[98_statistics] Modul hinkt scheinbar hinterher
Begonnen von andi11, 01 November 2021, 08:05:34
rob
So, nun das Log von meinem "burn-in Test"  :)
Zeitumstellung zw. 27.03.21 und 29.03.21
fhem-2021-03-27.log
2021.03.27 22:51:18.236 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-27 22:59:55
2021.03.27 22:51:18.236 4: statistics statistic: PeriodChange.380 Calculating statistics at startup
2021.03.27 22:51:18.236 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 0) for device 'at_stat'
2021.03.27 22:51:18.237 4: statistics statistic: doStatisticDuration.956 Calculating duration statistics for 'at_stat:state = Next: 23:01:07'
2021.03.27 22:59:55.009 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-27 23:59:55 (Day Change)
2021.03.27 22:59:55.009 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.27 22:59:55.009 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.27 22:59:55.009 4: statistics statistic: doStatisticDuration.956 Calculating duration statistics for 'at_stat:state = Next: 23:01:07'
2021.03.27 23:01:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 1'
2021.03.27 23:01:07.223 4: statistics statistic: doStatisticDelta.723 Initializing statistic of '.at_stat:count'.
2021.03.27 23:01:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 1'
2021.03.27 23:11:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 2'
2021.03.27 23:11:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 2'
2021.03.27 23:21:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 3'
2021.03.27 23:21:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 3'
2021.03.27 23:31:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 4'
2021.03.27 23:31:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 4'
2021.03.27 23:41:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 5'
2021.03.27 23:41:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 5'
2021.03.27 23:51:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 6'
2021.03.27 23:51:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 6'
2021.03.27 23:59:55.002 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 00:59:55
2021.03.27 23:59:55.002 4: statistics statistic: PeriodChange.362 Calculating day change
2021.03.27 23:59:55.002 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 2) for device 'at_stat'
2021.03.27 23:59:55.002 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 6'
2021.03.27 23:59:55.002 4: statistics statistic: doStatisticDelta.782 Shifting current day in last value of 'statCount'.
2021.03.27 23:59:55.003 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.27 23:59:55.003 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 5 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
fhem-2021-03-28.log
2021.03.28 00:01:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 7'
2021.03.28 00:01:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 7'
2021.03.28 00:11:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 8'
2021.03.28 00:11:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 8'
2021.03.28 00:21:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 9'
2021.03.28 00:21:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 9'
2021.03.28 00:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 10'
2021.03.28 00:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 10'
2021.03.28 00:41:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 11'
2021.03.28 00:41:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 11'
2021.03.28 00:51:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 12'
2021.03.28 00:51:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 12'
2021.03.28 00:59:55.001 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 01:59:55
2021.03.28 00:59:55.001 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 00:59:55.001 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 00:59:55.001 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 12'
2021.03.28 00:59:55.001 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 00:59:55.001 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 01:01:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 13'
2021.03.28 01:01:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 13'
2021.03.28 01:11:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 14'
2021.03.28 01:11:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 14'
2021.03.28 01:21:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 15'
2021.03.28 01:21:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 15'
2021.03.28 01:31:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 16'
2021.03.28 01:31:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 16'
2021.03.28 01:41:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 17'
2021.03.28 01:41:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 17'
2021.03.28 01:51:07.237 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 18'
2021.03.28 01:51:07.238 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 18'
2021.03.28 01:59:55.018 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 03:59:55
2021.03.28 01:59:55.019 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 01:59:55.019 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 01:59:55.019 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 18'
2021.03.28 01:59:55.019 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 01:59:55.019 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 03:01:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 19'
2021.03.28 03:01:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 19'
2021.03.28 03:11:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 20'
2021.03.28 03:11:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 20'
2021.03.28 03:21:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 21'
2021.03.28 03:21:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 21'
2021.03.28 03:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 22'
2021.03.28 03:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 22'
2021.03.28 03:41:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 23'
2021.03.28 03:41:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 23'
2021.03.28 03:51:07.234 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 24'
2021.03.28 03:51:07.235 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 24'
2021.03.28 03:59:55.006 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 04:59:55
2021.03.28 03:59:55.006 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 03:59:55.006 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 03:59:55.006 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 24'
2021.03.28 03:59:55.006 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 03:59:55.006 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 04:01:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 25'
2021.03.28 04:01:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 25'
2021.03.28 04:11:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 26'
2021.03.28 04:11:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 26'
2021.03.28 04:21:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 27'
2021.03.28 04:21:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 27'
2021.03.28 04:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 28'
2021.03.28 04:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 28'
2021.03.28 04:41:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 29'
2021.03.28 04:41:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 29'
2021.03.28 04:51:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 30'
2021.03.28 04:51:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 30'
2021.03.28 04:59:55.003 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 05:59:55
2021.03.28 04:59:55.003 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 04:59:55.003 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 04:59:55.003 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 30'
2021.03.28 04:59:55.004 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 04:59:55.004 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 05:01:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 31'
2021.03.28 05:01:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 31'
2021.03.28 05:11:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 32'
2021.03.28 05:11:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 32'
2021.03.28 05:21:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 33'
2021.03.28 05:21:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 33'
2021.03.28 05:31:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 34'
2021.03.28 05:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 34'
2021.03.28 05:41:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 35'
2021.03.28 05:41:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 35'
2021.03.28 05:51:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 36'
2021.03.28 05:51:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 36'
2021.03.28 05:59:55.003 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 06:59:55
2021.03.28 05:59:55.003 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 05:59:55.003 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 05:59:55.003 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 36'
2021.03.28 05:59:55.004 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 05:59:55.004 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 06:01:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 37'
2021.03.28 06:11:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 38'
2021.03.28 06:11:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 38'
2021.03.28 06:21:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 39'
2021.03.28 06:21:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 39'
2021.03.28 06:31:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 40'
2021.03.28 06:31:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 40'
2021.03.28 06:41:07.235 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 41'
2021.03.28 06:41:07.236 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 41'
2021.03.28 06:51:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 42'
2021.03.28 06:51:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 42'
2021.03.28 06:59:55.005 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 07:59:55
2021.03.28 06:59:55.005 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 06:59:55.006 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 06:59:55.006 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 42'
2021.03.28 06:59:55.006 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 06:59:55.006 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 07:01:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 43'
2021.03.28 07:01:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 43'
2021.03.28 07:11:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 44'
2021.03.28 07:11:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 44'
2021.03.28 07:21:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 45'
2021.03.28 07:21:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 45'
2021.03.28 07:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 46'
2021.03.28 07:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 46'
2021.03.28 07:41:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 47'
2021.03.28 07:41:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 47'
2021.03.28 07:51:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 48'
2021.03.28 07:51:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 48'
2021.03.28 07:59:55.002 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 08:59:55
2021.03.28 07:59:55.002 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 07:59:55.002 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 07:59:55.002 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 48'
2021.03.28 07:59:55.002 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 07:59:55.003 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 08:01:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 49'
2021.03.28 08:01:07.231 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 49'
2021.03.28 08:11:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 50'
2021.03.28 08:11:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 50'
2021.03.28 08:21:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 51'
2021.03.28 08:21:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 51'
2021.03.28 08:31:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 52'
2021.03.28 08:31:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 52'
2021.03.28 08:41:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 53'
2021.03.28 08:41:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 53'
2021.03.28 08:51:07.216 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 54'
2021.03.28 08:51:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 54'
2021.03.28 08:59:55.004 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 09:59:55
2021.03.28 08:59:55.004 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 08:59:55.004 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 08:59:55.004 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 54'
2021.03.28 08:59:55.004 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 08:59:55.005 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 09:01:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 55'
2021.03.28 09:01:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 55'
2021.03.28 09:11:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 56'
2021.03.28 09:11:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 56'
2021.03.28 09:21:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 57'
2021.03.28 09:21:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 57'
2021.03.28 09:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 58'
2021.03.28 09:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 58'
2021.03.28 09:41:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 59'
2021.03.28 09:41:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 59'
2021.03.28 09:51:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 60'
2021.03.28 09:51:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 60'
2021.03.28 09:59:55.009 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 10:59:55
2021.03.28 09:59:55.009 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 09:59:55.009 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 09:59:55.009 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 60'
2021.03.28 09:59:55.009 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 09:59:55.009 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 10:01:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 61'
2021.03.28 10:01:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 61'
2021.03.28 10:11:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 62'
2021.03.28 10:11:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 62'
2021.03.28 10:21:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 63'
2021.03.28 10:21:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 63'
2021.03.28 10:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 64'
2021.03.28 10:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 64'
2021.03.28 10:41:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 65'
2021.03.28 10:41:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 65'
2021.03.28 10:51:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 66'
2021.03.28 10:51:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 66'
2021.03.28 10:59:55.003 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 11:59:55
2021.03.28 10:59:55.003 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 10:59:55.003 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 10:59:55.003 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 66'
2021.03.28 10:59:55.003 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 10:59:55.004 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 11:01:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 67'
2021.03.28 11:01:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 67'
2021.03.28 11:11:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 68'
2021.03.28 11:11:07.231 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 68'
2021.03.28 11:21:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 69'
2021.03.28 11:21:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 69'
2021.03.28 11:31:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 70'
2021.03.28 11:31:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 70'
2021.03.28 11:41:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 71'
2021.03.28 11:41:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 71'
2021.03.28 11:51:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 72'
2021.03.28 11:51:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 72'
2021.03.28 11:59:55.009 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 12:59:55
2021.03.28 11:59:55.009 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 11:59:55.009 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 11:59:55.009 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 72'
2021.03.28 11:59:55.009 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 11:59:55.010 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 12:01:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 73'
2021.03.28 12:01:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 73'
2021.03.28 12:11:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 74'
2021.03.28 12:11:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 74'
2021.03.28 12:21:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 75'
2021.03.28 12:21:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 75'
2021.03.28 12:31:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 76'
2021.03.28 12:31:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 76'
2021.03.28 12:41:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 77'
2021.03.28 12:41:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 77'
2021.03.28 12:51:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 78'
2021.03.28 12:51:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 78'
2021.03.28 12:59:55.005 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 13:59:55
2021.03.28 12:59:55.005 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 12:59:55.005 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 12:59:55.006 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 78'
2021.03.28 12:59:55.006 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 12:59:55.006 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 13:01:07.234 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 79'
2021.03.28 13:01:07.235 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 79'
2021.03.28 13:11:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 80'
2021.03.28 13:11:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 80'
2021.03.28 13:21:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 81'
2021.03.28 13:21:07.234 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 81'
2021.03.28 13:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 82'
2021.03.28 13:31:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 82'
2021.03.28 13:41:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 83'
2021.03.28 13:41:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 83'
2021.03.28 13:51:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 84'
2021.03.28 13:51:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 84'
2021.03.28 13:59:55.003 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 14:59:55
2021.03.28 13:59:55.003 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 13:59:55.003 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 13:59:55.003 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 84'
2021.03.28 13:59:55.003 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 13:59:55.003 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 14:01:07.231 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 85'
2021.03.28 14:01:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 85'
2021.03.28 14:11:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 86'
2021.03.28 14:11:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 86'
2021.03.28 14:21:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 87'
2021.03.28 14:21:07.231 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 87'
2021.03.28 14:31:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 88'
2021.03.28 14:31:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 88'
2021.03.28 14:41:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 89'
2021.03.28 14:41:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 89'
2021.03.28 14:51:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 90'
2021.03.28 14:51:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 90'
2021.03.28 14:59:55.000 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 15:59:55
2021.03.28 14:59:55.000 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 14:59:55.001 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 14:59:55.001 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 90'
2021.03.28 14:59:55.001 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 14:59:55.001 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 15:01:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 91'
2021.03.28 15:01:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 91'
2021.03.28 15:11:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 92'
2021.03.28 15:11:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 92'
2021.03.28 15:21:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 93'
2021.03.28 15:21:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 93'
2021.03.28 15:31:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 94'
2021.03.28 15:31:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 94'
2021.03.28 15:41:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 95'
2021.03.28 15:41:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 95'
2021.03.28 15:51:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 96'
2021.03.28 15:51:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 96'
2021.03.28 15:59:55.002 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 16:59:55
2021.03.28 15:59:55.002 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 15:59:55.002 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 15:59:55.002 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 96'
2021.03.28 15:59:55.002 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 15:59:55.003 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 16:01:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 97'
2021.03.28 16:01:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 97'
2021.03.28 16:11:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 98'
2021.03.28 16:11:07.235 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 98'
2021.03.28 16:21:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 99'
2021.03.28 16:21:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 99'
2021.03.28 16:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 100'
2021.03.28 16:31:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 100'
2021.03.28 16:41:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 101'
2021.03.28 16:41:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 101'
2021.03.28 16:51:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 102'
2021.03.28 16:51:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 102'
2021.03.28 16:59:55.005 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 17:59:55
2021.03.28 16:59:55.005 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 16:59:55.005 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 16:59:55.006 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 102'
2021.03.28 16:59:55.006 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 16:59:55.006 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 17:01:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 103'
2021.03.28 17:01:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 103'
2021.03.28 17:11:07.231 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 104'
2021.03.28 17:11:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 104'
2021.03.28 17:21:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 105'
2021.03.28 17:21:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 105'
2021.03.28 17:31:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 106'
2021.03.28 17:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 106'
2021.03.28 17:41:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 107'
2021.03.28 17:41:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 107'
2021.03.28 17:51:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 108'
2021.03.28 17:51:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 108'
2021.03.28 17:59:55.010 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 18:59:55
2021.03.28 17:59:55.010 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 17:59:55.010 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 17:59:55.011 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 108'
2021.03.28 17:59:55.011 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 17:59:55.011 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 18:01:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 109'
2021.03.28 18:01:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 109'
2021.03.28 18:11:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 110'
2021.03.28 18:11:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 110'
2021.03.28 18:21:07.216 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 111'
2021.03.28 18:21:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 111'
2021.03.28 18:31:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 112'
2021.03.28 18:31:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 112'
2021.03.28 18:41:07.236 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 113'
2021.03.28 18:41:07.237 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 113'
2021.03.28 18:51:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 114'
2021.03.28 18:51:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 114'
2021.03.28 18:59:55.007 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 19:59:55
2021.03.28 18:59:55.007 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 18:59:55.007 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 18:59:55.007 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 114'
2021.03.28 18:59:55.008 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 18:59:55.008 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 19:01:07.235 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 115'
2021.03.28 19:01:07.236 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 115'
2021.03.28 19:11:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 116'
2021.03.28 19:11:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 116'
2021.03.28 19:21:07.234 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 117'
2021.03.28 19:21:07.235 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 117'
2021.03.28 19:31:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 118'
2021.03.28 19:31:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 118'
2021.03.28 19:41:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 119'
2021.03.28 19:41:07.234 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 119'
2021.03.28 19:51:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 120'
2021.03.28 19:51:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 120'
2021.03.28 19:59:55.004 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 20:59:55
2021.03.28 19:59:55.004 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 19:59:55.004 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 19:59:55.004 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 120'
2021.03.28 19:59:55.004 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 19:59:55.005 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 20:01:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 121'
2021.03.28 20:01:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 121'
2021.03.28 20:11:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 122'
2021.03.28 20:11:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 122'
2021.03.28 20:21:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 123'
2021.03.28 20:21:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 123'
2021.03.28 20:31:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 124'
2021.03.28 20:31:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 124'
2021.03.28 20:41:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 125'
2021.03.28 20:41:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 125'
2021.03.28 20:51:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 126'
2021.03.28 20:51:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 126'
2021.03.28 20:59:55.000 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 21:59:55
2021.03.28 20:59:55.001 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 20:59:55.001 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 20:59:55.001 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 126'
2021.03.28 20:59:55.001 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 20:59:55.001 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 21:01:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 127'
2021.03.28 21:01:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 127'
2021.03.28 21:11:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 128'
2021.03.28 21:11:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 128'
2021.03.28 21:21:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 129'
2021.03.28 21:21:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 129'
2021.03.28 21:31:07.228 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 130'
2021.03.28 21:31:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 130'
2021.03.28 21:41:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 131'
2021.03.28 21:41:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 131'
2021.03.28 21:51:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 132'
2021.03.28 21:51:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 132'
2021.03.28 21:59:55.008 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 22:59:55
2021.03.28 21:59:55.008 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 21:59:55.008 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 21:59:55.008 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 132'
2021.03.28 21:59:55.008 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 21:59:55.009 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 22:01:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 133'
2021.03.28 22:01:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 133'
2021.03.28 22:11:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 134'
2021.03.28 22:11:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 134'
2021.03.28 22:21:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 135'
2021.03.28 22:21:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 135'
2021.03.28 22:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 136'
2021.03.28 22:31:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 136'
2021.03.28 22:41:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 137'
2021.03.28 22:41:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 137'
2021.03.28 22:51:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 138'
2021.03.28 22:51:07.233 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 138'
2021.03.28 22:59:55.014 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-28 23:59:55 (Day Change)
2021.03.28 22:59:55.014 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.28 22:59:55.014 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.28 22:59:55.014 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 138'
2021.03.28 22:59:55.014 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 22:59:55.015 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 5 Month: - Year: - (since: 2021-03-27_23:01:07 )'
2021.03.28 23:01:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 139'
2021.03.28 23:01:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 139'
2021.03.28 23:11:07.231 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 140'
2021.03.28 23:11:07.232 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 140'
2021.03.28 23:21:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 141'
2021.03.28 23:21:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 141'
2021.03.28 23:31:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 142'
2021.03.28 23:31:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 142'
2021.03.28 23:41:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 143'
2021.03.28 23:41:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 143'
2021.03.28 23:51:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 144'
2021.03.28 23:51:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 144'
2021.03.28 23:59:55.011 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-29 00:59:55
2021.03.28 23:59:55.011 4: statistics statistic: PeriodChange.362 Calculating day change
2021.03.28 23:59:55.011 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 2) for device 'at_stat'
2021.03.28 23:59:55.011 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 144'
2021.03.28 23:59:55.011 4: statistics statistic: doStatisticDelta.782 Shifting current day in last value of 'statCount'.
2021.03.28 23:59:55.011 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.28 23:59:55.011 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 138 Month: - Year: -'
rob
war zu lang... hier der 29.03. noch
fhem-2021-03-29.log
2021.03.29 00:01:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 145'
2021.03.29 00:01:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 145'
2021.03.29 00:11:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 146'
2021.03.29 00:11:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 146'
2021.03.29 00:21:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 147'
2021.03.29 00:21:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 147'
2021.03.29 00:31:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 148'
2021.03.29 00:31:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 148'
2021.03.29 00:41:07.236 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 149'
2021.03.29 00:41:07.237 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 149'
2021.03.29 00:51:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 150'
2021.03.29 00:51:07.227 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 150'
2021.03.29 00:59:55.004 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-29 01:59:55
2021.03.29 00:59:55.004 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.29 00:59:55.004 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.29 00:59:55.004 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 150'
2021.03.29 00:59:55.004 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.29 00:59:55.004 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 138 Month: - Year: -'
2021.03.29 01:01:07.235 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 151'
2021.03.29 01:01:07.236 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 151'
2021.03.29 01:11:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 152'
2021.03.29 01:11:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 152'
2021.03.29 01:21:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 153'
2021.03.29 01:21:07.224 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 153'
2021.03.29 01:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 154'
2021.03.29 01:31:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 154'
2021.03.29 01:41:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 155'
2021.03.29 01:41:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 155'
2021.03.29 01:51:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 156'
2021.03.29 01:51:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 156'
2021.03.29 01:59:55.004 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-29 02:59:55
2021.03.29 01:59:55.004 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.29 01:59:55.004 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.29 01:59:55.004 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 156'
2021.03.29 01:59:55.005 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.29 01:59:55.005 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 138 Month: - Year: -'
2021.03.29 02:01:07.225 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 157'
2021.03.29 02:01:07.226 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 157'
2021.03.29 02:11:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 158'
2021.03.29 02:11:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 158'
2021.03.29 02:21:07.217 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 159'
2021.03.29 02:21:07.218 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 159'
2021.03.29 02:31:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 160'
2021.03.29 02:31:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 160'
2021.03.29 02:41:07.222 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 161'
2021.03.29 02:41:07.223 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 161'
2021.03.29 02:51:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 162'
2021.03.29 02:51:07.221 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 162'
2021.03.29 02:59:55.001 4: statistics statistic: PeriodChange.345 Next period change will be calculated at 2021-03-29 03:59:55
2021.03.29 02:59:55.001 4: statistics statistic: PeriodChange.378 Calculating hour change
2021.03.29 02:59:55.001 4: statistics statistic: DoStatisticsAll.399 Doing statistics (period 1) for device 'at_stat'
2021.03.29 02:59:55.001 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 162'
2021.03.29 02:59:55.001 4: statistics statistic: doStatisticDelta.791 Shifting current hour in last value of 'statCount'.
2021.03.29 02:59:55.002 4: statistics statistic: doStatisticDelta.811 Set 'statCountLast'='Hour: 6 Day: 138 Month: - Year: -'
2021.03.29 03:01:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 163'
2021.03.29 03:01:07.231 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 163'
2021.03.29 03:11:07.219 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 164'
2021.03.29 03:11:07.220 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 164'
2021.03.29 03:21:07.229 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 165'
2021.03.29 03:21:07.230 4: statistics statistic: doStatisticDelta.707 Calculating delta statistics for 'at_stat:count = 165'
 8) Dann würde ich mal behaupten, dass der "Hosenträger" gehalten hat. Sieht für mich ok aus. Dann hoffen wir mal, dass @tupol irgendwann dazu kommt, sich das auch nochmal näher anzusehen und ggf. irgendeine Maschine findet, es einzuchecken :) .
Fettes DANKE für die geduldigen Tests!
Server: HP-elitedesk@Debian 12, aktuelles FHEM@ConfigDB | CUL_HM (VCCU) | MQTT2: MiLight@ESP-GW, BT@OpenMQTTGw | MySensors: seriell, v.a. 2.3.1@RS485 | ZWave | ZigBee@deCONZ | SIGNALduino | MapleCUN | RHASSPY
rob
booster
Hallo zusammen, ist das Modul schon im Repositiory geupdatet worden?
Bislang hat tupol sich hierzu nicht wieder gemeldet, letzte Info war:
Zitat von: tupol am 06 November 2021, 10:48:27
Bei mir ist (mal wieder) die SD-Karte von der Raspberry Pi abgeschmiert. Wird aber leider noch eine Weile dauern bis ich dies und die Bug hier fixen kann.
Im svn ist auch nichts passiert, von daher ist wohl die Fassung aus https://forum.fhem.de/index.php/topic,123815.msg1187615.html#msg1187615 "Stand der Dinge"...
Adimarantis
@Beta-User:
Nachdem ich auch Probleme mit dem Modul hatte, habe ich die erfolgreich mit deiner Version beheben können.
Da das "offizielle" Modul im SVN somit faktisch nicht richtig funktioniert, würde ich dafür plädieren deine Version im SVN einzuchecken. Der original Autor hat sich ja scheinbar immer noch nicht gemeldet und auch wenn du es nicht offiziell maintainen möchtest, wäre das immer noch besser, als weitere Anwender in die selben Probleme laufen zu lassen bis sie nach langem Suchen in diesem Thread landen (oder aufgeben).
Dann könnte ich mein "exclude-from-update" wieder löschen  :)
Falls du doch Lust aufs maintainen kriegt, hätte ich gleich einen Verbesserungsvorschlag: Mir sind das zu viele Statistics - mir würde jeweils "Monat" reichen - die anderen würde ich gerne unterdrücken können - oder kapier ich bloss nicht wie das geht?
Jörg
Raspberry 4 + HM-MOD-RPI-PCB (pivCCU) + RfxTrx433XL + 2xRaspberry 1
Module: 50_Signalbot, 52_I2C_ADS1x1x , 58_RPI_1Wire, (50_SPI_MAX31865)
Zitat von: Adimarantis am 20 Februar 2022, 17:11:06
@Beta-User:
Danke für die Rückmeldung, sowas ist sicher für tupol auch wichtig zu wissen in der Entscheidungsfindung, ob das eingecheckt werden soll.
Ich mache das im Auftrag ggf. auch, aber nicht ohne offizielle Aufforderung durch den verantwortlichen Maintainer, ich habe keine große Neigung, ohne Not ein nicht verwaistes Modul an mich zu ziehen! Falls seitens des Maintainers Unterstützung gewünscht ist, ist das ggf. was anderes, hier ist allerdings das coding (wie bei allen älteren Modulen) so, dass sich ein paar grundsätzliche Fragen stellen würden (Perlcritic...)...
PS: Neue Module sollte man m.E. im "package-Format" auslegen, "Rummosten" im main-namespace ist m.E. ein "no-go".
Die Kritik ist btw. zu weitgehend, "nur" weil es in einer bestimmten, sehr speziellen Konstellation Probleme gab.
Diese Sichtweise teile ich durchaus :) .
Falls ich mir noch was "reinziehe", dann eher "monitoring", und patches nimmt grundsätzlich jeder Maintainer entgegen, also falls du was beisteuern magst ;) . Mich haben die weiteren statistics-Readings bisher nicht gestört.
Allerdings gabe es da mal noch eine Diskussion, die mir von ferne in Erinnerung war, dass bestimmte Konstellationen nicht miteinander gingen. Falls das noch aktuell ist (?), wäre eine Beschriebung/ein Link hilfreich, dann kann ggf. wer auch immer sich da unter das Auto legen will diesen Punkt vielleicht auch gleich lösen.
Allgaeuer
Ich habe jetzt auch die Version von Beta-User eingespielt. An dieser Stelle herzlichen Dank an Beta-User und rob  :)
Beim Wechsel von Winter- auf Sommerzeit in diesem März wird auch das alte Modul funktionieren, weil das nicht auf den Monatswechsel fällt. Früher oder später ist das aber wieder der Fall und dann sollte alles richtig laufen. Ich muss nur aufpassen, dass ich bei einem Update nicht versehentlich die alte Version wieder draufnagle.
Viele Grüße vom Allgäuer.
@tupol: Da mal wieder Umstellungszeit war: Hattest du zwischenzeitlich Gelegenheit, dir das anzusehen?
tupol
Danke für deine tolle Arbeit, Beta-User  :) . Du kannst die Änderung gerne einspielen.
NB: Bin aus diversen Gründen kaum noch aktiv in FHEM.
Danke für die Rückmeldung, ist seit eben im svn.
Danke auch nochmal an rob für's geduldige Testen!
Allgaeuer
am kommenden Monatsende mit Umstellung auf Sommerzeit gibt's wieder die kritische Situation.
Ich drück die Daumen, dass es diesmal klappt :-)
Danke an Beta-user und rob für die Modulanpassung und das Testen.
Gruß Allgäuer
