem.pl (773)
2021.05.07 09:57:24.226 1 : PERL WARNING: Use of uninitialized value $_ in pattern match (m//) at ./FHEM/98_HMtemplate.pm line 629.
2021.05.07 09:57:24.226 1 : stacktrace:
2021.05.07 09:57:24.227 1 :     main::__ANON__                      called by ./FHEM/98_HMtemplate.pm (629)
2021.05.07 09:57:24.227 1 :     main::HMtemplate_sourceList         called by ./FHEM/98_HMtemplate.pm (399)
2021.05.07 09:57:24.228 1 :     main::HMtemplate_SetFn              called by fhem.pl (3842)
2021.05.07 09:57:24.228 1 :     main::CallFn                        called by fhem.pl (1937)
2021.05.07 09:57:24.228 1 :     main::DoSet                         called by fhem.pl (1969)
2021.05.07 09:57:24.229 1 :     main::CommandSet                    called by fhem.pl (1265)
2021.05.07 09:57:24.229 1 :     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2762)
2021.05.07 09:57:24.230 1 :     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1005)
2021.05.07 09:57:24.230 1 :     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (597)
2021.05.07 09:57:24.230 1 :     main::FW_Read                       called by fhem.pl (3847)
2021.05.07 09:57:24.231 1 :     main::CallFn                        called by fhem.pl (773)
« Letzte Änderung: 11 Oktober 2021, 16:57:37 von frank »
FHEM: 6.0(SVN) => Pi3(buster)
Offline martinp876
  • Moderator
Antw:[hmtemplate] warnings bei "set select"
« Antwort #1 am: 18 Juli 2021, 19:07:45 »
wird in CUL_HM gelöst. Version wenn die renovierte Attributverwaltung scharf ist.
Offline frank
« Antwort #2 am: 20 Juli 2021, 16:06:37 »
mit dem neuen 98_HMtemplate sind die warnungen weg, prima.
jetzt habe ich noch ein problem mit 98_HMtemplate im edit modus.
ich kann den wert eines registers nicht ändern => "attr ht Reg_txThrFrq 0.01" erzeugt die meldung:
value 0.01 not numeric for txThrFrq
0.1 funktioniert. 2 stellen nach dem komma sind scheinbar verboten.
der range von txThrFrq ist nach regList 0.00-2.55, und unused.
über regSet kann ich auch 0.01 erfolgreich setzen.
txThrFrq aus channel2 vom device: mId         :00AC  Model=HM-ES-PMSW1-PL
template:
set hm templateDef ES01_normal 0 "brunnenpumpe" txThrVlt:unused averaging:1 txThrPwr:unused txMinDly:0 txThrCur:50 txThrFrq:unused
list ht:
   FUUID      5c4ce2ed-f33f-09c4-baf5-37c730e0b2bb7cd2
   NAME       ht
   NR         572
   NTFY_ORDER 50-ht
   STATE      edit
   TYPE       HMtemplate
   tpl_Info0  change attr Reg_ as desired
   tpl_Info1  change attr tpl_params ':' separated
   tpl_Info2  save    if finished
   tpl_Info3  saveAs  to create a copy
   tpl_Info4  dismiss will reset HMtemplate
   tpl_Name   ES01_normal
   tpl_Param
   tpl_type   basic
   .attraggr:
   .attreocr:
   .attrminint:
     2021-07-20 14:37:34   state           edit
   helper:
     attrList   tpl_params tpl_description event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading
     cSt        s1
   Reg_averaging 1
   Reg_txMinDly 0
   Reg_txThrCur 50
   Reg_txThrFrq unused
   Reg_txThrPwr unused
   Reg_txThrVlt unused
   event-on-change-reading .*
   room       04_Test
   tpl_description brunnenpumpe
   tpl_params
Offline martinp876
  • Moderator
« Antwort #3 am: 08 August 2021, 18:01:28 »
sorry for delay.
jetzt sollten auch mehr Nachkommastellen möglich sein.
Offline frank
Antw:[gelöst] warnings bei "set select" in 98_HMtemplate.pm
« Antwort #4 am: 11 Oktober 2021, 17:02:45 »
funktioniert.
