Autor Thema: COMET DECT - windowopen ohne Funktion  (Gelesen 384 mal)
Offline Matze89
  • Jr. Member
« am: 18 November 2021, 09:59:27 »
Hallo an euch,
FritzBox! OS: 07.29
FritzBox! 6590 Cable
Komischerweise bei FRITZ!DECT 301 funktioniert - bei COMET DECT nicht.
windowopen 300 - ohne Funktion.
Anbei die Debugdaten vom FBDect und FBAHAHTTP:
2021.11.18 11:08:15.333 5: FBAHAHTTP_Write reply for FB: 253
2021.11.18 11:08:14.829 5: FBAHAHTTP_Write reply for FB: 1637231893
2021.11.18 11:08:14.310 5: FB: dispatch <group synchronized="1" identifier="grpEEDBB2-3B29A3899" id="900" functionbitmask="4160" fwversion="1.0" manufacturer="AVM" productname=""><present>1</present><txbusy>0</txbusy><name>WZ-Heizung</name><hkr><tist></tist><tsoll>40</tsoll><absenk>30</absenk><komfort>40</komfort><lock>0</lock><devicelock>0</devicelock><errorcode>0</errorcode><windowopenactiv>0</windowopenactiv><windowopenactiveendtime>0</windowopenactiveendtime><boostactive>0</boostactive><boostactiveendtime>0</boostactiveendtime><nextchange><endperiod>1637258400</endperiod><tchange>30</tchange></nextchange><summeractive>0</summeractive><holidayactive>0</holidayactive></hkr><groupinfo><masterdeviceid>0</masterdeviceid><members>16,17</members></groupinfo></group>
2021.11.18 11:08:14.301 5: FB: dispatch <device identifier="01803 0048324" id="22" functionbitmask="320" fwversion="04.94" manufacturer="AVM" productname="FRITZ!DECT 301"><present>1</present><txbusy>0</txbusy><name>SZ-Heizung</name><battery>70</battery><batterylow>0</batterylow><temperature><celsius>150</celsius><offset>20</offset></temperature><hkr><tist>30</tist><tsoll>253</tsoll><absenk>30</absenk><komfort>40</komfort><lock>0</lock><devicelock>0</devicelock><errorcode>0</errorcode><windowopenactiv>0</windowopenactiv><windowopenactiveendtime>0</windowopenactiveendtime><boostactive>0</boostactive><boostactiveendtime>0</boostactiveendtime><batterylow>0</batterylow><battery>70</battery><nextchange><endperiod>1637258400</endperiod><tchange>40</tchange></nextchange><summeractive>0</summeractive><holidayactive>0</holidayactive></hkr></device>
2021.11.18 11:08:14.299 5:    name = BZ-Heizung
2021.11.18 11:08:14.298 5:    offset = 15
2021.11.18 11:08:14.298 5:    summeractive = 0
2021.11.18 11:08:14.298 5:    windowopenactiv = 0
2021.11.18 11:08:14.297 5:    batterylow = 0
2021.11.18 11:08:14.297 5:    manufacturer = AVM
2021.11.18 11:08:14.297 5:    id = 19
2021.11.18 11:08:14.297 5:    productname = Comet DECT
2021.11.18 11:08:14.296 5:    battery = 90
2021.11.18 11:08:14.296 5:    boostactive = 0
2021.11.18 11:08:14.296 5:    tsoll = 253
2021.11.18 11:08:14.296 5:    lock = 0
2021.11.18 11:08:14.295 5:    celsius = 190
2021.11.18 11:08:14.295 5:    identifier = 11959 0389176
2021.11.18 11:08:14.295 5:    tist = 38
2021.11.18 11:08:14.295 5:    absenk = 32
2021.11.18 11:08:14.294 5:    errorcode = 0
2021.11.18 11:08:14.294 5:    tchange = 42
2021.11.18 11:08:14.294 5:    txbusy = 0
2021.11.18 11:08:14.294 5:    endperiod = 1637251200
2021.11.18 11:08:14.293 5:    present = 1
2021.11.18 11:08:14.293 5:    komfort = 42
2021.11.18 11:08:14.293 5:    functionbitmask = 320
2021.11.18 11:08:14.293 5:    devicelock = 0
2021.11.18 11:08:14.292 5:    fwversion = 03.68
2021.11.18 11:08:14.292 5:    boostactiveendtime = 0
2021.11.18 11:08:14.291 5:    windowopenactiveendtime = 0
2021.11.18 11:08:14.291 5:    holidayactive = 0
2021.11.18 11:08:14.291 5: FB_Heater_BZ
2021.11.18 11:08:14.290 5: FB: dispatch <device identifier="11959 0389176" id="19" functionbitmask="320" fwversion="03.68" manufacturer="AVM" productname="Comet DECT"><present>1</present><txbusy>0</txbusy><name>BZ-Heizung</name><battery>90</battery><batterylow>0</batterylow><temperature><celsius>190</celsius><offset>15</offset></temperature><hkr><tist>38</tist><tsoll>253</tsoll><absenk>32</absenk><komfort>42</komfort><lock>0</lock><devicelock>0</devicelock><errorcode>0</errorcode><windowopenactiv>0</windowopenactiv><windowopenactiveendtime>0</windowopenactiveendtime><boostactive>0</boostactive><boostactiveendtime>0</boostactiveendtime><batterylow>0</batterylow><battery>90</battery><nextchange><endperiod>1637251200</endperiod><tchange>42</tchange></nextchange><summeractive>0</summeractive><holidayactive>0</holidayactive></hkr></device>
Allerdings Boost 300 geht testweise
2021.11.18 11:06:13.364 5:    boostactive = 1
2021.11.18 11:06:13.364 5:    tsoll = 253
2021.11.18 11:06:13.363 5:    celsius = 190
2021.11.18 11:06:13.363 5:    lock = 0
2021.11.18 11:06:13.362 5:    windowopenactiv = 0
2021.11.18 11:06:13.362 5:    summeractive = 0
2021.11.18 11:06:13.361 5:    manufacturer = AVM
2021.11.18 11:06:13.360 5:    batterylow = 0
2021.11.18 11:06:13.359 5:    offset = 15
2021.11.18 11:06:13.358 5:    name = BZ-Heizung
2021.11.18 11:06:13.358 5:    productname = Comet DECT
2021.11.18 11:06:13.357 5:    battery = 90
2021.11.18 11:06:13.356 5:    id = 19
2021.11.18 11:06:13.356 5:    functionbitmask = 320
2021.11.18 11:06:13.354 5:    komfort = 42
2021.11.18 11:06:13.352 5:    endperiod = 1637251200
2021.11.18 11:06:13.352 5:    present = 1
2021.11.18 11:06:13.351 5:    boostactiveendtime = 1637230263
2021.11.18 11:06:13.348 5:    holidayactive = 0
2021.11.18 11:06:13.343 5:    windowopenactiveendtime = 0
2021.11.18 11:06:13.342 5:    devicelock = 0
2021.11.18 11:06:13.340 5:    fwversion = 03.68
2021.11.18 11:06:13.339 5:    tist = 38
2021.11.18 11:06:13.338 5:    errorcode = 0
2021.11.18 11:06:13.337 5:    absenk = 32
2021.11.18 11:06:13.336 5:    identifier = 11959 0389176
2021.11.18 11:06:13.336 5:    tchange = 42
2021.11.18 11:06:13.335 5:    txbusy = 0
2021.11.18 11:06:13.335 5: FB_Heater_BZ
2021.11.18 11:06:03.020 5: FB_Heater_BZ: raw sethkrboost&endtimestamp=1637230263
2021.11.18 11:06:03.019 3: FBDECT set FB_Heater_BZ boost
Hier die RAW-Daten
defmod FB_Heater_BZ FBDECT FB:11959_0389176 actuator,tempSensor
attr FB_Heater_BZ IODev FB
attr FB_Heater_BZ alexaName Heizung Badezimmer
attr FB_Heater_BZ alias Heizung Badezimmer
attr FB_Heater_BZ event-min-interval HeatingCoolingStat:260,temperature:260,atemp:260,mtemp:260
attr FB_Heater_BZ event-on-change-reading .*
attr FB_Heater_BZ genericDeviceType thermostat
attr FB_Heater_BZ group Heizungen
attr FB_Heater_BZ homebridgeMapping clear\
CurrentTemperature=mtemp\
TargetTemperature=desired-temp::atemp,minValue=8,maxValue=28,minStep=0.5\
TargetHeatingCoolingState=HeatingCoolingStat,values=OFF:0;;;;HEAT:1;;;;COOL:2;;;;AUTO:3,cmds=OFF:closed;;HEAT:day-temp-n;;COOL:night-temp-n\
CurrentHeatingCoolingState=HeatingCoolingStat,values=HEAT:1;;;;COOL:2;;;;OFF:0;;;;AUTO:0,valud=AUTO\
LockPhysicalControls=devicelock,values=no:CONTROL_LOCK_DISABLED;;yes:CONTROL_LOCK_ENABLED\
StatusActive=present,valueOn=yes,valueOff=no\
history:size=1024\
BatteryService#BatteryLevel=battery,default=0,minValue=0,maxValue=100,minStep=1\
BatteryService#StatusLowBattery:batteryState,values=ok:BATTERY_LEVEL_NORMAL;;/^.*/:BATTERY_LEVEL_LOW\
BatteryService#ChargingState:default=2
attr FB_Heater_BZ icon sani_heating
attr FB_Heater_BZ room Home,HomeKit,Räume->Badezimmer
attr FB_Heater_BZ siriName Heizung Badezimmer
attr FB_Heater_BZ stateFormat mtemp °C Zimmertemperatur
attr FB_Heater_BZ userReadings HeatingCoolingStat {if((ReadingsVal($NAME,"desired-temp","") eq "off") or (ReadingsVal($NAME,"desired-temp","") eq "7.5"))  {return "OFF"} \
elsif (ReadingsVal($NAME,"desired-temp","") eq ReadingsVal($NAME,"day-temp","")) {return "HEAT"} \
elsif (ReadingsVal($NAME,"desired-temp","") eq ReadingsVal($NAME,"night-temp","")) {return "COOL"} \
else {return "AUTO"}},\
atemp {if(ReadingsVal($NAME,"desired-temp","") eq "off") {return "0"} \
elsif (ReadingsVal($NAME,"desired-temp","") eq "on") {return "28"} \
else {ReadingsNum($NAME,"state",1)}},\
mtemp {ReadingsNum($NAME,"temperature",1)},\
dtemp {ReadingsNum($NAME,"desired-temp",1)},\
day-temp-n {ReadingsNum($NAME,"day-temp",1)},\
night-temp-n {ReadingsNum($NAME,"night-temp",1)},\
ContactSensor  { ReadingsVal("HUE_Contact_W_BZ","state",0) }
attr FB_Heater_BZ verbose 5
attr FB_Heater_BZ webCmd desired-temp
setstate FB_Heater_BZ 19.0 °C Zimmertemperatur
setstate FB_Heater_BZ 2021-11-18 11:03:35 AIN 11959 0389176
setstate FB_Heater_BZ 2021-11-18 11:03:35 ContactSensor open
setstate FB_Heater_BZ 2021-11-18 11:03:35 FBNAME BZ-Heizung
setstate FB_Heater_BZ 2021-11-18 11:03:35 FBPROP actuator,tempSensor
setstate FB_Heater_BZ 2021-11-18 11:03:35 FBTYPE Comet DECT
setstate FB_Heater_BZ 2021-11-18 11:03:35 HeatingCoolingStat OFF
setstate FB_Heater_BZ 2021-11-18 11:03:35 ID 19
setstate FB_Heater_BZ 2021-11-16 13:07:00 IODev FB
setstate FB_Heater_BZ 2021-11-18 11:03:35 atemp 7.5
setstate FB_Heater_BZ 2021-11-18 11:03:35 battery 90 %
setstate FB_Heater_BZ 2021-11-18 11:03:35 batteryPercent 90
setstate FB_Heater_BZ 2021-11-18 11:03:35 batteryState ok
setstate FB_Heater_BZ 2021-11-18 11:03:35 batterylow 0
setstate FB_Heater_BZ 2021-11-18 11:03:35 boostactive no
setstate FB_Heater_BZ 2021-11-18 11:03:35 boostactiveendtime N/A
setstate FB_Heater_BZ 2021-11-18 11:03:35 day-temp 21.0 C
setstate FB_Heater_BZ 2021-11-18 11:03:35 day-temp-n 21.0
setstate FB_Heater_BZ 2021-11-18 11:03:35 desired-temp 7.5
setstate FB_Heater_BZ 2021-11-18 11:03:35 devicelock no
setstate FB_Heater_BZ 2021-11-18 11:03:35 dtemp 7.5
setstate FB_Heater_BZ 2021-11-18 11:03:35 errorcode noError (0)
setstate FB_Heater_BZ 2021-11-18 11:03:35 fwversion 03.68
setstate FB_Heater_BZ 2021-11-18 11:03:35 holidayactive no
setstate FB_Heater_BZ 2021-11-18 11:03:35 locked no
setstate FB_Heater_BZ 2021-11-18 11:03:35 mtemp 19.0
setstate FB_Heater_BZ 2021-11-18 11:03:35 nextPeriodStart 2021-11-18 17:00:00
setstate FB_Heater_BZ 2021-11-18 11:03:35 nextPeriodTemp 21.0 C
setstate FB_Heater_BZ 2021-11-18 11:03:35 night-temp 16.0 C
setstate FB_Heater_BZ 2021-11-18 11:03:35 night-temp-n 16.0
setstate FB_Heater_BZ 2021-11-18 11:03:35 present yes
setstate FB_Heater_BZ 2021-11-18 11:03:35 state desired-temp: 7.5
setstate FB_Heater_BZ 2021-11-18 11:03:35 summeractive no
setstate FB_Heater_BZ 2021-11-18 11:03:35 tempadjust 1.5 C
setstate FB_Heater_BZ 2021-11-18 11:03:35 temperature 19.0 C (measured)
setstate FB_Heater_BZ 2021-11-18 11:03:35 windowopenactiv no
setstate FB_Heater_BZ 2021-11-18 11:03:35 windowopenactiveendtime N/A
Mit der Bitte um Hilfe. Vielen Dank.
« Letzte Änderung: 18 November 2021, 12:01:55 von Matze89 »
FHEM mit RPi4 ::: SIGNALduino ::: Homebridge + homebridge-fhem ::: Zigbee = RaspBee + Hue + Paulmann + Ikea + Xiaomi ::: DECT = FritzBox 6590 + FRITZ!DECT ::: IR = Harmony ::: SIRO Akku-Rolloantrieb ::: EchoDots + alexa-fhem
Offline rudolfkoenig
  • Administrator
Antw:COMET DECT - windowopen ohne Funktion
« Antwort #1 am: 18 November 2021, 12:26:11 »
Ich habe jetzt den Beitrag dreimal gelesen, die "raw" Daten (das sind die FB: dispatch Zeilen) auseinandergenommen und Wert fuer Wert mit dem Code verglichen, und verstehe immer noch nicht, was mit "windowopen ohne Funktion" gemeint ist.
Ich fuerchte ich brauche eine bessere Beschreibung des Problems.
Offline Matze89
  • Jr. Member
« Antwort #2 am: 18 November 2021, 13:01:35 »
okay, entschuldige meine sehr kurz gehaltene Zusammenfassung. Normalerweise schreibe ich viel zu viel, daher dachte ich - ich halte mich diesmal kurz und bündig.
Ich nutze diese COMET-Dect Heizsteuersysteme mit der FritzBox.
Als Befehl nutze ich Fenster auf den manuellen Weg über FHEM mit einer DOIF-Abfrage.
Wenn ich den Befehl:
"set FB_Heater_BZ windowopen 300" - 5 Minuten auf Fenster auf-Stellung stelle. - Wird die Heizung abgedreht.
Nur bei den COMET-Geräten funktioniert es nicht. (3 Stück.) Ich habe noch zwei mit FritzDect301! - Da funktioniert es einwandfrei.
Es wird auch nicht der Wert  windowopenactiv = 0 auf 1 gesetzt + Time aktualisiert.
« Letzte Änderung: 18 November 2021, 13:22:43 von Matze89 »
  • Administrator
« Antwort #3 am: 18 November 2021, 13:25:21 »
Ich fuerchte da kann ich nicht weiterhelfen, insb. wenn das bei FRITZ!DECT 301 funktioniert.
Das Modul sendet fuer beide Geraete die gleichen Anweisungen an die FritzBox, diese und die jeweiligen Firmwares muessen fuer die Umsetzung sorgen.
Funktioniert windowopen aus der FritzBox-Oberflaeche?
Offline juemuc
« Antwort #4 am: 18 November 2021, 13:30:46 »
meines Wissens funktioniert das nicht mit den "alten" CometDect.
Jürgen
Fritzbox 7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM Fensterkontakte und  Amazon Echo Dot, raspberry3B+ mit RPI-RF-MOD und piVCCU, Raspbian Buster Lite
