FHEM - Hausautomations-Systeme > Zigbee
Tradfri mit Rollo FYRTUR
(1/1)
Ruebezahl:
ich habe ein IKEA Fyrtur Rollo mittels Tradfri Device problem in FHEM eingebunden und es läuft auch vollkommen problemlos.
Nur würde ich gerne wissen, wie der Status des Akkus ist, leider ist das Reading dazu nun schon 12 Tage alt und bei 99%.
--- Code: ---Readings
IODev xxx_IKEA 2021-12-29 15:17:37
battery 99 2021-12-29 18:51:43
batteryPercent 99 2021-12-29 18:51:43
pct 0 2022-01-09 20:28:13
reachable 1 2021-12-29 18:51:43
state 0 2022-01-09 20:28:13
--- Ende Code ---
Gibt es einen Trick oder einen Befehl, welcher dieses Reading auf den neuesten Stand bringt?
Die Definitionen sehen folgendermaßen aus:
--- Code: ---define xxx_IKEA tradfri
setuuid xxx_IKEA xxxxxxxxxxxxxx
attr xxx_IKEA createGroupReadings 1
attr xxx_IKEA devStateIcon stopped:control_home@red:start stopping:control_on_off@orange running.*:control_on_off@green:stop
attr xxx_IKEA room IKEA
attr xxx_IKEA stateFormat tradfri-fhem
attr xxx_IKEA tradfriFHEM-securityCode crypt: .....................................................
define HUEGroup131073 HUEDevice group 131073 IODev=xxx_IKEA
setuuid HUEGroup131073 xxxxxxxxxxxxxxxxxxxxxxx
attr HUEGroup131073 userattr createActionReadings:1,0 createGroupReadings:1,0
attr HUEGroup131073 alias SuperGroup
attr HUEGroup131073 color-icons 2
attr HUEGroup131073 delayedUpdate 1
attr HUEGroup131073 devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
attr HUEGroup131073 room IKEA
define HUEGroup131074 HUEDevice group 131074 IODev=xxx_IKEA
setuuid HUEGroup131074 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
attr HUEGroup131074 userattr createActionReadings:1,0 createGroupReadings:1,0
attr HUEGroup131074 color-icons 2
attr HUEGroup131074 delayedUpdate 1
attr HUEGroup131074 devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
attr HUEGroup131074 room IKEA
define HUESensor65536 HUEDevice sensor 65536 IODev=xxx_IKEA
setuuid HUESensor65536 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
attr HUESensor65536 model TRADFRI open/close remote
attr HUESensor65536 room IKEA
define HUESensor65537 HUEDevice sensor 65537 IODev=xxx_IKEA
setuuid HUESensor65537 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
attr HUESensor65537 model TRADFRI Signal Repeater
attr HUESensor65537 room IKEA
define IKEA_Rollo HUEDevice 65538 IODev=xxx_IKEA
setuuid IKEA_Rollo xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
attr IKEA_Rollo color-icons 2
attr IKEA_Rollo devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
attr IKEA_Rollo model FYRTUR block-out roller blind
attr IKEA_Rollo room IKEA
attr IKEA_Rollo subType blind
attr IKEA_Rollo webCmd up:stop:down:pct
--- Ende Code ---
Bin für jede Lösung oder Hilfe dankbar.
justme1968:
der batteriestand wird in (unregelmäßigen ?) abständen geschickt. eventuell nur wenn er sich auch geändert hat.
das reading wird aber auch nur aktualisiert wenn es eine änderung gab.
also einfach geduld haben.
Navigation
[0] Themen-Index
Zur normalen Ansicht wechseln
