Autor Thema: ModbusAttr : Es werden nicht alle Readings aktualisiert  (Gelesen 1251 mal)
Offline m-d-ley
  • New Member
ich habe das Problem, dass bei meinem Modbus-Gateway nicht alle Readings im Intervall aktualisiert werden.
Händisch kann ich diese aber problemlos abfragen. Was könnte das sein?
Das Define:
defmod M_Bus_Gateway_W122_01 ModbusAttr 2 60 172.21.96.50:502 TCP
attr M_Bus_Gateway_W122_01 DbLogExclude state
attr M_Bus_Gateway_W122_01 dev-h-allowShortResponses 1
attr M_Bus_Gateway_W122_01 dev-h-combine 200
attr M_Bus_Gateway_W122_01 dev-h-defPoll 1
attr M_Bus_Gateway_W122_01 dev-timing-commDelay 1
attr M_Bus_Gateway_W122_01 dev-type-FP-format %.3f
attr M_Bus_Gateway_W122_01 dev-type-FP-len 2
attr M_Bus_Gateway_W122_01 dev-type-FP-unpack f>
attr M_Bus_Gateway_W122_01 dev-type-SI-len 16
attr M_Bus_Gateway_W122_01 dev-type-SI-unpack q>
attr M_Bus_Gateway_W122_01 disable 0
attr M_Bus_Gateway_W122_01 event-min-interval .*:60
attr M_Bus_Gateway_W122_01 event-on-change-reading .*
attr M_Bus_Gateway_W122_01 obj-h1040-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h1040-reading usage-UV08
attr M_Bus_Gateway_W122_01 obj-h1040-showGet usage-UV08
attr M_Bus_Gateway_W122_01 obj-h1040-type SI
attr M_Bus_Gateway_W122_01 obj-h110-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h110-reading current-UV01-1
attr M_Bus_Gateway_W122_01 obj-h110-showGet current-UV01-1
attr M_Bus_Gateway_W122_01 obj-h110-type SI
attr M_Bus_Gateway_W122_01 obj-h1230-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h1230-reading current-UV08-1
attr M_Bus_Gateway_W122_01 obj-h1230-showGet current-UV08-1
attr M_Bus_Gateway_W122_01 obj-h1230-type SI
attr M_Bus_Gateway_W122_01 obj-h1240-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h1240-reading current-UV08-2
attr M_Bus_Gateway_W122_01 obj-h1240-showGet current-UV08-2
attr M_Bus_Gateway_W122_01 obj-h1240-type SI
attr M_Bus_Gateway_W122_01 obj-h1250-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h1250-reading current-UV08-3
attr M_Bus_Gateway_W122_01 obj-h1250-showGet current-UV08-3
attr M_Bus_Gateway_W122_01 obj-h1250-type SI
attr M_Bus_Gateway_W122_01 obj-h1330-expr $val*100
attr M_Bus_Gateway_W122_01 obj-h1330-reading usage-UV09
attr M_Bus_Gateway_W122_01 obj-h1330-showGet usage-UV09
attr M_Bus_Gateway_W122_01 obj-h1330-type SI
attr M_Bus_Gateway_W122_01 obj-h1370-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h1370-reading current-UV09-1
attr M_Bus_Gateway_W122_01 obj-h1370-showGet current-UV09-1
attr M_Bus_Gateway_W122_01 obj-h1370-type SI
attr M_Bus_Gateway_W122_01 obj-h1410-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h1410-reading current-UV09-2
attr M_Bus_Gateway_W122_01 obj-h1410-showGet current-UV09-2
attr M_Bus_Gateway_W122_01 obj-h1410-type SI
attr M_Bus_Gateway_W122_01 obj-h1450-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h1450-reading current-UV09-3
attr M_Bus_Gateway_W122_01 obj-h1450-showGet current-UV09-3
attr M_Bus_Gateway_W122_01 obj-h1450-type SI
attr M_Bus_Gateway_W122_01 obj-h150-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h150-reading current-UV01-2
attr M_Bus_Gateway_W122_01 obj-h150-showGet current-UV01-2
attr M_Bus_Gateway_W122_01 obj-h150-type SI
attr M_Bus_Gateway_W122_01 obj-h1530-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h1530-reading usage-UV10-11
attr M_Bus_Gateway_W122_01 obj-h1530-showGet usage-UV10-11
attr M_Bus_Gateway_W122_01 obj-h1530-type SI
attr M_Bus_Gateway_W122_01 obj-h1720-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h1720-reading current-UV10-11-1
attr M_Bus_Gateway_W122_01 obj-h1720-showGet current-UV10-11-1
attr M_Bus_Gateway_W122_01 obj-h1720-type SI
attr M_Bus_Gateway_W122_01 obj-h1730-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h1730-reading current-UV10-11-2
attr M_Bus_Gateway_W122_01 obj-h1730-showGet current-UV10-11-2
attr M_Bus_Gateway_W122_01 obj-h1730-type SI
attr M_Bus_Gateway_W122_01 obj-h1740-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h1740-reading current-UV10-11-3
attr M_Bus_Gateway_W122_01 obj-h1740-showGet current-UV10-11-3
attr M_Bus_Gateway_W122_01 obj-h1740-type SI
attr M_Bus_Gateway_W122_01 obj-h1810-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h1810-reading usage-UV17
attr M_Bus_Gateway_W122_01 obj-h1810-showGet usage-UV17
attr M_Bus_Gateway_W122_01 obj-h1810-type SI
attr M_Bus_Gateway_W122_01 obj-h190-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h190-reading current-UV01-3
attr M_Bus_Gateway_W122_01 obj-h190-showGet current-UV01-3
attr M_Bus_Gateway_W122_01 obj-h190-type SI
attr M_Bus_Gateway_W122_01 obj-h2000-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2000-reading current-UV17-1
attr M_Bus_Gateway_W122_01 obj-h2000-showGet current-UV17-1
attr M_Bus_Gateway_W122_01 obj-h2000-type SI
attr M_Bus_Gateway_W122_01 obj-h2010-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2010-reading current-UV17-2
attr M_Bus_Gateway_W122_01 obj-h2010-showGet current-UV17-2
attr M_Bus_Gateway_W122_01 obj-h2010-type SI
attr M_Bus_Gateway_W122_01 obj-h2020-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2020-reading current-UV17-3
attr M_Bus_Gateway_W122_01 obj-h2020-showGet current-UV17-3
attr M_Bus_Gateway_W122_01 obj-h2020-type SI
attr M_Bus_Gateway_W122_01 obj-h2090-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h2090-reading usage-UV18
attr M_Bus_Gateway_W122_01 obj-h2090-showGet usage-UV18
attr M_Bus_Gateway_W122_01 obj-h2090-type SI
attr M_Bus_Gateway_W122_01 obj-h2280-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2280-reading current-UV18-1
attr M_Bus_Gateway_W122_01 obj-h2280-showGet current-UV18-1
attr M_Bus_Gateway_W122_01 obj-h2280-type SI
attr M_Bus_Gateway_W122_01 obj-h2290-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2290-reading current-UV18-2
attr M_Bus_Gateway_W122_01 obj-h2290-showGet current-UV18-2
attr M_Bus_Gateway_W122_01 obj-h2290-type SI
attr M_Bus_Gateway_W122_01 obj-h2300-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2300-reading current-UV18-3
attr M_Bus_Gateway_W122_01 obj-h2300-showGet current-UV18-3
attr M_Bus_Gateway_W122_01 obj-h2300-type SI
attr M_Bus_Gateway_W122_01 obj-h2370-expr $val*10
attr M_Bus_Gateway_W122_01 obj-h2370-reading usage-UV19
attr M_Bus_Gateway_W122_01 obj-h2370-showGet usage-UV19
attr M_Bus_Gateway_W122_01 obj-h2370-type SI
attr M_Bus_Gateway_W122_01 obj-h2420-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h2420-reading current-UV19-1
attr M_Bus_Gateway_W122_01 obj-h2420-showGet current-UV19-1
attr M_Bus_Gateway_W122_01 obj-h2420-type SI
attr M_Bus_Gateway_W122_01 obj-h2460-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h2460-reading current-UV19-2
attr M_Bus_Gateway_W122_01 obj-h2460-showGet current-UV19-2
attr M_Bus_Gateway_W122_01 obj-h2460-type SI
attr M_Bus_Gateway_W122_01 obj-h2500-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h2500-reading current-UV19-3
attr M_Bus_Gateway_W122_01 obj-h2500-showGet current-UV19-3
attr M_Bus_Gateway_W122_01 obj-h2500-type SI
attr M_Bus_Gateway_W122_01 obj-h2580-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h2580-reading usage-UV20
attr M_Bus_Gateway_W122_01 obj-h2580-showGet usage-UV20
attr M_Bus_Gateway_W122_01 obj-h2580-type SI
attr M_Bus_Gateway_W122_01 obj-h270-expr $val*10
attr M_Bus_Gateway_W122_01 obj-h270-reading usage-UV02
attr M_Bus_Gateway_W122_01 obj-h270-showGet usage-UV02
attr M_Bus_Gateway_W122_01 obj-h270-type SI
attr M_Bus_Gateway_W122_01 obj-h2770-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2770-reading current-UV20-1
attr M_Bus_Gateway_W122_01 obj-h2770-showGet current-UV20-1
attr M_Bus_Gateway_W122_01 obj-h2770-type SI
attr M_Bus_Gateway_W122_01 obj-h2780-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2780-reading current-UV20-2
attr M_Bus_Gateway_W122_01 obj-h2780-showGet current-UV20-2
attr M_Bus_Gateway_W122_01 obj-h2780-type SI
attr M_Bus_Gateway_W122_01 obj-h2790-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h2790-reading current-UV20-3
attr M_Bus_Gateway_W122_01 obj-h2790-showGet current-UV20-3
attr M_Bus_Gateway_W122_01 obj-h2790-type SI
attr M_Bus_Gateway_W122_01 obj-h2860-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h2860-reading usage-UV23
attr M_Bus_Gateway_W122_01 obj-h2860-showGet usage-UV23
attr M_Bus_Gateway_W122_01 obj-h2860-type SI
attr M_Bus_Gateway_W122_01 obj-h3050-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3050-reading current-UV23-1
attr M_Bus_Gateway_W122_01 obj-h3050-showGet current-UV23-1
attr M_Bus_Gateway_W122_01 obj-h3050-type SI
attr M_Bus_Gateway_W122_01 obj-h3060-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3060-reading current-UV23-2
attr M_Bus_Gateway_W122_01 obj-h3060-showGet current-UV23-2
attr M_Bus_Gateway_W122_01 obj-h3060-type SI
attr M_Bus_Gateway_W122_01 obj-h3070-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3070-reading current-UV23-3
attr M_Bus_Gateway_W122_01 obj-h3070-showGet current-UV23-3
attr M_Bus_Gateway_W122_01 obj-h3070-type SI
attr M_Bus_Gateway_W122_01 obj-h3140-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h3140-reading usage-UV24
attr M_Bus_Gateway_W122_01 obj-h3140-showGet usage-UV24
attr M_Bus_Gateway_W122_01 obj-h3140-type SI
attr M_Bus_Gateway_W122_01 obj-h320-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h320-reading current-UV02-1
attr M_Bus_Gateway_W122_01 obj-h320-showGet current-UV02-1
attr M_Bus_Gateway_W122_01 obj-h320-type SI
attr M_Bus_Gateway_W122_01 obj-h3330-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3330-reading current-UV24-1
attr M_Bus_Gateway_W122_01 obj-h3330-showGet current-UV24-1
attr M_Bus_Gateway_W122_01 obj-h3330-type SI
attr M_Bus_Gateway_W122_01 obj-h3340-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3340-reading current-UV24-2
attr M_Bus_Gateway_W122_01 obj-h3340-showGet current-UV24-2
attr M_Bus_Gateway_W122_01 obj-h3340-type SI
attr M_Bus_Gateway_W122_01 obj-h3350-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3350-reading current-UV24-3
attr M_Bus_Gateway_W122_01 obj-h3350-showGet current-UV24-3
attr M_Bus_Gateway_W122_01 obj-h3350-type SI
attr M_Bus_Gateway_W122_01 obj-h3420-expr $val*10
attr M_Bus_Gateway_W122_01 obj-h3420-reading usage-UV25
attr M_Bus_Gateway_W122_01 obj-h3420-showGet usage-UV25
attr M_Bus_Gateway_W122_01 obj-h3420-type SI
attr M_Bus_Gateway_W122_01 obj-h3470-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h3470-reading current-UV25-1
attr M_Bus_Gateway_W122_01 obj-h3470-showGet current-UV25-1
attr M_Bus_Gateway_W122_01 obj-h3510-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h3510-reading current-UV25-2
attr M_Bus_Gateway_W122_01 obj-h3510-showGet current-UV25-2
attr M_Bus_Gateway_W122_01 obj-h3510-type SI
attr M_Bus_Gateway_W122_01 obj-h3550-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h3550-reading current-UV25-3
attr M_Bus_Gateway_W122_01 obj-h3550-showGet current-UV25-3
attr M_Bus_Gateway_W122_01 obj-h3550-type SI
attr M_Bus_Gateway_W122_01 obj-h360-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h360-reading current-UV02-2
attr M_Bus_Gateway_W122_01 obj-h360-showGet current-UV02-2
attr M_Bus_Gateway_W122_01 obj-h360-type SI
attr M_Bus_Gateway_W122_01 obj-h3630-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h3630-reading usage-UV28
attr M_Bus_Gateway_W122_01 obj-h3630-showGet usage-UV28
attr M_Bus_Gateway_W122_01 obj-h3630-type SI
attr M_Bus_Gateway_W122_01 obj-h3710-type SI
attr M_Bus_Gateway_W122_01 obj-h3820-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3820-reading current-UV28-1
attr M_Bus_Gateway_W122_01 obj-h3820-showGet current-UV28-1
attr M_Bus_Gateway_W122_01 obj-h3820-type SI
attr M_Bus_Gateway_W122_01 obj-h3830-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3830-reading current-UV28-2
attr M_Bus_Gateway_W122_01 obj-h3830-showGet current-UV28-2
attr M_Bus_Gateway_W122_01 obj-h3830-type SI
attr M_Bus_Gateway_W122_01 obj-h3840-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h3840-reading current-UV28-3
attr M_Bus_Gateway_W122_01 obj-h3840-showGet current-UV28-3
attr M_Bus_Gateway_W122_01 obj-h3840-type SI
attr M_Bus_Gateway_W122_01 obj-h3910-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h3910-reading usage-UV29
attr M_Bus_Gateway_W122_01 obj-h3910-showGet usage-UV29
attr M_Bus_Gateway_W122_01 obj-h3910-type SI
attr M_Bus_Gateway_W122_01 obj-h400-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h400-reading current-UV02-3
attr M_Bus_Gateway_W122_01 obj-h400-showGet current-UV02-3
attr M_Bus_Gateway_W122_01 obj-h400-type SI
attr M_Bus_Gateway_W122_01 obj-h4100-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4100-reading current-UV29-1
attr M_Bus_Gateway_W122_01 obj-h4100-showGet current-UV29-1
attr M_Bus_Gateway_W122_01 obj-h4100-type SI
attr M_Bus_Gateway_W122_01 obj-h4110-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4110-reading current-UV29-2
attr M_Bus_Gateway_W122_01 obj-h4110-showGet current-UV29-2
attr M_Bus_Gateway_W122_01 obj-h4110-type SI
attr M_Bus_Gateway_W122_01 obj-h4120-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4120-reading current-UV29-3
attr M_Bus_Gateway_W122_01 obj-h4120-showGet current-UV29-3
attr M_Bus_Gateway_W122_01 obj-h4120-type SI
attr M_Bus_Gateway_W122_01 obj-h4190-expr $val*100
attr M_Bus_Gateway_W122_01 obj-h4190-reading usage-UV31
attr M_Bus_Gateway_W122_01 obj-h4190-showGet usage-UV31
attr M_Bus_Gateway_W122_01 obj-h4190-type SI
attr M_Bus_Gateway_W122_01 obj-h4240-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h4240-reading current-UV31-1
attr M_Bus_Gateway_W122_01 obj-h4240-showGet current-UV31-1
attr M_Bus_Gateway_W122_01 obj-h4240-type SI
attr M_Bus_Gateway_W122_01 obj-h4280-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h4280-reading current-UV31-2
attr M_Bus_Gateway_W122_01 obj-h4280-showGet current-UV31-2
attr M_Bus_Gateway_W122_01 obj-h4280-type SI
attr M_Bus_Gateway_W122_01 obj-h4320-expr $val/1
attr M_Bus_Gateway_W122_01 obj-h4320-reading current-UV31-3
attr M_Bus_Gateway_W122_01 obj-h4320-showGet current-UV31-3
attr M_Bus_Gateway_W122_01 obj-h4320-type SI
attr M_Bus_Gateway_W122_01 obj-h4400-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h4400-reading usage-UV32
attr M_Bus_Gateway_W122_01 obj-h4400-showGet usage-UV32
attr M_Bus_Gateway_W122_01 obj-h4400-type SI
attr M_Bus_Gateway_W122_01 obj-h4590-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4590-reading current-UV32-1
attr M_Bus_Gateway_W122_01 obj-h4590-showGet current-UV32-1
attr M_Bus_Gateway_W122_01 obj-h4590-type SI
attr M_Bus_Gateway_W122_01 obj-h4600-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4600-reading current-UV32-2
attr M_Bus_Gateway_W122_01 obj-h4600-showGet current-UV32-2
attr M_Bus_Gateway_W122_01 obj-h4600-type SI
attr M_Bus_Gateway_W122_01 obj-h4610-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4610-reading current-UV32-3
attr M_Bus_Gateway_W122_01 obj-h4610-showGet current-UV32-3
attr M_Bus_Gateway_W122_01 obj-h4610-type SI
attr M_Bus_Gateway_W122_01 obj-h4680-reading usage-NSHV
attr M_Bus_Gateway_W122_01 obj-h4680-showGet usage-NSHV
attr M_Bus_Gateway_W122_01 obj-h4680-type SI
attr M_Bus_Gateway_W122_01 obj-h480-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h480-reading usage-UV05
attr M_Bus_Gateway_W122_01 obj-h480-showGet usage-UV05
attr M_Bus_Gateway_W122_01 obj-h480-type SI
attr M_Bus_Gateway_W122_01 obj-h4870-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4870-reading current-NSHV-1
attr M_Bus_Gateway_W122_01 obj-h4870-showGet current-NHSV-1
attr M_Bus_Gateway_W122_01 obj-h4870-type SI
attr M_Bus_Gateway_W122_01 obj-h4880-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4880-reading current-NSHV-2
attr M_Bus_Gateway_W122_01 obj-h4880-showGet current-NSHV-2
attr M_Bus_Gateway_W122_01 obj-h4880-type SI
attr M_Bus_Gateway_W122_01 obj-h4890-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h4890-reading current-NSHV-3
attr M_Bus_Gateway_W122_01 obj-h4890-showGet current-NSHV-3
attr M_Bus_Gateway_W122_01 obj-h4890-type SI
attr M_Bus_Gateway_W122_01 obj-h4960-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h4960-reading usage-UV18.1
attr M_Bus_Gateway_W122_01 obj-h4960-showGet usage-UV18.1
attr M_Bus_Gateway_W122_01 obj-h4960-type SI
attr M_Bus_Gateway_W122_01 obj-h4980-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h4980-reading usage-backward-UV18.1
attr M_Bus_Gateway_W122_01 obj-h4980-showGet usage-backward-UV18.1
attr M_Bus_Gateway_W122_01 obj-h4980-type SI
attr M_Bus_Gateway_W122_01 obj-h5120-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h5120-reading current-UV18.1-1
attr M_Bus_Gateway_W122_01 obj-h5120-showGet current-UV18.1-1
attr M_Bus_Gateway_W122_01 obj-h5120-type SI
attr M_Bus_Gateway_W122_01 obj-h5130-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h5130-reading current-UV18.1-2
attr M_Bus_Gateway_W122_01 obj-h5130-showGet current-UV18.1-2
attr M_Bus_Gateway_W122_01 obj-h5130-type SI
attr M_Bus_Gateway_W122_01 obj-h5140-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h5140-reading current-UV18.1-3
attr M_Bus_Gateway_W122_01 obj-h5140-showGet current-UV18.1-3
attr M_Bus_Gateway_W122_01 obj-h5140-type SI
attr M_Bus_Gateway_W122_01 obj-h5230-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h5230-reading usage-UV18.2
attr M_Bus_Gateway_W122_01 obj-h5230-showGet usage-UV18.2
attr M_Bus_Gateway_W122_01 obj-h5230-type SI
attr M_Bus_Gateway_W122_01 obj-h5250-expr $val/10
attr M_Bus_Gateway_W122_01 obj-h5250-reading usage-backward-UV18.2
attr M_Bus_Gateway_W122_01 obj-h5250-showGet usage-backward-UV18.2
attr M_Bus_Gateway_W122_01 obj-h5250-type SI
attr M_Bus_Gateway_W122_01 obj-h5390-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h5390-reading current-UV18.2-1
attr M_Bus_Gateway_W122_01 obj-h5390-showGet current-UV18.2-1
attr M_Bus_Gateway_W122_01 obj-h5390-type SI
attr M_Bus_Gateway_W122_01 obj-h5400-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h5400-reading current-UV18.2-2
attr M_Bus_Gateway_W122_01 obj-h5400-showGet current-UV18.2-2
attr M_Bus_Gateway_W122_01 obj-h5400-type SI
attr M_Bus_Gateway_W122_01 obj-h5410-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h5410-reading current-UV18.2-3
attr M_Bus_Gateway_W122_01 obj-h5410-showGet current-UV18.2-3
attr M_Bus_Gateway_W122_01 obj-h5410-type SI
attr M_Bus_Gateway_W122_01 obj-h60-expr $val*100
attr M_Bus_Gateway_W122_01 obj-h60-reading usage-UV01
attr M_Bus_Gateway_W122_01 obj-h60-showGet usage-UV01
attr M_Bus_Gateway_W122_01 obj-h60-type SI
attr M_Bus_Gateway_W122_01 obj-h670-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h670-reading current-UV05-1
attr M_Bus_Gateway_W122_01 obj-h670-showGet current-UV05-1
attr M_Bus_Gateway_W122_01 obj-h670-type SI
attr M_Bus_Gateway_W122_01 obj-h680-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h680-reading current-UV05-2
attr M_Bus_Gateway_W122_01 obj-h680-showGet current-UV05-2
attr M_Bus_Gateway_W122_01 obj-h680-type SI
attr M_Bus_Gateway_W122_01 obj-h690-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h690-reading current-UV05-3
attr M_Bus_Gateway_W122_01 obj-h690-showGet current-UV05-3
attr M_Bus_Gateway_W122_01 obj-h690-type SI
attr M_Bus_Gateway_W122_01 obj-h760-expr $val*1
attr M_Bus_Gateway_W122_01 obj-h760-reading usage-UV07
attr M_Bus_Gateway_W122_01 obj-h760-showGet usage-UV07
attr M_Bus_Gateway_W122_01 obj-h760-type SI
attr M_Bus_Gateway_W122_01 obj-h950-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h950-reading current-UV07-1
attr M_Bus_Gateway_W122_01 obj-h950-showGet current-UV07-1
attr M_Bus_Gateway_W122_01 obj-h950-type SI
attr M_Bus_Gateway_W122_01 obj-h960-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h960-reading current-UV07-2
attr M_Bus_Gateway_W122_01 obj-h960-showGet current-UV07-2
attr M_Bus_Gateway_W122_01 obj-h960-type SI
attr M_Bus_Gateway_W122_01 obj-h970-expr $val/1000
attr M_Bus_Gateway_W122_01 obj-h970-reading current-UV07-3
attr M_Bus_Gateway_W122_01 obj-h970-showGet current-UV07-3
attr M_Bus_Gateway_W122_01 obj-h970-type SI
attr M_Bus_Gateway_W122_01 room Modbus
setstate M_Bus_Gateway_W122_01 active
setstate M_Bus_Gateway_W122_01 2021-06-30 13:00:58 current-NSHV-1 405.181
setstate M_Bus_Gateway_W122_01 2021-06-30 12:02:44 current-NSHV-2 451.417
setstate M_Bus_Gateway_W122_01 2021-06-30 12:14:52 current-NSHV-3 499.342
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:47 current-UV01-1 12
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:48 current-UV01-2 5
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:48 current-UV01-3 5
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:49 current-UV02-1 12.5
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:50 current-UV02-2 18.1
setstate M_Bus_Gateway_W122_01 2021-06-30 13:01:01 current-UV02-3 28.8
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:35 current-UV05-1 0.145
setstate M_Bus_Gateway_W122_01 2021-06-30 12:02:15 current-UV05-2 7.115
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:35 current-UV05-3 4.031
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:36 current-UV07-1 27.977
setstate M_Bus_Gateway_W122_01 2021-06-30 12:02:19 current-UV07-2 38.073
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:36 current-UV07-3 27.24
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:54 current-UV08-1 11.933
setstate M_Bus_Gateway_W122_01 2021-06-30 12:02:24 current-UV08-2 13.135
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:54 current-UV08-3 12.185
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:30 current-UV09-1 116
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:30 current-UV09-2 119
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:38 current-UV09-3 129
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:39 current-UV10-11-1 17.122
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:55 current-UV10-11-2 9.195
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:39 current-UV10-11-3 13.661
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:40 current-UV17-1 5.119
setstate M_Bus_Gateway_W122_01 2021-06-30 12:15:55 current-UV17-2 4.505
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:40 current-UV17-3 4.531
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:56 current-UV18-1 5.992
setstate M_Bus_Gateway_W122_01 2021-06-30 12:15:13 current-UV18-2 1.798
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:56 current-UV18-3 0.283
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:46 current-UV18.1-1 16.627
setstate M_Bus_Gateway_W122_01 2021-06-30 12:16:18 current-UV18.1-2 0.024
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:46 current-UV18.1-3 15.574
setstate M_Bus_Gateway_W122_01 2021-06-30 12:21:52 current-UV18.2-1 0.019
setstate M_Bus_Gateway_W122_01 2021-06-30 12:16:23 current-UV18.2-2 0.023
setstate M_Bus_Gateway_W122_01 2021-06-30 12:21:52 current-UV18.2-3 0.02
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:37 current-UV19-1 7.5
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:38 current-UV19-2 6.8
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:42 current-UV19-3 8.6
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:43 current-UV20-1 3.16
setstate M_Bus_Gateway_W122_01 2021-06-30 12:15:42 current-UV20-2 5.95
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:43 current-UV20-3 0.003
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:44 current-UV23-1 9.763
setstate M_Bus_Gateway_W122_01 2021-06-30 12:15:28 current-UV23-2 4.536
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:44 current-UV23-3 4.807
setstate M_Bus_Gateway_W122_01 2021-06-30 12:16:29 current-UV24-1 4.112
setstate M_Bus_Gateway_W122_01 2021-06-30 12:02:36 current-UV24-2 4.004
setstate M_Bus_Gateway_W122_01 2021-06-30 12:16:47 current-UV24-3 7.278
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:59 current-UV25-1 0
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:42 current-UV25-2 8.9
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:46 current-UV25-3 90
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:47 current-UV28-1 58.844
setstate M_Bus_Gateway_W122_01 2021-06-30 12:16:53 current-UV28-2 95.492
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:47 current-UV28-3 63.344
setstate M_Bus_Gateway_W122_01 2021-06-30 12:17:29 current-UV29-1 62.29
setstate M_Bus_Gateway_W122_01 2021-06-30 12:02:40 current-UV29-2 73.399
setstate M_Bus_Gateway_W122_01 2021-06-30 12:17:35 current-UV29-3 65.162
setstate M_Bus_Gateway_W122_01 2021-06-30 12:05:01 current-UV31-1 6
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:44 current-UV31-2 4
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:49 current-UV31-3 0
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:50 current-UV32-1 1.051
setstate M_Bus_Gateway_W122_01 2021-06-30 12:17:46 current-UV32-2 0.733
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:50 current-UV32-3 0.921
setstate M_Bus_Gateway_W122_01 2021-06-30 12:39:56 state active
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:50 usage-NSHV 3969046366
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:47 usage-UV01 87513800
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:49 usage-UV02 387535180
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:34 usage-UV05 5906350
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:35 usage-UV07 113472280
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:36 usage-UV08 27815791
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:30 usage-UV09 998182400
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:38 usage-UV10-11 96168465
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:39 usage-UV17 29506673
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:40 usage-UV18 12326729
setstate M_Bus_Gateway_W122_01 2021-06-30 12:05:03 usage-UV18.1 153976.1
setstate M_Bus_Gateway_W122_01 2021-06-29 12:24:30 usage-UV18.2 5279.4
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:37 usage-UV19 78953170
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:42 usage-UV20 35901791
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:43 usage-UV23 55727058
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:44 usage-UV24 30102164
setstate M_Bus_Gateway_W122_01 2021-06-30 12:04:59 usage-UV25 200034430
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:46 usage-UV28 499332530
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:47 usage-UV29 602604581
setstate M_Bus_Gateway_W122_01 2021-06-30 12:05:01 usage-UV31 74971600
setstate M_Bus_Gateway_W122_01 2021-07-12 08:33:49 usage-UV32 119710365
setstate M_Bus_Gateway_W122_01 2021-06-30 12:05:03 usage-backward-UV18.1 216864533.7
setstate M_Bus_Gateway_W122_01 2021-06-30 12:06:05 usage-backward-UV18.2 2930.4
Ein Teil der Readings:
current-UV02-1
12.5
2021-06-30 12:04:49
current-UV02-2
18.1
2021-06-30 12:04:50
current-UV02-3
28.8
2021-06-30 13:01:01
current-UV05-1
0.145
2021-07-12 08:28:35
current-UV05-2
7.115
2021-06-30 12:02:15
current-UV05-3
4.042
2021-07-12 08:28:35
current-UV07-1
25.176
2021-07-12 08:28:36
Vielleicht hat hier jemand eine Idee?
Vielen Dank im Vorraus.
Offline StefanStrobel
Antw:ModbusAttr : Es werden nicht alle Readings aktualisiert
« Antwort #1 am: 12 Juli 2021, 20:28:42 »
vermutlich ist dein combine-Wert zu hoch.
Gruss
   Stefan
Offline m-d-ley
  • New Member
« Antwort #2 am: 13 Juli 2021, 07:33:43 »
Das könnte sein, wenn ich den ändere werden einige Readings mehr aktualisiert, aber nicht alle.
Aber wie ist dieses Attribute zu deuten, bzw. wie ermittelt man dort den richtigen Wert?
Oder ist es eher sinnvoll mehrere ModbusAttr-Devices anzulegen, da ich ja schon recht viele Register
in meinem Gateway habe?
« Antwort #3 am: 13 Juli 2021, 17:26:24 »
ein Aufsplitten in mehrere Devices macht es nicht besser.
Das mit combine ist eine Protokoll-Sache. Der function code 3 kann laut spec bis zu 125 Register in einem Request abfragen. Die meisten Geräte können aber nur weniger. Manche Antworten einfach nicht, wenn der Wert zu groß ist, andere liefern nur einen Teil der angefragten Register zurück, andere liefern eine Fehlermeldung.
Man muss es einfach ausprobieren. Wenn der Wert zu groß ist, kann es auch sein, dass die Performance schlechter wird. Ebenso wenn er zu klein ist.
Beispiel: wenn Du Register 100 und 200 lesen möchtest und combine auf 120 steht, dann würde das Modul Alle Register von 100 bis 200 in einem gemeinsamen Request lesen. 101 bis 199 sind dabei überflüssig. Da wäre es vermutlich besser, die beiden Register einzeln anzufragen. Im Zweifelsfall sollte bei combine 1 alles einzeln angefragt werden und auch nichts mehr fehlen.
Bei verbose 5 siehst Du im Log, was das Modul anfrägt und was zurück kommt.
Wenn etwas fehlt, würde ich erst mal in Ruhe das Log bei verbose 5 ansehen.
Gruss
   Stefan
Offline m-d-ley
  • New Member
« Antwort #4 am: 14 Juli 2021, 07:53:05 »
Okay, habe combine jetzt auf 1 und trotzdem werden nicht alle Readings aktualisiert.
Auf verbose 5 steht im log:
2021.07.14 07:48:43 3: M_Bus_Gateway_W122_01: QueueRequest queue too long (101), dropping new request
und diese Zeilen wiederholen sich immer wieder.
Wie bekommt man sowas denn in den Griff?
Danke erstmal für den Suppport.
« Antwort #5 am: 14 Juli 2021, 17:58:29 »
wenn die Queue überläuft ist sie entweder zu kurz oder etwas anderes läuft schief.
Das sieht man im Log.
Am besten Du postest einen großen Ausschnitt aus dem Log mit verbose 5, dann kann ich das mal ansehen.
Falls die Anzahl der Requests bei combine 1 tatsächlich zu groß für die Queue ist, kannst Du die mit dem Attribut queueMax z.B. auf 300 setzen.
Es gibt aber auch Geräte, bei denen man bestimmte Register nur als Gruppen mit einer vorgegebenen Länge abfragen kann.
Dann musst Du das manuell konfigurieren.
Gruss
   Stefan
Offline m-d-ley
  • New Member
« Antwort #6 am: 15 Juli 2021, 07:58:21 »
Hallo mal wieder,
also ich muss sagen, dass ich das Modbusprotokoll schon sehr kompliziert finde, oder gibt es dafür eine einfache Erklärung?
Alleine schon die ganzen verschiedenen Datentypen. Gefühlt kann man das Protokoll nicht nutzen, wenn man nicht Informatik Studiert hat.
Anbei mal ein Auszug von einem Modbusrun mit Verbose 5:
[code]2021.07.15 07:22:59 4: M_Bus_Gateway_W122_01: GetUpdate (V4.4.02 - 31.3.2021) called from Fhem internal timer
2021.07.15 07:22:59 4: M_Bus_Gateway_W122_01: UpdateTimer called from GetUpdate with cmd next sets timer to call update function in 60.0 sec at 07:23:59.227, interval 60
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList full object list: h1040 h110 h1230 h1240 h1250 h1330 h1370 h1410 h1450 h150 h1530 h1720 h1730 h1740 h1810 h190 h2000 h2010 h2020 h2090 h2280 h2290 h2300 h2370 h2420 h2460 h2500 h2580 h270 h2770 h2780 h2790 h2860 h3050 h3060 h3070 h3140 h320 h3330 h3340 h3350 h3420 h3470 h3510 h3550 h360 h3630 h3820 h3830 h3840 h3910 h400 h4100 h4110 h4120 h4190 h4240 h4280 h4320 h4400 h4590 h4600 h4610 h4680 h480 h4870 h4880 h4890 h4960 h4980 h5120 h5130 h5140 h5230 h5250 h5390 h5400 h5410 h60 h670 h680 h690 h760 h950 h960 h970
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h60 len 16 usage-UV01
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h110 len 16 current-UV01-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h150 len 16 current-UV01-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h190 len 16 current-UV01-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h270 len 16 usage-UV02
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h320 len 16 current-UV02-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h360 len 16 current-UV02-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h400 len 16 current-UV02-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h480 len 16 usage-UV05
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h670 len 16 current-UV05-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h680 len 16 current-UV05-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h690 len 16 current-UV05-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h760 len 16 usage-UV07
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h950 len 16 current-UV07-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h960 len 16 current-UV07-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h970 len 16 current-UV07-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1040 len 16 usage-UV08
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1230 len 16 current-UV08-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1240 len 16 current-UV08-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1250 len 16 current-UV08-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1330 len 16 usage-UV09
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1370 len 16 current-UV09-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1410 len 16 current-UV09-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1450 len 16 current-UV09-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1530 len 16 usage-UV10-11
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1720 len 16 current-UV10-11-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1730 len 16 current-UV10-11-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1740 len 16 current-UV10-11-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h1810 len 16 usage-UV17
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2000 len 16 current-UV17-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2010 len 16 current-UV17-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2020 len 16 current-UV17-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2090 len 16 usage-UV18
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2280 len 16 current-UV18-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2290 len 16 current-UV18-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2300 len 16 current-UV18-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2370 len 16 usage-UV19
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2420 len 16 current-UV19-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2460 len 16 current-UV19-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2500 len 16 current-UV19-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2580 len 16 usage-UV20
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2770 len 16 current-UV20-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2780 len 16 current-UV20-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2790 len 16 current-UV20-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h2860 len 16 usage-UV23
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3050 len 16 current-UV23-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3060 len 16 current-UV23-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3070 len 16 current-UV23-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3140 len 16 usage-UV24
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3330 len 16 current-UV24-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3340 len 16 current-UV24-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3350 len 16 current-UV24-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3420 len 16 usage-UV25
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3470 len 16 current-UV25-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3510 len 16 current-UV25-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3550 len 16 current-UV25-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3630 len 16 usage-UV28
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3820 len 16 current-UV28-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3830 len 16 current-UV28-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3840 len 16 current-UV28-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h3910 len 16 usage-UV29
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4100 len 16 current-UV29-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4110 len 16 current-UV29-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4120 len 16 current-UV29-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4190 len 16 usage-UV31
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4240 len 16 current-UV31-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4280 len 16 current-UV31-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4320 len 16 current-UV31-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4400 len 16 usage-UV32
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4590 len 16 current-UV32-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4600 len 16 current-UV32-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4610 len 16 current-UV32-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4680 len 16 usage-NSHV
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4870 len 16 current-NSHV-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4880 len 16 current-NSHV-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4890 len 16 current-NSHV-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4960 len 16 usage-UV18.1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h4980 len 16 usage-backward-UV18.1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5120 len 16 current-UV18.1-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5130 len 16 current-UV18.1-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5140 len 16 current-UV18.1-3
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5230 len 16 usage-UV18.2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5250 len 16 usage-backward-UV18.2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5390 len 16 current-UV18.2-1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5400 len 16 current-UV18.2-2
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CreateUpdateList will request h5410 len 16 current-UV18.2-3
2021.07.15 07:22:59 4: M_Bus_Gateway_W122_01: CombineUpdateHash objHash keys before combine: h1740,h960,h4110,h4890,h4600,h3050,h5130,h150,h3510,h4400,h1250,h1810,h4320,h1240,h3840,h4680,h1370,h3630,h5250,h2000,h3070,h5400,h670,h3060,h970,h3330,h760,h2290,h4280,h4240,h3820,h3140,h4190,h2020,h1450,h1720,h950,h2790,h2860,h2010,h2780,h1040,h2770,h3340,h2500,h2300,h3420,h690,h320,h2580,h4590,h4980,h3350,h2370,h3550,h2420,h4100,h5120,h270,h4610,h2460,h2280,h400,h360,h480,h110,h5230,h1730,h4960,h5140,h1410,h680,h1330,h1530,h3830,h4880,h2090,h4120,h4870,h3910,h3470,h5410,h60,h1230,h190,h5390
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash tries to combine read commands
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h60 len 16 usage-UV01 with h110 len 16 current-UV01-1, span 66 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h110 len 16 current-UV01-1 with h150 len 16 current-UV01-2, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h150 len 16 current-UV01-2 with h190 len 16 current-UV01-3, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h190 len 16 current-UV01-3 with h270 len 16 usage-UV02, span 96 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h270 len 16 usage-UV02 with h320 len 16 current-UV02-1, span 66 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h320 len 16 current-UV02-1 with h360 len 16 current-UV02-2, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h360 len 16 current-UV02-2 with h400 len 16 current-UV02-3, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h400 len 16 current-UV02-3 with h480 len 16 usage-UV05, span 96 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h480 len 16 usage-UV05 with h670 len 16 current-UV05-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h670 len 16 current-UV05-1 with h680 len 16 current-UV05-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h680 len 16 current-UV05-2 with h690 len 16 current-UV05-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h690 len 16 current-UV05-3 with h760 len 16 usage-UV07, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h760 len 16 usage-UV07 with h950 len 16 current-UV07-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h950 len 16 current-UV07-1 with h960 len 16 current-UV07-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h960 len 16 current-UV07-2 with h970 len 16 current-UV07-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h970 len 16 current-UV07-3 with h1040 len 16 usage-UV08, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1040 len 16 usage-UV08 with h1230 len 16 current-UV08-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1230 len 16 current-UV08-1 with h1240 len 16 current-UV08-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1240 len 16 current-UV08-2 with h1250 len 16 current-UV08-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1250 len 16 current-UV08-3 with h1330 len 16 usage-UV09, span 96 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1330 len 16 usage-UV09 with h1370 len 16 current-UV09-1, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1370 len 16 current-UV09-1 with h1410 len 16 current-UV09-2, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1410 len 16 current-UV09-2 with h1450 len 16 current-UV09-3, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1450 len 16 current-UV09-3 with h1530 len 16 usage-UV10-11, span 96 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1530 len 16 usage-UV10-11 with h1720 len 16 current-UV10-11-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1720 len 16 current-UV10-11-1 with h1730 len 16 current-UV10-11-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1730 len 16 current-UV10-11-2 with h1740 len 16 current-UV10-11-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1740 len 16 current-UV10-11-3 with h1810 len 16 usage-UV17, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h1810 len 16 usage-UV17 with h2000 len 16 current-UV17-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2000 len 16 current-UV17-1 with h2010 len 16 current-UV17-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2010 len 16 current-UV17-2 with h2020 len 16 current-UV17-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2020 len 16 current-UV17-3 with h2090 len 16 usage-UV18, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2090 len 16 usage-UV18 with h2280 len 16 current-UV18-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2280 len 16 current-UV18-1 with h2290 len 16 current-UV18-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2290 len 16 current-UV18-2 with h2300 len 16 current-UV18-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2300 len 16 current-UV18-3 with h2370 len 16 usage-UV19, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2370 len 16 usage-UV19 with h2420 len 16 current-UV19-1, span 66 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2420 len 16 current-UV19-1 with h2460 len 16 current-UV19-2, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2460 len 16 current-UV19-2 with h2500 len 16 current-UV19-3, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2500 len 16 current-UV19-3 with h2580 len 16 usage-UV20, span 96 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2580 len 16 usage-UV20 with h2770 len 16 current-UV20-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2770 len 16 current-UV20-1 with h2780 len 16 current-UV20-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2780 len 16 current-UV20-2 with h2790 len 16 current-UV20-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2790 len 16 current-UV20-3 with h2860 len 16 usage-UV23, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h2860 len 16 usage-UV23 with h3050 len 16 current-UV23-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3050 len 16 current-UV23-1 with h3060 len 16 current-UV23-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3060 len 16 current-UV23-2 with h3070 len 16 current-UV23-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3070 len 16 current-UV23-3 with h3140 len 16 usage-UV24, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3140 len 16 usage-UV24 with h3330 len 16 current-UV24-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3330 len 16 current-UV24-1 with h3340 len 16 current-UV24-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3340 len 16 current-UV24-2 with h3350 len 16 current-UV24-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3350 len 16 current-UV24-3 with h3420 len 16 usage-UV25, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3420 len 16 usage-UV25 with h3470 len 16 current-UV25-1, span 66 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3470 len 16 current-UV25-1 with h3510 len 16 current-UV25-2, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3510 len 16 current-UV25-2 with h3550 len 16 current-UV25-3, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3550 len 16 current-UV25-3 with h3630 len 16 usage-UV28, span 96 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3630 len 16 usage-UV28 with h3820 len 16 current-UV28-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3820 len 16 current-UV28-1 with h3830 len 16 current-UV28-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3830 len 16 current-UV28-2 with h3840 len 16 current-UV28-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3840 len 16 current-UV28-3 with h3910 len 16 usage-UV29, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h3910 len 16 usage-UV29 with h4100 len 16 current-UV29-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4100 len 16 current-UV29-1 with h4110 len 16 current-UV29-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4110 len 16 current-UV29-2 with h4120 len 16 current-UV29-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4120 len 16 current-UV29-3 with h4190 len 16 usage-UV31, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4190 len 16 usage-UV31 with h4240 len 16 current-UV31-1, span 66 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4240 len 16 current-UV31-1 with h4280 len 16 current-UV31-2, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4280 len 16 current-UV31-2 with h4320 len 16 current-UV31-3, span 56 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4320 len 16 current-UV31-3 with h4400 len 16 usage-UV32, span 96 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4400 len 16 usage-UV32 with h4590 len 16 current-UV32-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4590 len 16 current-UV32-1 with h4600 len 16 current-UV32-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4600 len 16 current-UV32-2 with h4610 len 16 current-UV32-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4610 len 16 current-UV32-3 with h4680 len 16 usage-NSHV, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4680 len 16 usage-NSHV with h4870 len 16 current-NSHV-1, span 206 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4870 len 16 current-NSHV-1 with h4880 len 16 current-NSHV-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4880 len 16 current-NSHV-2 with h4890 len 16 current-NSHV-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4890 len 16 current-NSHV-3 with h4960 len 16 usage-UV18.1, span 86 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4960 len 16 usage-UV18.1 with h4980 len 16 usage-backward-UV18.1, span 36 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h4980 len 16 usage-backward-UV18.1 with h5120 len 16 current-UV18.1-1, span 156 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h5120 len 16 current-UV18.1-1 with h5130 len 16 current-UV18.1-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h5130 len 16 current-UV18.1-2 with h5140 len 16 current-UV18.1-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h5140 len 16 current-UV18.1-3 with h5230 len 16 usage-UV18.2, span 106 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h5230 len 16 usage-UV18.2 with h5250 len 16 usage-backward-UV18.2, span 36 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h5250 len 16 usage-backward-UV18.2 with h5390 len 16 current-UV18.2-1, span 156 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h5390 len 16 current-UV18.2-1 with h5400 len 16 current-UV18.2-2, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash cant combine h5400 len 16 current-UV18.2-2 with h5410 len 16 current-UV18.2-3, span 26 would be bigger than max 1
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: CombineUpdateHash keys are now h1740,h960,h4110,h4890,h4600,h3050,h5130,h150,h3510,h4400,h1250,h1810,h4320,h1240,h3840,h4680,h1370,h3630,h5250,h2000,h3070,h5400,h670,h3060,h970,h3330,h760,h2290,h4280,h4240,h3820,h3140,h4190,h2020,h1450,h1720,h950,h2790,h2860,h2010,h2780,h1040,h2770,h3340,h2500,h2300,h3420,h690,h320,h2580,h4590,h4980,h3350,h2370,h3550,h2420,h4100,h5120,h270,h4610,h2460,h2280,h400,h360,h480,h110,h5230,h1730,h4960,h5140,h1410,h680,h1330,h1530,h3830,h4880,h2090,h4120,h4870,h3910,h3470,h5410,h60,h1230,h190,h5390
2021.07.15 07:22:59 4: M_Bus_Gateway_W122_01: GetUpdate will now create requests for h60 len 16 (usage-UV01), h110 len 16 (current-UV01-1), h150 len 16 (current-UV01-2), h190 len 16 (current-UV01-3), h270 len 16 (usage-UV02), h320 len 16 (current-UV02-1), h360 len 16 (current-UV02-2), h400 len 16 (current-UV02-3), h480 len 16 (usage-UV05), h670 len 16 (current-UV05-1), h680 len 16 (current-UV05-2), h690 len 16 (current-UV05-3), h760 len 16 (usage-UV07), h950 len 16 (current-UV07-1), h960 len 16 (current-UV07-2), h970 len 16 (current-UV07-3), h1040 len 16 (usage-UV08), h1230 len 16 (current-UV08-1), h1240 len 16 (current-UV08-2), h1250 len 16 (current-UV08-3), h1330 len 16 (usage-UV09), h1370 len 16 (current-UV09-1), h1410 len 16 (current-UV09-2), h1450 len 16 (current-UV09-3), h1530 len 16 (usage-UV10-11), h1720 len 16 (current-UV10-11-1), h1730 len 16 (current-UV10-11-2), h1740 len 16 (current-UV10-11-3), h1810 len 16 (usage-UV17), h2000 len 16 (current-UV17-1), h2010 len 16 (current-UV17-2), h2020 len 16 (current-UV17-3), h2090 len 16 (usage-UV18), h2280 len 16 (current-UV18-1), h2290 len 16 (current-UV18-2), h2300 len 16 (current-UV18-3), h2370 len 16 (usage-UV19), h2420 len 16 (current-UV19-1), h2460 len 16 (current-UV19-2), h2500 len 16 (current-UV19-3), h2580 len 16 (usage-UV20), h2770 len 16 (current-UV20-1), h2780 len 16 (current-UV20-2), h2790 len 16 (current-UV20-3), h2860 len 16 (usage-UV23), h3050 len 16 (current-UV23-1), h3060 len 16 (current-UV23-2), h3070 len 16 (current-UV23-3), h3140 len 16 (usage-UV24), h3330 len 16 (current-UV24-1), h3340 len 16 (current-UV24-2), h3350 len 16 (current-UV24-3), h3420 len 16 (usage-UV25), h3470 len 16 (current-UV25-1), h3510 len 16 (current-UV25-2), h3550 len 16 (current-UV25-3), h3630 len 16 (usage-UV28), h3820 len 16 (current-UV28-1), h3830 len 16 (current-UV28-2), h3840 len 16 (current-UV28-3), h3910 len 16 (usage-UV29), h4100 len 16 (current-UV29-1), h4110 len 16 (current-UV29-2), h4120 len 16 (current-UV29-3), h4190 len 16 (usage-UV31), h4240 len 16 (current-UV31-1), h4280 len 16 (current-UV31-2), h4320 len 16 (current-UV31-3), h4400 len 16 (usage-UV32), h4590 len 16 (current-UV32-1), h4600 len 16 (current-UV32-2), h4610 len 16 (current-UV32-3), h4680 len 16 (usage-NSHV), h4870 len 16 (current-NSHV-1), h4880 len 16 (current-NSHV-2), h4890 len 16 (current-NSHV-3), h4960 len 16 (usage-UV18.1), h4980 len 16 (usage-backward-UV18.1), h5120 len 16 (current-UV18.1-1), h5130 len 16 (current-UV18.1-2), h5140 len 16 (current-UV18.1-3), h5230 len 16 (usage-UV18.2), h5250 len 16 (usage-backward-UV18.2), h5390 len 16 (current-UV18.2-1), h5400 len 16 (current-UV18.2-2), h5410 len 16 (current-UV18.2-3)
2021.07.15 07:22:59 4: M_Bus_Gateway_W122_01: DoRequest called from GetUpdate created new request, read buffer empty,
request: id 2, read fc 3 h60, len 16, tid 243, master device M_Bus_Gateway_W122_01, reading usage-UV01 (getUpdate for usage-UV01 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h60, qlen 0 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: StartQueueTimer called from QueueRequest sets internal timer to process queue in 0.000 seconds
request: id 2, read fc 3 h110, len 16, tid 158, master device M_Bus_Gateway_W122_01, reading current-UV01-1 (getUpdate for current-UV01-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h110, qlen 1 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h150, len 16, tid 149, master device M_Bus_Gateway_W122_01, reading current-UV01-2 (getUpdate for current-UV01-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h150, qlen 2 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h190, len 16, tid 208, master device M_Bus_Gateway_W122_01, reading current-UV01-3 (getUpdate for current-UV01-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h190, qlen 3 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h270, len 16, tid 247, master device M_Bus_Gateway_W122_01, reading usage-UV02 (getUpdate for usage-UV02 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h270, qlen 4 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h320, len 16, tid 61, master device M_Bus_Gateway_W122_01, reading current-UV02-1 (getUpdate for current-UV02-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h320, qlen 5 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h360, len 16, tid 152, master device M_Bus_Gateway_W122_01, reading current-UV02-2 (getUpdate for current-UV02-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h360, qlen 6 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h400, len 16, tid 169, master device M_Bus_Gateway_W122_01, reading current-UV02-3 (getUpdate for current-UV02-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h400, qlen 7 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h480, len 16, tid 65, master device M_Bus_Gateway_W122_01, reading usage-UV05 (getUpdate for usage-UV05 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h480, qlen 8 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h670, len 16, tid 99, master device M_Bus_Gateway_W122_01, reading current-UV05-1 (getUpdate for current-UV05-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h670, qlen 9 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h680, len 16, tid 117, master device M_Bus_Gateway_W122_01, reading current-UV05-2 (getUpdate for current-UV05-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h680, qlen 10 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h690, len 16, tid 254, master device M_Bus_Gateway_W122_01, reading current-UV05-3 (getUpdate for current-UV05-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h690, qlen 11 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h760, len 16, tid 52, master device M_Bus_Gateway_W122_01, reading usage-UV07 (getUpdate for usage-UV07 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h760, qlen 12 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h950, len 16, tid 16, master device M_Bus_Gateway_W122_01, reading current-UV07-1 (getUpdate for current-UV07-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h950, qlen 13 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h960, len 16, tid 70, master device M_Bus_Gateway_W122_01, reading current-UV07-2 (getUpdate for current-UV07-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h960, qlen 14 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h970, len 16, tid 165, master device M_Bus_Gateway_W122_01, reading current-UV07-3 (getUpdate for current-UV07-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h970, qlen 15 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1040, len 16, tid 15, master device M_Bus_Gateway_W122_01, reading usage-UV08 (getUpdate for usage-UV08 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1040, qlen 16 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1230, len 16, tid 248, master device M_Bus_Gateway_W122_01, reading current-UV08-1 (getUpdate for current-UV08-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1230, qlen 17 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1240, len 16, tid 138, master device M_Bus_Gateway_W122_01, reading current-UV08-2 (getUpdate for current-UV08-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1240, qlen 18 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1250, len 16, tid 227, master device M_Bus_Gateway_W122_01, reading current-UV08-3 (getUpdate for current-UV08-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1250, qlen 19 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1330, len 16, tid 174, master device M_Bus_Gateway_W122_01, reading usage-UV09 (getUpdate for usage-UV09 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1330, qlen 20 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1370, len 16, tid 132, master device M_Bus_Gateway_W122_01, reading current-UV09-1 (getUpdate for current-UV09-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1370, qlen 21 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1410, len 16, tid 251, master device M_Bus_Gateway_W122_01, reading current-UV09-2 (getUpdate for current-UV09-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1410, qlen 22 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1450, len 16, tid 229, master device M_Bus_Gateway_W122_01, reading current-UV09-3 (getUpdate for current-UV09-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1450, qlen 23 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1530, len 16, tid 115, master device M_Bus_Gateway_W122_01, reading usage-UV10-11 (getUpdate for usage-UV10-11 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1530, qlen 24 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1720, len 16, tid 253, master device M_Bus_Gateway_W122_01, reading current-UV10-11-1 (getUpdate for current-UV10-11-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1720, qlen 25 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1730, len 16, tid 127, master device M_Bus_Gateway_W122_01, reading current-UV10-11-2 (getUpdate for current-UV10-11-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1730, qlen 26 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1740, len 16, tid 222, master device M_Bus_Gateway_W122_01, reading current-UV10-11-3 (getUpdate for current-UV10-11-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1740, qlen 27 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h1810, len 16, tid 130, master device M_Bus_Gateway_W122_01, reading usage-UV17 (getUpdate for usage-UV17 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h1810, qlen 28 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2000, len 16, tid 212, master device M_Bus_Gateway_W122_01, reading current-UV17-1 (getUpdate for current-UV17-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2000, qlen 29 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2010, len 16, tid 56, master device M_Bus_Gateway_W122_01, reading current-UV17-2 (getUpdate for current-UV17-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2010, qlen 30 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2020, len 16, tid 229, master device M_Bus_Gateway_W122_01, reading current-UV17-3 (getUpdate for current-UV17-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2020, qlen 31 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2090, len 16, tid 243, master device M_Bus_Gateway_W122_01, reading usage-UV18 (getUpdate for usage-UV18 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2090, qlen 32 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2280, len 16, tid 146, master device M_Bus_Gateway_W122_01, reading current-UV18-1 (getUpdate for current-UV18-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2280, qlen 33 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2290, len 16, tid 118, master device M_Bus_Gateway_W122_01, reading current-UV18-2 (getUpdate for current-UV18-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2290, qlen 34 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2300, len 16, tid 138, master device M_Bus_Gateway_W122_01, reading current-UV18-3 (getUpdate for current-UV18-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2300, qlen 35 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2370, len 16, tid 177, master device M_Bus_Gateway_W122_01, reading usage-UV19 (getUpdate for usage-UV19 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2370, qlen 36 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2420, len 16, tid 30, master device M_Bus_Gateway_W122_01, reading current-UV19-1 (getUpdate for current-UV19-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2420, qlen 37 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2460, len 16, tid 203, master device M_Bus_Gateway_W122_01, reading current-UV19-2 (getUpdate for current-UV19-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2460, qlen 38 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2500, len 16, tid 189, master device M_Bus_Gateway_W122_01, reading current-UV19-3 (getUpdate for current-UV19-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2500, qlen 39 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2580, len 16, tid 172, master device M_Bus_Gateway_W122_01, reading usage-UV20 (getUpdate for usage-UV20 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2580, qlen 40 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2770, len 16, tid 53, master device M_Bus_Gateway_W122_01, reading current-UV20-1 (getUpdate for current-UV20-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2770, qlen 41 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2780, len 16, tid 106, master device M_Bus_Gateway_W122_01, reading current-UV20-2 (getUpdate for current-UV20-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2780, qlen 42 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2790, len 16, tid 43, master device M_Bus_Gateway_W122_01, reading current-UV20-3 (getUpdate for current-UV20-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2790, qlen 43 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h2860, len 16, tid 238, master device M_Bus_Gateway_W122_01, reading usage-UV23 (getUpdate for usage-UV23 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h2860, qlen 44 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3050, len 16, tid 223, master device M_Bus_Gateway_W122_01, reading current-UV23-1 (getUpdate for current-UV23-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3050, qlen 45 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3060, len 16, tid 18, master device M_Bus_Gateway_W122_01, reading current-UV23-2 (getUpdate for current-UV23-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3060, qlen 46 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3070, len 16, tid 84, master device M_Bus_Gateway_W122_01, reading current-UV23-3 (getUpdate for current-UV23-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3070, qlen 47 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3140, len 16, tid 23, master device M_Bus_Gateway_W122_01, reading usage-UV24 (getUpdate for usage-UV24 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3140, qlen 48 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3330, len 16, tid 49, master device M_Bus_Gateway_W122_01, reading current-UV24-1 (getUpdate for current-UV24-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3330, qlen 49 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3340, len 16, tid 200, master device M_Bus_Gateway_W122_01, reading current-UV24-2 (getUpdate for current-UV24-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3340, qlen 50 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3350, len 16, tid 19, master device M_Bus_Gateway_W122_01, reading current-UV24-3 (getUpdate for current-UV24-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3350, qlen 51 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3420, len 16, tid 3, master device M_Bus_Gateway_W122_01, reading usage-UV25 (getUpdate for usage-UV25 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3420, qlen 52 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3470, len 16, tid 104, master device M_Bus_Gateway_W122_01, reading current-UV25-1 (getUpdate for current-UV25-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3470, qlen 53 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3510, len 16, tid 139, master device M_Bus_Gateway_W122_01, reading current-UV25-2 (getUpdate for current-UV25-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3510, qlen 54 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3550, len 16, tid 7, master device M_Bus_Gateway_W122_01, reading current-UV25-3 (getUpdate for current-UV25-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3550, qlen 55 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3630, len 16, tid 63, master device M_Bus_Gateway_W122_01, reading usage-UV28 (getUpdate for usage-UV28 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3630, qlen 56 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3820, len 16, tid 185, master device M_Bus_Gateway_W122_01, reading current-UV28-1 (getUpdate for current-UV28-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3820, qlen 57 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3830, len 16, tid 104, master device M_Bus_Gateway_W122_01, reading current-UV28-2 (getUpdate for current-UV28-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3830, qlen 58 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3840, len 16, tid 124, master device M_Bus_Gateway_W122_01, reading current-UV28-3 (getUpdate for current-UV28-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3840, qlen 59 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h3910, len 16, tid 181, master device M_Bus_Gateway_W122_01, reading usage-UV29 (getUpdate for usage-UV29 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h3910, qlen 60 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4100, len 16, tid 58, master device M_Bus_Gateway_W122_01, reading current-UV29-1 (getUpdate for current-UV29-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4100, qlen 61 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4110, len 16, tid 96, master device M_Bus_Gateway_W122_01, reading current-UV29-2 (getUpdate for current-UV29-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4110, qlen 62 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4120, len 16, tid 114, master device M_Bus_Gateway_W122_01, reading current-UV29-3 (getUpdate for current-UV29-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4120, qlen 63 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4190, len 16, tid 241, master device M_Bus_Gateway_W122_01, reading usage-UV31 (getUpdate for usage-UV31 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4190, qlen 64 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4240, len 16, tid 71, master device M_Bus_Gateway_W122_01, reading current-UV31-1 (getUpdate for current-UV31-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4240, qlen 65 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4280, len 16, tid 99, master device M_Bus_Gateway_W122_01, reading current-UV31-2 (getUpdate for current-UV31-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4280, qlen 66 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4320, len 16, tid 204, master device M_Bus_Gateway_W122_01, reading current-UV31-3 (getUpdate for current-UV31-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4320, qlen 67 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4400, len 16, tid 102, master device M_Bus_Gateway_W122_01, reading usage-UV32 (getUpdate for usage-UV32 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4400, qlen 68 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4590, len 16, tid 184, master device M_Bus_Gateway_W122_01, reading current-UV32-1 (getUpdate for current-UV32-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4590, qlen 69 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4600, len 16, tid 12, master device M_Bus_Gateway_W122_01, reading current-UV32-2 (getUpdate for current-UV32-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4600, qlen 70 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4610, len 16, tid 80, master device M_Bus_Gateway_W122_01, reading current-UV32-3 (getUpdate for current-UV32-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4610, qlen 71 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4680, len 16, tid 197, master device M_Bus_Gateway_W122_01, reading usage-NSHV (getUpdate for usage-NSHV len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4680, qlen 72 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4870, len 16, tid 35, master device M_Bus_Gateway_W122_01, reading current-NSHV-1 (getUpdate for current-NSHV-1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4870, qlen 73 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4880, len 16, tid 175, master device M_Bus_Gateway_W122_01, reading current-NSHV-2 (getUpdate for current-NSHV-2 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4880, qlen 74 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4890, len 16, tid 196, master device M_Bus_Gateway_W122_01, reading current-NSHV-3 (getUpdate for current-NSHV-3 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4890, qlen 75 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4960, len 16, tid 241, master device M_Bus_Gateway_W122_01, reading usage-UV18.1 (getUpdate for usage-UV18.1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4960, qlen 76 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h4980, len 16, tid 58, master device M_Bus_Gateway_W122_01, reading usage-backward-UV18.1 (getUpdate for usage-backward-UV18.1 len 16)
2021.07.15 07:22:59 5: M_Bus_Gateway_W122_01: QueueRequest called from DoRequest with h4980, qlen 77 from master M_Bus_Gateway_W122_01 through io device M_Bus_Gateway_W122_01
request: id 2, read fc 3 h5120, len 16, tid 175, master device M_Bus_Gateway_W122_01, reading current-UV18.1-1 (getUpdate for current-UV18.1-1 len 16)
« Antwort #7 am: 15 Juli 2021, 17:28:24 »
soweit sieht im Log alles gut aus. Das war aber auch nur der Anfang. Das spannende müsste danach kommen ;-)
Im Log sieht man wie die Register aufgelistet, die ersten Requests erzeugt werden und dann die ersten 77 in die Queue gehen.
Ein Überlauf der Queue oder ein tatsächlich gesendeter bzw. beantworteter Request war in dem Log-Ausschnitt nicht drin ...
Kannst Du da mal noch mehr posten?
Am besten innerhalb von Code-Tags, sonst wird Dein Post sehr lang ...
Gruss
   Stefan
Offline m-d-ley
  • New Member
« Antwort #8 am: 16 Juli 2021, 09:24:01 »
Anbei nochmal zwei Runs:
https://easyupload.io/t7gn68
Der andwere Beitrag war wohl zu lang, sodass er unten abgeschnitten wurde, obwohl er in Code geklammert war.
« Antwort #9 am: 16 Juli 2021, 22:00:12 »
welche Readings fehlen denn dabei?
Noch was ganz anderes:
Warum definierst Du die Typen mit Länge 16? Das sind 16 Register a 16 Bit, also 256 Bit.
beim Unpack wird davon aber nur ein kleiner Teil verwendet. Bei q sind es 64 Bit und bei f in der Regel 32...
Auch die Expr-Attribute mit $val*1 oder $val/1 sind überflüssig.
Mit fehlenden Readings hat das natürlich nichts zu tun, aber es ist mir aufgefallen.
Gruss
   Stefan
« Antwort #10 am: 17 Juli 2021, 16:14:19 »
Hallo nochmal,
laut Konfiguration sind 86 Readings definiert.
Im Log werden je Runde auch 86 Readings mit einem Wert belegt.
Bis alle 86 Readings abgefragt und gesetzt sind, vergehen 10 Sekunden.
Kann es sein, dass doch nichts fehlt, sondern dass es nur ein paar Sekunden dauert, bis alle da sind?
Gruss
    Stefan
Offline m-d-ley
  • New Member
« Antwort #11 am: 18 Juli 2021, 11:08:38 »
ich habe gerade noch einmal gecheckt:
Seit dem 15.07. werden alle Readings aktualisiert,
leider weiss ich nicht was der Fehler war.
Es scheint so, dass du einiges von dem Modbus verstehst.
Wie ist das ganze vernünftig zu konfigurieren?
Die Länge z.B.? Wie gehe ich mit Signed Integer genau um?
Und wie mit Floating Points oder BOOL? Und wie bekomme ich den Wert, der innerhalb eines Registers in einer anderen Spalte steht?
Ich finde das Modbusprotokoll sehr schwierig und verstehe ehrlich gesagt die CommandRef an der stelle nicht wirklich.
Gibt es eine Möglichkeit, dass sich die Register selbst im Modul konfigurieren?
Danke und LG
« Antwort #12 am: 20 Juli 2021, 18:33:42 »
das ganze ist nicht einfach, aber das liegt nicht an Modbus sondern an den Geräte-Herstellern.
Modbus kennt eigentlich nur zwei Typen von Daten: 16-Bit-Werte und 1-Bit-Werte.
16-Bit-Werte gibt es als Holding Register wenn man sie auch ändern kann
oder als Input Register wenn man sie nur lesen kann.
1-Bit-Werte werden Coils genannt, wenn man sie auch schreiben kann und Digital Inputs wenn man sie nur lesen kann.
Und da beginnt das Problem. Wenn ein Hersteller eine Fließkommazahl verwendet, dann kann er das so machen wie er möchte. Z.B. als 32-Bit-Wert, der über zwei Holding-Register geht. Welcher Teil dabei im ersten Register und welcher im zweiten steht, das kann er machen wie er will. Manche verwenden auch gar keine Fließkommazahlen sondern speichern einen Wert multipliziert mit 100, so dass die beiden letzten Ziffern für Nachkommastellen stehen.
Manche Hersteller dokumentieren das sehr gut, bei anderen gibt es gar keine Doku. Und dann gibt es auch solche, die den Modbus-Standard falsch verstehen und nicht mal korrekte Antworten auf Protokollebene erzeugen.
Auch bei den Längen ist es oft ein Problem. Bei den meisten Hersteller kann man jedes Register einzeln oder zusammen mit anderen Register lesen. Manche ignorieren dann aber den Request und antworten nur wenn man genau 4 Register zusammen abfragt.
Man muss es daher oft ausprobieren.
Sorry, dass ich keine erfreulichere Antwort für Dich habe.
Gruss
   Stefan
Offline m-d-ley
  • New Member
Antw:ModbusAttr : Es werden nicht alle Readings aktualisiert
« Antwort #13 am: 18 August 2021, 06:59:37 »
Hallo nochmal,
jetzt habe ich einmal alles an Doku zusammen gelesen und habe einigermaßen verstanden, wie ich mit den Registern etc. umgehen muss.
Ich muss sagen, dass es schwierig ist, da jeder in seiner Doku anders dokumentiert, sodass es schwierig ist es auf einen Nenner zu bringen.
Aber gut das habe ich soweit im Griff.
Allerdings habe ich ein großes Problem mit der Stabilität im Modul:
Alle Register werden fein säuberlich aktualisiert so wie sie es sollen. Mittlerweile habe ich 3 Modbus-TCP Gateways und 2 BHKW´s eingerichtet, also schon sehr sehr Register bzw. auch sehr viele Zähler dahinter.
Nun ist es aber so, dass nach Zeit X (also wirklich sporadisch, können Stunden oder auch Tage sein) auf einmal die Verbindung unterbrochen ist und das Modul auch nicht in der Lage ist diese wieder aufzubauen.
Dann steht im State immer ein wechsel zwischen "connectet" und "disconnectet". Die einzige Möglichkeit diese Verbindung wieder herzustellen ist, dass man händisch im Device ein "get <modbusattrdevice> <reading>" auslöst.
Damit aber nicht genug:
Dies muss so oft wiederholt werden, bis man einen Wert aus dem Reading bekommt. Die ersten "get-Kommandos" werden mit "Device disconnectet" oder "ReadAnswer got no Data" beantwortet. Erst wenn die gegenstelle mit einem Wert antwortet werden die Register wieder bis zum nächsten Disconnect aktualisiert.
Ich weiss ehrlich gesagt nicht wo ich zur Fehlerdiagnose ansetzen soll. Anbei noch einmal ein Link zu den Logfiles. Einmal mit den Disconnects und einmal mit dem händischen "get-Kommando".
https://easyupload.io/m/a7nb7e
Danke für den guten Support erstmal, selten so eine gute Community gesehen.
Offline StefanStrobel
« Antwort #14 am: 18 August 2021, 22:04:40 »
ich hab Deine Log-Auszüge mal grob durchgesehen. Für mich sieht das nicht nach einer Instabilität des Moduls sondern nach einem Timing- oder Last-Problem des Slaves aus.
Der Client schließt die TCP-Verbindung direkt nach Empfang der Requests. Das Modul öffnet die Verbindung erneut, schickt den nächsten Request und der Slave macht wieder zu statt zu antworten.
Warum es dann manchmal doch wieder geht kann ich Dir nicht mit Gewissheit sagen. Eventuell liegt es daran dass der Slave davor doch mal eine Pause hatte oder es liegt an dem Request. Irgendetwas mag der Slave jedenfalls nicht und statt mit einer Fehlermeldung zu antworten, macht er einfach die Verbindung zu.
Ähnlich war es ja mit Deinen überlangen Requests als Du combine zu hoch eingestellt hast. Auch da hat er einfach ohne Fehlermeldung ein paar Dinge nicht mehr beantwortet.
Ich würde folgendes probieren:
1. Gib dem Slave mehr Zeit. Probier die verschiedenen Delays und das Intervall zu erhöhen.
2. Fass die Requests wieder etwas zusammen. Combine auf 1 zu stellen war zur Fehlersuche ok. Offenbar lag Dein letztes Problem an einem zu hohen Combine. Aber jedes Register einzeln abzufragen erzeugt dann doch zu viele Requests und lässt dem Slave kaum eine Pause. Ich würde den Wert mal langsam erhöhen und herausfinden, wo sein Maximum ist, bevor Antworten fehlen. 8 oder auch 16 sollten eigentlich drin sein.
3. Wenn weiterhin Disconnects kommen, würde ich testen ob eine temporäre Unterbrechung des Abfragezyklus schon ausreicht dass er wieder antwortet.
Modbus-Slave-Implementationen bei IoT-Geräten sind leider oft buggy und "zickig". Da hilft nur Ausprobieren ...
Gruss
   Stefan
decade-submarginal
