und
define HmIP_SCTH230_002D1D89B2B57E_11 HMCCUDEV 002D1D89B2B57E sd=11.LEVEL cd=12.LEVEL
attr HmIP_SCTH230_002D1D89B2B57E_11 ccureadingfilter 11,12,15,4..*
attr HmIP_SCTH230_002D1D89B2B57E_11 cmdIcon on:general_an off:general_aus
attr HmIP_SCTH230_002D1D89B2B57E_11 group Wozi.CO2_Sensor
attr HmIP_SCTH230_002D1D89B2B57E_11 substexcl pct|level
attr HmIP_SCTH230_002D1D89B2B57E_11 webCmd level:on:off
attr HmIP_SCTH230_002D1D89B2B57E_11 widgetOverride level:slider,0,10,100
# CFGFN
# DEF 002D1D89B2B57E sd=11.LEVEL cd=12.LEVEL
# FUUID 6376538b-f33f-6422-a1ab-26dd97dbdd4e16bb
# IODev CCU3
# NAME HmIP_SCTH230_002D1D89B2B57E_11
# NR 2617
# STATE 45
# TYPE HMCCUDEV
# ccuaddr 002D1D89B2B57E
# ccudevstate active
# ccuif HmIP-RF
# ccuname Wozi.CO2_Sensor
# ccurolectrl DIMMER_VIRTUAL_RECEIVER
# ccurolestate DIMMER_TRANSMITTER
# ccusubtype SCTH230
# ccutype HmIP-SCTH230
# eventCount 2
# firmware 1.0.6
# readonly no
# OLDREADINGS:
# READINGS:
# 2022-11-17 16:30:21 11.ACTIVITY_STATE UNKNOWN
# 2022-11-17 16:30:21 11.LEVEL 45
# 2022-11-17 16:30:21 11.LEVEL_STATUS NORMAL
# 2022-11-17 16:30:21 11.PROCESS STABLE
# 2022-11-17 16:30:21 11.SECTION 3
# 2022-11-17 16:30:21 11.SECTION_STATUS NORMAL
# 2022-11-17 16:30:21 12.ACTIVITY_STATE UNKNOWN
# 2022-11-17 16:30:21 12.LEVEL 45
# 2022-11-17 16:30:21 12.LEVEL_STATUS NORMAL
# 2022-11-17 16:30:21 12.PROCESS STABLE
# 2022-11-17 16:30:21 12.SECTION 3
# 2022-11-17 16:30:21 12.SECTION_STATUS NORMAL
# 2022-11-17 16:30:21 15.WEEK_PROGRAM_CHANNEL_LOCKS 0
# 2022-11-17 16:30:21 4.ACTUAL_TEMPERATURE 20.6
# 2022-11-17 16:30:21 4.ACTUAL_TEMPERATURE_STATUS NORMAL
# 2022-11-17 16:30:21 4.HUMIDITY 54
# 2022-11-17 16:30:21 4.HUMIDITY_STATUS NORMAL
# 2022-11-17 16:30:21 activity alive
# 2022-11-17 16:30:21 control 45
# 2022-11-17 16:30:21 devstate ok
# 2022-11-17 16:30:21 hmstate 45
# 2022-11-17 16:30:21 level 45
# 2022-11-17 16:30:21 pct 45
# 2022-11-17 16:30:21 rssidevice -92
# 2022-11-17 16:30:21 rssipeer -92
# 2022-11-17 16:30:21 state 45
# 2022-11-17 16:30:21 voltage 0.0
# hmccu:
# channels 16
# defCDP 12.LEVEL
# defSDP 11.LEVEL
# detect 5
# devspec 002D1D89B2B57E
# forcedev 0
# nodefaults 0
# role 0:MAINTENANCE,1:CARBON_DIOXIDE_RECEIVER,2:COND_SWITCH_TRANSMITTER,3:COND_SWITCH_TRANSMITTER,4:CLIMATE_TRANSCEIVER,5:COND_SWITCH_TRANSMITTER,6:COND_SWITCH_TRANSMITTER,7:SWITCH_TRANSMITTER,8:SWITCH_VIRTUAL_RECEIVER,9:SWITCH_VIRTUAL_RECEIVER,10:SWITCH_VIRTUAL_RECEIVER,11:DIMMER_TRANSMITTER,12:DIMMER_VIRTUAL_RECEIVER,13:DIMMER_VIRTUAL_RECEIVER,14:DIMMER_VIRTUAL_RECEIVER,15:DIMMER_WEEK_PROFILE
# setDefaults 0
# cmdlist:
# get
# set down oldLevel:noArg on-for-timer on-till on:noArg pct up off:noArg level toggle:noArg
# control:
# chn 12
# dpt LEVEL
# dp:
# 0.CONFIG_PENDING:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL false
# OVAL false
# SVAL false
# VAL false
# 0.DUTY_CYCLE:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL false
# OVAL false
# SVAL false
# VAL false
# 0.ERROR_CODE:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 0.INSTALL_TEST:
# VALUES:
# NVAL true
# ONVAL true
# OSVAL true
# OVAL true
# SVAL true
# VAL true
# 0.OPERATING_VOLTAGE:
# VALUES:
# NVAL 0.000000
# ONVAL 0.000000
# OSVAL 0.0
# OVAL 0.000000
# SVAL 0.0
# VAL 0.000000
# 0.OPERATING_VOLTAGE_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 0.RSSI_DEVICE:
# VALUES:
# NVAL -92
# ONVAL -92
# OSVAL -92
# OVAL 164
# SVAL -92
# VAL 164
# 0.RSSI_PEER:
# VALUES:
# NVAL -92
# ONVAL -92
# OSVAL -92
# OVAL 164
# SVAL -92
# VAL 164
# 0.UNREACH:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL alive
# OVAL false
# SVAL alive
# VAL false
# 0.UPDATE_PENDING:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL false
# OVAL false
# SVAL false
# VAL false
# 1.CONCENTRATION:
# VALUES:
# NVAL 706.000000
# ONVAL 706.000000
# OSVAL 706.0
# OVAL 706.000000
# SVAL 706.0
# VAL 706.000000
# 1.CONCENTRATION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 10.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 10.SECTION:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 10.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 10.STATE:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL off
# OVAL false
# SVAL off
# VAL false
# 11.ACTIVITY_STATE:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL UNKNOWN
# OVAL 0
# SVAL UNKNOWN
# VAL 0
# 11.LEVEL:
# VALUES:
# NVAL 45
# ONVAL 45
# OSVAL 45
# OVAL 0.450000
# SVAL 45
# VAL 0.450000
# 11.LEVEL_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 11.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 11.SECTION:
# VALUES:
# NVAL 3
# ONVAL 3
# OSVAL 3
# OVAL 3
# SVAL 3
# VAL 3
# 11.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 12.ACTIVITY_STATE:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL UNKNOWN
# OVAL 0
# SVAL UNKNOWN
# VAL 0
# 12.LEVEL:
# VALUES:
# NVAL 45
# ONVAL 45
# OSVAL 45
# OVAL 0.450000
# SVAL 45
# VAL 0.450000
# 12.LEVEL_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 12.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 12.SECTION:
# VALUES:
# NVAL 3
# ONVAL 3
# OSVAL 3
# OVAL 3
# SVAL 3
# VAL 3
# 12.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 13.ACTIVITY_STATE:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL UNKNOWN
# OVAL 0
# SVAL UNKNOWN
# VAL 0
# 13.LEVEL:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL off
# OVAL 0.000000
# SVAL off
# VAL 0.000000
# 13.LEVEL_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 13.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 13.SECTION:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 13.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 14.ACTIVITY_STATE:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL UNKNOWN
# OVAL 0
# SVAL UNKNOWN
# VAL 0
# 14.LEVEL:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL off
# OVAL 0.000000
# SVAL off
# VAL 0.000000
# 14.LEVEL_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 14.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 14.SECTION:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 14.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 15.WEEK_PROGRAM_CHANNEL_LOCKS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 4.ACTUAL_TEMPERATURE:
# VALUES:
# NVAL 20.600000
# ONVAL 20.600000
# OSVAL 20.6
# OVAL 20.600000
# SVAL 20.6
# VAL 20.600000
# 4.ACTUAL_TEMPERATURE_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 4.HUMIDITY:
# VALUES:
# NVAL 54
# ONVAL 54
# OSVAL 54
# OVAL 54
# SVAL 54
# VAL 54
# 4.HUMIDITY_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 7.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 7.SECTION:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 7.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 7.STATE:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL off
# OVAL false
# SVAL off
# VAL false
# 8.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 8.SECTION:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 8.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 8.STATE:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL off
# OVAL false
# SVAL off
# VAL false
# 9.PROCESS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL STABLE
# OVAL 0
# SVAL STABLE
# VAL 0
# 9.SECTION:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL 0
# OVAL 0
# SVAL 0
# VAL 0
# 9.SECTION_STATUS:
# VALUES:
# NVAL 0
# ONVAL 0
# OSVAL NORMAL
# OVAL 0
# SVAL NORMAL
# VAL 0
# 9.STATE:
# VALUES:
# NVAL false
# ONVAL false
# OSVAL off
# OVAL false
# SVAL off
# VAL false
# roleCmds:
# get:
# set:
# down:
# channel 12
# role DIMMER_VIRTUAL_RECEIVER
# subcount 1
# syntax V:LEVEL:?delta=-10
# usage down [delta]
# subcmd:
# 000:
# args -10
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname delta
# partype 2
# ps VALUES
# scn 000
# unit 100%
# level:
# channel 12
# subcount 1
# syntax V:LEVEL:?level
# usage level level
# subcmd:
# 000:
# args
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname level
# partype 2
# ps VALUES
# scn 000
# unit 100%
# off:
# channel 12
# subcount 1
# syntax V:LEVEL:0
# usage off
# subcmd:
# 000:
# args 0
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname LEVEL
# partype 3
# ps VALUES
# scn 000
# unit 100%
# oldLevel:
# channel 12
# subcount 1
# syntax V:LEVEL:100.5
# usage oldLevel
# subcmd:
# 000:
# args 100.5
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname LEVEL
# partype 3
# ps VALUES
# scn 000
# unit 100%
# on:
# channel 12
# subcount 1
# usage on
# subcmd:
# 000:
# args 100
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname LEVEL
# partype 3
# ps VALUES
# scn 000
# unit 100%
# on-for-timer:
# channel 12
# subcount 2
# syntax 1:V:DURATION_UNIT:0 2:V:ON_TIME,DURATION_VALUE:?duration 3:V:LEVEL:100
# usage on-for-timer duration
# subcmd:
# 000:
# args
# dpt ON_TIME
# fnc
# max 8580000.0
# min 0.0
# parname duration
# partype 2
# ps VALUES
# scn 002
# unit s
# 001:
# args 100
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname LEVEL
# partype 3
# ps VALUES
# scn 003
# unit 100%
# on-till:
# channel 12
# subcount 2
# syntax 1:V:DURATION_UNIT:0 2:V:ON_TIME,DURATION_VALUE:?time 3:V:LEVEL:100
# usage on-till time
# subcmd:
# 000:
# args
# dpt ON_TIME
# fnc
# max 8580000.0
# min 0.0
# parname time
# partype 2
# ps VALUES
# scn 002
# unit s
# 001:
# args 100
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname LEVEL
# partype 3
# ps VALUES
# scn 003
# unit 100%
# pct:
# channel 12
# subcount 3
# syntax 5:V:LEVEL:?level 1:V:DURATION_UNIT:0 2:V:ON_TIME,DURATION_VALUE:?time=0.0 3:V:RAMP_TIME_UNIT:0 4:V:RAMP_TIME,RAMP_TIME_VALUE:?ramp=0.5
# usage pct level [time] [ramp]
# subcmd:
# 000:
# args
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname level
# partype 2
# ps VALUES
# scn 005
# unit 100%
# 001:
# args 0.0
# dpt ON_TIME
# fnc
# max 8580000.0
# min 0.0
# parname time
# partype 2
# ps VALUES
# scn 002
# unit s
# 002:
# args 0.5
# dpt RAMP_TIME
# fnc
# max 8580000.0
# min 0.0
# parname ramp
# partype 2
# ps VALUES
# scn 004
# unit s
# up:
# channel 12
# subcount 1
# syntax V:LEVEL:?delta=+10
# usage up [delta]
# subcmd:
# 000:
# args +10
# dpt LEVEL
# fnc
# max 1.01
# min 0.0
# parname delta
# partype 2
# ps VALUES
# scn 000
# unit 100%
# state:
# chn 11
# dpt LEVEL
# powerMap:
# readingsDesc:
# energyCalc:
# rtype whr
# power:
# rtype w
setstate HmIP_SCTH230_002D1D89B2B57E_11 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 11.ACTIVITY_STATE UNKNOWN
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 11.LEVEL 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 11.LEVEL_STATUS NORMAL
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 11.PROCESS STABLE
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 11.SECTION 3
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 11.SECTION_STATUS NORMAL
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 12.ACTIVITY_STATE UNKNOWN
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 12.LEVEL 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 12.LEVEL_STATUS NORMAL
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 12.PROCESS STABLE
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 12.SECTION 3
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 12.SECTION_STATUS NORMAL
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 15.WEEK_PROGRAM_CHANNEL_LOCKS 0
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 4.ACTUAL_TEMPERATURE 20.6
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 4.ACTUAL_TEMPERATURE_STATUS NORMAL
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 4.HUMIDITY 54
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 4.HUMIDITY_STATUS NORMAL
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 activity alive
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 control 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 devstate ok
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 hmstate 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 level 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 pct 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 rssidevice -92
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 rssipeer -92
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 state 45
setstate HmIP_SCTH230_002D1D89B2B57E_11 2022-11-17 16:30:21 voltage 0.0
Bekommt man es hin die Funktionen (CO"-Wert, Temperatur, Feuchte, LED-Dimmer, Schaltausgang) in einem Device vernünftig abzubilden? Oder muss das Modul angepasst werden?
Danke für sachdienliche Hinweise!
Grüße,
Oliver
