(Erledigt )HeatIt Thermostat
Begonnen von Wolfgang Hochweller, 07 Dezember 2021, 16:22:27
Wolfgang Hochweller
Hier ist das Listing dieses Devices :
   DEF        cfba8db6 80
   FUUID      5cb87507-f33f-775d-e984-68852c7c3aaf98ce
   IODev      ZWAVE2
   LASTInputDev ZWAVE2
   MSGCNT     3507
   NAME       HeizungWC
   NR         155
   STATE      meterReset
   TYPE       ZWave
   ZWAVE2_MSGCNT 3507
   ZWAVE2_RAWMSG 0004005006700602020000
   ZWAVE2_TIME 2021-12-07 16:18:26
   ZWaveSubDevice no
   cmdsPending 0
   homeId     cfba8db6
   isWakeUp
   lastMsgSent 1638890305.98405
   nodeIdHex  50
   webCmd     desired-temp
   Helper:
     DBLOG:
       temperature:
         logdb:
           TIME       1638889367.72656
           VALUE      20.0
   OLDREADINGS:
     2021-12-07 16:17:10   basicReport     255
     2021-12-07 16:14:47   basicSet        255
     2021-12-07 16:18:25   configAHiAirMaxLimit 400
     2021-12-07 16:18:25   configALoAirMinLimit 50
     2021-12-07 16:18:25   configCOModeSetpoint 220
     2021-12-07 16:18:25   configCOOLSetpoint 210
     2021-12-07 16:18:25   configDIFFL4    10
     2021-12-07 16:18:25   configECOModeSetpoint 200
     2021-12-07 16:18:25   configFHiFloorMaxLimit 270
     2021-12-07 16:18:25   configFLoFloorMinLimit 50
     2021-12-07 16:18:25   configFloorSensorType 10kNtc
     2021-12-07 16:18:25   configOperationMode Heat
     2021-12-07 16:18:25   configPLoMinTemperatureInPowerRegMode 0
     2021-12-07 16:18:25   configPSetting  2
     2021-12-07 16:18:26   configTemperatureSensor FFloorMode
     2021-12-07 16:18:15   desired-temp    22.0
     2021-12-07 16:10:14   meterSupported  type:energy, import only (consumed), resetable:yes, scales: 0:kWh
     2021-12-07 16:18:18   model           ThermoFloor AS Heatit Thermostat TF 021
     2021-12-07 16:18:18   modelConfig     thermofloor/heatit021.xml
     2021-12-07 16:18:18   modelId         019b-0001-0001
     2021-12-07 16:18:15   setpointTemp    22.0 C heating
     2021-12-07 16:16:38   state           meterReset
     2021-12-07 16:16:05   temperature     20.0 C
     2021-12-07 16:14:59   thermostatMode  heating
     2021-12-07 16:18:26   timeToAck       0.026
     2021-12-07 16:18:26   transmit        OK
     2021-12-07 16:17:05   undef           26 undef previous: 0 delta_time: 26 s
   DbLogInclude temperature
   IODev      ZWAVE2
   classes    ZWAVEPLUS_INFO THERMOSTAT_SETPOINT SENSOR_MULTILEVEL VERSION THERMOSTAT_MODE ASSOCIATION_GRP_INFO ASSOCIATION POWERLEVEL MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY METER CONFIGURATION
   devStateIcon .*Off:sani_floor_heating_off .*On:sani_floor_heating .*Save:sani_floor_heating_neutral .*:sani_floor_heating
   event-on-change-reading temperature,state
   eventMap   /tmOff:Off/tmHeating:On/tmEnergySaveHeating:Save
   icon       sani_heating
   room       Erdgeschoss,Heizung,ZWave
   vclasses   ASSOCIATION:2 ASSOCIATION_GRP_INFO:1 CONFIGURATION:2 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 METER:4 POWERLEVEL:1 SENSOR_MULTILEVEL:6 THERMOSTAT_MODE:3 THERMOSTAT_SETPOINT:3 VERSION:2 ZWAVEPLUS_INFO:2
   webCmd     Off:On:Save
Das letzte Reading ist das Ergebnis von :
get HeizungWC meter
aber das Egebnis ist  wenig sinnvoll.
Das Geraet liefert Daten, mit dem das Modul nichts anfangen kann.
Ich habe nochmal die Doku (SDS13781) konsultiert, finde da aber auch keine neuen "Bits" fuer die METER Klasse.
Ich habe jetzt immerhin das FHEM ZWave Modul geaendert, so dass es statt undef ab sofort UNKNOWN_XX zurueckliefert, in der Hoffnung, dass XX weiterhilft.
Wolfgang Hochweller
Danke, habe ich mir fast gedacht.
Das sollte ja offiziell etwas ueber den Stromverbrauch stehen.
Wolfgang Hochweller
Ich habe das mit dem Hersteller klaeren koennen.
Die Information ueber dem zugehoerigen xml-File ist nicht ganz korrekt : Dieser Thermostat kann keine Energie messen.
