Xiaomi - YeeLight -> merkwürdiges Verhalten seit Update
Begonnen von GoldenAmerican, 01 Dezember 2021, 19:38:40
GoldenAmerican
Servus zusammen,
habe mal mein Raspi und danach mein FHEM updatet und seitdem gehen meine YeeLights von alleine wieder aus. Da ich am Webinterface sitze und die Lampe im Blick habe, kann ich mit Sicherheit sagen, dass keine Aktion "von außen" passiert. Trotz allem gehen meine Lampen von allein aus. Warum? Anbei mal ein Verbose 5 einer Birne (sind insgesamt 4 in einer Lampe).
2021.12.01 19:23:30 4: YeeLight_1 is sending: {"method":"set_power","params":["on","smooth",5000],"id":53}
2021.12.01 19:23:30 5: YeeLight_1: Reading raw: {"id":53,"result":["ok"]}
2021.12.01 19:23:30 4: reading from YeeLight_1: {"id":53,"result":["ok"]}
2021.12.01 19:23:30 5: YeeLight_1 AnswerQueue: added {"id":53,"result":["ok"]}
2021.12.01 19:23:30 3: YeeLight_1 success sending 53: {"method":"set_power","params":["on","smooth",5000],"id":53}
2021.12.01 19:23:30 5: YeeLight_1 SendQueue: deleted {"method":"set_power","params":["on","smooth",5000],"id":53}
2021.12.01 19:23:30 5: YeeLight_1 AnswerQueue: deleted {"id":53,"result":["ok"]}
2021.12.01 19:23:30 5: YeeLight_1: Reading raw: {"method":"props","params":{"power":"on"}}
2021.12.01 19:23:30 4: reading from YeeLight_1: {"method":"props","params":{"power":"on"}}
2021.12.01 19:23:30 5: YeeLight_1 AnswerQueue: added {"method":"props","params":{"power":"on"}}
2021.12.01 19:23:30 4: YeeLight_1: detected notification broadcast ({"method":"props","params":{"power":"on"}})
2021.12.01 19:23:30 3: YeeLight_1 updated readings.
2021.12.01 19:23:30 5: YeeLight_1 AnswerQueue: deleted {"method":"props","params":{"power":"on"}}
2021.12.01 19:24:24 4: YeeLight_1 is sending: {"id":54,"method":"set_power","params":["off","smooth",5000]}
2021.12.01 19:24:24 5: YeeLight_1: Reading raw: {"id":54,"result":["ok"]}{"method":"props","params":{"power":"off"}}
2021.12.01 19:24:24 4: reading from YeeLight_1: {"id":54,"result":["ok"]}
2021.12.01 19:24:24 5: YeeLight_1 AnswerQueue: added {"id":54,"result":["ok"]}
2021.12.01 19:24:24 3: YeeLight_1 success sending 54: {"id":54,"method":"set_power","params":["off","smooth",5000]}
2021.12.01 19:24:24 5: YeeLight_1 SendQueue: deleted {"id":54,"method":"set_power","params":["off","smooth",5000]}
2021.12.01 19:24:24 5: YeeLight_1 AnswerQueue: deleted {"id":54,"result":["ok"]}
2021.12.01 19:24:24 4: reading from YeeLight_1: {"method":"props","params":{"power":"off"}}
2021.12.01 19:24:24 5: YeeLight_1 AnswerQueue: added {"method":"props","params":{"power":"off"}}
2021.12.01 19:24:24 4: YeeLight_1: detected notification broadcast ({"method":"props","params":{"power":"off"}})
2021.12.01 19:24:24 3: YeeLight_1 updated readings.
2021.12.01 19:24:24 5: YeeLight_1 AnswerQueue: deleted {"method":"props","params":{"power":"off"}}
Exakt so wird es ins Log geschrieben meine Aktion war nur um 19:23 "YeeLight_1 on" über die DeviceOverview in Deviceansicht. Kann sich einer erklären woher der Befehl um 19:24 kommt? Aus dem Modul???
GoldenAmerican
das Problem hat sich mit einer Reinstallation der vorherigen Perlversion erledigt. Offenbar gibt es in der Version 5.29 keine Unterstützung von JSON::XS mehr. Da bei der Installation ein Hinweis darauf kam kann ich nur davon ausgehen, dass es damit zusammenhängt.
