fhempy: Tuya Cloud
Begonnen von dominik, 30 Juli 2021, 21:36:48
dominik
Neustart von fhempy hat auch keine Änderung gebracht? Die Readings sollten eigentlich innerhalb einer Sekunden aktualisiert werden nach dem Schalten.
fhempy -  https://github.com/fhempy/fhempy: GoogleCast, Tuya, UPnP, Ring, EQ3BT, Nespresso, Xiaomi, Spotify, Object Detection, ...
Kaffeespende: https://paypal.me/todominik
patator
leider nein,
2021-08-05 11:24:49,146 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-08-05 11:24:49,173 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-08-05 11:25:24,754 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-08-05 11:25:24,816 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-08-05 11:25:32,046 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 127.0.0.1
[2021-08-05 11:25:41,067] [tuya-openmq] error while get mqtt config
2021-08-05 11:25:41,067 - ERROR    - tuya iot: error while get mqtt config
2021-08-05 11:36:27,246 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-08-05 11:36:27,300 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-08-05 11:36:37,937 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 127.0.0.1
2021-08-05 11:39:19,035 - INFO     - fhempy.lib.fhem_pythonbinding: Starting fhempy...
2021-08-05 11:39:19,097 - INFO     - fhempy.lib.fhem_pythonbinding: Waiting for FHEM connection
2021-08-05 11:39:26,941 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 127.0.0.1
2021-08-05 11:39:27,048 - WARNING  - asyncio: Executing <Handle <TaskWakeupMethWrapper object at 0x75adc770>(<Future finis...events.py:396>) created at /usr/lib/python3.7/asyncio/streams.py:408> took 0.121 seconds
Exception in thread Thread-2:
  File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
    self.run()
  File "/opt/fhem/.local/lib/python3.7/site-packages/tuya_iot/openmq.py", line 170, in run
    self.__run_mqtt()
  File "/opt/fhem/.local/lib/python3.7/site-packages/tuya_iot/openmq.py", line 184, in __run_mqtt
    mqttc = self._start(mq_config)
  File "/opt/fhem/.local/lib/python3.7/site-packages/tuya_iot/openmq.py", line 204, in _start
    mqttc.connect(url.hostname, url.port)
  File "/opt/fhem/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 941, in connect
    return self.reconnect()
  File "/opt/fhem/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 1075, in reconnect
    sock = self._create_socket_connection()
  File "/opt/fhem/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 3546, in _create_socket_connection
    return socket.create_connection(addr, source_address=source, timeout=self._keepalive)
  File "/usr/lib/python3.7/socket.py", line 727, in create_connection
    raise err
  File "/usr/lib/python3.7/socket.py", line 716, in create_connection
    sock.connect(sa)
socket.timeout: timed out
dominik
Aha, er kann keine MQTT Connection zu tuya aufbauen. Hast du irgendeine Firewall oder so aktiv?
patator
tatsache, danke für den Hinweis.
Port 8883 muss nach extern erlaubt sein.
Prima, danke nochmal
patator
Ich würde gerne fhempy vom fhem raspberry wegbekommen.
Ich hatte ja versucht auf einer Ubuntu 20.04 Maschine fhempy mit pyhton3.8 zu implementieren.
Sobald fhem versucht zu verbinden knallts:
2021-08-06 08:57:02,897 - INFO     - fhempy.lib.fhem_pythonbinding: Incoming FHEM connection: 10.10.20.109
2021-08-06 08:57:02,899 - ERROR    - websockets.server: Error in connection handler
  File "/home/bitnami/.local/lib/python3.8/site-packages/websockets/legacy/server.py", line 293, in handler
    await self.ws_handler(self, path)
  File "/home/bitnami/.local/lib/python3.8/site-packages/fhempy/lib/fhem_pythonbinding.py", line 64, in pybinding
    await activate_internal_modules()
  File "/home/bitnami/.local/lib/python3.8/site-packages/fhempy/lib/fhem_pythonbinding.py", line 47, in activate_internal_modules
    await instance.activate()
  File "/home/bitnami/.local/lib/python3.8/site-packages/fhempy/lib/core/discover_fhempy/discover_fhempy.py", line 82, in activate
    await self.runZeroconfScan()
  File "/home/bitnami/.local/lib/python3.8/site-packages/fhempy/lib/core/discover_fhempy/discover_fhempy.py", line 79, in runZeroconfScan
    self.browser = ServiceBrowser(self.zeroconf, services, listener)
  File "/home/bitnami/.local/lib/python3.8/site-packages/zeroconf/_services/browser.py", line 505, in __init__
    raise RuntimeError("The event loop is not running")
RuntimeError: The event loop is not running
dominik
Startest du fhempy per Commandline? Mach mal
fhempy --local
Dann startet es kein Zeroconf.
dominik
Mach bitte mal
pip3 install zeroconf==0.28.6
Ich glaub mit 0.32.0 sind da ein paar Breaking Changes reingekommen.
patator
Hallo ich habe immer wieder das Problem,
dass auf meinem Raspi keine MQTT Informationen mehr kommen.
Im fhempy Log erscheint dann:
2021-08-08 12:42:41,823 - ERROR    - tuya_cloud_connector: 'TuyaDeviceManager' object has no attribute '_on_message'
  File "/opt/fhem/.local/lib/python3.7/site-packages/fhempy/lib/tuya_cloud/tuya_cloud_setup.py", line 71, in restart_mqtt_loop
    await self.restart_mqtt()
  File "/opt/fhem/.local/lib/python3.7/site-packages/fhempy/lib/tuya_cloud/tuya_cloud_setup.py", line 81, in restart_mqtt
    tuya_mq.add_message_listener(self.device_manager._on_message)
AttributeError: 'TuyaDeviceManager' object has no attribute '_on_message'
2021-08-08 14:41:01,847 - ERROR    - tuya_cloud_connector: 'TuyaDeviceManager' object has no attribute '_on_message'
2021-08-08 16:39:21,960 - ERROR    - tuya_cloud_connector: 'TuyaDeviceManager' object has no attribute '_on_message'
Restarte ich das Pythonbinding, geht es wieder für einen Weile.
Ne Idee?
dominik
#53
Ah, da ist was bei der Tuya iot Library geändert worden. Korrigiere ich heute Abend bzw. fixiere ich dann gleich die Library Version.
//Edit
Bitte mal ein Update machen, in 0.1.82 wird nun die "alte" Tuya Library verwendet, dann klappt es wieder.
patator
juergen012
leider muss ich mich nochmal melden, da ich alleine nicht weiterkomme. Eigentlich funktioniert alles wie es soll.. Bis auf meinen smart_power_strip. Dieser hat 4 Steckdosen, die alle separat geschaltet werden können. Zusätzlich noch 4 USB Ports, die gemeinsam geschaltet werden. Bis auf die Steckdose 1 (switch1) kann ich alles schalten. Der Switch wird mir in fhem nicht angezeigt. In der App funktioniert das.
Hier das List..
DEF        tuya_cloud tuya_cloud_connector yyyyy
   DEVICEID   aaaaaaaa
   FUUID      xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
   IODev      local_pybinding
   NAME       smart_power_strip_xxxxxx
   NR         297
   PYTHONTYPE tuya_cloud
   STATE      off
   TYPE       PythonModule
     2021-08-11 14:10:17   active_time     1626194558
     2021-08-11 14:10:17   biz_type        0
     2021-08-11 14:10:17   category        pc
     2021-08-12 12:28:11   countdown_1     0.0
     2021-08-12 12:28:11   countdown_2     0.0
     2021-08-12 12:28:11   countdown_3     0.0
     2021-08-12 12:28:11   countdown_4     0.0
     2021-08-12 12:28:11   countdown_usb1  0.0
     2021-08-11 14:10:17   create_time     1620742633
     2021-08-11 14:10:17   icon            https://images.tuyaeu.com/smart/icon/1555585425a1oqvs7elur_0.jpg
     2021-08-11 14:10:17   id              aaaaa
     2021-08-11 14:10:17   ip              11111
     2021-08-11 14:10:17   lat             53.685hhh
     2021-08-11 14:10:17   local_key       7xxxxx
     2021-08-11 14:10:17   lon             10.029nnn
     2021-08-11 14:10:17   model           A339
     2021-08-11 14:10:17   name            smart power strip
     2021-08-11 14:10:17   online          on
     2021-08-11 14:10:17   owner_id        xxxxxxxxxxxxx
     2021-08-11 14:10:17   product_id      gl5fdiv1tc9mkvlp
     2021-08-11 14:10:17   product_name    smart power strip
     2021-08-12 12:28:11   state           off
     2021-08-11 14:10:17   sub             off
     2021-08-12 12:28:11   switch_2        off
     2021-08-12 12:28:11   switch_3        off
     2021-08-12 12:28:11   switch_4        off
     2021-08-12 12:28:11   switch_usb1     off
     2021-08-11 14:10:17   time_zone       +01:00
     2021-08-11 14:10:17   uid             eu1598540337292fORIB
     2021-08-11 14:10:17   update_time     1628669008
     2021-08-11 14:10:17   uuid            xxxxxxxxxxxxxxxxxxx
   args:
     smart_power_strip_xxxxxxx
     PythonModule
     tuya_cloud
   argsh:
   DbLogExclude .*
   alias      smart power strip
   room       tuya
   verbose    2
Wenn ich am smart_power_strip die Steckdose 1 schalte, dann wird mir das in fhem angezeigt..
Beste Grüße
Jürgen K.
Fhem unter Proxmox
dominik
schalte Mal direkt das Device On/Off
set smart_power_strip_xxxxxx on
Damit sollte es funktionieren.
juergen012
Hallo dominik,
wenn ich set smart_power_strip_xxxxxxxxxxxxxxxxxxx  switch_1 on mache, bekomme ich:  Command not available for this device.
Mit den andere Steckdosen (2-4) funktioniert das.
Fhem unter Proxmox
dominik
Ohne switch_1, nur das Command von oben.
juergen012
mit dem Kommando werden alle Steckdosen geschaltet..
Fhem unter Proxmox
