[cul_hm] probleme mit HM-CC-TC: cmds werden nicht mehr abgearbeitet
Begonnen von frank, 12 Mai 2021, 12:54:14
frank
moin ansgar,
plötzlich werden bei meinem hm-cc-tc keine cmds mehr abgearbeitet.
weder über wakeup, noch über configbutton.
Device name:Thermostat.OZ
   org ID    :0039  Model=HM-CC-TC
   alias ID :0039  Model=HM-CC-TC
   mode    :config,wakeup,burstCond - activity:alive
   protState : CMDs_pending pending: 6 CMDs_pending
   Thermostat.OZ_Weather state:T: 19.5 H: 64
   Thermostat.OZ_Climate state:- tmpl_0 TC_02_sensor,
   Thermostat.OZ_WindowRec state:last:trigLast
configuration check: updating
   .triggerUsed 1
   DEF        20DFE1
   FUUID      5c4ce2e8-f33f-09c4-04f3-beb05c80b7c6df87
   IODev      cul868
   LASTInputDev hmlan1
   MSGCNT     158
   NAME       Thermostat.OZ
   NOTIFYDEV  global
   NR         194
   NTFY_ORDER 50-Thermostat.OZ
   STATE      Tsoll:6.0°C, Tist:19.5°C, Hist:64%, Mode:central, Bat:ok, Ventil:actuator
   TYPE       CUL_HM
   channel_01 Thermostat.OZ_Weather
   channel_02 Thermostat.OZ_Climate
   channel_03 Thermostat.OZ_WindowRec
   cul868_MSGCNT 52
   cul868_RAWMSG A0C9E867020DFE100000000C340::-76.5:cul868
   cul868_RSSI -76.5
   cul868_TIME 2021-05-12 12:11:11
   hmlan1_MSGCNT 55
   hmlan1_RAWMSG E20DFE1,0000,57CD7C67,FF,FFCD,9E867020DFE100000000C340
   hmlan1_RSSI -51
   hmlan1_TIME 2021-05-12 12:11:12
   hmuart1_MSGCNT 51
   hmuart1_RAWMSG 0500003E9E867020DFE100000000C340
   hmuart1_RSSI -62
   hmuart1_TIME 2021-05-12 12:11:12
   lastMsg    No:9E - t:70 s:20DFE1 d:000000 00C340
   protCmdPend 6 CMDs_pending
   protLastRcv 2021-05-12 12:11:11
   protRcv    54 last_at:2021-05-12 12:11:11
   protResnd  2 last_at:2021-05-12 11:52:51
   protSnd    16 last_at:2021-05-12 12:08:40
   protState  CMDs_pending
   rssi_at_cul868 cnt:52 min:-80.5 max:-59.5 avg:-66.31 lst:-76.5
   rssi_at_hmlan1 cnt:55 min:-57 max:-50 avg:-52.58 lst:-51
   rssi_at_hmuart1 cnt:51 min:-65 max:-59 avg:-59.68 lst:-62
   rssi_cul868 cnt:2 min:-78 max:-73 avg:-75.5 lst:-78
   rssi_hmlan1 cnt:1 min:-58 max:-58 avg:-58 lst:-58
   .attraggr:
   .attreocr:
   .attreour:
     time-request
   .attrminint:
   .attrtocr:
   .userReadings:
     HASH(0x3d91400)
   CL:
     Authenticated 0
     BUF
     FD         77
     FW_ID      33941
     LASTACCESS 1620814320
     NAME       WEB_192.168.1.31_50312
     NR         1257
     PEER       192.168.1.31
     PORT       50312
     SNAME      WEB
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-12 12:11:58   state           Connected
     2021-05-12 12:09:22   .D-devInfo      00FFFF
     2021-05-12 12:09:22   .D-stc          58
     2021-05-12 11:17:34   .associatedWith Thermostat.OZ,Thermostat.OZ_Climate,Thermostat.OZ_Weather,Thermostat.OZ_WindowRec,Thermostat.OZ
     2021-05-12 12:11:11   .protLastRcv    20210512121111
     2021-03-23 13:08:49   Activity        alive
     2021-03-23 13:08:10   CommandAccepted yes
     from archivexx        D-firmware      2.1
     from archivexx        D-serialNr      KEQ0176062
     2021-05-12 11:17:32   IODev           hmlan1
     2021-03-23 13:10:47   PairedTo        0x1ACE1F
     2021-05-12 11:17:41   R-backlOnMode   off
     2021-05-12 11:17:41   R-backlOnTime   0
     2021-05-12 11:17:41   R-btnLock       off
     2021-05-12 11:17:41   R-burstRx       off
     2021-05-12 11:17:41   R-pairCentral   0x1ACE1F
     2021-03-23 13:08:11   battery         ok
     2021-05-12 12:10:10   cfgState        updating
     2021-05-12 12:10:10   commState       CMDs_pending
     2021-04-08 19:02:50   controlMode     central
     2021-04-08 19:44:35   day-temp        21 C
     2021-04-08 19:02:50   decalcDay       Sat
     2021-03-23 13:08:11   desired-temp    6.0
     2021-04-08 19:02:50   displayMode     temp-hum
     2021-04-08 19:02:50   displayTemp     actual
     2021-04-08 19:02:50   displayTempUnit celsius
     2021-05-12 12:11:11   humidity        64
     2021-05-12 12:11:11   humidityAbsolut 10.7
     2021-05-12 12:11:12   humidityAbsolutTrend ↗→
     2021-05-12 12:11:11   measured-temp   19.5
     2021-04-08 19:44:35   night-temp      17 C
     2021-04-08 19:44:35   party-temp      20 C
     2021-05-12 12:11:11   state           T: 19.5 H: 64
     2021-05-12 00:02:26   time-request    -
     -                     tmpl_0          tc1:a:off b:0 c:off d:off,
   cmdStack:
     ++A0011ACE1F20DFE100040000000000
     ##A0011ACE1F20DFE10103
     ##A0011ACE1F20DFE10203
     ##A0011ACE1F20DFE102040000000005
     ##A0011ACE1F20DFE102040000000006
     ##A0011ACE1F20DFE10303
   helper:
     HM_CMDNR   158
     cSnd       011ACE1F20DFE1020E,011ACE1F20DFE1020E
     mId        0039
     peerFriend -
     peerOpt    -:thermostat
     regLst     0
     rxType     140
     supp_Pair_Rep 0
     tmplChg    0
     ack:
     cmds:
       TmplKey    :1620811060.62932:1620811061.84441
       TmplTs     1620811061.84441
       cmdKey     0:1:0::Thermostat.OZ:0039:00:
       cmdLst:
         assignHmKey noArg
         burstXmit  noArg
         clear      [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
         desired-temp (on|off|6.0..30.0;0.5)
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- -addr2:data2-...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sysTime    noArg
         tplDel     -tplDel-
         unpair     noArg
       lst:
         condition  slider,0,1,255
         peer
         peerOpt
         tplChan    TC_00_sensor,tc1
         tplDel     0>tc1
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     io:
       flgs       0
       newChn     +20DFE1,00,00,00
       nextSend   1620814272.16503
       rxt        2
       supWu      1
       vccu       ccu
       p:
         20DFE1
         00
         00
         00
       prefIO:
         cul868
     mRssi:
       mNo        9E
       io:
         cul868:
           -74.5
           -74.5
         hmlan1:
           -51
           -51
         hmuart1:
           -62
           -62
         hmusb1:
     peerIDsH:
     prt:
       bErr       0
       sProc      2
       sleeping   0
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       dev        1
     rssi:
       at_cul868:
         avg        -66.3173076923077
         cnt        52
         lst        -76.5
         max        -59.5
         min        -80.5
       at_hmlan1:
         avg        -52.5818181818182
         cnt        55
         lst        -51
         max        -50
         min        -57
       at_hmuart1:
         avg        -59.6862745098039
         cnt        51
         lst        -62
         max        -59
         min        -65
       cul868:
         avg        -75.5
         cnt        2
         lst        -78
         max        -73
         min        -78
       hmlan1:
         avg        -58
         cnt        1
         lst        -58
         max        -58
         min        -58
     shadowReg:
     tmpl:
       0>tc1      off 0 off off
   .mId       0039
   IODev      cul868
   IOgrp      ccu:cul868
   actCycle   000:10
   actStatus  alive
   alias      10. Thermostat
   autoReadReg 5_readMissing
   event-on-change-reading .*
   event-on-update-reading time-request
   expert     defReg,allReg,rawReg,templ
   firmware   2.1
   group      Heizung.OZ
   model      HM-CC-TC
   room       00_heating_test,15_OZ
   serialNr   KEQ0176062
   sortby     50
   stateFormat Tsoll:desired-temp°C, Tist:measured-temp°C, Hist:humidity%, Mode:controlMode, Bat:battery, Ventil:actuator
   subType    thermostat
   timestamp-on-change-reading .*
   userReadings humidityAbsolut:(measured-temp|humidity).* {AbsoluteFeuchte(ReadingsVal($name,"measured-temp",0),ReadingsVal($name,"humidity",0))}
   webCmd     getConfig:statusRequest
edit:
gerade noch mal über configbutton probiert und alle cmds wurden erfolgreich bearbeitet.
voodoo?
aktuelles list:
   .triggerUsed 1
   DEF        20DFE1
   IODev      cul868
   LASTInputDev hmuart1
   MSGCNT     329
   NAME       Thermostat.OZ
   NOTIFYDEV  global
   NR         194
   STATE      Tsoll:6.0°C, Tist:20.2°C, Hist:63%, Mode:central, Bat:ok, Ventil:actuator
   TYPE       CUL_HM
   cul868_MSGCNT 109
   cul868_RAWMSG A0CB8867020DFE100000000CA3F::-71:cul868
   cul868_RSSI -71
   cul868_TIME 2021-05-12 13:16:48
   hmlan1_MSGCNT 112
   hmlan1_RAWMSG E20DFE1,0000,58098EF6,FF,FFCF,B8867020DFE100000000CA3F
   hmlan1_RSSI -49
   hmlan1_TIME 2021-05-12 13:16:48
   hmuart1_MSGCNT 108
   hmuart1_RAWMSG 0500003EB8867020DFE100000000CA3F
   hmuart1_RSSI -62
   hmuart1_TIME 2021-05-12 13:16:48
   lastMsg    No:B8 - t:70 s:20DFE1 d:000000 00CA3F
   protLastRcv 2021-05-12 13:16:48
   protRcv    111 last_at:2021-05-12 13:16:48
   protSnd    46 last_at:2021-05-12 13:13:13
   protState  CMDs_done
   rssi_at_cul868 cnt:109 min:-84 max:-59.5 avg:-67.69 lst:-71
   rssi_at_hmlan1 cnt:112 min:-61 max:-47 avg:-51.97 lst:-49
   rssi_at_hmuart1 cnt:108 min:-77 max:-56 avg:-61.14 lst:-62
   .attraggr:
   .attreocr:
   .attreour:
     time-request
   .attrminint:
   .attrtocr:
   .userReadings:
     HASH(0x3d91400)
   CL:
     Authenticated 0
     BUF
     FD         77
     FW_ID      33941
     LASTACCESS 1620818325
     NAME       WEB_192.168.1.31_50646
     NR         2269
     PEER       192.168.1.31
     PORT       50646
     SNAME      WEB
     SSL
     STATE      Connected
     TEMPORARY  1
     TYPE       FHEMWEB
     canAsyncOutput 1
     .attraggr:
     .attrminint:
       2021-05-12 13:17:52   state           Connected
     2021-05-12 13:13:05   .D-devInfo      00FFFF
     2021-05-12 13:13:05   .D-stc          58
     2021-05-12 13:16:48   .protLastRcv    20210512131648
     2021-05-12 13:13:05   RegL_00.         00:00 01:00 02:01 05:00 0A:1A 0B:CE 0C:1F 0F:00
     2021-05-12 13:14:13   cfgState        ok
     2021-05-12 13:13:13   commState       CMDs_done
     2021-05-12 12:25:34   humidity        63
     2021-05-12 13:16:48   humidityAbsolut 11.0
     2021-05-12 13:16:48   humidityAbsolutTrend ↘↑
     2021-05-12 13:16:48   measured-temp   20.2
     2021-05-12 13:16:48   state           T: 20.2 H: 63
   helper:
     HM_CMDNR   184
     cSnd       011ACE1F20DFE102040000000006,011ACE1F20DFE10303
     mId        0039
     peerFriend -
     regLst     0
     rxType     140
     supp_Pair_Rep 0
     tmplChg    0
     ack:
     cmds:
       cmdLst:
         assignHmKey noArg
         burstXmit  noArg
         getConfig  noArg
         getDevInfo noArg
         raw        -data- [...]
         reset      noArg
         sysTime    noArg
         tplDel     -tplDel-
         unpair     noArg
       lst:
         peer
         peerOpt
         tplDel     0>tc1
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        1
       tpl        1
     io:
       flgs       0
       nextSend   1620818208.5591
       rxt        2
       vccu       ccu
       p:
         20DFE1
         00
         00
         00
       prefIO:
         cul868
     mRssi:
       mNo        B8
       io:
         cul868:
           -69
           -69
         hmlan1:
           -49
           -49
         hmuart1:
           -62
           -62
         hmusb1:
     peerIDsH:
     prt:
       bErr       0
       sProc      0
       sleeping   1
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       dev        1
     rssi:
       at_cul868:
         avg        -67.697247706422
         cnt        109
         lst        -71
         max        -59.5
         min        -84
       at_hmlan1:
         avg        -51.9732142857143
         cnt        112
         lst        -49
         max        -47
         min        -61
       at_hmuart1:
         avg        -61.1481481481481
         cnt        108
         lst        -62
         max        -56
         min        -77
       cul868:
         avg        -75.5
         cnt        2
         lst        -78
         max        -73
         min        -78
       hmlan1:
         avg        -58
         cnt        1
         lst        -58
         max        -58
         min        -58
     shadowReg:
     tmpl:
       0>tc1      off 0 off off
   .mId       0039
   IODev      cul868
   IOgrp      ccu:cul868
   actCycle   000:10
   actStatus  alive
   firmware   2.1
   group      Heizung.OZ
   model      HM-CC-TC
   serialNr   KEQ0176062
   sortby     50
   subType    thermostat
FHEM: 6.0(SVN) => Pi3(buster)
frank
eventuell entsteht das problem beim wechsel des IODev von hmlan auf cul.
hier mal ein sniff:
1. getconfig erfolgreich mit hmlan über wakeup ausgelöst.
2. IOgrp auf cul umgestellt und 2 statusrequest ausgeführt, damit die io richtig präpariert sind
3. getconfig ausgelöst, probleme beginnen
zunächst 2 versuche über configbutton erfolglos, dann 25 wakeups ohne reaktion.
4. nach ca 1 std plötzliches abarbeiten der pending cmds durch configbutton.
########################## 1. getconfig mit hmlan
2021.05.12 12:03:17.777 3: CUL_HM set Thermostat.OZ getConfig noArg
2021.05.12 12:03:17.891 0: HMLAN_Send:  hmlan1 I:+20DFE1,02,00,00
2021.05.12 12:05:54.155 4: CUL_Parse: cul868 A 0C 9C 8670 20DFE1 000000 00C13F13 -64.5
2021.05.12 12:05:54.257 0: HMLAN_Send:  hmlan1 S:S600A3DE9 stat:  00 t:00000000 d:01 r:600A3DE9 m:9D A001 1ACE1F 20DFE1 00040000000000
2021.05.12 12:05:54.374 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: 9C 86 70 20DFE1 000000 00C13F
2021.05.12 12:05:54.377 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: 9C A1 12 1ACE1F 20DFE1
2021.05.12 12:05:54.380 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8A2F8 d:FF r:FFCB     m:9C 8670 20DFE1 000000 00C13F
2021.05.12 12:05:54.383 4: CUL_Parse: cul868 A 09 9C A112 1ACE1F 20DFE1 41 -41.5
2021.05.12 12:05:54.404 4: CUL_Parse: cul868 A 0A 9C 8002 20DFE1 1ACE1F 0013 -64.5
2021.05.12 12:05:54.409 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: 9C 80 02 20DFE1 1ACE1F 00
2021.05.12 12:05:54.413 0: HMLAN_Parse: hmlan1 R:R6004810D stat:0081 t:57C8A3F6 d:FF r:FFCC     m:9C 8002 20DFE1 1ACE1F 00
2021.05.12 12:05:54.687 4: CUL_Parse: cul868 A 10 9D A001 1ACE1F 20DFE1 0004000000000041 -41.5
2021.05.12 12:05:54.699 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: 9D A0 01 1ACE1F 20DFE1 00040000000000
2021.05.12 12:05:54.822 4: CUL_Parse: cul868 A 1A 9D 8010 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F00000013 -64.5
2021.05.12 12:05:54.924 0: HMLAN_Send:  hmlan1 S:S600A4088 stat:  00 t:00000000 d:01 r:600A4088 m:AD A001 1ACE1F 20DFE1 0103
2021.05.12 12:05:54.932 0: HMLAN_Parse: hmlan1 R:R600A3DE9 stat:0001 t:57C8A597 d:FF r:FFCB     m:9D 8010 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F000000
2021.05.12 12:05:54.937 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: 9D 80 10 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F000000
2021.05.12 12:05:55.026 0: HMLAN_Send:  hmlan1 I:K
2021.05.12 12:05:55.030 0: HMLAN_Parse: hmlan1 V:03C5 sNo:JEQ0315335 d:1C671E O:1ACE1F t:57C8A664 IDcnt:0015 L:15 %
2021.05.12 12:05:55.098 4: CUL_Parse: cul868 A 0B AD A001 1ACE1F 20DFE1 010340 -42
2021.05.12 12:05:55.103 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: AD A0 01 1ACE1F 20DFE1 0103
2021.05.12 12:05:55.227 4: CUL_Parse: cul868 A 0E AD 8010 20DFE1 1ACE1F 010000000013 -64.5
2021.05.12 12:05:55.328 0: HMLAN_Send:  hmlan1 S:S600A421A stat:  00 t:00000000 d:01 r:600A421A m:BD A001 1ACE1F 20DFE1 0203
2021.05.12 12:05:55.334 0: HMLAN_Parse: hmlan1 R:R600A4088 stat:0001 t:57C8A72D d:FF r:FFCB     m:AD 8010 20DFE1 1ACE1F 0100000000
2021.05.12 12:05:55.338 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: AD 80 10 20DFE1 1ACE1F 0100000000
2021.05.12 12:05:55.503 4: CUL_Parse: cul868 A 0B BD A001 1ACE1F 20DFE1 020341 -41.5
2021.05.12 12:05:55.509 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: BD A0 01 1ACE1F 20DFE1 0203
2021.05.12 12:05:55.632 4: CUL_Parse: cul868 A 0E BD 8010 20DFE1 1ACE1F 010000000013 -64.5
2021.05.12 12:05:55.734 0: HMLAN_Send:  hmlan1 S:S600A43AE stat:  00 t:00000000 d:01 r:600A43AE m:CD A001 1ACE1F 20DFE1 02040000000005
2021.05.12 12:05:55.739 0: HMLAN_Parse: hmlan1 R:R600A421A stat:0001 t:57C8A8C3 d:FF r:FFCB     m:BD 8010 20DFE1 1ACE1F 0100000000
2021.05.12 12:05:55.744 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: BD 80 10 20DFE1 1ACE1F 0100000000
2021.05.12 12:05:55.913 4: CUL_Parse: cul868 A 10 CD A001 1ACE1F 20DFE1 0204000000000541 -41.5
2021.05.12 12:05:55.919 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: CD A0 01 1ACE1F 20DFE1 02040000000005
2021.05.12 12:05:56.050 4: CUL_Parse: cul868 A 1A CD A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A13 -64.5
2021.05.12 12:05:56.057 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: CD A0 10 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.12 12:05:56.060 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8AA5E d:FF r:FFCC     m:CD A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.12 12:05:56.165 4: CUL_Parse: cul868 A 0A CD 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:56.170 0: HMLAN_Parse: hmlan1 R:R600A43AE stat:0001 t:57C8AA63 d:FF r:FFCC     m:CD A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.12 12:05:56.174 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: CD 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:56.305 4: CUL_Parse: cul868 A 1A CE A010 20DFE1 1ACE1F 03102A902290289028902890289028902813 -64.5
2021.05.12 12:05:56.312 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: CE A0 10 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.12 12:05:56.321 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8AB5E d:FF r:FFCB     m:CE A010 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.12 12:05:56.415 4: CUL_Parse: cul868 A 0A CE 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:05:56.421 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: CE 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:56.557 4: CUL_Parse: cul868 A 1A CF A010 20DFE1 1ACE1F 031F90289028902890289028902890289014 -64
2021.05.12 12:05:56.563 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: CF A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 12:05:56.567 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8AC59 d:FF r:FFCC     m:CF A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 12:05:56.666 4: CUL_Parse: cul868 A 0A CF 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:05:56.671 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: CF 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:56.807 4: CUL_Parse: cul868 A 1A D0 A010 20DFE1 1ACE1F 032E28902890289028902890289028242214 -64
2021.05.12 12:05:56.813 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D0 A0 10 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.12 12:05:56.817 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8AD54 d:FF r:FFCB     m:D0 A010 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.12 12:05:56.917 4: CUL_Parse: cul868 A 0A D0 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:56.923 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D0 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:57.057 4: CUL_Parse: cul868 A 1A D1 A010 20DFE1 1ACE1F 033D482A8A2A902290289028902890289013 -64.5
2021.05.12 12:05:57.063 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D1 A0 10 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.12 12:05:57.067 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8AE4F d:FF r:FFCB     m:D1 A010 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.12 12:05:57.167 4: CUL_Parse: cul868 A 0A D1 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:05:57.173 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D1 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:57.309 4: CUL_Parse: cul868 A 1A D2 A010 20DFE1 1ACE1F 034C28902890289028902890289028902813 -64.5
2021.05.12 12:05:57.315 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D2 A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 12:05:57.319 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8AF4A d:FF r:FFCB     m:D2 A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 12:05:57.478 4: CUL_Parse: cul868 A 0A D2 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:57.485 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D2 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:57.559 4: CUL_Parse: cul868 A 1A D3 A010 20DFE1 1ACE1F 035B90289028902890289028902890289013 -64.5
2021.05.12 12:05:57.566 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D3 A0 10 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.12 12:05:57.570 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B045 d:FF r:FFCB     m:D3 A010 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.12 12:05:57.669 4: CUL_Parse: cul868 A 0A D3 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:57.675 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D3 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:57.811 4: CUL_Parse: cul868 A 1A D4 A010 20DFE1 1ACE1F 036A282422482A8A2A902290289028902813 -64.5
2021.05.12 12:05:57.817 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D4 A0 10 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.12 12:05:57.821 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B140 d:FF r:FFCB     m:D4 A010 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.12 12:05:57.830 0: HMUARTLGW hmuart1 send: 00 08
2021.05.12 12:05:57.834 0: HMUARTLGW hmuart1 recv: 00 04020F, state 98
2021.05.12 12:05:57.835 0: HMUARTLGW hmuart1 GetSet Ack: 02, state 98
2021.05.12 12:05:57.836 0: HMUARTLGW hmuart1 roundtrip delay: 0.0028
2021.05.12 12:05:57.919 4: CUL_Parse: cul868 A 0A D4 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:57.925 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D4 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:58.061 4: CUL_Parse: cul868 A 1A D5 A010 20DFE1 1ACE1F 037990289028902890289028902890289013 -64.5
2021.05.12 12:05:58.067 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D5 A0 10 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.12 12:05:58.071 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B23B d:FF r:FFCC     m:D5 A010 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.12 12:05:58.171 4: CUL_Parse: cul868 A 0A D5 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:05:58.176 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D5 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:58.312 4: CUL_Parse: cul868 A 1A D6 A010 20DFE1 1ACE1F 038828902890289028902890289028902813 -64.5
2021.05.12 12:05:58.318 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D6 A0 10 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.12 12:05:58.322 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B336 d:FF r:FFCB     m:D6 A010 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.12 12:05:58.421 4: CUL_Parse: cul868 A 0A D6 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:05:58.426 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D6 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:58.562 4: CUL_Parse: cul868 A 1A D7 A010 20DFE1 1ACE1F 0397902890282422482A8A2A902290289013 -64.5
2021.05.12 12:05:58.569 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D7 A0 10 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.12 12:05:58.573 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B431 d:FF r:FFCB     m:D7 A010 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.12 12:05:58.672 4: CUL_Parse: cul868 A 0A D7 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:58.678 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D7 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:58.813 4: CUL_Parse: cul868 A 1A D8 A010 20DFE1 1ACE1F 03A628902890289028902890289028902813 -64.5
2021.05.12 12:05:58.819 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D8 A0 10 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.12 12:05:58.823 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B52B d:FF r:FFCB     m:D8 A010 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.12 12:05:58.923 4: CUL_Parse: cul868 A 0A D8 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:58.928 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D8 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:59.063 4: CUL_Parse: cul868 A 1A D9 A010 20DFE1 1ACE1F 03B590289028902890289028902890289014 -64
2021.05.12 12:05:59.069 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: D9 A0 10 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.12 12:05:59.073 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B626 d:FF r:FFCB     m:D9 A010 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.12 12:05:59.177 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: D9 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:59.188 4: CUL_Parse: cul868 A 0A D9 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:59.313 4: CUL_Parse: cul868 A 1A DA A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A902213 -64.5
2021.05.12 12:05:59.320 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: DA A0 10 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.12 12:05:59.324 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B721 d:FF r:FFCB     m:DA A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.12 12:05:59.424 4: CUL_Parse: cul868 A 0A DA 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:05:59.430 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: DA 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:59.565 4: CUL_Parse: cul868 A 1A DB A010 20DFE1 1ACE1F 03D390289028902890289028902890289013 -64.5
2021.05.12 12:05:59.571 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: DB A0 10 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.12 12:05:59.575 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B81C d:FF r:FFCB     m:DB A010 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.12 12:05:59.675 4: CUL_Parse: cul868 A 0A DB 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:05:59.680 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: DB 80 02 1ACE1F 20DFE1 00
2021.05.12 12:05:59.819 4: CUL_Parse: cul868 A 1A DC A010 20DFE1 1ACE1F 03E228902890289028902890289028902813 -64.5
2021.05.12 12:05:59.835 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8B917 d:FF r:FFCB     m:DC A010 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.12 12:05:59.841 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: DC A0 10 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.12 12:05:59.926 4: CUL_Parse: cul868 A 0A DC 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:05:59.932 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: DC 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:00.063 4: CUL_Parse: cul868 A 15 DD A010 20DFE1 1ACE1F 03F19028902890289028902813 -64.5
2021.05.12 12:06:00.069 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: DD A0 10 20DFE1 1ACE1F 03F190289028902890289028
2021.05.12 12:06:00.073 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8BA0E d:FF r:FFCB     m:DD A010 20DFE1 1ACE1F 03F190289028902890289028
2021.05.12 12:06:00.178 4: CUL_Parse: cul868 A 0A DD 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:06:00.183 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: DD 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:00.304 4: CUL_Parse: cul868 A 0B DE 8010 20DFE1 1ACE1F 030013 -64.5
2021.05.12 12:06:00.406 0: HMLAN_Send:  hmlan1 S:S600A55F5 stat:  00 t:00000000 d:01 r:600A55F5 m:EE A001 1ACE1F 20DFE1 02040000000006
2021.05.12 12:06:00.437 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8BB00 d:FF r:FFCB     m:DE 8010 20DFE1 1ACE1F 0300
2021.05.12 12:06:00.440 4: CUL_Parse: cul868 A 10 EE A001 1ACE1F 20DFE1 0204000000000641 -41.5
2021.05.12 12:06:00.444 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: DE 80 10 20DFE1 1ACE1F 0300
2021.05.12 12:06:00.448 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: EE A0 01 1ACE1F 20DFE1 02040000000006
2021.05.12 12:06:00.572 4: CUL_Parse: cul868 A 1A EE A010 20DFE1 1ACE1F 03012422482A8A2A90229028902890289013 -64.5
2021.05.12 12:06:00.578 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: EE A0 10 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.12 12:06:00.582 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8BC0A d:FF r:FFCB     m:EE A010 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.12 12:06:00.686 4: CUL_Parse: cul868 A 0A EE 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:06:00.691 0: HMLAN_Parse: hmlan1 R:R600A55F5 stat:0001 t:57C8BC0F d:FF r:FFCB     m:EE A010 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.12 12:06:00.694 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: EE 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:00.761 4: CUL_Parse: cul868 A 14 25 805E 266EA5 1ACE1F 0000000000000000000000F4 -80
2021.05.12 12:06:00.767 0: HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: 25 80 5E 266EA5 1ACE1F 0000000000000000000000
2021.05.12 12:06:00.771 0: HMLAN_Parse: hmlan1 R:E266EA5   stat:0000 t:57C8BCC8 d:FF r:FFBD     m:25 805E 266EA5 1ACE1F 0000000000000000000000
2021.05.12 12:06:00.827 4: CUL_Parse: cul868 A 1A EF A010 20DFE1 1ACE1F 031028902890289028902890289028902813 -64.5
2021.05.12 12:06:00.834 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: EF A0 10 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.12 12:06:00.837 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8BD0A d:FF r:FFCB     m:EF A010 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.12 12:06:00.939 4: CUL_Parse: cul868 A 0A EF 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:06:00.944 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: EF 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:01.079 4: CUL_Parse: cul868 A 1A F0 A010 20DFE1 1ACE1F 031F90289028902890289028902890289013 -64.5
2021.05.12 12:06:01.085 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: F0 A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 12:06:01.089 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8BE06 d:FF r:FFCB     m:F0 A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 12:06:01.189 4: CUL_Parse: cul868 A 0A F0 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:06:01.194 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: F0 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:01.330 4: CUL_Parse: cul868 A 1A F1 A010 20DFE1 1ACE1F 032E2890282422482A8A2A90229028902813 -64.5
2021.05.12 12:06:01.340 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8BF01 d:FF r:FFCB     m:F1 A010 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.12 12:06:01.344 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: F1 A0 10 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.12 12:06:01.440 4: CUL_Parse: cul868 A 0A F1 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:06:01.446 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: F1 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:01.581 4: CUL_Parse: cul868 A 1A F2 A010 20DFE1 1ACE1F 033D90289028902890289028902890289013 -64.5
2021.05.12 12:06:01.588 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: F2 A0 10 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.12 12:06:01.593 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8BFFC d:FF r:FFCB     m:F2 A010 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.12 12:06:01.691 4: CUL_Parse: cul868 A 0A F2 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:06:01.696 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: F2 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:01.832 4: CUL_Parse: cul868 A 1A F3 A010 20DFE1 1ACE1F 034C28902890289028902890289028902813 -64.5
2021.05.12 12:06:01.839 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: F3 A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 12:06:01.843 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8C0F7 d:FF r:FFCB     m:F3 A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 12:06:01.943 4: CUL_Parse: cul868 A 0A F3 8002 1ACE1F 20DFE1 0040 -42
2021.05.12 12:06:01.959 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: F3 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:02.075 4: CUL_Parse: cul868 A 11 F4 A010 20DFE1 1ACE1F 035B90289028902813 -64.5
2021.05.12 12:06:02.083 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: F4 A0 10 20DFE1 1ACE1F 035B902890289028
2021.05.12 12:06:02.087 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8C1EB d:FF r:FFCB     m:F4 A010 20DFE1 1ACE1F 035B902890289028
2021.05.12 12:06:02.192 4: CUL_Parse: cul868 A 0A F4 8002 1ACE1F 20DFE1 0041 -41.5
2021.05.12 12:06:02.198 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: F4 80 02 1ACE1F 20DFE1 00
2021.05.12 12:06:02.321 4: CUL_Parse: cul868 A 0B F5 8010 20DFE1 1ACE1F 030013 -64.5
2021.05.12 12:06:02.423 0: HMLAN_Send:  hmlan1 S:S600A5DDB stat:  00 t:00000000 d:01 r:600A5DDB m:05 A001 1ACE1F 20DFE1 0303
2021.05.12 12:06:02.487 4: CUL_Parse: cul868 A 0B 05 A001 1ACE1F 20DFE1 030341 -41.5
2021.05.12 12:06:02.491 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57C8C2E1 d:FF r:FFCB     m:F5 8010 20DFE1 1ACE1F 0300
2021.05.12 12:06:02.495 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: F5 80 10 20DFE1 1ACE1F 0300
2021.05.12 12:06:02.498 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: 05 A0 01 1ACE1F 20DFE1 0303
2021.05.12 12:06:02.580 4: CUL_Parse: cul868 A 0E 05 8010 20DFE1 1ACE1F 010000000013 -64.5
2021.05.12 12:06:02.587 0: HMLAN_Send:  hmlan1 I:+20DFE1,00,00,00
2021.05.12 12:06:02.688 0: HMLAN_Parse: hmlan1 R:R600A5DDB stat:0001 t:57C8C3E9 d:FF r:FFCB     m:05 8010 20DFE1 1ACE1F 0100000000
2021.05.12 12:06:02.693 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: 05 80 10 20DFE1 1ACE1F 0100000000
2021.05.12 12:07:02.606 2: HMinfo hminfo get:configCheck :-f,^(Thermostat.OZ|Thermostat.OZ_Climate|Thermostat.OZ_Weather|Thermostat.OZ_WindowRec|Thermostat.OZ)$
########################## 2. IOgrp auf cul umgestellt
2021-05-12 12:07:31.129 Global global ATTR Thermostat.OZ IOgrp ccu:cul868
2021.05.12 12:07:44.672 3: CUL_HM set Thermostat.OZ_Climate statusRequest noArg
2021.05.12 12:07:44.786 0: HMLAN_Send:  hmlan1 I:+20DFE1,02,00,00
2021.05.12 12:07:54.677 4: CUL_Parse: cul868 A 1A 9D 8400 20DFE1 000000 2100394B4551303137363036325800FFFF05 -71.5
2021.05.12 12:07:54.682 0: HMLAN_Send:  hmlan1 I:+20DFE1,00,00,00
2021.05.12 12:07:54.684 0: HMLAN_Send:  hmlan1 I:-20DFE1
2021.05.12 12:07:54.891 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: 9D 84 00 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 12:07:54.894 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: C5 A0 01 1ACE1F 20DFE1 020E
2021.05.12 12:07:54.898 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CA79D3 d:FF r:FFCC     m:9D 8400 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 12:07:54.901 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:57CA7A57 d:FF r:FFDA     m:C5 A001 1ACE1F 20DFE1 020E
2021.05.12 12:07:54.938 4: CUL_Parse: cul868 A 0E C5 8002 20DFE1 1ACE1F 01020C004905 -71.5
2021.05.12 12:07:55.046 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3E msg: C5 80 02 20DFE1 1ACE1F 01020C0049
2021.05.12 12:07:55.049 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CA7AD9 d:FF r:FFCC     m:C5 8002 20DFE1 1ACE1F 01020C0049
2021.05.12 12:08:27.110 3: CUL_HM set Thermostat.OZ_Climate statusRequest noArg
2021.05.12 12:08:40.359 4: CUL_Parse: cul868 A 0C 9D 8670 20DFE1 000000 00C13FF9 -77.5
2021.05.12 12:08:40.575 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: 9D 86 70 20DFE1 000000 00C13F
2021.05.12 12:08:40.579 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 9E A1 12 1ACE1F 20DFE1
2021.05.12 12:08:40.583 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CB2C4C d:FF r:FFCE     m:9D 8670 20DFE1 000000 00C13F
2021.05.12 12:08:40.586 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:57CB2CCF d:FF r:FFD9     m:9E A112 1ACE1F 20DFE1
2021.05.12 12:08:40.616 4: CUL_Parse: cul868 A 0A 9E 8002 20DFE1 1ACE1F 00F7 -78.5
2021.05.12 12:08:40.748 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: 9E 80 02 20DFE1 1ACE1F 00
2021.05.12 12:08:40.760 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CB2D4E d:FF r:FFCE     m:9E 8002 20DFE1 1ACE1F 00
2021.05.12 12:08:40.764 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:57CB2DD0 d:FF r:FFDA     m:9F A001 1ACE1F 20DFE1 020E
2021.05.12 12:08:40.773 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 9F A0 01 1ACE1F 20DFE1 020E
2021.05.12 12:08:40.875 4: CUL_Parse: cul868 A 0E 9F 8002 20DFE1 1ACE1F 01020C004EF9 -77.5
2021.05.12 12:08:40.989 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: 9F 80 02 20DFE1 1ACE1F 01020C004E
2021.05.12 12:08:40.992 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CB2E51 d:FF r:FFCE     m:9F 8002 20DFE1 1ACE1F 01020C004E
2021.05.12 12:09:22.558 4: CUL_Parse: cul868 A 1A 9E 8400 20DFE1 000000 2100394B4551303137363036325800FFFFF8 -78
2021.05.12 12:09:22.571 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CBD129 d:FF r:FFCD     m:9E 8400 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 12:09:22.576 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3C msg: 9E 84 00 20DFE1 000000 2100394B4551303137363036325800FFFF
########################## 3. getconfig ausgelöst, cmds werden nicht mehr abgearbeitet
2021.05.12 12:10:10.458 3: CUL_HM set Thermostat.OZ getConfig noArg
2021.05.12 12:10:18.241 4: CUL_Parse: cul868 A 1A 9E 8400 20DFE1 000000 2100394B4551303137363036325800FFFFF7 -78.5
2021.05.12 12:10:18.247 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: 9E 84 00 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 12:10:18.252 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CCAAB5 d:FF r:FFCD     m:9E 8400 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 12:10:45.940 4: CUL_Parse: cul868 A 1A 9E 8400 20DFE1 000000 2100394B4551303137363036325800FFFFF3 -80.5
2021.05.12 12:10:45.945 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3D msg: 9E 84 00 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 12:10:45.951 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CD16EB d:FF r:FFCD     m:9E 8400 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 12:11:11.915 4: CUL_Parse: cul868 A 0C 9E 8670 20DFE1 000000 00C340FB -76.5
2021.05.12 12:11:12.070 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3E msg: 9E 86 70 20DFE1 000000 00C340
2021.05.12 12:11:12.074 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:57CD7C67 d:FF r:FFCD     m:9E 8670 20DFE1 000000 00C340
....... 23 weatherevents
2021.05.12 13:11:12.523 4: CUL_Parse: cul868 A 0C B6 8670 20DFE1 000000 00C83F14 -64
2021.05.12 13:11:12.652 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: B6 86 70 20DFE1 000000 00C83F
2021.05.12 13:11:12.656 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58046F38 d:FF r:FFCF     m:B6 8670 20DFE1 000000 00C83F
########################## 4. erneut configbutton gedrückt, plötzlich erfolgreiches abarbeiten
2021.05.12 13:13:05.132 4: CUL_Parse: cul868 A 1A B7 8400 20DFE1 000000 2100394B4551303137363036325800FFFF05 -71.5
2021.05.12 13:13:05.357 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: B7 84 00 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 13:13:05.360 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: DF A0 01 1ACE1F 20DFE1 00040000000000
2021.05.12 13:13:05.365 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062727 d:FF r:FFCB     m:B7 8400 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.12 13:13:05.367 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:580627B0 d:FF r:FFD9     m:DF A001 1ACE1F 20DFE1 00040000000000
2021.05.12 13:13:05.403 4: CUL_Parse: cul868 A 1A DF 8010 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F00000005 -71.5
2021.05.12 13:13:05.511 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: DF 80 10 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F000000
2021.05.12 13:13:05.514 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062837 d:FF r:FFCB     m:DF 8010 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F000000
2021.05.12 13:13:05.535 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: EF A0 01 1ACE1F 20DFE1 0103
2021.05.12 13:13:05.543 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:580628B9 d:FF r:FFD9     m:EF A001 1ACE1F 20DFE1 0103
2021.05.12 13:13:05.662 4: CUL_Parse: cul868 A 0E EF 8010 20DFE1 1ACE1F 010000000004 -72
2021.05.12 13:13:05.769 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: EF 80 10 20DFE1 1ACE1F 0100000000
2021.05.12 13:13:05.772 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5806293B d:FF r:FFCB     m:EF 8010 20DFE1 1ACE1F 0100000000
2021.05.12 13:13:05.794 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: FF A0 01 1ACE1F 20DFE1 0203
2021.05.12 13:13:05.802 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:580629BC d:FF r:FFD9     m:FF A001 1ACE1F 20DFE1 0203
2021.05.12 13:13:05.921 4: CUL_Parse: cul868 A 0E FF 8010 20DFE1 1ACE1F 010000000005 -71.5
2021.05.12 13:13:06.029 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: FF 80 10 20DFE1 1ACE1F 0100000000
2021.05.12 13:13:06.032 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062A3D d:FF r:FFCB     m:FF 8010 20DFE1 1ACE1F 0100000000
2021.05.12 13:13:06.058 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 0F A0 01 1ACE1F 20DFE1 02040000000005
2021.05.12 13:13:06.065 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58062AC3 d:FF r:FFD9     m:0F A001 1ACE1F 20DFE1 02040000000005
2021.05.12 13:13:06.191 4: CUL_Parse: cul868 A 1A 0F A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A04 -72
2021.05.12 13:13:06.298 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 0F A0 10 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.12 13:13:06.301 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062B4A d:FF r:FFCB     m:0F A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.12 13:13:06.322 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 0F 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:06.330 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58062BCC d:FF r:FFD9     m:0F 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:06.461 4: CUL_Parse: cul868 A 1A 10 A010 20DFE1 1ACE1F 03102A902290289028902890289028902805 -71.5
2021.05.12 13:13:06.568 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 10 A0 10 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.12 13:13:06.571 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062C58 d:FF r:FFCB     m:10 A010 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.12 13:13:06.592 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 10 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:06.601 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58062CDA d:FF r:FFDA     m:10 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:06.731 4: CUL_Parse: cul868 A 1A 11 A010 20DFE1 1ACE1F 031F90289028902890289028902890289005 -71.5
2021.05.12 13:13:06.838 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 11 A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 13:13:06.841 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062D66 d:FF r:FFCB     m:11 A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 13:13:06.862 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 11 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:06.871 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58062DE9 d:FF r:FFD9     m:11 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:07.001 4: CUL_Parse: cul868 A 1A 12 A010 20DFE1 1ACE1F 032E28902890289028902890289028242205 -71.5
2021.05.12 13:13:07.109 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 12 A0 10 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.12 13:13:07.112 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062E75 d:FF r:FFCB     m:12 A010 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.12 13:13:07.133 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 12 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:07.141 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58062EF7 d:FF r:FFD9     m:12 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:07.271 4: CUL_Parse: cul868 A 1A 13 A010 20DFE1 1ACE1F 033D482A8A2A902290289028902890289003 -72.5
2021.05.12 13:13:07.379 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 13 A0 10 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.12 13:13:07.382 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58062F83 d:FF r:FFCB     m:13 A010 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.12 13:13:07.403 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 13 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:07.411 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063005 d:FF r:FFD9     m:13 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:07.541 4: CUL_Parse: cul868 A 1A 14 A010 20DFE1 1ACE1F 034C28902890289028902890289028902805 -71.5
2021.05.12 13:13:07.649 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 14 A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 13:13:07.652 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063091 d:FF r:FFCB     m:14 A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 13:13:07.673 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 14 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:07.681 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063113 d:FF r:FFDA     m:14 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:07.812 4: CUL_Parse: cul868 A 1A 15 A010 20DFE1 1ACE1F 035B90289028902890289028902890289005 -71.5
2021.05.12 13:13:07.922 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 15 A0 10 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.12 13:13:07.934 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5806319E d:FF r:FFCB     m:15 A010 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.12 13:13:07.945 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 15 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:07.953 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063223 d:FF r:FFD9     m:15 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:08.083 4: CUL_Parse: cul868 A 1A 16 A010 20DFE1 1ACE1F 036A282422482A8A2A902290289028902806 -71
2021.05.12 13:13:08.190 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 16 A0 10 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.12 13:13:08.193 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:580632AF d:FF r:FFCB     m:16 A010 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.12 13:13:08.214 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 16 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:08.222 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063331 d:FF r:FFD9     m:16 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:08.352 4: CUL_Parse: cul868 A 1A 17 A010 20DFE1 1ACE1F 037990289028902890289028902890289005 -71.5
2021.05.12 13:13:08.459 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 17 A0 10 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.12 13:13:08.462 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:580633BC d:FF r:FFCB     m:17 A010 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.12 13:13:08.483 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 17 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:08.491 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5806343E d:FF r:FFD9     m:17 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:08.622 4: CUL_Parse: cul868 A 1A 18 A010 20DFE1 1ACE1F 038828902890289028902890289028902805 -71.5
2021.05.12 13:13:08.729 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 18 A0 10 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.12 13:13:08.732 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:580634C9 d:FF r:FFCB     m:18 A010 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.12 13:13:08.753 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 18 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:08.761 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5806354C d:FF r:FFD9     m:18 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:08.769 0: HMUARTLGW hmuart1 send: 00 08
2021.05.12 13:13:08.773 0: HMUARTLGW hmuart1 recv: 00 04021B, state 98
2021.05.12 13:13:08.774 0: HMUARTLGW hmuart1 GetSet Ack: 02, state 98
2021.05.12 13:13:08.775 0: HMUARTLGW hmuart1 roundtrip delay: 0.0028
2021.05.12 13:13:08.892 4: CUL_Parse: cul868 A 1A 19 A010 20DFE1 1ACE1F 0397902890282422482A8A2A902290289005 -71.5
2021.05.12 13:13:08.999 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 19 A0 10 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.12 13:13:09.002 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:580635D8 d:FF r:FFCB     m:19 A010 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.12 13:13:09.023 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 19 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:09.031 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5806365A d:FF r:FFD9     m:19 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:09.162 4: CUL_Parse: cul868 A 1A 1A A010 20DFE1 1ACE1F 03A628902890289028902890289028902806 -71
2021.05.12 13:13:09.278 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 1A A0 10 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.12 13:13:09.282 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:580636E6 d:FF r:FFCB     m:1A A010 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.12 13:13:09.293 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 1A 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:09.301 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063768 d:FF r:FFD9     m:1A 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:09.432 4: CUL_Parse: cul868 A 1A 1B A010 20DFE1 1ACE1F 03B590289028902890289028902890289006 -71
2021.05.12 13:13:09.540 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 1B A0 10 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.12 13:13:09.543 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:580637F4 d:FF r:FFCB     m:1B A010 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.12 13:13:09.564 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 1B 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:09.571 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063876 d:FF r:FFD9     m:1B 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:09.701 4: CUL_Parse: cul868 A 1A 1C A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A902206 -71
2021.05.12 13:13:09.808 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 1C A0 10 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.12 13:13:09.811 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063901 d:FF r:FFCB     m:1C A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.12 13:13:09.832 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 1C 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:09.840 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063983 d:FF r:FFD9     m:1C 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:09.971 4: CUL_Parse: cul868 A 1A 1D A010 20DFE1 1ACE1F 03D390289028902890289028902890289006 -71
2021.05.12 13:13:10.079 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 1D A0 10 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.12 13:13:10.082 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063A0F d:FF r:FFCB     m:1D A010 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.12 13:13:10.102 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 1D 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:10.110 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063A91 d:FF r:FFD9     m:1D 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:10.241 4: CUL_Parse: cul868 A 1A 1E A010 20DFE1 1ACE1F 03E228902890289028902890289028902806 -71
2021.05.12 13:13:10.349 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 1E A0 10 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.12 13:13:10.351 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063B1D d:FF r:FFCB     m:1E A010 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.12 13:13:10.373 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 1E 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:10.380 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063B9F d:FF r:FFD9     m:1E 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:10.507 4: CUL_Parse: cul868 A 15 1F A010 20DFE1 1ACE1F 03F19028902890289028902807 -70.5
2021.05.12 13:13:10.642 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063C27 d:FF r:FFCB     m:1F A010 20DFE1 1ACE1F 03F190289028902890289028
2021.05.12 13:13:10.646 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 1F A0 10 20DFE1 1ACE1F 03F190289028902890289028
2021.05.12 13:13:10.649 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 1F 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:10.655 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063CAB d:FF r:FFD9     m:1F 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:10.765 4: CUL_Parse: cul868 A 0B 20 8010 20DFE1 1ACE1F 030006 -71
2021.05.12 13:13:10.898 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063D2B d:FF r:FFCB     m:20 8010 20DFE1 1ACE1F 0300
2021.05.12 13:13:10.901 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 20 80 10 20DFE1 1ACE1F 0300
2021.05.12 13:13:10.905 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 30 A0 01 1ACE1F 20DFE1 02040000000006
2021.05.12 13:13:10.910 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063DB0 d:FF r:FFD9     m:30 A001 1ACE1F 20DFE1 02040000000006
2021.05.12 13:13:11.035 4: CUL_Parse: cul868 A 1A 30 A010 20DFE1 1ACE1F 03012422482A8A2A90229028902890289006 -71
2021.05.12 13:13:11.142 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063E37 d:FF r:FFCB     m:30 A010 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.12 13:13:11.146 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 30 A0 10 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.12 13:13:11.167 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 30 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:11.175 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063EBA d:FF r:FFD9     m:30 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:11.305 4: CUL_Parse: cul868 A 1A 31 A010 20DFE1 1ACE1F 031028902890289028902890289028902805 -71.5
2021.05.12 13:13:11.412 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58063F46 d:FF r:FFCB     m:31 A010 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.12 13:13:11.416 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 31 A0 10 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.12 13:13:11.437 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 31 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:11.445 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58063FC8 d:FF r:FFDA     m:31 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:11.574 4: CUL_Parse: cul868 A 1A 32 A010 20DFE1 1ACE1F 031F90289028902890289028902890289005 -71.5
2021.05.12 13:13:11.681 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58064053 d:FF r:FFCB     m:32 A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 13:13:11.685 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 32 A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.12 13:13:11.706 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 32 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:11.714 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:580640D5 d:FF r:FFD9     m:32 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:11.844 4: CUL_Parse: cul868 A 1A 33 A010 20DFE1 1ACE1F 032E2890282422482A8A2A90229028902804 -72
2021.05.12 13:13:11.951 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58064160 d:FF r:FFCB     m:33 A010 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.12 13:13:11.955 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 33 A0 10 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.12 13:13:11.976 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 33 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:11.984 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:580641E3 d:FF r:FFD9     m:33 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:12.115 4: CUL_Parse: cul868 A 1A 34 A010 20DFE1 1ACE1F 033D90289028902890289028902890289005 -71.5
2021.05.12 13:13:12.221 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5806426F d:FF r:FFCB     m:34 A010 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.12 13:13:12.225 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 34 A0 10 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.12 13:13:12.246 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 34 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:12.254 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:580642F1 d:FF r:FFD9     m:34 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:12.385 4: CUL_Parse: cul868 A 1A 35 A010 20DFE1 1ACE1F 034C28902890289028902890289028902806 -71
2021.05.12 13:13:12.491 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5806437D d:FF r:FFCB     m:35 A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 13:13:12.495 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 35 A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.12 13:13:12.516 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 35 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:12.524 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:580643FF d:FF r:FFD9     m:35 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:12.647 4: CUL_Parse: cul868 A 11 36 A010 20DFE1 1ACE1F 035B90289028902806 -71
2021.05.12 13:13:12.754 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58064484 d:FF r:FFCB     m:36 A010 20DFE1 1ACE1F 035B902890289028
2021.05.12 13:13:12.758 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 36 A0 10 20DFE1 1ACE1F 035B902890289028
2021.05.12 13:13:12.779 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 36 80 02 1ACE1F 20DFE1 00
2021.05.12 13:13:12.787 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58064506 d:FF r:FFD9     m:36 8002 1ACE1F 20DFE1 00
2021.05.12 13:13:12.904 4: CUL_Parse: cul868 A 0B 37 8010 20DFE1 1ACE1F 030006 -71
2021.05.12 13:13:13.037 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58064586 d:FF r:FFCB     m:37 8010 20DFE1 1ACE1F 0300
2021.05.12 13:13:13.041 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 37 80 10 20DFE1 1ACE1F 0300
2021.05.12 13:13:13.044 0: HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 47 A0 01 1ACE1F 20DFE1 0303
2021.05.12 13:13:13.048 0: HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:58064607 d:FF r:FFD9     m:47 A001 1ACE1F 20DFE1 0303
2021.05.12 13:13:13.163 4: CUL_Parse: cul868 A 0E 47 8010 20DFE1 1ACE1F 010000000006 -71
2021.05.12 13:13:13.260 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58064689 d:FF r:FFCB     m:47 8010 20DFE1 1ACE1F 0100000000
2021.05.12 13:13:13.264 0: HMUARTLGW hmuart1 recv: 01 05 00 00 38 msg: 47 80 10 20DFE1 1ACE1F 0100000000
2021.05.12 13:14:07.528 4: CUL_Parse: cul868 A 0C B7 8670 20DFE1 000000 00C93FEF -82.5
2021.05.12 13:14:07.605 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:58071AED d:FF r:FFC3     m:B7 8670 20DFE1 000000 00C93F
2021.05.12 13:14:07.614 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3F msg: B7 86 70 20DFE1 000000 00C93F
2021.05.12 13:14:13.184 2: HMinfo hminfo get:configCheck :-f,^(Thermostat.OZ|Thermostat.OZ_Climate|Thermostat.OZ_Weather|Thermostat.OZ_WindowRec|Thermostat.OZ)$
edit:
scheinbar hat helper/prt/sleeping einfluss. sobald sleeping=0 ist werden die cmds nicht mehr über wakeup abgearbeitet.
edit2:
config und wakeup "verriegeln" sich quasi gegenseitig.
wenn ich bei leerem cmd stack eine configmsg erzeuge, wird ein danach gefüllter cmd stack nie wieder über wakeup abgearbeitet. der cmd stack lässt sich aber andererseits erst über configbutton abarbeiten, wenn nach dem füllen des cmd stacks eine wakemeup msg vom device gekommen ist (wie im sniff zu sehen, beginnt mit configmsg vor punkt 3.).
auch ein cmd stack der einmal über configbutton angefangen wurde abzuarbeiten, aber zwischendrin abgebrochen wurde, muss weiterhin über configbutton bis zum ende abgearbeitet werden.
frank
hallo ansgar,
mit deiner aktuellen version:
beim problematischen scenario fehlt nun beim ersten wakeup die A112 msg, daher wird nur der erste cmd ausgeführt.
beim nächsten zyklus funktioniert es dann.
2021.05.13 18:08:15.881 4 : CUL_Parse: cul868 A 0C 64 8670 20DFE1 000000 00BD3F0B -68.5
2021.05.13 18:08:15.984 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 64 86 70 20DFE1 000000 00BD3F
2021.05.13 18:08:15.987 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3AF7DD d:FF r:FFC5     m:64 8670 20DFE1 000000 00BD3F
2021.05.13 18:08:28.235 4 : CUL_Parse: cul868 A 1A 65 8400 20DFE1 000000 2100394B4551303137363036325800FFFF0C -68
2021.05.13 18:08:28.249 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3B281F d:FF r:FFC7     m:65 8400 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.13 18:08:28.254 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 3F msg: 65 84 00 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.13 18:08:42.589 3 : CUL_HM set Thermostat.OZ getConfig noArg
2021.05.13 18:10:37.636 4 : CUL_Parse: cul868 A 0C 65 8670 20DFE1 000000 00BF3E0F -66.5
2021.05.13 18:10:37.864 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3D21AA d:FF r:FFCA     m:65 8670 20DFE1 000000 00BF3E
2021.05.13 18:10:37.867 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3D2231 d:FF r:FFDA     m:66 A001 1ACE1F 20DFE1 00040000000000
2021.05.13 18:10:37.871 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 43 msg: 65 86 70 20DFE1 000000 00BF3E
2021.05.13 18:10:37.874 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 66 A0 01 1ACE1F 20DFE1 00040000000000
2021.05.13 18:10:37.906 4 : CUL_Parse: cul868 A 1A 66 8010 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F0000000F -66.5
2021.05.13 18:10:38.014 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3D22B7 d:FF r:FFCA     m:66 8010 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F000000
2021.05.13 18:10:38.018 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 43 msg: 66 80 10 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F000000
2021.05.13 18:10:38.039 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 76 A0 01 1ACE1F 20DFE1 0103
2021.05.13 18:10:38.047 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3D233B d:FF r:FFDA     m:76 A001 1ACE1F 20DFE1 0103
2021.05.13 18:12:44.890 4 : CUL_Parse: cul868 A 0C 66 8670 20DFE1 000000 00C03E0F -66.5
2021.05.13 18:12:45.113 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F12D2 d:FF r:FFCC     m:66 8670 20DFE1 000000 00C03E
2021.05.13 18:12:45.116 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1352 d:FF r:FFD9     m:67 A112 1ACE1F 20DFE1
2021.05.13 18:12:45.120 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 42 msg: 66 86 70 20DFE1 000000 00C03E
2021.05.13 18:12:45.123 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 67 A1 12 1ACE1F 20DFE1
2021.05.13 18:12:45.147 4 : CUL_Parse: cul868 A 0A 67 8002 20DFE1 1ACE1F 0010 -66
2021.05.13 18:12:45.254 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F13D2 d:FF r:FFCC     m:67 8002 20DFE1 1ACE1F 00
2021.05.13 18:12:45.258 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 67 80 02 20DFE1 1ACE1F 00
2021.05.13 18:12:45.279 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 68 A0 01 1ACE1F 20DFE1 0103
2021.05.13 18:12:45.287 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1454 d:FF r:FFDA     m:68 A001 1ACE1F 20DFE1 0103
2021.05.13 18:12:45.407 4 : CUL_Parse: cul868 A 0E 68 8010 20DFE1 1ACE1F 01000000000E -67
2021.05.13 18:12:45.514 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F14D6 d:FF r:FFCC     m:68 8010 20DFE1 1ACE1F 0100000000
2021.05.13 18:12:45.518 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 68 80 10 20DFE1 1ACE1F 0100000000
2021.05.13 18:12:45.540 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 78 A0 01 1ACE1F 20DFE1 0203
2021.05.13 18:12:45.547 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1558 d:FF r:FFDA     m:78 A001 1ACE1F 20DFE1 0203
2021.05.13 18:12:45.666 4 : CUL_Parse: cul868 A 0E 78 8010 20DFE1 1ACE1F 01000000000F -66.5
2021.05.13 18:12:45.773 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F15D9 d:FF r:FFCC     m:78 8010 20DFE1 1ACE1F 0100000000
2021.05.13 18:12:45.777 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 78 80 10 20DFE1 1ACE1F 0100000000
2021.05.13 18:12:45.804 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 88 A0 01 1ACE1F 20DFE1 02040000000005
2021.05.13 18:12:45.811 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1660 d:FF r:FFD9     m:88 A001 1ACE1F 20DFE1 02040000000005
2021.05.13 18:12:45.936 4 : CUL_Parse: cul868 A 1A 88 A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A10 -66
2021.05.13 18:12:46.044 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F16E7 d:FF r:FFCC     m:88 A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.13 18:12:46.048 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 88 A0 10 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.13 18:12:46.068 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 88 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:46.076 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1769 d:FF r:FFD9     m:88 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:46.206 4 : CUL_Parse: cul868 A 1A 89 A010 20DFE1 1ACE1F 03102A90229028902890289028902890280F -66.5
2021.05.13 18:12:46.313 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F17F4 d:FF r:FFCC     m:89 A010 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.13 18:12:46.317 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 89 A0 10 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.13 18:12:46.338 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 89 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:46.346 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1877 d:FF r:FFDA     m:89 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:46.476 4 : CUL_Parse: cul868 A 1A 8A A010 20DFE1 1ACE1F 031F9028902890289028902890289028900F -66.5
2021.05.13 18:12:46.583 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F1903 d:FF r:FFCC     m:8A A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.13 18:12:46.587 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 8A A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.13 18:12:46.608 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 8A 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:46.616 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1985 d:FF r:FFD9     m:8A 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:46.746 4 : CUL_Parse: cul868 A 1A 8B A010 20DFE1 1ACE1F 032E28902890289028902890289028242210 -66
2021.05.13 18:12:46.853 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F1A10 d:FF r:FFCC     m:8B A010 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.13 18:12:46.857 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 8B A0 10 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.13 18:12:46.878 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 8B 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:46.886 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1A93 d:FF r:FFD9     m:8B 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:47.016 4 : CUL_Parse: cul868 A 1A 8C A010 20DFE1 1ACE1F 033D482A8A2A902290289028902890289010 -66
2021.05.13 18:12:47.124 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F1B1F d:FF r:FFCC     m:8C A010 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.13 18:12:47.127 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 8C A0 10 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.13 18:12:47.148 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 8C 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:47.156 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1BA1 d:FF r:FFDA     m:8C 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:47.286 4 : CUL_Parse: cul868 A 1A 8D A010 20DFE1 1ACE1F 034C2890289028902890289028902890280F -66.5
2021.05.13 18:12:47.393 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F1C2D d:FF r:FFCC     m:8D A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.13 18:12:47.397 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 8D A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.13 18:12:47.418 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 8D 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:47.426 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1CAF d:FF r:FFDA     m:8D 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:47.557 4 : CUL_Parse: cul868 A 1A 8E A010 20DFE1 1ACE1F 035B9028902890289028902890289028900F -66.5
2021.05.13 18:12:47.664 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F1D3B d:FF r:FFCB     m:8E A010 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.13 18:12:47.667 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 8E A0 10 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.13 18:12:47.688 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 8E 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:47.696 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1DBD d:FF r:FFDA     m:8E 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:47.827 4 : CUL_Parse: cul868 A 1A 8F A010 20DFE1 1ACE1F 036A282422482A8A2A902290289028902810 -66
2021.05.13 18:12:47.934 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F1E4A d:FF r:FFCB     m:8F A010 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.13 18:12:47.938 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 8F A0 10 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.13 18:12:47.958 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 8F 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:47.967 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1ECC d:FF r:FFDA     m:8F 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:48.097 4 : CUL_Parse: cul868 A 1A 90 A010 20DFE1 1ACE1F 037990289028902890289028902890289010 -66
2021.05.13 18:12:48.205 0 : HMUARTLGW hmuart1 send: 00 08
2021.05.13 18:12:48.208 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F1F57 d:FF r:FFCB     m:90 A010 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.13 18:12:48.212 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 90 A0 10 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.13 18:12:48.215 0 : HMUARTLGW hmuart1 recv: 00 040218, state 98
2021.05.13 18:12:48.216 0 : HMUARTLGW hmuart1 GetSet Ack: 02, state 98
2021.05.13 18:12:48.228 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 90 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:48.237 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F1FDA d:FF r:FFDA     m:90 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:48.367 4 : CUL_Parse: cul868 A 1A 91 A010 20DFE1 1ACE1F 038828902890289028902890289028902810 -66
2021.05.13 18:12:48.474 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2066 d:FF r:FFCB     m:91 A010 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.13 18:12:48.478 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 91 A0 10 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.13 18:12:48.499 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 91 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:48.507 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F20E8 d:FF r:FFD9     m:91 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:48.637 4 : CUL_Parse: cul868 A 1A 92 A010 20DFE1 1ACE1F 0397902890282422482A8A2A90229028900E -67
2021.05.13 18:12:48.744 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2174 d:FF r:FFCC     m:92 A010 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.13 18:12:48.748 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 92 A0 10 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.13 18:12:48.769 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 92 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:48.777 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F21F6 d:FF r:FFD9     m:92 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:48.907 4 : CUL_Parse: cul868 A 1A 93 A010 20DFE1 1ACE1F 03A62890289028902890289028902890280F -66.5
2021.05.13 18:12:49.015 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2282 d:FF r:FFCC     m:93 A010 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.13 18:12:49.019 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 40 msg: 93 A0 10 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.13 18:12:49.039 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 93 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:49.047 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2304 d:FF r:FFDA     m:93 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:49.177 4 : CUL_Parse: cul868 A 1A 94 A010 20DFE1 1ACE1F 03B59028902890289028902890289028900F -66.5
2021.05.13 18:12:49.285 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2390 d:FF r:FFCC     m:94 A010 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.13 18:12:49.289 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 42 msg: 94 A0 10 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.13 18:12:49.309 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 94 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:49.317 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2412 d:FF r:FFDA     m:94 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:49.447 4 : CUL_Parse: cul868 A 1A 95 A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A90220F -66.5
2021.05.13 18:12:49.555 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F249E d:FF r:FFCB     m:95 A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.13 18:12:49.558 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 44 msg: 95 A0 10 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.13 18:12:49.579 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 95 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:49.587 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2521 d:FF r:FFD9     m:95 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:49.718 4 : CUL_Parse: cul868 A 1A 96 A010 20DFE1 1ACE1F 03D39028902890289028902890289028900E -67
2021.05.13 18:12:49.825 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F25AD d:FF r:FFCB     m:96 A010 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.13 18:12:49.828 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 44 msg: 96 A0 10 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.13 18:12:49.849 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 96 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:49.857 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F262F d:FF r:FFDA     m:96 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:49.987 4 : CUL_Parse: cul868 A 1A 97 A010 20DFE1 1ACE1F 03E22890289028902890289028902890280F -66.5
2021.05.13 18:12:50.097 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F26BA d:FF r:FFCB     m:97 A010 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.13 18:12:50.101 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: 97 A0 10 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.13 18:12:50.121 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 97 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:50.128 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F273E d:FF r:FFDA     m:97 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:50.254 4 : CUL_Parse: cul868 A 15 98 A010 20DFE1 1ACE1F 03F1902890289028902890280F -66.5
2021.05.13 18:12:50.361 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F27C6 d:FF r:FFCA     m:98 A010 20DFE1 1ACE1F 03F190289028902890289028
2021.05.13 18:12:50.365 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: 98 A0 10 20DFE1 1ACE1F 03F190289028902890289028
2021.05.13 18:12:50.386 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: 98 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:50.393 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2847 d:FF r:FFDA     m:98 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:50.512 4 : CUL_Parse: cul868 A 0B 99 8010 20DFE1 1ACE1F 030010 -66
2021.05.13 18:12:50.642 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F28C7 d:FF r:FFCB     m:99 8010 20DFE1 1ACE1F 0300
2021.05.13 18:12:50.646 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: 99 80 10 20DFE1 1ACE1F 0300
2021.05.13 18:12:50.651 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: A9 A0 01 1ACE1F 20DFE1 02040000000006
2021.05.13 18:12:50.656 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F294E d:FF r:FFDA     m:A9 A001 1ACE1F 20DFE1 02040000000006
2021.05.13 18:12:50.782 4 : CUL_Parse: cul868 A 1A A9 A010 20DFE1 1ACE1F 03012422482A8A2A9022902890289028900F -66.5
2021.05.13 18:12:50.889 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F29D5 d:FF r:FFCB     m:A9 A010 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.13 18:12:50.893 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: A9 A0 10 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.13 18:12:50.914 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: A9 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:50.921 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2A57 d:FF r:FFD9     m:A9 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:51.052 4 : CUL_Parse: cul868 A 1A AA A010 20DFE1 1ACE1F 03102890289028902890289028902890280F -66.5
2021.05.13 18:12:51.159 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2AE3 d:FF r:FFCB     m:AA A010 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.13 18:12:51.163 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: AA A0 10 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.13 18:12:51.184 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: AA 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:51.191 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2B65 d:FF r:FFDA     m:AA 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:51.322 4 : CUL_Parse: cul868 A 1A AB A010 20DFE1 1ACE1F 031F90289028902890289028902890289010 -66
2021.05.13 18:12:51.429 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2BF1 d:FF r:FFCA     m:AB A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.13 18:12:51.433 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 44 msg: AB A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.13 18:12:51.454 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: AB 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:51.462 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2C74 d:FF r:FFD9     m:AB 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:51.592 4 : CUL_Parse: cul868 A 1A AC A010 20DFE1 1ACE1F 032E2890282422482A8A2A90229028902810 -66
2021.05.13 18:12:51.700 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2CFF d:FF r:FFCA     m:AC A010 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.13 18:12:51.703 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: AC A0 10 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.13 18:12:51.724 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: AC 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:51.730 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2D81 d:FF r:FFD9     m:AC 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:51.862 4 : CUL_Parse: cul868 A 1A AD A010 20DFE1 1ACE1F 033D90289028902890289028902890289010 -66
2021.05.13 18:12:51.970 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2E0E d:FF r:FFCA     m:AD A010 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.13 18:12:51.974 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: AD A0 10 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.13 18:12:51.994 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: AD 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:52.002 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2E91 d:FF r:FFDA     m:AD 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:52.132 4 : CUL_Parse: cul868 A 1A AE A010 20DFE1 1ACE1F 034C2890289028902890289028902890280F -66.5
2021.05.13 18:12:52.240 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F2F1C d:FF r:FFCA     m:AE A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.13 18:12:52.243 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: AE A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.13 18:12:52.264 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: AE 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:52.272 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F2F9F d:FF r:FFDA     m:AE 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:52.360 4 : CUL_Parse: cul868 A 14 7E A270 6869B6 1ACE1F 80B23A2ACB0001C30F08FC18 -62
2021.05.13 18:12:52.395 0 : HMLAN_Parse: hmlan1 R:E6869B6   stat:0000 t:5E3F3001 d:FF r:FFD8     m:7E A270 6869B6 1ACE1F 80B23A2ACB0001C30F08FC
2021.05.13 18:12:52.399 4 : CUL_Parse: cul868 A 11 AF A010 20DFE1 1ACE1F 035B9028902890280F -66.5
2021.05.13 18:12:52.506 0 : HMUARTLGW hmuart1 recv: 01 05 01 00 2F msg: 7E A2 70 6869B6 1ACE1F 80B23A2ACB0001C30F08FC
2021.05.13 18:12:52.509 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: AF A0 10 20DFE1 1ACE1F 035B902890289028
2021.05.13 18:12:52.513 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F3023 d:FF r:FFCA     m:AF A010 20DFE1 1ACE1F 035B902890289028
2021.05.13 18:12:52.516 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F3075 d:FF r:FFCF     m:7E 8002 1ACE1F 6869B6 00
2021.05.13 18:12:52.520 4 : CUL_Parse: cul868 A 0A 7E 8002 1ACE1F 6869B6 0067 -22.5
2021.05.13 18:12:52.530 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: AF 80 02 1ACE1F 20DFE1 00
2021.05.13 18:12:52.538 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F30A9 d:FF r:FFDA     m:AF 8002 1ACE1F 20DFE1 00
2021.05.13 18:12:52.655 4 : CUL_Parse: cul868 A 0B B0 8010 20DFE1 1ACE1F 03000F -66.5
2021.05.13 18:12:52.787 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F3129 d:FF r:FFCA     m:B0 8010 20DFE1 1ACE1F 0300
2021.05.13 18:12:52.791 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: B0 80 10 20DFE1 1ACE1F 0300
2021.05.13 18:12:52.794 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 0E msg: C0 A0 01 1ACE1F 20DFE1 0303
2021.05.13 18:12:52.799 0 : HMLAN_Parse: hmlan1 R:E1ACE1F   stat:0000 t:5E3F31AB d:FF r:FFD9     m:C0 A001 1ACE1F 20DFE1 0303
2021.05.13 18:12:52.914 4 : CUL_Parse: cul868 A 0E C0 8010 20DFE1 1ACE1F 01000000000F -66.5
2021.05.13 18:12:53.015 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:5E3F322C d:FF r:FFCB     m:C0 8010 20DFE1 1ACE1F 0100000000
2021.05.13 18:12:53.019 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: C0 80 10 20DFE1 1ACE1F 0100000000
gruss frank
FHEM: 6.0(SVN) => Pi3(buster)
noansi
Hallo Frank,
ich habe hier https://forum.fhem.de/index.php/topic,120268.msg1156463.html#msg1156463 nochmal aktualisiert.
Ich hoffe, das hilft auch noch bei dem fehlenden A112.
Gruß, Ansgar.
frank
hallo ansgar,
test mit version von heute nacht 2:41:
tc mit io=hmlan und attr autoreadReg=5_missing.
ein "normales" getconfig wird in allen situationen sauber abgearbeitet, auch keine dupe blockade mehr.
nächste probleme gibt es nun beim ändern von registern:
1. doppelte io präparation bei 8400 und 8670
2. das automatische getconfig kommt nur, wenn regset durch 8670 abgearbeitet wird.
also grundsätzlich nicht bei 8400.
3. wenn es nicht sofort kommt (8400), wird das io beim nächsten zyklus ausserdem zu spät präpariert, so dass ein 3. zyklus notwendig wird.
2021.05.15 11:14:24.203 3: CUL_HM set Thermostat.OZ regSet prep backlOnTime 0
2021.05.15 11:14:24.206 3: CUL_HM set Thermostat.OZ regSet exec backlOnMode off
2021.05.15 11:14:24.249 2: HMinfo hminfo get:configCheck :-f,^(Thermostat.OZ|Thermostat.OZ_Climate|Thermostat.OZ_Weather|Thermostat.OZ_WindowRec|Thermostat.OZ)$
2021.05.15 11:14:24.422 0: HMLAN_Send:  hmlan1 I:+20DFE1,02,00,00
2021.05.15 11:14:24.428 0: HMLAN_Send:  hmlan1 I:+20DFE1,02,00,00
2021.05.15 11:14:33.296 4: CUL_Parse: cul868 A 1A 32 8400 20DFE1 000000 2100394B4551303137363036325800FFFF10 -66
2021.05.15 11:14:33.300 0: HMLAN_Send:  hmlan1 I:+20DFE1,00,00,00
2021.05.15 11:14:33.398 0: HMLAN_Send:  hmlan1 S:S6F4E4F4F stat:  00 t:00000000 d:01 r:6F4E4F4F m:5A A001 1ACE1F 20DFE1 00050000000000
2021.05.15 11:14:34.251 0: HMUARTLGW hmuart1 recv: 01 05 00 00 39 msg: 32 84 00 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.15 11:14:34.255 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5A A0 01 1ACE1F 20DFE1 00050000000000
2021.05.15 11:14:34.258 4: CUL_Parse: cul868 A 10 5A A001 1ACE1F 20DFE1 000500000000003F -42.5
2021.05.15 11:14:34.262 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:670D3A4C d:FF r:FFCB     m:32 8400 20DFE1 000000 2100394B4551303137363036325800FFFF
2021.05.15 11:14:34.315 4: CUL_Parse: cul868 A 0A 5A 8002 20DFE1 1ACE1F 000E -67
2021.05.15 11:14:34.406 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: 5A 80 02 20DFE1 1ACE1F 00
2021.05.15 11:14:34.409 0: HMLAN_Parse: hmlan1 R:R6F4E4F4F stat:0001 t:670D3E4E d:FF r:FFCA     m:5A 8002 20DFE1 1ACE1F 00
2021.05.15 11:14:34.413 0: HMLAN_Send:  hmlan1 S:S6F4E53A5 stat:  00 t:00000000 d:01 r:6F4E53A5 m:5B A001 1ACE1F 20DFE1 00080500
2021.05.15 11:14:34.595 4: CUL_Parse: cul868 A 0D 5B A001 1ACE1F 20DFE1 0008050040 -42
2021.05.15 11:14:34.600 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5B A0 01 1ACE1F 20DFE1 00080500
2021.05.15 11:14:34.719 4: CUL_Parse: cul868 A 0A 5B 8002 20DFE1 1ACE1F 000D -67.5
2021.05.15 11:14:34.817 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: 5B 80 02 20DFE1 1ACE1F 00
2021.05.15 11:14:34.821 0: HMLAN_Parse: hmlan1 R:R6F4E53A5 stat:0001 t:670D3FE2 d:FF r:FFCA     m:5B 8002 20DFE1 1ACE1F 00
2021.05.15 11:14:34.824 0: HMLAN_Send:  hmlan1 S:S6F4E5540 stat:  00 t:00000000 d:01 r:6F4E5540 m:5C A001 1ACE1F 20DFE1 0006
2021.05.15 11:14:34.998 4: CUL_Parse: cul868 A 0B 5C A001 1ACE1F 20DFE1 00063F -42.5
2021.05.15 11:14:35.004 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5C A0 01 1ACE1F 20DFE1 0006
2021.05.15 11:14:35.123 4: CUL_Parse: cul868 A 0A 5C 8002 20DFE1 1ACE1F 000D -67.5
2021.05.15 11:14:35.221 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3B msg: 5C 80 02 20DFE1 1ACE1F 00
2021.05.15 11:14:35.224 0: HMLAN_Parse: hmlan1 R:R6F4E5540 stat:0001 t:670D4176 d:FF r:FFCB     m:5C 8002 20DFE1 1ACE1F 00
2021.05.15 11:15:24.438 2: HMinfo hminfo get:configCheck :-f,^(Thermostat.OZ|Thermostat.OZ_Climate|Thermostat.OZ_Weather|Thermostat.OZ_WindowRec|Thermostat.OZ)$
2021.05.15 11:17:13.085 4: CUL_Parse: cul868 A 0C 33 8670 20DFE1 000000 00C53D11 -65.5
2021.05.15 11:17:13.089 3: CUL_HM set Thermostat.OZ getConfig noArg
2021.05.15 11:17:13.091 0: HMLAN_Send:  hmlan1 I:+20DFE1,02,00,00
2021.05.15 11:17:13.187 0: HMLAN_Send:  hmlan1 S:S6F50BF7F stat:  00 t:00000000 d:01 r:6F50BF7F m:34 A001 1ACE1F 20DFE1 00040000000000
2021.05.15 11:17:13.310 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:670FAA8F d:FF r:FFCD     m:33 8670 20DFE1 000000 00C53D
2021.05.15 11:17:13.314 0: HMUARTLGW hmuart1 recv: 01 05 00 00 45 msg: 33 86 70 20DFE1 000000 00C53D
2021.05.15 11:17:13.318 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 34 A0 01 1ACE1F 20DFE1 00040000000000
2021.05.15 11:17:13.323 4: CUL_Parse: cul868 A 10 34 A001 1ACE1F 20DFE1 000400000000003F -42.5
2021.05.15 11:17:13.343 0: HMUARTLGW hmuart1 recv: 01 05 00 00 3A msg: 7C 86 70 1D252E 000000 00BE3D
2021.05.15 11:17:13.362 0: HMLAN_Parse: hmlan1 R:R6F50BF7F stat:0001 t:670FABA0 d:FF r:FFCC     m:34 8010 20DFE1 1ACE1F 020100020105000A1A0BCE0C1F0F000000
2021.05.15 11:17:13.458 0: HMLAN_Send:  hmlan1 S:S6F50C093 stat:  00 t:00000000 d:01 r:6F50C093 m:44 A001 1ACE1F 20DFE1 0103
2021.05.15 11:17:13.631 4: CUL_Parse: cul868 A 0B 44 A001 1ACE1F 20DFE1 01033F -42.5
2021.05.15 11:17:13.637 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 44 A0 01 1ACE1F 20DFE1 0103
2021.05.15 11:17:13.831 4: CUL_Parse: cul868 A 0B 44 A001 1ACE1F 20DFE1 01033F -42.5
2021.05.15 11:17:13.836 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 44 A0 01 1ACE1F 20DFE1 0103
2021.05.15 11:17:14.031 4: CUL_Parse: cul868 A 0B 44 A001 1ACE1F 20DFE1 01033F -42.5
2021.05.15 11:17:14.036 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 44 A0 01 1ACE1F 20DFE1 0103
2021.05.15 11:17:14.211 0: HMLAN_Parse: hmlan1 R:R6F50C093 stat:0008 t:00000000 d:FF r:7FFF     m:44 A001 1ACE1F 20DFE1 0103
2021.05.15 11:17:14.212 0: HMLAN_Parse: hmlan1 no ACK from 20DFE1
2021.05.15 11:17:16.946 4: CUL_Parse: cul868 A 0C EF 8670 206219 000000 008552ED -83.5
2021.05.15 11:17:17.106 0: HMUARTLGW hmuart1 recv: 01 05 00 00 4E msg: EF 86 70 206219 000000 008552
2021.05.15 11:17:17.111 0: HMLAN_Parse: hmlan1 R:E206219   stat:0000 t:670FB9A5 d:FF r:FFAE     m:EF 8670 206219 000000 008552
2021.05.15 11:17:18.149 0: HMLAN_Send:  hmlan1 I:+20DFE1,02,00,00
2021.05.15 11:19:37.590 4: CUL_Parse: cul868 A 0C 34 8670 20DFE1 000000 00C43C10 -66
2021.05.15 11:19:37.694 0: HMLAN_Send:  hmlan1 S:S6F52F3F9 stat:  00 t:00000000 d:01 r:6F52F3F9 m:35 A001 1ACE1F 20DFE1 0103
2021.05.15 11:19:37.888 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711DF1B d:FF r:FFCD     m:34 8670 20DFE1 000000 00C43C
2021.05.15 11:19:37.890 0: HMLAN_Parse: hmlan1 R:R6F50C093 stat:0081 t:6711E019 d:FF r:FFCD     m:34 8002 20DFE1 1ACE1F 00
2021.05.15 11:19:37.904 4: CUL_Parse: cul868 A 09 34 A112 1ACE1F 20DFE1 3F -42.5
2021.05.15 11:19:37.907 4: CUL_Parse: cul868 A 0A 34 8002 20DFE1 1ACE1F 0010 -66
2021.05.15 11:19:37.911 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 34 86 70 20DFE1 000000 00C43C
2021.05.15 11:19:37.917 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 34 A1 12 1ACE1F 20DFE1
2021.05.15 11:19:37.920 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 34 80 02 20DFE1 1ACE1F 00
2021.05.15 11:19:38.116 4: CUL_Parse: cul868 A 0B 35 A001 1ACE1F 20DFE1 01033F -42.5
2021.05.15 11:19:38.122 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 35 A0 01 1ACE1F 20DFE1 0103
2021.05.15 11:19:38.252 4: CUL_Parse: cul868 A 0E 35 8010 20DFE1 1ACE1F 010000000010 -66
2021.05.15 11:19:38.355 0: HMLAN_Send:  hmlan1 S:S6F52F691 stat:  00 t:00000000 d:01 r:6F52F691 m:45 A001 1ACE1F 20DFE1 0203
2021.05.15 11:19:38.365 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 35 80 10 20DFE1 1ACE1F 0100000000
2021.05.15 11:19:38.370 0: HMLAN_Parse: hmlan1 R:R6F52F3F9 stat:0001 t:6711E1B0 d:FF r:FFCD     m:35 8010 20DFE1 1ACE1F 0100000000
2021.05.15 11:19:38.523 4: CUL_Parse: cul868 A 0B 45 A001 1ACE1F 20DFE1 02033F -42.5
2021.05.15 11:19:38.530 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 45 A0 01 1ACE1F 20DFE1 0203
2021.05.15 11:19:38.652 4: CUL_Parse: cul868 A 0E 45 8010 20DFE1 1ACE1F 010000000010 -66
2021.05.15 11:19:38.754 0: HMLAN_Send:  hmlan1 S:S6F52F81B stat:  00 t:00000000 d:01 r:6F52F81B m:55 A001 1ACE1F 20DFE1 02040000000005
2021.05.15 11:19:38.762 0: HMLAN_Parse: hmlan1 R:R6F52F691 stat:0001 t:6711E346 d:FF r:FFCD     m:45 8010 20DFE1 1ACE1F 0100000000
2021.05.15 11:19:38.765 0: HMLAN_Parse: hmlan1 R:E266EA5   stat:0000 t:6711E389 d:FF r:FFC9     m:42 805E 266EA5 1ACE1F 0000000000000000000000
2021.05.15 11:19:38.772 4: CUL_Parse: cul868 A 14 42 805E 266EA5 1ACE1F 00000000000000000000001C -60
2021.05.15 11:19:38.776 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 45 80 10 20DFE1 1ACE1F 0100000000
2021.05.15 11:19:38.780 0: HMUARTLGW hmuart1 recv: 01 05 00 00 36 msg: 42 80 5E 266EA5 1ACE1F 0000000000000000000000
2021.05.15 11:19:38.856 0: HMLAN_Send:  hmlan1 I:K
2021.05.15 11:19:38.861 0: HMLAN_Parse: hmlan1 V:03C5 sNo:JEQ0315335 d:1C671E O:1ACE1F t:6711E413 IDcnt:0017 L:18 %
2021.05.15 11:19:38.934 4: CUL_Parse: cul868 A 10 55 A001 1ACE1F 20DFE1 020400000000053F -42.5
2021.05.15 11:19:38.940 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 55 A0 01 1ACE1F 20DFE1 02040000000005
2021.05.15 11:19:39.069 4: CUL_Parse: cul868 A 1A 55 A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A10 -66
2021.05.15 11:19:39.079 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711E4E1 d:FF r:FFCD     m:55 A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.15 11:19:39.084 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 55 A0 10 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.15 11:19:39.184 4: CUL_Parse: cul868 A 0A 55 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:39.190 0: HMLAN_Parse: hmlan1 R:R6F52F81B stat:0001 t:6711E4E6 d:FF r:FFCD     m:55 A010 20DFE1 1ACE1F 0301110C2A221828005800002422482A8A
2021.05.15 11:19:39.194 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 55 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:39.324 4: CUL_Parse: cul868 A 1A 56 A010 20DFE1 1ACE1F 03102A902290289028902890289028902810 -66
2021.05.15 11:19:39.334 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711E5E1 d:FF r:FFCD     m:56 A010 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.15 11:19:39.339 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 56 A0 10 20DFE1 1ACE1F 03102A9022902890289028902890289028
2021.05.15 11:19:39.435 4: CUL_Parse: cul868 A 0A 56 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:39.441 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 56 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:39.575 4: CUL_Parse: cul868 A 1A 57 A010 20DFE1 1ACE1F 031F90289028902890289028902890289010 -66
2021.05.15 11:19:39.584 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711E6DC d:FF r:FFCD     m:57 A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.15 11:19:39.588 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 57 A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.15 11:19:39.685 4: CUL_Parse: cul868 A 0A 57 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:39.690 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 57 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:39.827 4: CUL_Parse: cul868 A 1A 58 A010 20DFE1 1ACE1F 032E28902890289028902890289028242210 -66
2021.05.15 11:19:39.835 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711E7D7 d:FF r:FFCD     m:58 A010 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.15 11:19:39.839 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 58 A0 10 20DFE1 1ACE1F 032E289028902890289028902890282422
2021.05.15 11:19:39.937 4: CUL_Parse: cul868 A 0A 58 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:39.942 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 58 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:40.077 4: CUL_Parse: cul868 A 1A 59 A010 20DFE1 1ACE1F 033D482A8A2A902290289028902890289010 -66
2021.05.15 11:19:40.086 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711E8D2 d:FF r:FFCD     m:59 A010 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.15 11:19:40.089 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 59 A0 10 20DFE1 1ACE1F 033D482A8A2A9022902890289028902890
2021.05.15 11:19:40.187 4: CUL_Parse: cul868 A 0A 59 8002 1ACE1F 20DFE1 0040 -42
2021.05.15 11:19:40.192 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: 59 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:40.328 4: CUL_Parse: cul868 A 1A 5A A010 20DFE1 1ACE1F 034C28902890289028902890289028902810 -66
2021.05.15 11:19:40.337 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711E9CD d:FF r:FFCD     m:5A A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.15 11:19:40.341 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 5A A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.15 11:19:40.438 4: CUL_Parse: cul868 A 0A 5A 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:40.444 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5A 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:40.579 4: CUL_Parse: cul868 A 1A 5B A010 20DFE1 1ACE1F 035B90289028902890289028902890289010 -66
2021.05.15 11:19:40.587 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711EAC8 d:FF r:FFCD     m:5B A010 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.15 11:19:40.591 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 5B A0 10 20DFE1 1ACE1F 035B902890289028902890289028902890
2021.05.15 11:19:40.689 4: CUL_Parse: cul868 A 0A 5B 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:40.694 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5B 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:40.830 4: CUL_Parse: cul868 A 1A 5C A010 20DFE1 1ACE1F 036A282422482A8A2A902290289028902810 -66
2021.05.15 11:19:40.839 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711EBC2 d:FF r:FFCD     m:5C A010 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.15 11:19:40.842 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 5C A0 10 20DFE1 1ACE1F 036A282422482A8A2A9022902890289028
2021.05.15 11:19:40.939 4: CUL_Parse: cul868 A 0A 5C 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:40.944 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5C 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:41.080 4: CUL_Parse: cul868 A 1A 5D A010 20DFE1 1ACE1F 037990289028902890289028902890289010 -66
2021.05.15 11:19:41.089 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711ECBD d:FF r:FFCD     m:5D A010 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.15 11:19:41.093 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 5D A0 10 20DFE1 1ACE1F 0379902890289028902890289028902890
2021.05.15 11:19:41.190 4: CUL_Parse: cul868 A 0A 5D 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:41.196 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5D 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:41.333 4: CUL_Parse: cul868 A 1A 5E A010 20DFE1 1ACE1F 038828902890289028902890289028902811 -65.5
2021.05.15 11:19:41.351 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711EDB8 d:FF r:FFCD     m:5E A010 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.15 11:19:41.356 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 5E A0 10 20DFE1 1ACE1F 0388289028902890289028902890289028
2021.05.15 11:19:41.441 4: CUL_Parse: cul868 A 0A 5E 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:41.447 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5E 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:41.582 4: CUL_Parse: cul868 A 1A 5F A010 20DFE1 1ACE1F 0397902890282422482A8A2A902290289010 -66
2021.05.15 11:19:41.592 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711EEB3 d:FF r:FFCD     m:5F A010 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.15 11:19:41.596 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 5F A0 10 20DFE1 1ACE1F 0397902890282422482A8A2A9022902890
2021.05.15 11:19:41.692 4: CUL_Parse: cul868 A 0A 5F 8002 1ACE1F 20DFE1 0040 -42
2021.05.15 11:19:41.698 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 5F 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:41.834 4: CUL_Parse: cul868 A 1A 60 A010 20DFE1 1ACE1F 03A628902890289028902890289028902810 -66
2021.05.15 11:19:41.843 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711EFAE d:FF r:FFCD     m:60 A010 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.15 11:19:41.847 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 60 A0 10 20DFE1 1ACE1F 03A6289028902890289028902890289028
2021.05.15 11:19:41.944 4: CUL_Parse: cul868 A 0A 60 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:41.949 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 60 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:42.084 4: CUL_Parse: cul868 A 1A 61 A010 20DFE1 1ACE1F 03B590289028902890289028902890289010 -66
2021.05.15 11:19:42.093 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F0A9 d:FF r:FFCD     m:61 A010 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.15 11:19:42.097 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 61 A0 10 20DFE1 1ACE1F 03B5902890289028902890289028902890
2021.05.15 11:19:42.194 4: CUL_Parse: cul868 A 0A 61 8002 1ACE1F 20DFE1 0040 -42
2021.05.15 11:19:42.200 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 61 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:42.335 4: CUL_Parse: cul868 A 1A 62 A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A902210 -66
2021.05.15 11:19:42.344 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F1A4 d:FF r:FFCD     m:62 A010 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.15 11:19:42.348 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 62 A0 10 20DFE1 1ACE1F 03C4289028902890282422482A8A2A9022
2021.05.15 11:19:42.445 4: CUL_Parse: cul868 A 0A 62 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:42.451 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 62 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:42.586 4: CUL_Parse: cul868 A 1A 63 A010 20DFE1 1ACE1F 03D390289028902890289028902890289010 -66
2021.05.15 11:19:42.594 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F29F d:FF r:FFCD     m:63 A010 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.15 11:19:42.598 0: HMUARTLGW hmuart1 recv: 01 05 00 00 47 msg: 63 A0 10 20DFE1 1ACE1F 03D3902890289028902890289028902890
2021.05.15 11:19:42.696 4: CUL_Parse: cul868 A 0A 63 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:42.701 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 63 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:42.837 4: CUL_Parse: cul868 A 1A 64 A010 20DFE1 1ACE1F 03E228902890289028902890289028902810 -66
2021.05.15 11:19:42.846 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F39A d:FF r:FFCD     m:64 A010 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.15 11:19:42.850 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 64 A0 10 20DFE1 1ACE1F 03E2289028902890289028902890289028
2021.05.15 11:19:42.947 4: CUL_Parse: cul868 A 0A 64 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:42.953 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 64 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:43.084 4: CUL_Parse: cul868 A 15 65 A010 20DFE1 1ACE1F 03F19028902890289028902810 -66
2021.05.15 11:19:43.092 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F491 d:FF r:FFCD     m:65 A010 20DFE1 1ACE1F 03F190289028902890289028
2021.05.15 11:19:43.096 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 65 A0 10 20DFE1 1ACE1F 03F190289028902890289028
2021.05.15 11:19:43.197 4: CUL_Parse: cul868 A 0A 65 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:43.203 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 65 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:43.416 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F584 d:FF r:FFCD     m:66 8010 20DFE1 1ACE1F 0300
2021.05.15 11:19:43.428 0: HMLAN_Send:  hmlan1 S:S6F530ABC stat:  00 t:00000000 d:01 r:6F530ABC m:76 A001 1ACE1F 20DFE1 02040000000006
2021.05.15 11:19:43.456 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 66 80 10 20DFE1 1ACE1F 0300
2021.05.15 11:19:43.459 4: CUL_Parse: cul868 A 0B 66 8010 20DFE1 1ACE1F 03000F -66.5
2021.05.15 11:19:43.462 4: CUL_Parse: cul868 A 10 76 A001 1ACE1F 20DFE1 020400000000063F -42.5
2021.05.15 11:19:43.468 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 76 A0 01 1ACE1F 20DFE1 02040000000006
2021.05.15 11:19:43.594 4: CUL_Parse: cul868 A 1A 76 A010 20DFE1 1ACE1F 03012422482A8A2A90229028902890289010 -66
2021.05.15 11:19:43.604 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 76 A0 10 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.15 11:19:43.607 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F690 d:FF r:FFCD     m:76 A010 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.15 11:19:43.709 4: CUL_Parse: cul868 A 0A 76 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:43.714 0: HMLAN_Parse: hmlan1 R:R6F530ABC stat:0001 t:6711F695 d:FF r:FFCD     m:76 A010 20DFE1 1ACE1F 03012422482A8A2A902290289028902890
2021.05.15 11:19:43.718 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 76 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:43.851 4: CUL_Parse: cul868 A 1A 77 A010 20DFE1 1ACE1F 03102890289028902890289028902890280F -66.5
2021.05.15 11:19:43.859 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F790 d:FF r:FFCD     m:77 A010 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.15 11:19:43.863 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 77 A0 10 20DFE1 1ACE1F 0310289028902890289028902890289028
2021.05.15 11:19:43.961 4: CUL_Parse: cul868 A 0A 77 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:43.966 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 77 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:44.102 4: CUL_Parse: cul868 A 1A 78 A010 20DFE1 1ACE1F 031F90289028902890289028902890289010 -66
2021.05.15 11:19:44.111 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F88B d:FF r:FFCD     m:78 A010 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.15 11:19:44.114 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 78 A0 10 20DFE1 1ACE1F 031F902890289028902890289028902890
2021.05.15 11:19:44.212 4: CUL_Parse: cul868 A 0A 78 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:44.217 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2C msg: 78 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:44.353 4: CUL_Parse: cul868 A 1A 79 A010 20DFE1 1ACE1F 032E2890282422482A8A2A90229028902810 -66
2021.05.15 11:19:44.361 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711F986 d:FF r:FFCD     m:79 A010 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.15 11:19:44.365 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 79 A0 10 20DFE1 1ACE1F 032E2890282422482A8A2A902290289028
2021.05.15 11:19:44.462 4: CUL_Parse: cul868 A 0A 79 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:44.468 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 79 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:44.603 4: CUL_Parse: cul868 A 1A 7A A010 20DFE1 1ACE1F 033D90289028902890289028902890289010 -66
2021.05.15 11:19:44.611 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711FA80 d:FF r:FFCD     m:7A A010 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.15 11:19:44.615 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 7A A0 10 20DFE1 1ACE1F 033D902890289028902890289028902890
2021.05.15 11:19:44.713 4: CUL_Parse: cul868 A 0A 7A 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:44.718 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 7A 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:44.853 4: CUL_Parse: cul868 A 1A 7B A010 20DFE1 1ACE1F 034C28902890289028902890289028902810 -66
2021.05.15 11:19:44.861 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711FB7A d:FF r:FFCD     m:7B A010 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.15 11:19:44.865 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 7B A0 10 20DFE1 1ACE1F 034C289028902890289028902890289028
2021.05.15 11:19:44.963 4: CUL_Parse: cul868 A 0A 7B 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:44.968 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 7B 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:45.094 4: CUL_Parse: cul868 A 11 7C A010 20DFE1 1ACE1F 035B90289028902810 -66
2021.05.15 11:19:45.104 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 7C A0 10 20DFE1 1ACE1F 035B902890289028
2021.05.15 11:19:45.107 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711FC6D d:FF r:FFCD     m:7C A010 20DFE1 1ACE1F 035B902890289028
2021.05.15 11:19:45.213 4: CUL_Parse: cul868 A 0A 7C 8002 1ACE1F 20DFE1 003F -42.5
2021.05.15 11:19:45.219 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 7C 80 02 1ACE1F 20DFE1 00
2021.05.15 11:19:45.340 4: CUL_Parse: cul868 A 0B 7D 8010 20DFE1 1ACE1F 030011 -65.5
2021.05.15 11:19:45.441 0: HMLAN_Send:  hmlan1 S:S6F53123F stat:  00 t:00000000 d:01 r:6F53123F m:8D A001 1ACE1F 20DFE1 0303
2021.05.15 11:19:45.470 0: HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6711FD62 d:FF r:FFCD     m:7D 8010 20DFE1 1ACE1F 0300
2021.05.15 11:19:45.473 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 7D 80 10 20DFE1 1ACE1F 0300
2021.05.15 11:19:45.476 0: HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 8D A0 01 1ACE1F 20DFE1 0303
2021.05.15 11:19:45.480 4: CUL_Parse: cul868 A 0B 8D A001 1ACE1F 20DFE1 03033F -42.5
2021.05.15 11:19:45.596 4: CUL_Parse: cul868 A 0E 8D 8010 20DFE1 1ACE1F 010000000010 -66
2021.05.15 11:19:45.602 0: HMLAN_Send:  hmlan1 I:+20DFE1,00,00,00
2021.05.15 11:19:45.690 0: HMLAN_Parse: hmlan1 R:R6F53123F stat:0001 t:6711FE68 d:FF r:FFCD     m:8D 8010 20DFE1 1ACE1F 0100000000
2021.05.15 11:19:45.694 0: HMUARTLGW hmuart1 recv: 01 05 00 00 46 msg: 8D 80 10 20DFE1 1ACE1F 0100000000
wenn das getconfig sofort kommt, ist direkt zu beginn des 1. zyklus das set getconfig im log zu sehen:
2021.05.15 11:56:46.665 4 : CUL_Parse: cul868 A 0C 43 8670 20DFE1 000000 00C83C13 -64.5
2021.05.15 11:56:46.669 3 : CUL_HM set Thermostat.OZ getConfig noArg
2021.05.15 11:56:46.766 0 : HMLAN_Send:  hmlan1 S:S6F74F74B stat:  00 t:00000000 d:01 r:6F74F74B m:44 A001 1ACE1F 20DFE1 00050000000000
2021.05.15 11:56:46.865 0 : HMLAN_Parse: hmlan1 R:E20DFE1   stat:0000 t:6733E399 d:FF r:FFCC     m:43 8670 20DFE1 000000 00C83C
2021.05.15 11:56:46.868 4 : CUL_Parse: cul868 A 09 43 A112 1ACE1F 20DFE1 3F -42.5
2021.05.15 11:56:46.872 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 43 86 70 20DFE1 000000 00C83C
2021.05.15 11:56:46.875 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 43 A1 12 1ACE1F 20DFE1
2021.05.15 11:56:46.914 4 : CUL_Parse: cul868 A 0A 43 8002 20DFE1 1ACE1F 0012 -65
2021.05.15 11:56:46.919 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 41 msg: 43 80 02 20DFE1 1ACE1F 00
2021.05.15 11:56:46.923 0 : HMLAN_Parse: hmlan1 R:R6F53123F stat:0081 t:6733E497 d:FF r:FFCC     m:43 8002 20DFE1 1ACE1F 00
2021.05.15 11:56:47.196 4 : CUL_Parse: cul868 A 10 44 A001 1ACE1F 20DFE1 0005000000000040 -42
2021.05.15 11:56:47.201 0 : HMUARTLGW hmuart1 recv: 01 05 00 00 2D msg: 44 A0 01 1ACE1F 20DFE1 00050000000000
2021.05.15 11:56:47.318 4 : CUL_Parse: cul868 A 0A 44 8002 20DFE1 1ACE1F 0013 -64.5
Zitatsind Dir Readings dazu bei crashes kaputt gegangen?
Wo besteht der Zusammenhang mit cfgstate triggern?
im habe noch keinen plan, aber an fehlenden readings liegt es scheinbar nicht.
edit: du bist erstmal raus, da es in der offiziellen cul_hm 24374 auch nicht funktioniert.  ;)
gruss frank
noansi
Hallo Frank,
Zitattest mit version von heute nacht 2:41:
Ach deswegen war es dunkel.  8)
Zitatnächste probleme gibt es nun beim ändern von registern:
Neu oder alt von Deiner Pinwand?
1. vermutlich neu, aber wenn ich das ändere, dann klappt eine neuerliche Präparation bei Protokolltimeout vermutlich nicht mehr. Fällt erst mal unter später vielleicht, da es erst mal nicht weh tut.
2. wohl auch neu, weil die vorherige Korrektur bezüglich immer wieder neues getConfig an der Stelle es nun verhindert bzw. nicht mehr generell auslöst.
Zitatedit: du bist erstmal raus, da es in der offiziellen cul_hm 24374 auch nicht funktioniert.   :)
Puhh, Glück gehabt. Die Baustellen reichen auch erst mal wieder.  ;)
Gruß, Ansgar.
noansi
Hallo Frank,
zu 2. habe ich hier nochmal aktualisiert https://forum.fhem.de/index.php/topic,120268.msg1156527.html#msg1156527.
Ich denke und hoffe, es war nur ein Überbleibsel, was jetzt nicht mehr nötig ist.
Das getConfig war nicht weg, sondern nach dem Register Schreiben hätte nur nochmal Knöpfchen gedrückt werden müssen.
Gruß, Ansgar.
noansi
Hallo Frank,
zu 3. noch eine Schwäche. Wenn das Protokoll durch ist (Stack weg und done/error), wird nicht geprüft, ob noch was in den Request Queues hängt, was eine neue Vorbereitung auslösen sollte. Mal sehen.
Gruß, Ansgar.
noansi
noansi
Hallo Frank,
an 1. werde ich nichts ändern. Kommt wohl, weil erst schon das Register Schreiben auf den Stack geschoben wird und dann noch ein configRequest in die Warteschlange gepackt wird.
Wenn HMLAN oder HMUARTLGW vorbereitet werden, dann bekommt CUL_HM nicht direkt mit, ob es angewendet wurde und damit von den IOs automatisch zurück gesetzt wurde.
D.h. bei einem Fehler in der Stackabarbeitung muss es erneut gesetzt werden, um wieder zu wirken.
Das jetzt einzusammeln, woraus sich denn schließen ließe, dass das IO es wieder zurück gesetzt hat, um die Dopplung korrekt zu vermeiden, ist mir den Aufwand und mögliche Fehlerträchtigkeit nicht wert.
Besser es ist auf wakeup vorbereitet und wenn's doppelt gemoppelt ist.
Gruß, Ansgar.
