gelöst ...Fehler oder nicht -> HTTPUtils
Begonnen von rico5588, 21 Oktober 2021, 17:13:51
rico5588
ich bin auf der suche nach einem Warning welches ich im Log stehen habe.
Dieses wird mir angezeigt sobald ich Stacktrace auf 1 stelle.
2021.10.21 16:27:36 1: stacktrace:
2021.10.21 16:27:36 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:27:36 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:27:36 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:29:01 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:29:01 1: stacktrace:
2021.10.21 16:29:01 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:29:01 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:29:01 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:30:26 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:30:26 1: stacktrace:
2021.10.21 16:30:26 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:30:26 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:30:26 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:31:51 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:31:51 1: stacktrace:
2021.10.21 16:31:51 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:31:51 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:31:51 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:33:16 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:33:16 1: stacktrace:
2021.10.21 16:33:16 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:33:16 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:33:16 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:34:41 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:34:41 1: stacktrace:
2021.10.21 16:34:41 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:34:41 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:34:41 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:36:06 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:36:06 1: stacktrace:
2021.10.21 16:36:06 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:36:06 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:36:06 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:37:31 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:37:31 1: stacktrace:
2021.10.21 16:37:31 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:37:31 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:37:31 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:38:56 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:38:56 1: stacktrace:
2021.10.21 16:38:56 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:38:56 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:38:56 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:40:21 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:40:21 1: stacktrace:
2021.10.21 16:40:21 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:40:21 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:40:21 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:41:48 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:41:48 1: stacktrace:
2021.10.21 16:41:48 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:41:48 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:41:48 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:43:12 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:43:12 1: stacktrace:
2021.10.21 16:43:12 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:43:12 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:43:12 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:44:38 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:44:38 1: stacktrace:
2021.10.21 16:44:38 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:44:38 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:44:38 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:46:02 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:46:02 1: stacktrace:
2021.10.21 16:46:02 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:46:02 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:46:02 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:47:28 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:47:28 1: stacktrace:
2021.10.21 16:47:28 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:47:28 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:47:28 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:48:52 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:48:52 1: stacktrace:
2021.10.21 16:48:52 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:48:52 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:48:52 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:50:17 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:50:17 1: stacktrace:
2021.10.21 16:50:17 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:50:17 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:50:17 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:51:43 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:51:43 1: stacktrace:
2021.10.21 16:51:43 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:51:43 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:51:43 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:53:08 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:53:08 1: stacktrace:
2021.10.21 16:53:08 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:53:08 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:53:08 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:54:33 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:54:33 1: stacktrace:
2021.10.21 16:54:33 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:54:33 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:54:33 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:55:57 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:55:57 1: stacktrace:
2021.10.21 16:55:57 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:55:57 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:55:57 1:     main::__ANON__                      called by fhem.pl (780)
2021.10.21 16:57:23 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at FHEM/HttpUtils.pm line 599.
2021.10.21 16:57:23 1: stacktrace:
2021.10.21 16:57:23 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (599)
2021.10.21 16:57:23 1:     main::HttpUtils_Connect2            called by FHEM/HttpUtils.pm (449)
2021.10.21 16:57:23 1:     main::__ANON__                      called by fhem.pl (780)
Wie kann ich den Ursprung des Warnings finden?
Ist das Überhaupt ein Fehler?
MFG Rico
Geht nicht gibt's nicht.
NUC-I3+Proxmox, Fritzbox 7590 AX, Synology DS414
Dimplex Wärmepumpe, Lüftungsanlage, Solarlog 1200
HM,IT,Lacross,EspEasy,Modbus,MQTT2, Freund von Shelly
ZitatWie kann ich den Ursprung des Warnings finden?
Ich wuerde "attr global verbose 5" setzen.
ZitatIst das Überhaupt ein Fehler?
Laut Ausgabe ist es ja nur eine Warnung :)
rico5588
Hängt vermutlich mit dem Modul Denon zusammen. Nach Verbose 5 im angelegten Denon Device sind die Meldungen weg.
