Autor Thema: Probleme bei Installation Aeon Labs Z-Stick Series 2 auf Synology DS1511+ (x86-Architektur)  (Gelesen 11366 mal)
wolkensurfer
  • Gast
Sehr guter Hinweis Andre!
Habe mknod /dev/ttyUSB0 c 188 0 eingegeben und danach in fhem ein shutdown und restart ausgeführt - voila:
2013.05.16 23:42:40 1: usb scan starting
2013.05.16 23:42:40 3: Opening TCM310 device /dev/ttyUSB0
2013.05.16 23:42:40 3: Setting TCM310 baudrate to 57600
2013.05.16 23:42:40 3: TCM310 device opened
2013.05.16 23:42:41 3: Opening TCM120 device /dev/ttyUSB0
2013.05.16 23:42:41 3: Setting TCM120 baudrate to 9600
2013.05.16 23:42:41 3: TCM120 device opened
2013.05.16 23:42:41 3: Opening FHZ device /dev/ttyUSB0
2013.05.16 23:42:41 3: Setting FHZ baudrate to 9600
2013.05.16 23:42:41 3: FHZ device opened
2013.05.16 23:42:41 3: Opening TRX device /dev/ttyUSB0
2013.05.16 23:42:41 3: Setting TRX baudrate to 38400
2013.05.16 23:42:41 3: TRX device opened
2013.05.16 23:42:42 3: Opening ZWDongle device /dev/ttyUSB0
2013.05.16 23:42:42 3: Setting ZWDongle baudrate to 115200
2013.05.16 23:42:42 3: ZWDongle device opened
2013.05.16 23:42:42 1: usb scan end
2013.05.16 23:42:42 3: Opening ZWStick device /dev/ttyUSB0
2013.05.16 23:42:42 3: ZWStick device opened
2013.05.16 23:42:43 1: ZWStick: SOF missing (got 92 instead of 01)
2013.05.16 23:42:45 1: ZWStick: SOF missing (got 92 instead of 01)
2013.05.16 23:42:46 1: ZWStick: SOF missing (got 92 instead of 01)
2013.05.16 23:42:49 1: configfile: ### ttyUSB0: checking if it is a TCM310
got wrong answer for a TCM310
### ttyUSB0: checking if it is a TCM120
got wrong answer for a TCM120
### ttyUSB0: checking if it is a FHZ
got wrong answer for a FHZ
### ttyUSB0: checking if it is a TRX
got wrong answer for a TRX
### ttyUSB0: checking if it is a ZWDongle
create as a fhem device with: define ZWDongle_0 ZWDongle /dev/ttyUSB0@115200
2013.05.16 23:42:49 1: Including /usr/local/FHEM/var/log/fhem.save
2013.05.16 23:42:49 1: usb scan starting
2013.05.16 23:42:50 1: usb scan end
2013.05.16 23:42:50 3: initialUsbCheck return value: ### ttyUSB0: checking if it is a TCM310
already used by the ZWStick fhem device
2013.05.16 23:42:50 2: SecurityCheck:  WEB,WEBphone,WEBtablet has no basicAuth attribute. telnetPort has no password/globalpassword attribute. Running with root privileges. Restart fhem for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2013.05.16 23:42:50 0: Server started (version Fhem 5.3 (DEVELOPMENT), $Id: fhem.pl 1996 2012-10-20 07:11:56Z rudolfkoenig $, pid 9214)
Der Stick ist also schon mal ansprechbar! :-)
Jetzt muss ich "nur" noch herausfinden, was ich an gut gewählter Stelle ändern muss, damit dieser mknod-Befehl beim Systemstart der DS erfolgreich ausgeführt wird.
Ein dickes Dankeschön an Dich, Andre!
Gruss,
Andreas
Offline justme1968
die mit mknod angelegten devices bleiben erhalten bis sie gelöscht werden. d.h. sie sollten auch einen reboot überstehen.
  andre
FS20:fs20as4,fs20bs,fs20di
AKCP:THS01,WS15
CUL_WS:S300TH
wolkensurfer
  • Gast
Danke für den Hinweis, das macht die Sache für den Augenblick etwas entspannter. Ich werde mir die startup-Skripte intensiver anschauen. Habe gerade das hier im www gefunden:
Now you have to load the modules into the kernel and create the devices:
insmod usbserial.ko
insmod ftdi.ko
mknod /dev/usb/ttyUSB0 c 188 0
mknod /dev/usb/ttyUSB1 c 188 1
Also, add some lines like these to /etc/rc.local to make it persistent over reboot:
insmod /volume1/archive/usbserial.ko
insmod /volume1/archive/ftdi_sio.ko
[/b]
An der Stelle werde ich dann nächstens weiter machen...
Andre, nochmals vielen Dank für Deine tolle Unterstützung - Du hast mir sehr weiter geholfen!
Gruss,
Andreas
